Revision 1.241 - (view) (download) (annotate) - [select for diffs]
Thu Jul 31 18:32:41 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2
Changes since 1.240: +3 -1 lines
Diff to previous 1.240 , to selected 1.135
Preparation for 4.2 release
Revision 1.240 - (view) (download) (annotate) - [select for diffs]
Mon Jul 28 17:25:03 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.239: +2 -0 lines
Diff to previous 1.239 , to selected 1.135
Revision 1.239 - (view) (download) (annotate) - [select for diffs]
Tue Jul 22 21:55:31 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.238: +4 -0 lines
Diff to previous 1.238 , to selected 1.135
Revision 1.238 - (view) (download) (annotate) - [select for diffs]
Sat Jul 19 18:19:33 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.237: +3 -0 lines
Diff to previous 1.237 , to selected 1.135
Revision 1.237 - (view) (download) (annotate) - [select for diffs]
Thu Jun 19 16:26:55 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.236: +6 -0 lines
Diff to previous 1.236 , to selected 1.135
Revision 1.236 - (view) (download) (annotate) - [select for diffs]
Sat May 31 21:33:21 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.235: +4 -0 lines
Diff to previous 1.235 , to selected 1.135
Added rmtxop command for manipulating component matrices
Revision 1.235 - (view) (download) (annotate) - [select for diffs]
Fri May 30 00:00:54 2014 UTC (11 years, 6 months ago) by greg
Changes since 1.234: +4 -0 lines
Diff to previous 1.234 , to selected 1.135
Revision 1.234 - (view) (download) (annotate) - [select for diffs]
Tue Apr 15 22:36:25 2014 UTC (11 years, 8 months ago) by greg
Changes since 1.233: +3 -0 lines
Diff to previous 1.233 , to selected 1.135
Revision 1.233 - (view) (download) (annotate) - [select for diffs]
Tue Feb 18 12:13:42 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.232: +3 -0 lines
Diff to previous 1.232 , to selected 1.135
Revision 1.232 - (view) (download) (annotate) - [select for diffs]
Tue Feb 11 22:01:44 2014 UTC (11 years, 10 months ago) by greg
Changes since 1.231: +2 -0 lines
Diff to previous 1.231 , to selected 1.135
Revision 1.231 - (view) (download) (annotate) - [select for diffs]
Sat Feb 8 01:28:05 2014 UTC (11 years, 10 months ago) by greg
Changes since 1.230: +3 -0 lines
Diff to previous 1.230 , to selected 1.135
Revision 1.230 - (view) (download) (annotate) - [select for diffs]
Sat Jan 25 18:27:39 2014 UTC (11 years, 10 months ago) by greg
Changes since 1.229: +7 -0 lines
Diff to previous 1.229 , to selected 1.135
Revision 1.229 - (view) (download) (annotate) - [select for diffs]
Fri Jan 24 01:26:44 2014 UTC (11 years, 10 months ago) by greg
Changes since 1.228: +2 -0 lines
Diff to previous 1.228 , to selected 1.135
Revision 1.228 - (view) (download) (annotate) - [select for diffs]
Thu Dec 19 16:38:12 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.227: +4 -0 lines
Diff to previous 1.227 , to selected 1.135
Revision 1.227 - (view) (download) (annotate) - [select for diffs]
Sun Dec 8 18:59:53 2013 UTC (12 years ago) by greg
Changes since 1.226: +4 -0 lines
Diff to previous 1.226 , to selected 1.135
Revision 1.226 - (view) (download) (annotate) - [select for diffs]
Thu Dec 5 18:11:41 2013 UTC (12 years ago) by greg
Changes since 1.225: +2 -0 lines
Diff to previous 1.225 , to selected 1.135
Added mention of new Perl scripts by Axel
Revision 1.225 - (view) (download) (annotate) - [select for diffs]
Fri Oct 18 17:04:13 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.224: +3 -0 lines
Diff to previous 1.224 , to selected 1.135
Added rvu "origin" command requested by John M.
Revision 1.224 - (view) (download) (annotate) - [select for diffs]
Tue Oct 8 18:59:42 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.223: +3 -0 lines
Diff to previous 1.223 , to selected 1.135
Revision 1.223 - (view) (download) (annotate) - [select for diffs]
Wed Sep 25 16:52:28 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.222: +2 -0 lines
Diff to previous 1.222 , to selected 1.135
Revision 1.222 - (view) (download) (annotate) - [select for diffs]
Thu Sep 5 17:53:22 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.221: +3 -0 lines
Diff to previous 1.221 , to selected 1.135
Revision 1.221 - (view) (download) (annotate) - [select for diffs]
Thu Aug 29 15:37:15 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.220: +4 -0 lines
Diff to previous 1.220 , to selected 1.135
Fixed double-counting bug in mirror type with secondary material
Revision 1.220 - (view) (download) (annotate) - [select for diffs]
Thu Aug 8 05:26:55 2013 UTC (12 years, 4 months ago) by greg
Changes since 1.219: +4 -0 lines
Diff to previous 1.219 , to selected 1.135
Fixed bug in sampling of isotropic tensor trees from surface normal direction
Revision 1.219 - (view) (download) (annotate) - [select for diffs]
Mon Aug 5 22:56:50 2013 UTC (12 years, 4 months ago) by greg
Changes since 1.218: +3 -0 lines
Diff to previous 1.218 , to selected 1.135
Revision 1.218 - (view) (download) (annotate) - [select for diffs]
Sun Apr 21 23:01:14 2013 UTC (12 years, 7 months ago) by greg
Changes since 1.217: +3 -0 lines
Diff to previous 1.217 , to selected 1.135
Revision 1.217 - (view) (download) (annotate) - [select for diffs]
Thu Apr 4 15:13:43 2013 UTC (12 years, 8 months ago) by greg
Changes since 1.216: +1 -1 lines
Diff to previous 1.216 , to selected 1.135
Man page wording fix
Revision 1.216 - (view) (download) (annotate) - [select for diffs]
Thu Apr 4 02:59:20 2013 UTC (12 years, 8 months ago) by greg
Changes since 1.215: +2 -0 lines
Diff to previous 1.215 , to selected 1.135
Axel Jacobs added -pal eco option to falsecolor
Revision 1.215 - (view) (download) (annotate) - [select for diffs]
Tue Feb 5 06:00:19 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.214: +3 -0 lines
Diff to previous 1.214 , to selected 1.135
