--- ray/doc/notes/ReleaseNotes 2008/02/21 01:22:06 1.145 +++ ray/doc/notes/ReleaseNotes 2009/06/06 20:18:32 1.158 @@ -1644,9 +1644,6 @@ The only caveat is that -n setting > 1 requires -PP ra Added -c option to rtcontrib to facilitate cumulative calculations. -Added ability to incorporate LBNL Window 6 bidirectional scattering -distribution function (BSDF) data in mkillum. - ****** COMPATIBILITY CHANGE ******** Fixed long-standing bug in source.cal, which caused it to produce reversed anisotropic photometric distributions due to the @@ -1660,3 +1657,43 @@ Zack Rogers for finding this error. Added rsensor program to compute sensor signal for daylighting controls. Funding for this component was provided by the Architectural Energy Corporation in Boulder, CO, and directed by Zack Rogers. + +Added "planisphere" (stereographic) fisheye view type for traditional +daylighting analysis. Feature requested & explained by Axel Jacobs. + +Modified -c option to rtcontrib so it can take a number of input +rays to average over, rather than only produce a single accumulated +record (which can now be done with -c 0). + +===================== +Version 4.0 + +Added -n option to rvu to provide parallel rendering. + +****** COMPATIBILITY CHANGE ******** +Changed ".pic" extension to ".hdr" in all sources and documentation +to improve interoperability with other software, since this has become +the de facto extension for Radiance RGBE and XYZE pictures. Since file +extensions were never more than a convention in Radiance, this does not +affect operation, but may require the update of scripts, etc. written +by others that assume the ".pic" suffix for Radiance output. + +Added -N option to objview to support multiprocessing. + +Improved sampling of circular sources (source, sphere, ring types) with +quite a bit of help from David Geisler-Moroder. + +Added "rpict" and "rvu" variables to rad, and made these as well as +the "oconv", "mkillum" and "pfilt" variables accept an alternate +command path in each case. Change suggested by Lars Grobe based +on similar Radzilla (radz) facility by Carsten Bauer. + +Fixed rad -v N specification to use actual view name if one. + +Fixed error in mkillum calculation where it neglected indirect +source contributions from BTDF illum's. + +Added GMT and LATLONG header lines for Greenwich Mean Time and +degrees North Latitude / East Longitude. + +Added gendaylit to distribution (finally).
