--- ray/doc/notes/ReleaseNotes 2003/09/18 16:53:52 1.14 +++ ray/doc/notes/ReleaseNotes 2003/09/19 18:33:04 1.16 @@ -1193,3 +1193,9 @@ Changed meta2tga to output correct colors. ****** COMPATIBILITY CHANGE ******** Changed local coordinate index from 32-bits to 16-bits, which requires that Radiance mesh files be recompiled. + +Changed integer tone-mapping routines to better deal with images +containing large, constant regions. + +Improved interaction with rholo -o ogl driver under OS X, which was +returning bad values from the depth buffer.
