--- ray/doc/notes/ReleaseNotes 2022/02/04 20:11:49 1.401 +++ ray/doc/notes/ReleaseNotes 2022/03/11 02:27:02 1.406 @@ -2504,3 +2504,22 @@ sanity checks. Added -O option to pvalue and pextrem to report watts/sr/m^2 even if picture is XYZE. + +Made subtle changes to header i/o routines to preserve alignment in +binary file formats to enable memory-mapping. Implemented memory-mapped +matrix loading in rmtxop for binary double files. + +Removed ambient value sorting, which was written when ambient caches +could overwhelm available memory. This is rarely the case these days, +and the added code complexity and updating of cache values with LRU +counts dirties pages that would otherwise remain clean, so it was +often a loss even when VM was an issue. + +Added iso2klems script to compute a Klems BSDF based on specular +and diffuse measurements as a function of incident angle. + +Fixed issue with over-counting diffuse component during aBSDF +peak extraction. + +Added dctimestep -x and -y options to specify image dimensions +for multiple outputs corresponding to result vectors.
