--- ray/doc/notes/ReleaseNotes 2018/06/13 21:23:45 1.320 +++ ray/doc/notes/ReleaseNotes 2018/06/26 14:42:18 1.322 @@ -2220,3 +2220,9 @@ optional build in src/cv/. Fixed bug in rcontrib with virtual sources, where pretest was adding to modifier accumulation buffers. Reported by Mostapha. + +Added an "aBSDF" material type that explicitly checks for peak extraction. +Its arguments are the same as the original "BSDF" type, but without the +thickness parameter, as proxy geometry is not supported by this new type. +The old "BSDF" type no longer does peak extraction under any circumstances, +since this behavior is superfluous for proxied geometry.
