Revision: 1.228
Committed: Thu Dec 19 16:38:12 2013 UTC (11 years, 10 months ago) by greg
Changes since 1.227: +4 -0 lines
1 =========================
3
11
12 pfilt -x 512 -y 400 -p 1
13
18
21
25 and vv parameters).
26
30
40
44
45 =========================
47
53
56
58
62
66
72
75
77 traced on an X11 display.
78
83
86
87 =========================
89
92
94
97 library directory.
98
101
105
107
110
112
114 white light assumption.
115
117
119 checking and clarity.
120
123
128
132
133 =========================
135
140
142 picture.
143
145
150
152
155 and transdata types.
156
158 component.
159
162
166
168 value labels.
169
172
179
183 undefined modifiers.
184
187
192
197
199
203
205 to slant the wrong way!
206
209
218
221
223
229
232
236
238 -version option.
239
242
244
251
253
258
260
273
275
278
282
286 pinterp and findglare.
287
290
295 support it.
296
298
304
308
312
315
317
319 from a file.
320
322
324
326
331
336 pointed this out to me!
337
340
345
350
352 and color ordering.
353
355
358
361
363 some scene files.
364
367
371
373 used consistently.
374
376
378 further reduce errors.
379
381
385
387
395
398
402
405 options.
406
408 cast by mirrors.
409
411
414 MS-DOS.
415
417 brightness.
418
421 unperturbed).
422
429
432
435
437
444
447 unconditionally.
448
452
455 suggestion.)
456
461
464
467
471 helped.
472
479
482
485
488
490
492 for each picture file.
493
496
502
505
508
511
515
521
524
526
528
531
535
538
541
544
546 Format) specification.
547
550
552 at all!
553
555 under X11.
556
560 for the same value!
561
563 changes to input files.
564
567
569 Radiance view parameters.
570
572
575
577 language.
578
580
582 files.
583
586
588 values.
589
591
594
597
599
601
603 interesting applications.
604
607
610
613
616
618 simulation with pinterp.
619
622
625
630
635
639 regions.
640
642
645
649 of clouds.
650
654 the same as before.
655
657 walk-through animations.
658
661
663 on multiple hosts.
664
667
670
672 Alphas.
673
678
681 large image patterns.
682
686 method.
687
692
694
699
709 back old behavior.
710
713
716
718
720
722
724
732
737 sources.
738
750 to bright exteriors.
751
754
758
763
768
771 definitions.
772
775 pcond(1).
776
779
782
784 (Included in 3.1.1.)
785
788
790
792 views or pictures.
793
797
801
803
806 (Included in 3.1.4.)
807
809 (Included in 3.1.3.)
810
812 (Included in 3.1.3.)
813
815 image formats.
816
820
823 to PostScript printers.
824
826 (Included in 3.1.6.)
827
830
832
836
840
844
847
849 commands.
850
852
855
857
860
863
867
870
872
878 material for shading.
879
882
884
889
891
893
895 forcing greyscale output.
896
899
902
904
906 directly using ximage.
907
909
912
914 CMCCAT2000 matrix.
915
917
919
921 by Erich Phillips.
922
925
928 instances).
929
932
934 to unity.
935
939
942 for pointing it out.
943
945
950
954
956
958 valid(s,t) function.
959
962
966
968 for standard input.
969
973 used to.
974
980
986
990
993
997
1000 feedback.
1001
1009 hurrah!
1010
1020
1024
1029
1032
1036 previous value of 1.0.
1037
1049
1058
1064
1072 specification.
1073
1076
1088
1097
1100
1103 textured surfaces.
1104
1122
1129 substitution.
1130
1140 the stack limit.
1141
1143 Version 3.6 (Released 10/21/04)
1144
1148
1150
1152
1155
1158
1162
1165
1169 IEEE float.)
1170
1172 parallel.
1173
1176
1178 files.
1179
1184 as well.
1185
1187 to new mesh primitive.
1188
1190 doubles, respectively.
1191
1193
1197
1200
1203
1205 didn't need to.
1206
1212
1215
1218
1220
1222
1224
1226
1234 have plenty.)
1235
1239 calc -> icalc
1240 lam -> rlam
1241 gencat -> gencatenary
1242
1244
1248
1253
1255
1258
1261
1264
1267
1271
1277
1279 locations.
1280
1283
1287
1289 protate commands.
1290
1293 middle of a stream.
1294
1298
1302
1304
1308
1311
1313
1320
1330
1333
1337
1341
1343 correctly.
