--- ray/doc/notes/ReleaseNotes 2017/09/25 18:48:11 1.305 +++ ray/doc/notes/ReleaseNotes 2018/01/05 02:47:45 1.311 @@ -2167,4 +2167,25 @@ division of same-sized matrices. Changed falsecolor so "-s" option is adjusted to match legend if one. -Legend changes and improvements by David G-M and Stephen W. +Falsecolor legend changes and improvements by David G-M and Stephen W. + +Fixed bug in peak extraction code that generated +"Bad call to SDqueryTreProjSA" error, reported by Lars Grobe. + +Increased maximum luminance to 10^7 in pcond to fix issue noticed +by Axel Jacobs where veiling glare not added for the sun under +some conditions. + +Increased maximum number of open files in rcontrib to the system upper +limit of 2048 rather than the default 512 under Windows. + +Added top-level resources directory with files from Rob Guglielmetti. + +Improved accuracy for peaky BSDFs and small light sources. + +Fixed issue with pmapdump noted by Axel Jacobs. + +Improved accuracy of bsdf2ttree when converting scattering interpolation +representatons with strong peaks. + +Tweaked peak-extraction code to work more reliably.
