--- ray/doc/notes/ReleaseNotes 2008/11/21 01:30:16 1.152 +++ ray/doc/notes/ReleaseNotes 2009/06/14 00:33:16 1.159 @@ -1679,3 +1679,26 @@ affect operation, but may require the update of script by others that assume the ".pic" suffix for Radiance output. Added -N option to objview to support multiprocessing. + +Improved sampling of circular sources (source, sphere, ring types) with +quite a bit of help from David Geisler-Moroder. + +Added "rpict" and "rvu" variables to rad, and made these as well as +the "oconv", "mkillum" and "pfilt" variables accept an alternate +command path in each case. Change suggested by Lars Grobe based +on similar Radzilla (radz) facility by Carsten Bauer. + +Fixed rad -v N specification to use actual view name if one. + +Fixed error in mkillum calculation where it neglected indirect +source contributions from BTDF illum's. + +Added GMT and LATLONG header lines for Greenwich Mean Time and +degrees North Latitude / East Longitude. + +Added gendaylit to distribution (finally). + +Added ability in vwright(1) to get view from command line arguments. + +Created genklemsamp(1) utility to generate samples suitable for BSDF-based annual calculations. +This is the first Perl script to be added to Radiance. Hopefully, others will follow.