Added -r option to gendaymtx for rotating the sky about the zenith
Revision 1.214 - (view) (download) (annotate) - [select for diffs]
Tue Feb 5 05:41:16 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.213: +3 -0 lines
Diff to previous 1.213 , to selected 1.135
Revision 1.213 - (view) (download) (annotate) - [select for diffs]
Wed Jan 30 01:02:42 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.212: +3 -0 lines
Diff to previous 1.212 , to selected 1.135
Replaced gendaylit with new version by Wendelin Sprenger and Jan Wienold
Revision 1.212 - (view) (download) (annotate) - [select for diffs]
Sun Jan 20 02:07:16 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.211: +4 -0 lines
Diff to previous 1.211 , to selected 1.135
Added documentation for new gendaymtx tool
Revision 1.211 - (view) (download) (annotate) - [select for diffs]
Fri Jan 11 17:21:39 2013 UTC (12 years, 11 months ago) by greg
Changes since 1.210: +2 -1 lines
Diff to previous 1.210 , to selected 1.135
Revision 1.210 - (view) (download) (annotate) - [select for diffs]
Fri Jan 11 05:07:47 2013 UTC (12 years, 11 months ago) by greg
Changes since 1.209: +3 -0 lines
Diff to previous 1.209 , to selected 1.135
Revision 1.209 - (view) (download) (annotate) - [select for diffs]
Mon Nov 26 07:04:07 2012 UTC (13 years ago) by greg
Changes since 1.208: +4 -0 lines
Diff to previous 1.208 , to selected 1.135
Fixed bug in depth-of-field with non-zero fore clipping plane
Revision 1.208 - (view) (download) (annotate) - [select for diffs]
Thu Nov 15 19:41:03 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.207: +3 -0 lines
Diff to previous 1.207 , to selected 1.135
Revision 1.207 - (view) (download) (annotate) - [select for diffs]
Sat Oct 13 20:15:43 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.206: +4 -0 lines
Diff to previous 1.206 , to selected 1.135
Revision 1.206 - (view) (download) (annotate) - [select for diffs]
Fri Oct 5 00:59:38 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.205: +3 -0 lines
Diff to previous 1.205 , to selected 1.135
Revision 1.205 - (view) (download) (annotate) - [select for diffs]
Fri Sep 28 22:20:49 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.204: +2 -0 lines
Diff to previous 1.204 , to selected 1.135
Revision 1.204 - (view) (download) (annotate) - [select for diffs]
Sun Sep 2 15:33:15 2012 UTC (13 years, 3 months ago) by greg
Changes since 1.203: +3 -0 lines
Diff to previous 1.203 , to selected 1.135
Revision 1.203 - (view) (download) (annotate) - [select for diffs]
Tue Aug 7 18:17:17 2012 UTC (13 years, 4 months ago) by greg
Changes since 1.202: +2 -0 lines
Diff to previous 1.202 , to selected 1.135
Revision 1.202 - (view) (download) (annotate) - [select for diffs]
Sun Jul 29 19:01:39 2012 UTC (13 years, 4 months ago) by greg
Changes since 1.201: +3 -0 lines
Diff to previous 1.201 , to selected 1.135
Revision 1.201 - (view) (download) (annotate) - [select for diffs]
Thu Jun 28 20:48:03 2012 UTC (13 years, 5 months ago) by greg
Changes since 1.200: +2 -0 lines
Diff to previous 1.200 , to selected 1.135
Added -d option for sun-only vector
Revision 1.200 - (view) (download) (annotate) - [select for diffs]
Thu Jun 14 22:42:21 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.199: +4 -0 lines
Diff to previous 1.199 , to selected 1.135
Revision 1.199 - (view) (download) (annotate) - [select for diffs]
Thu Jun 14 05:19:05 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.198: +2 -0 lines
Diff to previous 1.198 , to selected 1.135
Added -c option to repeat pixels
Revision 1.198 - (view) (download) (annotate) - [select for diffs]
Sun Jun 3 19:21:38 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.197: +3 -0 lines
Diff to previous 1.197 , to selected 1.135
Added slider to control rad -N option in trad
Revision 1.197 - (view) (download) (annotate) - [select for diffs]
Thu May 17 17:36:14 2012 UTC (13 years, 7 months ago) by greg
Changes since 1.196: +2 -0 lines
Diff to previous 1.196 , to selected 1.135
Permitted pflip to pipe from stdin for horizontal-only flip
Revision 1.196 - (view) (download) (annotate) - [select for diffs]
Wed Apr 25 22:21:06 2012 UTC (13 years, 7 months ago) by greg
Changes since 1.195: +2 -0 lines
Diff to previous 1.195 , to selected 1.135
Revision 1.195 - (view) (download) (annotate) - [select for diffs]
Fri Mar 30 15:08:40 2012 UTC (13 years, 8 months ago) by greg
Changes since 1.194: +2 -0 lines
Diff to previous 1.194 , to selected 1.135
Fixed serious bug in transmitting proxy material ambient sampling
Revision 1.194 - (view) (download) (annotate) - [select for diffs]
Tue Mar 20 02:56:08 2012 UTC (13 years, 8 months ago) by greg
Changes since 1.193: +5 -0 lines
Diff to previous 1.193 , to selected 1.135
Revision 1.193 - (view) (download) (annotate) - [select for diffs]
Fri Feb 17 00:14:46 2012 UTC (13 years, 10 months ago) by greg
Changes since 1.192: +2 -0 lines
Diff to previous 1.192 , to selected 1.135
Revision 1.192 - (view) (download) (annotate) - [select for diffs]
Wed Jan 18 00:30:35 2012 UTC (13 years, 11 months ago) by greg
Changes since 1.191: +6 -1 lines
Diff to previous 1.191 , to selected 1.135
Axel Jacobs added options and Windows compatibility to falsecolor
Revision 1.191 - (view) (download) (annotate) - [select for diffs]
Wed Oct 26 16:48:01 2011 UTC (14 years, 1 month ago) by greg
Changes since 1.190: +4 -0 lines
Diff to previous 1.190 , to selected 1.135
Revision 1.190 - (view) (download) (annotate) - [select for diffs]
Wed Oct 26 03:44:56 2011 UTC (14 years, 1 month ago) by greg
Changes since 1.189: +3 -0 lines
Diff to previous 1.189 , to selected 1.135
Fixed underestimation of reflection in non-metals below -st threshold
Revision 1.189 - (view) (download) (annotate) - [select for diffs]
Tue Aug 2 22:47:30 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.188: +3 -0 lines
Diff to previous 1.188 , to selected 1.135
