--- ray/doc/notes/ReleaseNotes 2021/09/02 16:11:24 1.394 +++ ray/doc/notes/ReleaseNotes 2021/11/16 03:30:45 1.395 @@ -2444,3 +2444,12 @@ produces normal smoothing unless normals are removed w Added exposure preservation to pcompos when possible (i.e., when there is only one input or inputs agree on exposure). + +Added -DSHARP_RGB compile-time option to use sharp RGB color space +rather than historic default. This can make for more accurate color +calculations, but requires that materials be recalibrated. The +PRIMARIES= line is also produced on output from rpict or rvu with +the correct set of primaries based on how the system was compiled. + +Added automatic flushing to the output of total, except when the -r +(running subtotals) option is used.
