--- ray/doc/notes/ReleaseNotes 2010/05/07 15:46:48 1.168 +++ ray/doc/notes/ReleaseNotes 2010/09/03 23:53:49 1.173 @@ -1729,3 +1729,17 @@ home directory. Changed standard transmission function normalization back to what it was in version 3.5, following recommendation of David Geisler-Moroder, who pointed out that the revised BTDF increased too much at grazing. + +Changed rad behavior with -N >1 on single view to call rpiece. + +Updated SCons build system for MINGW compilation, thanks to Christian +Kohler. + +Added -u option to rlam for unbuffered output. + +Modified dctimestep to accept sky vector and daylight coefficient matrix +or list of images to sum together, as suggested by Andy McNeil. + +Created genBSDF script to generate BSDF in Windows XML format. + +Modified mkillum to accept detailed geometry from BSDF XML files.
