Correction to Window 6 notes
Modified rtcontrib -c option to accumulate a specified number of rays
Added -c option to rtcontrib (barely tested, and -r does not work)
Allow -P and -PP options to be set by user for rtcontrib
Decreased default -n setting in obj2mesh from 15 to 9
Corrected ray weighting for mixed materials
Fixed original octree bug that made it take 8 times as much memory as it should
Added -spec and "-s auto" options to falsecolor
Added -o option to ra_xyze for original pixel values.
Changed default turbidity from 2.75 to 2.45
Fixed long-standing inaccuracy of +/-t threshold options
Minor fixes to last change with IEEE float lookup function
Made missing calls to SET_FILE_BINARY() for Windows
Added credit for -u+ bug fix
Changed default in rtrace to -u+ (random sampling)
Made -u+ option truly random
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Fixed byte ordering for 16-bit/channel PPM files
Fixed problems with genblinds
Removed NICE macro settings in rpict and rtrace to improve performance
Added threshold to disable Fresnel approximation for specularities below 1.8%
Improved default ordinal color scale in falsecolor
Fixed rtcontrib flushing behavior
Added rtcontrib -fo option to override new reluctance to clobber existing files
Added -i option to allow rlam to work with binary input records
Fixed serious bug where rtcontrib would sometimes forget to write last file
Added -e [default] and -o options for even/odd fields first
Changes for 3.7.1 patch release
Changed to 98th percentile for default threshold
Fixed serious bug in new Russian roulette algorithm
Onward to 3.8a
Documented new behavior with blank input lines in total(1)
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Fixed bug in rcalc with -l option where it sometimes hung
Changed rlam -t option to accept strings as well as tab characters
Added note on change to blackbody.cal
Created meta2bmp file to generate BMP output from metafile graphics
Created mksource program
Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Added comments on 3.6 bug fixes
Fixed minor spelling errors and typos
Corrected Gaussian reflectance model normalization (cosine factor)
Added notes about recent fixes
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Added -p option to histo to report percentiles and changed output slightly
Changed meta2tga so it outputs correct colors
Added mention of latest changes
Removed duplicate copies of file and fixed comment in release notes
