| 1 | ========================= |
| 2 | Version 1.2 (Released 3/9/90) |
| 3 |  |
| 4 | Added a -p option to rpict and pfilt to set the pixel aspect ratio for |
| 5 | output.  Instead of giving the absolute x and y resolutions, the user |
| 6 | now gives rpict and pfilt the maximum desired resolution for x and y |
| 7 | and the pixel aspect ratio is used along with the given view to |
| 8 | calculate appropriate values within this boundary.  This makes for |
| 9 | much more natural view specifications.  For example, for a 512x400 |
| 10 | device with a pixel aspect ratio of 1.0, the pfilt command: |
| 11 |  |
| 12 | pfilt -x 512 -y 400 -p 1 |
| 13 |  |
| 14 | will always produce the appropriate output, regardless of the aspect |
| 15 | ratio of the input picture.  If necessary, the x or y output resolution |
| 16 | will be reduced to accommodate the device's resolution.  A square image |
| 17 | would occupy a region of 400x400 pixels. |
| 18 |  |
| 19 | View shift and lift options were added to the list of standard view |
| 20 | parameters, for specifying views for panoramas and holograms. |
| 21 |  |
| 22 | Rview no longer takes options for x and y resolution, but instead |
| 23 | gets them from the device driver along with the pixel ratio.  This |
| 24 | makes it much easier to change the view aspect ratio (with the vh |
| 25 | and vv parameters). |
| 26 |  |
| 27 | A -z option was added to rpict to write out the distances for each |
| 28 | pixel in an image.  This may be useful for z-buffer operations, and |
| 29 | is used by the new program pinterp, described below. |
| 30 |  |
| 31 | A program called pinterp was added to the burgeoning list of |
| 32 | picture filters and converters.  This program is designed primarily |
| 33 | to interpolate animated frames for walk-throughs of static scenes, |
| 34 | but it has a number of other useful functions besides.  It takes as |
| 35 | its input one or more rendered pictures (with their corresponding z |
| 36 | value files) and desired viewpoint (hopefully not too far afield from |
| 37 | the given images).  Pinterp then takes the input frames and moves the |
| 38 | pixels to their new computed location.  Filling operations make sure |
| 39 | that the final image does not have large unpainted regions. |
| 40 |  |
| 41 | Added smoothing option to gensurf, using bilinear Phong surface normal |
| 42 | interpolation.  Not perfect, but it's better than nothing and permits |
| 43 | the use of fewer polygons to represent smoothly curved surfaces. |
| 44 |  |
| 45 | ========================= |
| 46 | Version 1.3 (Released 10/22/90) |
| 47 |  |
| 48 | Added conversion utility for IES (Illuminating Engineering Society) standard |
| 49 | format luminaire data.  The translator, called ies2rad, takes any number |
| 50 | of luminaire data files and creates the necessary Radiance geometric |
| 51 | descriptions and data files and puts them in the specified library location. |
| 52 | A new data format was added to accommodate irregularly-spaced data points. |
| 53 |  |
| 54 | Added rview driver for NeWS for Sun and Silicon Graphics workstations. |
| 55 | This work was done by Isaac Kwo. |
| 56 |  |
| 57 | Fixed oconv for scenes with many overlapping instances (runs faster now). |
| 58 |  |
| 59 | Added consitency checks intended to detect stale octrees without restricting |
| 60 | changes to surface modifiers.  (But you still can't change total number of |
| 61 | objects).  Stale octrees caused some of the strangest behavior... |
| 62 |  |
| 63 | Finally broke down and wrote my own malloc(3) routines.  There is a |
| 64 | CalTech module floating around Berkeley that caused a lot of trouble |
| 65 | for bmalloc(), resulting in about twice the needed memory use. |
| 66 |  |
| 67 | Added translator for Architrion.  Arch2rad uses mapping rules to assign |
| 68 | materials to surfaces from input file.  This is a general method (dreamed |
| 69 | up by Charles Ehrlich) that allows users to assign materials based on |
| 70 | whatever information is available from the CAD file.  See the accompanying |
| 71 | description file on translators in the ray/doc/notes directory. |
| 72 |  |
| 73 | Added fisheye view types to rpict and rview, useful for looking at |
| 74 | entire scenes and for LEEP virtual reality wide field stereo viewer. |
| 75 |  |
| 76 | Wrote xshowtrace, a fun program for watching rays as they are being |
| 77 | traced on an X11 display. |
| 78 |  |
| 79 | Write ra_pr24 for converting between 24-bit Sun rasterfiles and |
| 80 | Radiance pictures.  Perhaps this should be incorporated in ra_pr, as |
| 81 | ra_t8 and ra_t16 should be one program, but the algorithms and memory |
| 82 | requirements are totally different for colormapped images. |
| 83 |  |
| 84 | Added routines for performing 24-bit gamma correction in integer domain, |
| 85 | making programs like ra_pr24 and ra_t16 run faster. |