Revision 1.188 - (view) (download) (annotate) - [select for diffs]
Thu Jun 23 18:05:18 2011 UTC (14 years, 5 months ago) by greg
Changes since 1.187: +4 -0 lines
Diff to previous 1.187 , to selected 1.135
Created pkgBSDF program
Revision 1.187 - (view) (download) (annotate) - [select for diffs]
Fri Jun 3 19:41:14 2011 UTC (14 years, 6 months ago) by greg
Changes since 1.186: +2 -0 lines
Diff to previous 1.186 , to selected 1.135
Revision 1.186 - (view) (download) (annotate) - [select for diffs]
Thu May 19 16:09:38 2011 UTC (14 years, 7 months ago) by greg
Changes since 1.185: +2 -0 lines
Diff to previous 1.185 , to selected 1.135
Bug fix related to zero rows and added check for negative sensitivities
Revision 1.185 - (view) (download) (annotate) - [select for diffs]
Mon Feb 21 22:48:51 2011 UTC (14 years, 9 months ago) by greg
Changes since 1.184: +2 -0 lines
Diff to previous 1.184 , to selected 1.135
Revision 1.184 - (view) (download) (annotate) - [select for diffs]
Fri Feb 18 00:40:25 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.183: +2 -0 lines
Diff to previous 1.183 , to selected 1.135
Revision 1.183 - (view) (download) (annotate) - [select for diffs]
Thu Dec 16 21:34:41 2010 UTC (15 years ago) by greg
Changes since 1.182: +3 -0 lines
Diff to previous 1.182 , to selected 1.135
Added recording of other color spaces to pvalue -r conversion
Revision 1.182 - (view) (download) (annotate) - [select for diffs]
Thu Dec 2 18:08:11 2010 UTC (15 years ago) by greg
Changes since 1.181: +2 -0 lines
Diff to previous 1.181 , to selected 1.135
Revision 1.181 - (view) (download) (annotate) - [select for diffs]
Sun Oct 31 23:06:44 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.180: +2 -2 lines
Diff to previous 1.180 , to selected 1.135
Wording fixes
Revision 1.180 - (view) (download) (annotate) - [select for diffs]
Thu Oct 14 05:54:43 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.179: +2 -0 lines
Diff to previous 1.179 , to selected 1.135
Fixed long-standing bug in ambient file synchronization under FreeBSD
Revision 1.179 - (view) (download) (annotate) - [select for diffs]
Fri Oct 8 22:08:26 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.178: +6 -0 lines
Diff to previous 1.178 , to selected 1.135
Revision 1.178 - (view) (download) (annotate) - [select for diffs]
Tue Oct 5 00:59:38 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.177: +3 -0 lines
Diff to previous 1.177 , to selected 1.135
Revision 1.177 - (view) (download) (annotate) - [select for diffs]
Fri Oct 1 18:11:18 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.176: +3 -0 lines
Diff to previous 1.176 , to selected 1.135
Updated reflection model to match paper by Geisler-Moroder an Duer
Revision 1.176 - (view) (download) (annotate) - [select for diffs]
Tue Sep 28 21:28:22 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.175: +3 -0 lines
Diff to previous 1.175 , to selected 1.135
Fixed bug in "void" mapping of surfaces
Revision 1.175 - (view) (download) (annotate) - [select for diffs]
Sun Sep 26 15:51:15 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.174: +15 -0 lines
Diff to previous 1.174 , to selected 1.135
Revision 1.174 - (view) (download) (annotate) - [select for diffs]
Thu Sep 16 03:28:20 2010 UTC (15 years, 3 months ago) by greg
Changes since 1.173: +3 -0 lines
Diff to previous 1.173 , to selected 1.135
Changed obj2rad to accept illegal normals
Revision 1.173 - (view) (download) (annotate) - [select for diffs]
Fri Sep 3 23:53:49 2010 UTC (15 years, 3 months ago) by greg
Changes since 1.172: +4 -0 lines
Diff to previous 1.172 , to selected 1.135
Revision 1.172 - (view) (download) (annotate) - [select for diffs]
Thu Jul 1 21:54:55 2010 UTC (15 years, 5 months ago) by greg
Changes since 1.171: +3 -0 lines
Diff to previous 1.171 , to selected 1.135
Revision 1.171 - (view) (download) (annotate) - [select for diffs]
Fri Jun 18 21:22:49 2010 UTC (15 years, 6 months ago) by greg
Changes since 1.170: +2 -0 lines
Diff to previous 1.170 , to selected 1.135
Added -u option to rlam
Revision 1.170 - (view) (download) (annotate) - [select for diffs]
Thu May 27 19:32:12 2010 UTC (15 years, 6 months ago) by greg
Changes since 1.169: +3 -0 lines
Diff to previous 1.169 , to selected 1.135
Revision 1.169 - (view) (download) (annotate) - [select for diffs]
Tue May 18 00:01:02 2010 UTC (15 years, 7 months ago) by greg
Changes since 1.168: +2 -0 lines
Diff to previous 1.168 , to selected 1.135
Revision 1.168 - (view) (download) (annotate) - [select for diffs]
Fri May 7 15:46:48 2010 UTC (15 years, 7 months ago) by greg
Changes since 1.167: +4 -0 lines
Diff to previous 1.167 , to selected 1.135
Changed BTDF normalization back to what it was in version 3.5
Revision 1.167 - (view) (download) (annotate) - [select for diffs]
Tue Mar 16 04:44:22 2010 UTC (15 years, 9 months ago) by greg
Changes since 1.166: +8 -1 lines
Diff to previous 1.166 , to selected 1.135
Updated past 4.0
Revision 1.166 - (view) (download) (annotate) - [select for diffs]
Fri Mar 12 19:14:24 2010 UTC (15 years, 9 months ago) by greg
Changes since 1.165: +5 -5 lines
Diff to previous 1.165 , to selected 1.135
Added release dates
Revision 1.165 - (view) (download) (annotate) - [select for diffs]
Sun Dec 13 19:13:04 2009 UTC (16 years ago) by greg
Changes since 1.164: +1 -1 lines
Diff to previous 1.164 , to selected 1.135
Revision 1.164 - (view) (download) (annotate) - [select for diffs]
Sat Dec 12 19:00:59 2009 UTC (16 years ago) by greg
Changes since 1.163: +3 -0 lines
Diff to previous 1.163 , to selected 1.135
Revision 1.163 - (view) (download) (annotate) - [select for diffs]
Sat Dec 12 05:20:10 2009 UTC (16 years ago) by greg
Changes since 1.162: +3 -0 lines
Diff to previous 1.162 , to selected 1.135
Revision 1.162 - (view) (download) (annotate) - [select for diffs]
