--- ray/doc/notes/ReleaseNotes 2013/10/18 17:04:13 1.225 +++ ray/doc/notes/ReleaseNotes 2014/01/25 18:27:39 1.230 @@ -1902,3 +1902,22 @@ This will change the appearance of renderings using th Added "origin" command to rvu as requested by John Mardaljevic to place view origin at selected point in scene. + +Switch to Perl versions of objview and objpict written by Axel Jacobs. + +Improved rendering speed of scenes with aliases by not entering new +modifiers into table if they are the same as the previously defined +modifier for that name. + +Made it so icalc and rcalc search RAYPATH directories for *.cal files +given on command line. This simplifies script writing and makes these +utilities consistent with other tools in Radiance. + +Added triangulation routine to handle convex polygons in obj2mesh. + +****** COMPATIBILITY CHANGE ******** +Made backface visibility apply to all material types, including +transparent and translucent materials (except dielectric and interface). +This makes the option useful in cases where adjacent trans surfaces +are placed next to each other by a modeler that only understands +volumetric objects.
