Revision: 1.121
Committed: Sun May 7 15:44:27 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.120: +2 -0 lines
Made missing calls to SET_FILE_BINARY() for Windows
1 =========================
3
11
12 pfilt -x 512 -y 400 -p 1
13
18
21
25 and vv parameters).
26
30
40
44
45 =========================
47
53
56
58
62
66
72
75
77 traced on an X11 display.
78
83
86
87 =========================
89
92
94
97 library directory.
98
101
105
107
110
112
114 white light assumption.
115
117
119 checking and clarity.
120
123
128
132
133 =========================
135
140
142 picture.
143
145
150
152
155 and transdata types.
156
158 component.
159
162
166
168 value labels.
169
172
179
183 undefined modifiers.
184
187
192
197
199
203
205 to slant the wrong way!
206
209
218
221
223
229
232
236
238 -version option.
239
242
244
251
253
258
260
273
275
278
282
286 pinterp and findglare.
287
290
295 support it.
296
298
304
308
312
315
317
319 from a file.
320
322
324
326
331
336 pointed this out to me!
337
340
345
350
352 and color ordering.
353
355
358
361
363 some scene files.
364
367
371
373 used consistently.
374
376
378 further reduce errors.
379
381
385
387
395
398
402
405 options.
406
408 cast by mirrors.
409
411
414 MS-DOS.
415
417 brightness.
418
421 unperturbed).
422
429
432
435
437
444
447 unconditionally.
448
452
455 suggestion.)
456
461
464
467
471 helped.
472
479
482
485
488
490
492 for each picture file.
493
496
502
505
508
511
515
521
524
526
528
531
535
538
541
544
546 Format) specification.
547
550
552 at all!
553
555 under X11.
556
560 for the same value!
561
563 changes to input files.
564
567
569 Radiance view parameters.
570
572
575
577 language.
578
580
582 files.
583
586
588 values.
589
591
594
597
599
601
603 interesting applications.
604
607
610
613
616
618 simulation with pinterp.
619
622
625
630
635
639 regions.
640
642
645
649 of clouds.
650
654 the same as before.
655
657 walk-through animations.
658
661
663 on multiple hosts.
664
667
670
672 Alphas.
673
678
681 large image patterns.
682
686 method.
687
692
694
699
709 back old behavior.
710
713
716
718
720
722
724
732
737 sources.
738
750 to bright exteriors.
751
754
758
763
768
771 definitions.
772
775 pcond(1).
776
779
782
784 (Included in 3.1.1.)
785
788
790
792 views or pictures.
793
797
801
803
806 (Included in 3.1.4.)
807
809 (Included in 3.1.3.)
810
812 (Included in 3.1.3.)
813
815 image formats.
816
820
823 to PostScript printers.
824
826 (Included in 3.1.6.)
827
830
832
836
840
844
847
849 commands.
850
852
855
857
860
863
867
870
872
878 material for shading.
879
882
884
889
891
893
895 forcing greyscale output.
896
899
902
904
906 directly using ximage.
907
909
912
914 CMCCAT2000 matrix.
915
917
919
921 by Erich Phillips.
922
925
928 instances).
929
932
934 to unity.
935
939
942 for pointing it out.
943
945
950
954
956
958 valid(s,t) function.
959
962
966
968 for standard input.
969
973 used to.
974
980
986
990
993
997
1000 feedback.
1001
1009 hurrah!
1010
1020
1024
1029
1032
1036 previous value of 1.0.
1037
1049
1058
1064
1072 specification.
1073
1076
1088
1097
1100
1103 textured surfaces.
1104
1122
1129 substitution.
1130
1140 the stack limit.
1141
1143 Version 3.6
1144
1148
1150
1152
1155
1158
1162
1165
1169 IEEE float.)
1170
1172 parallel.
1173
1176
1178 files.
1179
1184 as well.
1185
1187 to new mesh primitive.
1188
1190 doubles, respectively.
1191
1193
1197
1200
1203
1205 didn't need to.
1206
1212
1215
1218
1220
1222
1224
1226
1234 have plenty.)
1235
1239 calc -> icalc
1240 lam -> rlam
1241 gencat -> gencatenary
1242
1244
1248
1253
1255
1258
1261
1264
1267
1271
1277
1279 locations.
1280
1283
1287
1289 protate commands.
1290
1293 middle of a stream.
1294
1298
1302
1304
1308
1311
1313
1320
1330
1333
1337
1341
1343 correctly.
1344
1345 =====================
1346 Version 3.7
1347
1350 finding the problem.)
1351
1355
1357
1360
1366 but never quite worked
1373 reinstate it.
1374
1377 this out.
1378
1381
1384
1388
1391
1395 by the vwright command.
1396
1399
1401 ('f'/"frame" command).
1402
1405
1411 works.)
1412
1414 TIFF i/o in ra_tiff.
1415
1418
1422
1425
1434 caching on (-aa > 0).
1435
1442
1444
1446
1449
1451
1455
1459
1462
1464
1466
1468
1471
1473
1476
1478
1480 infinite loop.
1481
1484
1486
1490
1491 =====================
1492 Version 3.8
1493
1497
1499
1501
1504
1508
1510
1512
1515
1518
1522
1524
1526
1529
1532
1534
1536
1539
1542
1545
1547
1551
1554
1556
1559 this bug.)
1560
1563
1565 just ray coefficients.
1566
1568
1571
1575
1577