Wed Jun 17 20:41:46 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.161: +4 -0 lines
Diff to previous 1.161 , to selected 1.135
Revision 1.161 - (view) (download) (annotate) - [select for diffs]
Tue Jun 16 04:54:08 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.160: +3 -0 lines
Diff to previous 1.160 , to selected 1.135
Revision 1.160 - (view) (download) (annotate) - [select for diffs]
Sun Jun 14 20:07:59 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.159: +5 -2 lines
Diff to previous 1.159 , to selected 1.135
Added klems_int.cal module for computing Klems window bins
Revision 1.159 - (view) (download) (annotate) - [select for diffs]
Sun Jun 14 00:33:16 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.158: +5 -0 lines
Diff to previous 1.158 , to selected 1.135
Revision 1.158 - (view) (download) (annotate) - [select for diffs]
Sat Jun 6 20:18:32 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.157: +2 -0 lines
Diff to previous 1.157 , to selected 1.135
Revision 1.157 - (view) (download) (annotate) - [select for diffs]
Thu May 21 18:08:43 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.156: +3 -0 lines
Diff to previous 1.156 , to selected 1.135
Revision 1.156 - (view) (download) (annotate) - [select for diffs]
Wed Mar 4 00:12:24 2009 UTC (16 years, 9 months ago) by greg
Changes since 1.155: +3 -0 lines
Diff to previous 1.155 , to selected 1.135
Revision 1.155 - (view) (download) (annotate) - [select for diffs]
Mon Feb 9 16:41:28 2009 UTC (16 years, 10 months ago) by greg
Changes since 1.154: +2 -0 lines
Diff to previous 1.154 , to selected 1.135
Revision 1.154 - (view) (download) (annotate) - [select for diffs]
Thu Dec 18 23:26:57 2008 UTC (17 years ago) by greg
Changes since 1.153: +5 -0 lines
Diff to previous 1.153 , to selected 1.135
Revision 1.153 - (view) (download) (annotate) - [select for diffs]
Sat Dec 6 01:08:52 2008 UTC (17 years ago) by greg
Changes since 1.152: +3 -0 lines
Diff to previous 1.152 , to selected 1.135
Revision 1.152 - (view) (download) (annotate) - [select for diffs]
Fri Nov 21 01:30:16 2008 UTC (17 years ago) by greg
Changes since 1.151: +2 -0 lines
Diff to previous 1.151 , to selected 1.135
Added -N option to support multiprocessing in objview
Revision 1.151 - (view) (download) (annotate) - [select for diffs]
Mon Nov 10 19:08:18 2008 UTC (17 years, 1 month ago) by greg
Changes since 1.150: +8 -0 lines
Diff to previous 1.150 , to selected 1.135
Revision 1.150 - (view) (download) (annotate) - [select for diffs]
Thu Aug 21 07:05:58 2008 UTC (17 years, 3 months ago) by greg
Changes since 1.149: +2 -0 lines
Diff to previous 1.149 , to selected 1.135
Revision 1.149 - (view) (download) (annotate) - [select for diffs]
Wed Apr 30 21:48:02 2008 UTC (17 years, 7 months ago) by greg
Changes since 1.148: +3 -0 lines
Diff to previous 1.148 , to selected 1.135
Post 3.9 release changes
Revision 1.148 - (view) (download) (annotate) - [select for diffs]
Wed Apr 30 21:11:35 2008 UTC (17 years, 7 months ago) by greg
Changes since 1.147: +0 -3 lines
Diff to previous 1.147 , to selected 1.135
Correction to Window 6 notes
Revision 1.147 - (view) (download) (annotate) - [select for diffs]
Fri Apr 18 18:06:29 2008 UTC (17 years, 8 months ago) by greg
Changes since 1.146: +4 -0 lines
Diff to previous 1.146 , to selected 1.135
Modified rtcontrib -c option to accumulate a specified number of rays
Revision 1.146 - (view) (download) (annotate) - [select for diffs]
Tue Mar 11 02:21:46 2008 UTC (17 years, 9 months ago) by greg
Changes since 1.145: +3 -0 lines
Diff to previous 1.145 , to selected 1.135
Revision 1.145 - (view) (download) (annotate) - [select for diffs]
Thu Feb 21 01:22:06 2008 UTC (17 years, 9 months ago) by greg
Changes since 1.144: +5 -1 lines
Diff to previous 1.144 , to selected 1.135
Revision 1.144 - (view) (download) (annotate) - [select for diffs]
Fri Jan 25 02:11:12 2008 UTC (17 years, 10 months ago) by greg
Changes since 1.143: +4 -0 lines
Diff to previous 1.143 , to selected 1.135
Revision 1.143 - (view) (download) (annotate) - [select for diffs]
Thu Jan 24 23:15:46 2008 UTC (17 years, 10 months ago) by greg
Changes since 1.142: +6 -0 lines
Diff to previous 1.142 , to selected 1.135
Revision 1.142 - (view) (download) (annotate) - [select for diffs]
Thu Dec 13 07:03:37 2007 UTC (18 years ago) by greg
Changes since 1.141: +3 -0 lines
Diff to previous 1.141 , to selected 1.135
Revision 1.141 - (view) (download) (annotate) - [select for diffs]
Sat Nov 17 01:13:51 2007 UTC (18 years, 1 month ago) by greg
Changes since 1.140: +2 -0 lines
Diff to previous 1.140 , to selected 1.135
Added -c option to rtcontrib (barely tested, and -r does not work)
Revision 1.140 - (view) (download) (annotate) - [select for diffs]
Thu Nov 15 18:33:50 2007 UTC (18 years, 1 month ago) by greg
Changes since 1.139: +3 -0 lines
Diff to previous 1.139 , to selected 1.135
Allow -P and -PP options to be set by user for rtcontrib
Revision 1.139 - (view) (download) (annotate) - [select for diffs]
Mon Nov 5 23:40:25 2007 UTC (18 years, 1 month ago) by greg
Changes since 1.138: +2 -0 lines
Diff to previous 1.138 , to selected 1.135
Revision 1.138 - (view) (download) (annotate) - [select for diffs]
Tue Sep 18 19:51:07 2007 UTC (18 years, 3 months ago) by greg
Changes since 1.137: +3 -0 lines
Diff to previous 1.137 , to selected 1.135
Revision 1.137 - (view) (download) (annotate) - [select for diffs]
Wed Jul 25 04:12:35 2007 UTC (18 years, 4 months ago) by greg
Changes since 1.136: +4 -0 lines
Diff to previous 1.136 , to selected 1.135
Revision 1.136 - (view) (download) (annotate) - [select for diffs]
Thu Jul 12 14:58:53 2007 UTC (18 years, 5 months ago) by greg
Changes since 1.135: +4 -1 lines
Diff to previous 1.135
Decreased default -n setting in obj2mesh from 15 to 9
Revision 1.135 - (view) (download) (annotate) - [selected]
Mon Jul 2 20:16:00 2007 UTC (18 years, 5 months ago) by greg
