--- ray/doc/notes/ReleaseNotes 2019/07/19 22:25:03 1.348 +++ ray/doc/notes/ReleaseNotes 2021/01/19 23:32:00 1.381 @@ -2237,7 +2237,7 @@ Updates to evalglare and gendaylit from Jan Wienold, i colored sky option. ========================= -Version 5.3 +Version 5.3 (Released September 1, 2020) Created radcompare program to compare Radiance tool output to reference outputs during unit-testing. @@ -2271,6 +2271,9 @@ Added gendaymtx -A option to compute average sky over time steps. Added ability to output color image from rtrace with any of -ovrx options. +Also fixed inconsistency of -oN output when ray casting versus full trace. +Before, it would flip normal to front side unless ray casting. Now, -oN +always reports the unflipped normal. Changed rlam behavior so -iaN reads N lines from a stream rather than N characters. This seems more useful, since -ibN is somewhat redundant with @@ -2280,7 +2283,8 @@ Created rsplit program as compliment to rlam and to ha rtrace output into separate files or streams. Improved getinfo so that it can also hop over resolution string with -c -and header elide mode. +and header elide mode. Use +d to include resolution string in output, +and -d to elide with - and -c options. Made pvalue -u option mean "uncompressed" with -r. Also, allow skipping bytes on standard input. @@ -2288,11 +2292,111 @@ bytes on standard input. Created rcode_depth tool to convert to and from a 16-bit/pixel portable depth image encoding that uses a mix of linear and reciprocal distance with explicit representations of 0 and infinity. Code for loading these -depth maps is in src/util/depthcodec.{h,c}. +depth maps is in src/common/depthcodec.{h,c}. Created rcode_norm tool to convert to and from 32-bit/pixel portable surface normal representation, matching the one in src/common/dircode.c. -Code for loading normal maps is in src/util/normcodec.{h,c}. +Code for loading normal maps is in src/common/normcodec.{h,c}. Created rcode_ident tool to create indexed identifier files. -Code for loading these files is in src/util/idmap.{h,c}. +Code for loading these files is in src/common/idmap.{h,c}. + +Added -o* option to rtpict to produce layered images that handle most +output types from rtrace (colors, surface normals, distances, IDs). + +Created rcode2bmp script to create images from new rcode_* output maps. + +Improved efficiency of rmtxop in cases where matrix multiplication is +faster evaluated right-to-left, as when the final component is a +column vector. Also added ability to apply trailing unary operators +(-t, and -s or -c) to resulting matrix. + +Added new depth, normal, and ID file types to radcompare. + +Added BigEndian= header line for automatic byte-swapping in rmtxop +and radcompare. + +Added new "turbo" palette to falsecolor (thanks to Taoning). + +Nathaniel Jones created the "dcglare" program for annual glare +simulations when the sun and sky are visible through the window. +Tutorial is posted at +"https://github.com/nljones/Accelerad/wiki/The-Imageless-Method-for-Spatial-and-Annual-Glare-Analysis". + +Added support for loading RGBE images into matrices in dctimestep. + +Added -y option to gensky and gendaylit to support more accurate Michalsky +solar position calculation. + +Changed rsplit, so specifying a space as the separator parses words +between whitespace. + +Added ability of vwrays, pinterp, and pmblur2 to read encoded depth files. + +Added -o RxCxR1xC1 facility to perform blocking in rcollate. + +Made it so number of segments in genworm, genrev, and gensurf can be +given as expressions of previously defined variables, etc. + +Added -D and -n option to gendaymtx to output sun description and skip +matrix output on request. A -M option was also added to output solar +modifiers for rcontrib. Support also added for leap days in WEA input. +Enhancements sponsored by Ladybug Tools. + +Updated eplus_uvf to work with IDF version 9.x, checking version number. + +Fix to glarendx issues with dgi calculation. + +Made it so rmtxop and dctimestep undo any exposure applied to Radiance +pictures they may load. + +Added robjutil utility to manipulate Wavefront .OBJ files. + +Fixed a crash related to rtrace -om or -oM with mesh instances containing +materials. + +Improved rtrace flushing function to handle any value for -x without +deadlock on controlling process. + +Eliminated unnecessary start-up procedures for rtrace when only ray-casting +is needed (i.e., no tracing or value output). + +Improved isotropic sampling method in bsdf2ttree using "zipper" approach +applied in genBSDF. + +Added limit to memory used by high-resolution tensor tree BSDFs for +cumulative cache during MC sampling (rendering). Limit set to 250MBytes +per BSDF for standard architectures. + +Added -n and -s options to bsdf2ttree to provide some user control +over super-sampling. + +Improved surface normal codec used by ambient file to store orthonormal +directions exactly. + +Improved peak extraction method, which was undervaluing transmission +in many cases. + +New version of evalglare from Jan Wienold. + +Added -u option to gendaymtx to elide data columns (time steps) when +the sun is not visible above the horizon. + +========================= +Version 5.4 + +Added rcollate -c option to force operation to continue even if it +seems unnecessary. Made tool more robust. + +Added -t option to rcontrib (and rfluxmtx) to report progress after the +given number of seconds. + +Added "test" target to makeall to run unit tests. + +Modified bsdf2ttree to allow different parameters per input SIR file. + +Fixed issues with very large matrix files (> 2GB) in dctimestep, rmtxop, +and rcollate. + +Added -rf and -rb options to rmtxop to load front or back reflectance +matrix data from XML file rather than transmission. (Lars Grobe suggested.)
