--- ray/doc/notes/ReleaseNotes 2015/04/05 01:32:01 1.257 +++ ray/doc/notes/ReleaseNotes 2015/07/14 16:08:28 1.266 @@ -1957,10 +1957,10 @@ to klems_full.cal in the process.) Added "-c" option to getinfo to execute command on data segment. ===================== -Version 4.3 +Version 5.0 Changed rmtxop so it writes out same type as lesser of inputs unless -direction otherwise using -f? option. +directed otherwise using -f? option. Changed order of oconv arguments in rfluxmtx so user can specify input octree using -i option at the end instead of (or in addition to) a @@ -2001,9 +2001,6 @@ some systems, and may have been source of other errors (Above changes included in 4.2.2 patch release.) -=================== -Version 5.0 - Improved ambient extrapolation to avoid zero values. Actual threshold set to 5% of recorded value. @@ -2022,3 +2019,33 @@ David Geisler-Moroder. Added color output to genBSDF (+C option) and support for color rendering of Klems and tensor tree data. + +Fixed another bug in rsensor that caused rays to be generated +on opposite side of hemisphere even where sensitivity was zero. + +Fixed bug discovered by Jacob Jonsson in Klems BSDF +interpolator that caused it to over-predict normal +transmittance and reflectance. + +Added ability to read input from commands in dctimestep +and rmtxop. + +Added photon map support to rad. Fixed some double-counting +issues in photon-mapping spotted by David Geisler-Moroder. + +Added photon map support to trad. + +Fixed bug in antimatter source testing when antimatter +definition follows potential obstructor in input. + +Fixed issue with missing character type identifier at head +of genBSDF XML output. + +Prompted by Roland S., added option to have pcompos -a order +rows from top rather than bottom of image. + +Changed dctimestep to accept matrix as well as BTDF input +in the VTDs invocation mode. This permits the output of +rmtxop to be used in a pinch when combining multiple BTDF +layers, although interreflection between layers is not +accounted for properly as it is in the WINDOW program.