Changes since 1.134: +2 -0 lines
Diff to previous 1.134
Corrected ray weighting for mixed materials
Revision 1.134 - (view) (download) (annotate) - [select for diffs]
Wed May 23 21:39:38 2007 UTC (18 years, 6 months ago) by greg
Changes since 1.133: +7 -0 lines
Diff to previous 1.133 , to selected 1.135
Fixed original octree bug that made it take 8 times as much memory as it should
Revision 1.133 - (view) (download) (annotate) - [select for diffs]
Mon Feb 26 21:16:02 2007 UTC (18 years, 9 months ago) by greg
Changes since 1.132: +2 -0 lines
Diff to previous 1.132 , to selected 1.135
Revision 1.132 - (view) (download) (annotate) - [select for diffs]
Sat Dec 23 17:27:45 2006 UTC (18 years, 11 months ago) by greg
Changes since 1.131: +2 -0 lines
Diff to previous 1.131 , to selected 1.135
Revision 1.131 - (view) (download) (annotate) - [select for diffs]
Mon Nov 13 02:41:46 2006 UTC (19 years, 1 month ago) by greg
Changes since 1.130: +6 -0 lines
Diff to previous 1.130 , to selected 1.135
Added -spec and "-s auto" options to falsecolor
Revision 1.130 - (view) (download) (annotate) - [select for diffs]
Fri Sep 8 21:38:25 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.129: +2 -0 lines
Diff to previous 1.129 , to selected 1.135
Revision 1.129 - (view) (download) (annotate) - [select for diffs]
Thu Sep 7 05:20:54 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.128: +3 -0 lines
Diff to previous 1.128 , to selected 1.135
Revision 1.128 - (view) (download) (annotate) - [select for diffs]
Tue Aug 22 21:38:21 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.127: +2 -0 lines
Diff to previous 1.127 , to selected 1.135
Added -o option to ra_xyze for original pixel values.
Revision 1.127 - (view) (download) (annotate) - [select for diffs]
Wed Jul 26 17:15:11 2006 UTC (19 years, 4 months ago) by greg
Changes since 1.126: +5 -0 lines
Diff to previous 1.126 , to selected 1.135
Changed default turbidity from 2.75 to 2.45
Revision 1.126 - (view) (download) (annotate) - [select for diffs]
Wed Jul 12 05:47:05 2006 UTC (19 years, 5 months ago) by greg
Changes since 1.125: +4 -0 lines
Diff to previous 1.125 , to selected 1.135
Revision 1.125 - (view) (download) (annotate) - [select for diffs]
Tue Jun 6 19:13:00 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.124: +2 -0 lines
Diff to previous 1.124 , to selected 1.135
Fixed long-standing inaccuracy of +/-t threshold options
Revision 1.124 - (view) (download) (annotate) - [select for diffs]
Mon May 29 17:31:25 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.123: +4 -0 lines
Diff to previous 1.123 , to selected 1.135
Revision 1.123 - (view) (download) (annotate) - [select for diffs]
Fri May 19 03:50:13 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.122: +4 -0 lines
Diff to previous 1.122 , to selected 1.135
Revision 1.122 - (view) (download) (annotate) - [select for diffs]
Wed May 10 15:34:16 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.121: +5 -0 lines
Diff to previous 1.121 , to selected 1.135
Minor fixes to last change with IEEE float lookup function
Revision 1.121 - (view) (download) (annotate) - [select for diffs]
Sun May 7 15:44:27 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.120: +2 -0 lines
Diff to previous 1.120 , to selected 1.135
Made missing calls to SET_FILE_BINARY() for Windows
Revision 1.120 - (view) (download) (annotate) - [select for diffs]
Fri Apr 7 19:39:10 2006 UTC (19 years, 8 months ago) by greg
Changes since 1.119: +2 -0 lines
Diff to previous 1.119 , to selected 1.135
Added credit for -u+ bug fix
Revision 1.119 - (view) (download) (annotate) - [select for diffs]
Wed Apr 5 14:30:38 2006 UTC (19 years, 8 months ago) by greg
Changes since 1.118: +2 -0 lines
Diff to previous 1.118 , to selected 1.135
Changed default in rtrace to -u+ (random sampling)
Revision 1.118 - (view) (download) (annotate) - [select for diffs]
Wed Apr 5 06:22:56 2006 UTC (19 years, 8 months ago) by greg
Changes since 1.117: +1 -0 lines
Diff to previous 1.117 , to selected 1.135
Made -u+ option truly random
Revision 1.117 - (view) (download) (annotate) - [select for diffs]
Fri Mar 10 19:40:11 2006 UTC (19 years, 9 months ago) by schorsch
Changes since 1.116: +4 -0 lines
Diff to previous 1.116 , to selected 1.135
Revision 1.116 - (view) (download) (annotate) - [select for diffs]
Tue Feb 28 03:44:54 2006 UTC (19 years, 9 months ago) by greg
Changes since 1.115: +2 -0 lines
Diff to previous 1.115 , to selected 1.135
Revision 1.115 - (view) (download) (annotate) - [select for diffs]
Sun Feb 5 22:22:20 2006 UTC (19 years, 10 months ago) by greg
Changes since 1.114: +3 -0 lines
Diff to previous 1.114 , to selected 1.135
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Revision 1.114 - (view) (download) (annotate) - [select for diffs]
Fri Jan 6 06:40:53 2006 UTC (19 years, 11 months ago) by greg
Changes since 1.113: +3 -0 lines
Diff to previous 1.113 , to selected 1.135
Fixed byte ordering for 16-bit/channel PPM files
Revision 1.113 - (view) (download) (annotate) - [select for diffs]
Wed Dec 28 19:42:13 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.112: +4 -0 lines
Diff to previous 1.112 , to selected 1.135
Fixed problems with genblinds
Revision 1.112 - (view) (download) (annotate) - [select for diffs]
Wed Dec 28 18:35:41 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.111: +2 -0 lines
Diff to previous 1.111 , to selected 1.135
Revision 1.111 - (view) (download) (annotate) - [select for diffs]
Fri Dec 16 04:05:16 2005 UTC (20 years ago) by greg
Changes since 1.110: +3 -0 lines
Diff to previous 1.110 , to selected 1.135
Removed NICE macro settings in rpict and rtrace to improve performance
Revision 1.110 - (view) (download) (annotate) - [select for diffs]
Thu Dec 8 17:56:38 2005 UTC (20 years ago) by greg
Changes since 1.109: +4 -0 lines
Diff to previous 1.109 , to selected 1.135