| 86 |  |
| 87 | ========================= |
| 88 | Version 1.4 (Released early 1991?) |
| 89 |  |
| 90 | Fixed bug in IES translator that resulted in the incorrect |
| 91 | interpretation of type B photometric data.  (1.3.1) |
| 92 |  |
| 93 | Added types for using BRDF data:  plasfunc, metfunc, plasdata and metdata. |
| 94 |  |
| 95 | Added interpretation of source color to ies2rad and color corrective |
| 96 | filtering to pfilt.  Reference file used by both is "lamp.tab" in |
| 97 | library directory. |
| 98 |  |
| 99 | Added picture flipping program, pflip, and pattern preprocessing script, |
| 100 | normpat.csh, to the px directory. |
| 101 |  |
| 102 | Fixed bug in ra_pr24 that caused the reversal of red and blue values. |
| 103 | New version accepts both RT_STANDARD and RT_FORMAT_RGB files but |
| 104 | produces only RT_STANDARD rasterfiles as output. |
| 105 |  |
| 106 | Added -m option to xform to change modifiers for surfaces. |
| 107 |  |
| 108 | Wrote replmarks program to replace markers in a Radiance scene file |
| 109 | for light sources or other objects. |
| 110 |  |
| 111 | Added global compilation script, makeall. |
| 112 |  |
| 113 | Fixed calculation of luminance in display programs and gensky to use |
| 114 | white light assumption. |
| 115 |  |
| 116 | Added options and features to pcomb. |
| 117 |  |
| 118 | Added FORMAT= line to all Radiance file headers for improved error |
| 119 | checking and clarity. |
| 120 |  |
| 121 | Added icon bitmaps for rview and x11image under X11 and fixed a bug |
| 122 | that caused x11image to ignore keyboard input. |
| 123 |  |
| 124 | ****** COMPATIBILITY CHANGE ******** |
| 125 | Added constant definitions to cal files using ':' instead of '='. |
| 126 | This makes for faster calculations since many more constant |
| 127 | expressions can be reduced at "compile" time. |
| 128 |  |
| 129 | Created glare calculation programs in util directory.  Findglare locates |
| 130 | glare sources, xglaresrc circles sources on a displayed image, and |
| 131 | glarendx computes various glare indices. |
| 132 |  |
| 133 | ========================= |
| 134 | Version 2.0 (Released 11/26/91) |
| 135 |  |
| 136 | Added -i option to renderers for computing irradiance rather than |
| 137 | radiance.  Eliminated redundant -oI option from rtrace and added |
| 138 | -I option to replace old -oi.  This hack ignores glass and similar |
| 139 | surfaces during the calculation. |
| 140 |  |
| 141 | Changed icon for x11image (renamed ximage) to miniature bitmap of |
| 142 | picture. |
| 143 |  |
| 144 | Fixed bug in xshowtrace that prevented it from working with twm. |
| 145 |  |
| 146 | Added memory recovery feature to rview so that when it refines |
| 147 | itself out of memory it doesn't quit but instead gives the user |
| 148 | a command line saying "out of memory:", which allows the output to |
| 149 | be written and so forth before quitting or restarting the image. |
| 150 |  |
| 151 | Added -g (gamma correction) option to pvalue. |
| 152 |  |
| 153 | Added the more general BRTDfunc for procedural definition of bidirectional |
| 154 | reflectance-transmittance distribution functions.  Also added transfunc |
| 155 | and transdata types. |
| 156 |  |
| 157 | Changed trans types to modify the color of the transmitted specular |
| 158 | component. |
| 159 |  |
| 160 | Fixed a bug in ra_t16 introduced in the last change which caused |
| 161 | problems for the (default) 16-bit output mode. |
| 162 |  |
| 163 | Improved Monte Carlo sampling for penumbras (-dj) and ambient |
| 164 | super-samples (-as) using stratified random number sequence introduced |
| 165 | by Christophe Schlick at '91 Eurographics workshop on rendering. |
| 166 |  |
| 167 | Wrote falsecolor program to transform images to false color with |
| 168 | value labels. |
| 169 |  |
| 170 | Modified pcomb to allow different output sizes and access to local |
| 171 | pixel neighborhood for specialty filtering applications. |
| 172 |  |
| 173 | Made cone and sphere routines more forgiving of negative radii, |
| 174 | switching between inverted types as necessary and giving warning |
| 175 | messages instead of bombing.  Cones with equal radii are now |
| 176 | silently converted into cylinders.  Hopefully, these changes will |
| 177 | make writing Radiance scene file translators a little bit easier. |
| 178 | Unfortunately, we still bomb for zero-sized cones and spheres. |
| 179 |  |
| 180 | Wrote a program called getbbox that just computes the bounding box |
| 181 | for a set of Radiance scene files.  It is basically a modified version |
| 182 | of oconv that doesn't store objects in memory and doesn't care about |
| 183 | undefined modifiers. |
| 184 |  |
| 185 | Added -a and -l options to pcompos and made both pcompos and pcomb |
| 186 | read from commands as well as files. |
| 187 |  |
| 188 | Substantially improved the accuracy and appearance of the interreflection |
