--- ray/doc/notes/ReleaseNotes 2015/05/04 20:53:21 1.259 +++ ray/doc/notes/ReleaseNotes 2015/05/26 10:00:47 1.261 @@ -1957,10 +1957,10 @@ to klems_full.cal in the process.) Added "-c" option to getinfo to execute command on data segment. ===================== -Version 4.3 +Version 5.0 Changed rmtxop so it writes out same type as lesser of inputs unless -direction otherwise using -f? option. +directed otherwise using -f? option. Changed order of oconv arguments in rfluxmtx so user can specify input octree using -i option at the end instead of (or in addition to) a @@ -2001,9 +2001,6 @@ some systems, and may have been source of other errors (Above changes included in 4.2.2 patch release.) -=================== -Version 5.0 - Improved ambient extrapolation to avoid zero values. Actual threshold set to 5% of recorded value. @@ -2023,9 +2020,15 @@ David Geisler-Moroder. Added color output to genBSDF (+C option) and support for color rendering of Klems and tensor tree data. +Fixed another bug in rsensor that caused rays to be generated +on opposite side of hemisphere even where sensitivity was zero. + Fixed bug discovered by Jacob Jonsson in Klems BSDF interpolator that caused it to over-predict normal transmittance and reflectance. Added ability to read input from commands in dctimestep -and rmtxop +and rmtxop. + +Added photon map support to rad. Fixed some double-counting +issues in photon-mapping spotted by David Geisler-Moroder.