Added threshold to disable Fresnel approximation for specularities below 1.8%
Revision 1.109 - (view) (download) (annotate) - [select for diffs]
Sat Nov 12 06:14:51 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.108: +2 -0 lines
Diff to previous 1.108 , to selected 1.135
Improved default ordinal color scale in falsecolor
Revision 1.108 - (view) (download) (annotate) - [select for diffs]
Tue Oct 11 23:41:44 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.107: +3 -0 lines
Diff to previous 1.107 , to selected 1.135
Fixed rtcontrib flushing behavior
Revision 1.107 - (view) (download) (annotate) - [select for diffs]
Tue Oct 11 16:54:26 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.106: +3 -0 lines
Diff to previous 1.106 , to selected 1.135
Added rtcontrib -fo option to override new reluctance to clobber existing files
Revision 1.106 - (view) (download) (annotate) - [select for diffs]
Thu Oct 6 05:49:44 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.105: +3 -0 lines
Diff to previous 1.105 , to selected 1.135
Revision 1.105 - (view) (download) (annotate) - [select for diffs]
Sun Sep 25 20:36:02 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.104: +2 -0 lines
Diff to previous 1.104 , to selected 1.135
Added -i option to allow rlam to work with binary input records
Revision 1.104 - (view) (download) (annotate) - [select for diffs]
Fri Sep 23 19:04:52 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.103: +2 -0 lines
Diff to previous 1.103 , to selected 1.135
Revision 1.103 - (view) (download) (annotate) - [select for diffs]
Wed Sep 21 17:17:24 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.102: +3 -0 lines
Diff to previous 1.102 , to selected 1.135
Revision 1.102 - (view) (download) (annotate) - [select for diffs]
Tue Sep 20 17:05:10 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.101: +3 -0 lines
Diff to previous 1.101 , to selected 1.135
Fixed serious bug where rtcontrib would sometimes forget to write last file
Revision 1.101 - (view) (download) (annotate) - [select for diffs]
Mon Sep 19 04:26:08 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.100: +2 -0 lines
Diff to previous 1.100 , to selected 1.135
Revision 1.100 - (view) (download) (annotate) - [select for diffs]
Mon Sep 19 02:23:58 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.99: +2 -0 lines
Diff to previous 1.99 , to selected 1.135
Revision 1.99 - (view) (download) (annotate) - [select for diffs]
Sat Sep 17 05:14:14 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.98: +4 -0 lines
Diff to previous 1.98 , to selected 1.135
Revision 1.98 - (view) (download) (annotate) - [select for diffs]
Thu Sep 15 18:06:23 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.97: +3 -0 lines
Diff to previous 1.97 , to selected 1.135
Revision 1.97 - (view) (download) (annotate) - [select for diffs]
Fri Sep 2 14:43:43 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.96: +1 -1 lines
Diff to previous 1.96 , to selected 1.135
Added -e [default] and -o options for even/odd fields first
Revision 1.96 - (view) (download) (annotate) - [select for diffs]
Fri Sep 2 04:15:42 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.95: +3 -0 lines
Diff to previous 1.95 , to selected 1.135
Revision 1.95 - (view) (download) (annotate) - [select for diffs]
Mon Aug 22 21:54:41 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R7P2
Changes since 1.94: +2 -0 lines
Diff to previous 1.94 , to selected 1.135
Revision 1.94 - (view) (download) (annotate) - [select for diffs]
Mon Aug 22 16:07:26 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.93: +6 -0 lines
Diff to previous 1.93 , to selected 1.135
Revision 1.93 - (view) (download) (annotate) - [select for diffs]
Fri Aug 19 02:31:32 2005 UTC (20 years, 4 months ago) by greg
Changes since 1.92: +3 -0 lines
Diff to previous 1.92 , to selected 1.135
Revision 1.92 - (view) (download) (annotate) - [select for diffs]
Fri Aug 5 17:24:53 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad3R7P1
Changes since 1.91: +3 -1 lines
Diff to previous 1.91 , to selected 1.135
Changes for 3.7.1 patch release
Revision 1.91 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 17:01:30 2005 UTC (20 years, 4 months ago) by greg
Changes since 1.90: +2 -0 lines
Diff to previous 1.90 , to selected 1.135
Changed to 98th percentile for default threshold
Revision 1.90 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 16:41:46 2005 UTC (20 years, 4 months ago) by greg
Changes since 1.89: +3 -0 lines
Diff to previous 1.89 , to selected 1.135
Fixed serious bug in new Russian roulette algorithm
Revision 1.89 - (view) (download) (annotate) - [select for diffs]
Wed Jul 27 05:34:17 2005 UTC (20 years, 4 months ago) by greg
Changes since 1.88: +5 -1 lines
Diff to previous 1.88 , to selected 1.135
Onward to 3.8a
Revision 1.88 - (view) (download) (annotate) - [select for diffs]
Tue Jun 21 02:34:22 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.87: +4 -0 lines
Diff to previous 1.87 , to selected 1.135
Documented new behavior with blank input lines in total(1)
Revision 1.87 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 22:23:31 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.86: +2 -0 lines
Diff to previous 1.86 , to selected 1.135
Revision 1.86 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 17:10:05 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.85: +3 -0 lines
Diff to previous 1.85 , to selected 1.135
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Revision 1.85 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 04:04:51 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.84: +2 -2 lines
Diff to previous 1.84 , to selected 1.135
Revision 1.84 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 01:25:02 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.83: +3 -0 lines
Diff to previous 1.83 , to selected 1.135
