--- ray/doc/notes/ReleaseNotes 2013/01/30 01:02:42 1.213 +++ ray/doc/notes/ReleaseNotes 2013/04/04 02:59:20 1.216 @@ -1869,3 +1869,11 @@ Output can be sent directly to dctimestep in ASCII or Replaced existing gendaylit.c with improved version from Wendelin Sprenger and Jan Wienold of ISE. + +Improved accuracy of ambient calculation for large -ad settings. Thanks +to Lars Grobe for noticing the problem. + +Added -r option to gendaymtx to rotate the sky the specified number of +degrees about the zenith as suggested by A. McNeil. + +Axel Jacobs added -pal eco color map that does a blue-to-yellow range.
