--- ray/doc/notes/ReleaseNotes 2007/02/26 21:16:02 1.133 +++ ray/doc/notes/ReleaseNotes 2007/07/12 14:58:53 1.136 @@ -1617,3 +1617,15 @@ Also added "-s auto" option to automatically set the m Added byte-swapping input and output to rcalc. Additional error-checking for source surfaces. + +Re-fixed bug in octree code that caused it to allocate 8 times as +much memory as it actually used(!) -- this was pointed out way back +in 1999 by Erik Reinhard and Erik Jansen, but the fix they gave me +got lost in the slightly borken release process at the time. This +should make a big difference in memory usage, especially for the +new mesh primitive. (I measured 30% less memory usage.) + +Corrected ray weights for material mixtures. + +Reduced the default -n setting for obj2mesh to take better advantage +of the smaller octree structure size.