Fixed bug in rcalc with -l option where it sometimes hung
Revision 1.83 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 22:40:46 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.82: +2 -0 lines
Diff to previous 1.82 , to selected 1.135
Changed rlam -t option to accept strings as well as tab characters
Revision 1.82 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 20:07:56 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.81: +3 -0 lines
Diff to previous 1.81 , to selected 1.135
Revision 1.81 - (view) (download) (annotate) - [select for diffs]
Thu Jun 9 17:27:27 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.80: +2 -0 lines
Diff to previous 1.80 , to selected 1.135
Revision 1.80 - (view) (download) (annotate) - [select for diffs]
Sun Jun 5 19:52:00 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.79: +3 -0 lines
Diff to previous 1.79 , to selected 1.135
Revision 1.79 - (view) (download) (annotate) - [select for diffs]
Thu Jun 2 04:47:26 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.78: +4 -0 lines
Diff to previous 1.78 , to selected 1.135
Revision 1.78 - (view) (download) (annotate) - [select for diffs]
Wed Jun 1 16:11:01 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.77: +4 -2 lines
Diff to previous 1.77 , to selected 1.135
Revision 1.77 - (view) (download) (annotate) - [select for diffs]
Tue May 31 18:01:08 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.76: +3 -0 lines
Diff to previous 1.76 , to selected 1.135
Revision 1.76 - (view) (download) (annotate) - [select for diffs]
Thu May 26 06:55:22 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.75: +4 -0 lines
Diff to previous 1.75 , to selected 1.135
Revision 1.75 - (view) (download) (annotate) - [select for diffs]
Wed May 25 04:44:25 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.74: +6 -0 lines
Diff to previous 1.74 , to selected 1.135
Revision 1.74 - (view) (download) (annotate) - [select for diffs]
Tue May 24 22:54:38 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.73: +3 -0 lines
Diff to previous 1.73 , to selected 1.135
Added note on change to blackbody.cal
Revision 1.73 - (view) (download) (annotate) - [select for diffs]
Wed May 4 23:43:19 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.72: +2 -0 lines
Diff to previous 1.72 , to selected 1.135
Created meta2bmp file to generate BMP output from metafile graphics
Revision 1.72 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 18:44:22 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.71: +2 -0 lines
Diff to previous 1.71 , to selected 1.135
Revision 1.71 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 01:15:06 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.70: +17 -0 lines
Diff to previous 1.70 , to selected 1.135
Thu Apr 14 18:04:12 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.69: +3 -0 lines
Diff to previous 1.69 , to selected 1.135
Wed Apr 13 23:00:58 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.68: +4 -0 lines
Diff to previous 1.68 , to selected 1.135
Tue Apr 12 03:30:43 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.67: +3 -0 lines
Diff to previous 1.67 , to selected 1.135
Created mksource program
Tue Mar 22 04:51:56 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.66: +3 -0 lines
Diff to previous 1.66 , to selected 1.135
Thu Mar 10 22:37:00 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.65: +7 -0 lines
Diff to previous 1.65 , to selected 1.135
Mon Feb 7 17:08:16 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.64: +4 -1 lines
Diff to previous 1.64 , to selected 1.135
Fri Jan 21 00:52:59 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.63: +3 -0 lines
Diff to previous 1.63 , to selected 1.135
Tue Jan 18 03:59:41 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.62: +3 -0 lines
Diff to previous 1.62 , to selected 1.135
Tue Jan 18 00:33:16 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.61: +5 -0 lines
Diff to previous 1.61 , to selected 1.135
Fri Jan 7 20:33:01 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.60: +3 -0 lines
Diff to previous 1.60 , to selected 1.135
Wed Jan 5 19:34:10 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.59: +4 -0 lines
Diff to previous 1.59 , to selected 1.135
Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Wed Dec 15 22:02:04 2004 UTC (21 years ago) by greg
Changes since 1.58: +3 -0 lines
Diff to previous 1.58 , to selected 1.135
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Thu Nov 25 14:47:03 2004 UTC (21 years ago) by greg
Changes since 1.57: +3 -0 lines
Diff to previous 1.57 , to selected 1.135
Mon Nov 8 15:50:59 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.56: +4 -0 lines
Diff to previous 1.56 , to selected 1.135
Fri Nov 5 03:31:36 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.55: +14 -0 lines
Diff to previous 1.55 , to selected 1.135
Sat Oct 30 04:59:41 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.54: +3 -0 lines
Diff to previous 1.54 , to selected 1.135
Thu Oct 28 00:49:27 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad3R6P1
Changes since 1.53: +13 -0 lines
Diff to previous 1.53 , to selected 1.135
Added comments on 3.6 bug fixes
Mon Oct 11 10:02:15 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.52: +3 -0 lines
Diff to previous 1.52 , to selected 1.135
Mon Oct 4 22:32:58 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.51: +2 -2 lines
Diff to previous 1.51 , to selected 1.135
Fixed minor spelling errors and typos
Mon Oct 4 17:44:22 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.50: +4 -0 lines
Diff to previous 1.50 , to selected 1.135
Fri Oct 1 07:45:30 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.49: +4 -0 lines
Diff to previous 1.49 , to selected 1.135
Thu Sep 23 18:00:54 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.48: +3 -0 lines
Diff to previous 1.48 , to selected 1.135
