--- ray/doc/notes/ReleaseNotes 2013/04/04 15:13:43 1.217 +++ ray/doc/notes/ReleaseNotes 2013/09/25 16:52:28 1.223 @@ -1877,3 +1877,22 @@ Added -r option to gendaymtx to rotate the sky the spe degrees about the zenith as suggested by A. McNeil. Axel Jacobs added -pal eco color map that does a blue-red-yellow scale. + +Created bsdf2klems tool to convert from various BSDF representations to +Klems basis matrix in XML file. + +Fixed problem with inappropriate reciprocity enforcement on tensor +tree reduction in genBSDF. (Thanks to A.McNeil for discovering issue.) + +Fixed bug in isotropic tensor tree sampling for impinging rays +exactly normal to surface. Thanks to Peter Apian-Bennewitz for +discovering and pointing out the error. + +Fixed double-counting bug in mirror material with alternate type. +Thanks to David Geisler-Moroder for spotting the problem and helping +to fix it. + +Created rcollate program to resize and transpose matrix data for Andy +McNeil's 5-phase annual simulation method. + +Added epw2wea conversion program by Christoph Reinhart.
