--- ray/doc/notes/ReleaseNotes 2022/03/07 17:55:09 1.403 +++ ray/doc/notes/ReleaseNotes 2022/03/11 02:27:02 1.406 @@ -2514,3 +2514,12 @@ could overwhelm available memory. This is rarely the and the added code complexity and updating of cache values with LRU counts dirties pages that would otherwise remain clean, so it was often a loss even when VM was an issue. + +Added iso2klems script to compute a Klems BSDF based on specular +and diffuse measurements as a function of incident angle. + +Fixed issue with over-counting diffuse component during aBSDF +peak extraction. + +Added dctimestep -x and -y options to specify image dimensions +for multiple outputs corresponding to result vectors.
