--- ray/doc/notes/ReleaseNotes 2021/01/31 18:08:04 1.382 +++ ray/doc/notes/ReleaseNotes 2021/02/19 22:05:46 1.387 @@ -2408,3 +2408,18 @@ If the materials are both transparent or both opaque, surface appeared later in the scene description will be selected. This came of a request for consistent behavior with legal CAD output from Peter Apian-Bennewitz. + +Added explicit tests for on-edge intersections with polygons. This should +eliminate stray rays and tiny light leaks that often appear even in +well-constructed geometry. + +Added "-s up" option to pabopto2bsdf to allow for 180 degree symmetry, +meaning that data repeats after 180 degree rotation (as distinguished +from "-s bilateral" whose data is mirrored about a vertical plane). +Thanks to Helen Rose Wilson for the suggestion and informing me that +such a thing exists. + +Removed upper limit on number of modifiers in rcontrib. + +Put cap on maximum ambient gradient to avoid over-extrapolation of +poorly computed irradiance cache values.