1344
1345 =====================
1346 Version 3.7 (Released 7/25/05)
1347
1350 finding the problem.)
1351
1355
1357
1360
1366 but never quite worked
1373 reinstate it.
1374
1377 this out.
1378
1381
1384
1388
1391
1395 by the vwright command.
1396
1399
1401 ('f'/"frame" command).
1402
1405
1411 works.)
1412
1414 TIFF i/o in ra_tiff.
1415
1418
1422
1425
1434 caching on (-aa > 0).
1435
1442
1444
1446
1449
1451
1455
1459
1462
1464
1466
1468
1471
1473
1476
1478
1480 infinite loop.
1481
1484
1486
1490
1491 =====================
1492 Version 3.8 (Released 10/17/06)
1493
1497
1499
1501
1504
1508
1510
1512
1515
1518
1522
1524
1526
1529
1532
1534
1536
1539
1542
1545
1547
1551
1554
1556
1559 this bug.)
1560
1563
1565 just ray coefficients.
1566
1568
1571
1575
1577
1579
1584
1588
1592
1594
1596
1598
1603
1605
1608
1610
1611 =====================
1612 Version 3.9 (Released 3/30/08)
1613
1616
1618
1620
1624 got lost in the slightly broken release process at the time. This
1627
1629
1632
1636
1639
1640 Fixed pixel alignment in pcomb for size reduction and enlargement.
1641
1642 Allow rtcontrib user to set -P and -PP options for persistent rendering.
1643 The only caveat is that -n setting > 1 requires -PP rather than -P.
1644
1645 Added -c option to rtcontrib to facilitate cumulative calculations.
1646
1647 ****** COMPATIBILITY CHANGE ********
1648 Fixed long-standing bug in source.cal, which caused it to produce
1649 reversed anisotropic photometric distributions due to the
1650 misorientation of the y-axis. Thanks to Zack Rogers for discovering
1651 and helping debug this problem.
1652
1653 Fixed long-standing bug in replmarks, where triangles with X-side
1654 aligned with Z-axis would cause incorrect rotations. Thanks to
1655 Zack Rogers for finding this error.
1656
1657 Added rsensor program to compute sensor signal for daylighting controls.
1658 Funding for this component was provided by the Architectural Energy
1659 Corporation in Boulder, CO, and directed by Zack Rogers.
1660
1661 Added "planisphere" (stereographic) fisheye view type for traditional
1662 daylighting analysis. Feature requested & explained by Axel Jacobs.
1663
1664 Modified -c option to rtcontrib so it can take a number of input
1665 rays to average over, rather than only produce a single accumulated
1666 record (which can now be done with -c 0).
1667
1668 =====================
1669 Version 4.0 (Released 3/12/10)
1670
1671 Added -n option to rvu to provide parallel rendering.
1672
1673 ****** COMPATIBILITY CHANGE ********
1674 Changed ".pic" extension to ".hdr" in all sources and documentation
1675 to improve interoperability with other software, since this has become
1676 the de facto extension for Radiance RGBE and XYZE pictures. Since file
1677 extensions were never more than a convention in Radiance, this does not
1678 affect operation, but may require the update of scripts, etc. written
1679 by others that assume the ".pic" suffix for Radiance output.
1680
1681 Added -N option to objview to support multiprocessing.
1682
1683 Improved sampling of circular sources (source, sphere, ring types) with
1684 quite a bit of help from David Geisler-Moroder.
1685
1686 Added "rpict" and "rvu" variables to rad, and made these as well as
1687 the "oconv", "mkillum" and "pfilt" variables accept an alternate
1688 command path in each case. Change suggested by Lars Grobe based
1689 on similar Radzilla (radz) facility by Carsten Bauer.
1690
1691 Fixed rad -v N specification to use actual view name if one.
1692
1693 Fixed error in mkillum calculation where it neglected indirect
1694 source contributions from BTDF illum's.
1695
1696 Added GMT and LATLONG header lines for Greenwich Mean Time and
1697 degrees North Latitude / East Longitude.
1698
1699 Added gendaylit to distribution (finally).
1700
1701 Added ability in vwright(1) to get view from command line arguments.
1702
1703 Created genklemsamp(1) utility to generate samples suitable for
1704 BSDF-based annual calculations. This is the first Perl script to
1705 be added to Radiance. Hopefully, others will follow.
