--- ray/doc/notes/ReleaseNotes 2021/01/15 23:16:06 1.380 +++ ray/doc/notes/ReleaseNotes 2021/02/15 23:22:50 1.384 @@ -2395,4 +2395,25 @@ Added "test" target to makeall to run unit tests. Modified bsdf2ttree to allow different parameters per input SIR file. -Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop, and rcollate. +Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop, +and rcollate. + +Added -rf and -rb options to rmtxop to load front or back reflectance +matrix data from XML file rather than transmission. (Lars Grobe suggested.) + +Improved behavior for coincident surfaces with different materials. +Rather than returning one surface or the other based on floating-point +vagaries, opaque materials are now preferred over transparent ones. +If the materials are both transparent or both opaque, then whichever +surface appeared later in the scene description will be selected. +This came of a request for consistent behavior with legal CAD output +from Peter Apian-Bennewitz. + +Added explicit tests for on-edge intersections with polygons. This should +eliminate stray rays and tiny light leaks that often appear even in +well-constructed geometry. + +Added "-s up" option to pabopto2bsdf to allow for 180 degree symmetry, +meaning that data repeats after 180 degree rotation (as distinguished +from "-s bilateral" that is mirrored about a vertical plane). Thanks +to Helen Rose for the suggestion and informing me that such a thing exists.
