--- ray/doc/notes/ReleaseNotes 2009/03/04 00:12:24 1.156 +++ ray/doc/notes/ReleaseNotes 2009/12/12 05:20:10 1.163 @@ -1692,3 +1692,26 @@ Fixed rad -v N specification to use actual view name i Fixed error in mkillum calculation where it neglected indirect source contributions from BTDF illum's. + +Added GMT and LATLONG header lines for Greenwich Mean Time and +degrees North Latitude / East Longitude. + +Added gendaylit to distribution (finally). + +Added ability in vwright(1) to get view from command line arguments. + +Created genklemsamp(1) utility to generate samples suitable for +BSDF-based annual calculations. This is the first Perl script to +be added to Radiance. Hopefully, others will follow. + +Added klems_int.cal file to compute Klems bins for windows. + +Created gentregvec utility to sample a particular sky and +evaluate average radiance over the standard Tregenza sky patches. + +Created dctimestep program to compute a set of sensor values or +a combined image for a particular time using the daylight +coefficient method. + +Created src/rt/rayfifo.c for first-in/first-out handling of +multiprocessing by raypcalls.c.
