--- ray/doc/notes/ReleaseNotes 2017/11/30 18:44:13 1.307 +++ ray/doc/notes/ReleaseNotes 2017/12/09 20:47:33 1.310 @@ -2167,7 +2167,7 @@ division of same-sized matrices. Changed falsecolor so "-s" option is adjusted to match legend if one. -Legend changes and improvements by David G-M and Stephen W. +Falsecolor legend changes and improvements by David G-M and Stephen W. Fixed bug in peak extraction code that generated "Bad call to SDqueryTreProjSA" error, reported by Lars Grobe. @@ -2175,3 +2175,12 @@ Fixed bug in peak extraction code that generated Increased maximum luminance to 10^7 in pcond to fix issue noticed by Axel Jacobs where veiling glare not added for the sun under some conditions. + +Increased maximum number of open files in rcontrib to the system upper +limit of 2048 rather than the default 512 under Windows. + +Added top-level resources directory with files from Rob Guglielmetti. + +Improved accuracy for peaky BSDFs and small light sources. + +Fixed issue with pmapdump noted by Axel Jacobs.
