--- ray/doc/notes/ReleaseNotes 2011/10/26 16:48:01 1.191 +++ ray/doc/notes/ReleaseNotes 2012/03/30 15:08:40 1.195 @@ -1720,7 +1720,7 @@ Added -n option to rtrace for executing on multiple co using new rayfifo calls. ===================== -Version 4.1 +Version 4.1 (Released 11/04/2011) Changed ranimate behavior so remote login under a different user doesn't necessarily require the presence of the originating user's @@ -1805,3 +1805,17 @@ when specular component was below -st threshold in non Checked in cross-platform cmake build system created by Bill Hoffman of KitWare and sponsored by NREL. This includes a qt-based driver for rvu, which is built in the new subdirectory src/qtrvu. + +===================== +Version 4.2 + +Axel Jacobs added -cp and -palettes options to falsecolor. + +Fixed bug in matrix output of genBSDF introduced shortly before 4.1 release. + +Made rvu more responsive in multi-processing mode when changing parameters. +Explicit "new" command not needed to show changes, because it goes back +to "immediate mode" once something is changed. Processing will be slow +but response time quick until next "new" command. + +Fixed major bug in transmitting proxy material sampling.
