--- ray/doc/notes/ReleaseNotes 2019/07/15 22:39:50 1.344 +++ ray/doc/notes/ReleaseNotes 2019/07/19 22:25:03 1.348 @@ -2282,4 +2282,17 @@ rtrace output into separate files or streams. Improved getinfo so that it can also hop over resolution string with -c and header elide mode. -Made pvalue -u option mean "uncompressed" with -r. +Made pvalue -u option mean "uncompressed" with -r. Also, allow skipping +bytes on standard input. + +Created rcode_depth tool to convert to and from a 16-bit/pixel portable +depth image encoding that uses a mix of linear and reciprocal distance +with explicit representations of 0 and infinity. Code for loading these +depth maps is in src/util/depthcodec.{h,c}. + +Created rcode_norm tool to convert to and from 32-bit/pixel portable +surface normal representation, matching the one in src/common/dircode.c. +Code for loading normal maps is in src/util/normcodec.{h,c}. + +Created rcode_ident tool to create indexed identifier files. +Code for loading these files is in src/util/idmap.{h,c}.
