--- ray/doc/notes/ReleaseNotes 2022/04/11 18:08:19 1.414 +++ ray/doc/notes/ReleaseNotes 2022/08/04 22:43:46 1.417 @@ -2544,3 +2544,16 @@ ambient cache is on and file is named. If straight im is requested, we randomize all samples and avoid cache collisions. Added cnt -s option to shuffle output. + +Fixed issue with divide-by-zero errors in the ambient super-sampling +routine discovered by Jon Sargent of Solemma. This affected regions +that had zero radiance, such as black backgrounds or unlit areas +with -av 0 0 0, when super-sampling was effectively disabled, causing +some loss in accuracy of the results. + +Updated Klems Half- and Quarter-bases to match angles currently used +in WINDOW. + +Eliminated most aiming failures for triangular light sources, at the +expense of conservative sampling near the centroid. Thanks to +David Geisler-Moroder for his help on this.