1706
1707 Added klems_int.cal file to compute Klems bins for windows.
1708
1709 Created genskyvec utility to sample a particular sky and
1710 evaluate average radiance over the standard Tregenza sky patches.
1711
1712 Created dctimestep program to compute a set of sensor values or
1713 a combined image for a particular time using the daylight
1714 coefficient method.
1715
1716 Created src/rt/rayfifo.c for first-in/first-out handling of
1717 multiprocessing by raypcalls.c.
1718
1719 Added -n option to rtrace for executing on multiple cores
1720 using new rayfifo calls.
1721
1722 =====================
1723 Version 4.1 (Released 11/04/2011)
1724
1725 Changed ranimate behavior so remote login under a different user
1726 doesn't necessarily require the presence of the originating user's
1727 home directory.
1728
1729 Changed standard transmission function normalization back to what
1730 it was in version 3.5, following recommendation of David Geisler-Moroder,
1731 who pointed out that the revised BTDF increased too much at grazing.
1732
1733 Changed rad behavior with -N >1 on single view to call rpiece.
1734
1735 Updated SCons build system for MINGW compilation, thanks to Christian
1736 Kohler.
1737
1738 Added -u option to rlam for unbuffered output.
1739
1740 Modified dctimestep to accept sky vector and daylight coefficient matrix
1741 or list of images to sum together, as suggested by Andy McNeil.
1742
1743 Created genBSDF script to generate BSDF in Windows XML format.
1744
1745 Modified mkillum to accept detailed geometry from BSDF XML files.
1746
1747 Altered obj2rad to ignore zero normals (thanks to Jack de Valpine for
1748 suggestions and help).
1749
1750 Fixed bug in genklemsamp that caused non-uniform sampling over surfaces.
1751
1752 Fixed bugs in rhoptimize and rhcopy for 64-bit compilation.
1753
1754 Made a change to avoid problem using gcc --fast-math compile option.
1755
1756 ****** COMPATIBILITY CHANGE ********
1757 Changed behavior of rtrace and rtcontrib so that every scanline is
1758 not flushed when both -x and -y are set. This avoids flush delays
1759 in rtcontrib for large numbers of output files and delays while
1760 rendering images using rtrace with the -n option.
1761
1762 Added ability for rsensor to output ray origins and directions
1763 rather than actually loading octree and computing sensor value.
1764
1765 Fixed old bug in obj2rad where it would stop processing and
1766 report a syntax error if the "void" type is used in the map file.
1767
1768 Updated reflection model according to EGSR 2010 paper by David
1769 Geisler-Moroder and Arne Duer.
1770
1771 Replaced C-shell version of falsecolor with Perl script written
1772 by Axel Jacobs.
1773
1774 ****** COMPATIBILITY CHANGE ********
1775 Changed -sj (specular jitter) option to something called specular
1776 sampling (-ss), which if set less than 1 has the same behavior as
1777 the old -sj, but when set greater than 1, spawns multiple ray
1778 samples from semi-specular surfaces.
1779
1780 Fixed bug noticed by Randolph Fritz that caused ambient sync errors.
1781
1782 Fixed bug in findglare for reading picture files under Windows.
1783
1784 Added options to pvalue to note other color spaces on reverse conversion.
1785 Thanks to Erich Philips for the feature request.
1786
1787 Added BSDF data-driven material type with full sampling support.
1788
1789 Added BRDF calculations to genBSDF.
1790
1791 Bug fixes in rsensor thanks to help from David Geisler-Moroder.
1792
1793 Added variable-resolution BSDF support in renderers and genBSDF.
1794
1795 Created pkgBSDF program to extract BSDF geometry and put it
1796 together with surface description suitable for inclusion in
1797 a Radiance scene.
1798
1799 Muted warning for "no light sources found" when there is at least
1800 one glow object and interreflections are on (-ab > 0).
1801
1802 Fixed long-standing bug that caused underestimation of reflection
1803 when specular component was below -st threshold in non-metals.
1804
1805 Checked in cross-platform cmake build system created by Bill Hoffman
1806 of KitWare and sponsored by NREL. This includes a qt-based
1807 driver for rvu, which is built in the new subdirectory src/qtrvu.
1808
1809 =====================
1810 Version 4.2
1811
1812 Axel Jacobs added -cp and -palettes options to falsecolor.
1813
1814 Fixed bug in matrix output of genBSDF introduced shortly before 4.1 release.
1815
1816 Made rvu more responsive in multi-processing mode when changing parameters.
1817 Explicit "new" command not needed to show changes, because it goes back
1818 to "immediate mode" once something is changed. Processing will be slow
1819 but response time quick until next "new" command.
