--- ray/doc/notes/ReleaseNotes 2022/03/18 18:31:47 1.409 +++ ray/doc/notes/ReleaseNotes 2022/04/26 03:00:02 1.415 @@ -2532,3 +2532,21 @@ for extracting rows and columns from matrices, mostly. Changed pcomb so -o option elides original exposure values from indented source headers. + +Added getinfo -r option, which is similar to -a except it will +replace indicated lines with new ones. + +Slight change to vwrays -d option to not spit out "-ld-", and to +produce "-ld+" without requiring input picture as argument. + +Added automatic overture calculation to rtpict with -n > 1 if +ambient cache is on and file is named. If straight image output +is requested, we randomize all samples and avoid cache collisions. + +Added cnt -s option to shuffle output. + +Fixed issue with divide-by-zero errors in the ambient super-sampling +routine discovered by Jon Sargent of Solemma. This affected regions +that had zero radiance, such as black backgrounds or unlit areas +with -av 0 0 0, when super-sampling was effectively disabled, causing +some loss in accuracy of the results.
