--- ray/doc/notes/ReleaseNotes 2017/08/28 15:59:46 1.303 +++ ray/doc/notes/ReleaseNotes 2017/12/04 21:58:10 1.309 @@ -2164,3 +2164,19 @@ objects, identified by modifier name(s). Added '*' and '/' operations to rmtxop for element-wise multiplication and division of same-sized matrices. + +Changed falsecolor so "-s" option is adjusted to match legend if one. + +Legend changes and improvements by David G-M and Stephen W. + +Fixed bug in peak extraction code that generated +"Bad call to SDqueryTreProjSA" error, reported by Lars Grobe. + +Increased maximum luminance to 10^7 in pcond to fix issue noticed +by Axel Jacobs where veiling glare not added for the sun under +some conditions. + +Increased maximum number of open files in rcontrib to the system upper +limit of 2048 rather than the default 512. + +Added top-level resources directory with files from Rob Guglielmetti.