1820
1821 Fixed major bug in transmitting proxy material sampling.
1822
1823 Patched cmake build tools (changes by Zack Galbreath).
1824
1825 Removed requirement for pflip -h to be given input file (can pipe from stdin).
1826
1827 Added "Number of processes" slider to trad "Action" pane to control rad -N
1828 option for rvu and batch rendering.
1829
1830 Added -c option to vwrays to repeat pixels for rtcontrib.
1831
1832 Reworked rtcontrib program and renamed to rcontrib. New version runs much
1833 faster, especially on multiprocessor systems, and doesn't require as much
1834 memory. No longer calls rtrace; instead does all the work itself.
1835
1836 Added -d option to genskyvec to produce direct-only (sun no sky) vector.
1837
1838 Added Ashikhmin-Shirley anisotropic BRDF model (ashik2) with help
1839 from Nicolas Boneel.
1840
1841 Added Ruby rewrite of objview.csh by Rob Guglielmetti.
1842
1843 Fixed bug in reciprocity for tensor tree BTDF representations. Thanks
1844 to Andy McNeil for identifying the problem.
1845
1846 Added MNAME and ZNAME variables to ranimove for debugging & testing.
1847
1848 Created pmblur2 command to take motion and depth buffers from ranimove
1849 to compute a better motion blur.
1850
1851 ****** COMPATIBILITY CHANGE ********
1852 Changed BSDF routines to use updated/corrected XML specification and
1853 removed depracated BSDF support from mkillum.
1854
1855 Fixed behavior of i/o flushing in rcontrib with -c > 1 (averaging). Thanks
1856 to Lars Grobe for help identifying this problem.
1857
1858 Fixed bug in depth-of-field blur where view distance was measured from
1859 fore clipping plane rather than viewpoint. Thanks to Peter A-B for
1860 pointing this out.
1861
1862 Added options to dctimestep to allow multiple time steps (-n)
1863 and multiple output pictures or sensor files (-o). Also added -i
1864 option to specify float (-if) or double (-id) input for sky matrix.
1865
1866 Created gendaymtx program to compute annual sky patch matrix based
1867 on Ian Ashdown's implementation of Perez all-weather sky model.
1868 Output can be sent directly to dctimestep in ASCII or binary stream.
1869
1870 Replaced existing gendaylit.c with improved version from Wendelin Sprenger
1871 and Jan Wienold of ISE.
1872
1873 Improved accuracy of ambient calculation for large -ad settings. Thanks
1874 to Lars Grobe for noticing the problem.
1875
1876 Added -r option to gendaymtx to rotate the sky the specified number of
1877 degrees about the zenith as suggested by A. McNeil.
1878
1879 Axel Jacobs added -pal eco color map that does a blue-red-yellow scale.
1880
1881 Created bsdf2klems tool to convert from various BSDF representations to
1882 Klems basis matrix in XML file.
1883
1884 Fixed problem with inappropriate reciprocity enforcement on tensor
1885 tree reduction in genBSDF. (Thanks to A.McNeil for discovering issue.)
1886
1887 Fixed bug in isotropic tensor tree sampling for impinging rays
1888 exactly normal to surface. Thanks to Peter Apian-Bennewitz for
1889 discovering and pointing out the error.
1890
1891 Fixed double-counting bug in mirror material with alternate type.
1892 Thanks to David Geisler-Moroder for spotting the problem and helping
1893 to fix it.
1894
1895 Created rcollate program to resize and transpose matrix data for Andy
1896 McNeil's 5-phase annual simulation method.
1897
1898 Added epw2wea conversion program by Christoph Reinhart.
1899
1900 Implemented Perlin's improved noise function with help from Rahul Narain.
1901 This will change the appearance of renderings using this function.
1902
1903 Added "origin" command to rvu as requested by John Mardaljevic
1904 to place view origin at selected point in scene.
1905
1906 Switch to Perl versions of objview and objpict written by Axel Jacobs.
1907
1908 Improved rendering speed of scenes with aliases by not entering new
1909 modifiers into table if they are the same as the previously defined
1910 modifier for that name.
1911
1912 Made it so icalc and rcalc search RAYPATH directories for *.cal files
1913 given on command line. This simplifies script writing and makes these
1914 utilities consistent with other tools in Radiance.