Mon Sep 20 17:32:04 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.47: +10 -0 lines
Diff to previous 1.47 , to selected 1.135
Corrected Gaussian reflectance model normalization (cosine factor)
Mon Sep 20 16:26:57 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.46: +6 -3 lines
Diff to previous 1.46 , to selected 1.135
Sun Sep 19 08:42:22 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.45: +4 -0 lines
Diff to previous 1.45 , to selected 1.135
Fri Sep 17 21:43:49 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.44: +2 -0 lines
Diff to previous 1.44 , to selected 1.135
Fri Sep 10 18:19:24 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.43: +3 -0 lines
Diff to previous 1.43 , to selected 1.135
Fri Sep 10 16:05:07 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.42: +4 -0 lines
Diff to previous 1.42 , to selected 1.135
Thu Sep 9 20:08:21 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 1.41 , to selected 1.135
Thu Sep 9 17:05:43 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.40: +8 -0 lines
Diff to previous 1.40 , to selected 1.135
Added notes about recent fixes
Wed Jun 9 16:00:13 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.39: +4 -0 lines
Diff to previous 1.39 , to selected 1.135
Fri Apr 30 20:29:24 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.38: +3 -0 lines
Diff to previous 1.38 , to selected 1.135
Fri Apr 30 17:00:29 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.37: +4 -0 lines
Diff to previous 1.37 , to selected 1.135
Fri Apr 23 16:20:54 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.36: +3 -0 lines
Diff to previous 1.36 , to selected 1.135
Fri Apr 23 00:56:27 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 1.35 , to selected 1.135
Mon Apr 12 17:31:27 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.34: +7 -1 lines
Diff to previous 1.34 , to selected 1.135
Sun Mar 28 16:31:14 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.33: +4 -0 lines
Diff to previous 1.33 , to selected 1.135
Fri Mar 26 22:58:21 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.32: +1 -2 lines
Diff to previous 1.32 , to selected 1.135
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.31: +4 -0 lines
Diff to previous 1.31 , to selected 1.135
Mon Mar 15 21:16:54 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 1.30 , to selected 1.135
Mon Mar 8 21:39:32 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 1.29 , to selected 1.135
Mon Mar 1 17:49:38 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.28: +5 -1 lines
Diff to previous 1.28 , to selected 1.135
Fri Jan 30 00:08:31 2004 UTC (21 years, 10 months ago) by greg
Diff to previous 1.27 , to selected 1.135
Thu Jan 29 22:20:31 2004 UTC (21 years, 10 months ago) by greg
Changes since 1.26: +13 -0 lines
Diff to previous 1.26 , to selected 1.135
Thu Jan 1 19:31:45 2004 UTC (21 years, 11 months ago) by greg
Changes since 1.25: +7 -0 lines
Diff to previous 1.25 , to selected 1.135
Wed Dec 31 01:50:02 2003 UTC (21 years, 11 months ago) by greg
Changes since 1.24: +9 -0 lines
Diff to previous 1.24 , to selected 1.135
Sun Dec 14 16:33:37 2003 UTC (22 years ago) by greg
Diff to previous 1.23 , to selected 1.135
Added -p option to histo to report percentiles and changed output slightly
Wed Nov 19 16:21:28 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.22: +2 -0 lines
Diff to previous 1.22 , to selected 1.135
Tue Nov 11 16:24:05 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.21 , to selected 1.135
Thu Nov 6 05:39:33 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.20 , to selected 1.135
Wed Oct 1 22:07:19 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.19: +3 -0 lines
Diff to previous 1.19 , to selected 1.135
Tue Sep 30 00:13:58 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.18: +3 -0 lines
Diff to previous 1.18 , to selected 1.135
Wed Sep 24 14:55:53 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.17: +6 -0 lines
Diff to previous 1.17 , to selected 1.135
Tue Sep 23 03:54:57 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.16: +3 -0 lines
Diff to previous 1.16 , to selected 1.135
Fri Sep 19 18:33:04 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.15: +3 -0 lines
Diff to previous 1.15 , to selected 1.135
Thu Sep 18 20:18:19 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.14 , to selected 1.135
Thu Sep 18 16:53:52 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.13 , to selected 1.135
Tue Sep 16 06:32:21 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.12 , to selected 1.135
Changed meta2tga so it outputs correct colors
Sat Sep 13 15:24:13 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.135
Fri Aug 29 21:44:17 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.10 , to selected 1.135
Tue Aug 26 16:09:43 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.9 , to selected 1.135
Mon Jul 14 04:56:53 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.8: +3 -0 lines
Diff to previous 1.8 , to selected 1.135
Thu Jul 10 03:47:00 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.135
Thu Jul 3 15:00:19 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.6: +3 -0 lines
Diff to previous 1.6 , to selected 1.135
Tue Jul 1 19:04:08 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.5 , to selected 1.135
Tue Jun 24 15:38:07 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.4 , to selected 1.135
Fri Jun 6 01:01:09 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.3: +21 -0 lines
Diff to previous 1.3 , to selected 1.135
Added mention of latest changes
Fri Mar 21 18:48:45 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 1.135
Tue Mar 18 04:45:28 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.135
Removed duplicate copies of file and fixed comment in release notes
Sat Mar 15 17:32:55 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 1.135