| 189 | calculation by computing gradients at the same time as primary values and |
| 190 | then using a first order interpolation scheme.  This affects the information |
| 191 | stored in ambient files, so old files will have to be thrown away. |
| 192 |  |
| 193 | Added secondary light sources from planar mirror, prismatic and |
| 194 | holographic surfaces.  This created the new options -dr (direct relays) |
| 195 | and -dp (direct presample density) to the renderers.  The document |
| 196 | secsrc.note describes this feature in greater detail. |
| 197 |  |
| 198 | Put many of the routines into a common library. |
| 199 |  |
| 200 | Wrote a replacement for makedist, called mkillum, which generates |
| 201 | light distribtuions and illum descriptions for windows, skylights, |
| 202 | etc. in a much more natural and automatic fashion. |
| 203 |  |
| 204 | Fixed long-standing bug in text routines which caused slanted text |
| 205 | to slant the wrong way! |
| 206 |  |
| 207 | Added -e option to ra_bn, ra_pr, ra_pr24, ra_t8 and ra_t16 programs |
| 208 | for faster and more convenient image conversion w/o using pfilt. |
| 209 |  |
| 210 | ****** COMPATIBILITY CHANGE ******** |
| 211 | Finally added contexts to calcomp routines so identical names in |
| 212 | different function files no longer conflict.  Loading of function |
| 213 | files also works automatically without those nasty "key" variables. |
| 214 | New context marks (backquote characters) appear in some local variables |
| 215 | defined in some of the cal files.  This is inconsistent with older |
| 216 | versions, and must be changed back to and underscore or some other legal |
| 217 | character if these files are used by 1.4 and earlier. |
| 218 |  |
| 219 | Wrote ra_tiff program, using Sam Leffler's libtiff package to read |
| 220 | and write 24-bit TIFF images. |
| 221 |  |
| 222 | Wrote ra_ppm program to convert to and from Poskanzer Pixmaps. |
| 223 |  |
| 224 | ****** COMPATIBILITY CHANGE ******** |
| 225 | Changed run-length encoding of Radiance pictures to gain better |
| 226 | compression.  Routines can still read old format, but new ra_rgbe |
| 227 | program must be used to write convert images to a more generic format |
| 228 | that can be read by release 1.4 and earlier. |
| 229 |  |
| 230 | Defined U and V parameters in rayinit.cal for more convenient (and |
| 231 | sloppy) use of 2-dimensional textures and patterns on planar surfaces. |
| 232 |  |
| 233 | Beefed up lampcolor program to compute spectral radiance for diffuse |
| 234 | emitters.  This was a previously a pain in the butt and a serious |
| 235 | source of error for scenes not modeled using IES data files. |
| 236 |  |
| 237 | Added version reporting to rpict, rtrace and rview.  Use standalone |
| 238 | -version option. |
| 239 |  |
| 240 | Changed to quincunx initial sampling pattern in rpict.  This should |
| 241 | reduce artifacts from adaptive image sampling at no added cost. |
| 242 |  |
| 243 | Added -rgb option to ra_pr24 to produce RT_FORMAT_RGB files. |
| 244 |  |
| 245 | Added -ds option to renderers to make source sampling more accurate |
| 246 | for large area sources.  It is no longer necessary or recommended |
| 247 | to break large sources (such as windows) into smaller pieces with |
| 248 | gensurf unless their output distribution changes over their surface. |
| 249 | Also, cylinders can now be used as light sources, provided they are not |
| 250 | too short compared to their radius (causing them to be frequently missed). |
| 251 |  |
| 252 | Added -I option to xform to invert surfaces. |
| 253 |  |
| 254 | Added SMLFLT and BIGMEM defines to better control the sizes of data |
| 255 | structures during compilation.  Made their setting relatively |
| 256 | straightforward in makeall and created a separate rmake program to |
| 257 | hold the options generated by makeall. |
| 258 |  |
| 259 | Made the programs more forgiving of machine differences on octrees. |
| 260 |  |
| 261 | ****** COMPATIBILITY CHANGE ******** |
| 262 | Fixed incorrect conversion factor between radiance and luminance. |
| 263 | The correct luminous efficacy value is now defined in color.h as |
| 264 | WHTEFFICACY.  It was 470 lumens/watt previously, now it has been |
| 265 | corrected to 179 lumens/watt.  This affects the absolute values |
| 266 | in the output of programs like gensky and ies2rad.  Thus, these |
| 267 | programs should be rerun to generate corrected files for this |
| 268 | version of Radiance.  Also, the new versions of display programs |
| 269 | like ximage will give different values with the 'l' command on |
| 270 | an image generated with 1.4 and previous releases.  The following |
| 271 | alias may be used to fix the radiance values in a picture generated |
| 272 | using previous versions of gensky and ies2rad: |
| 273 |  |
| 274 | alias pfixabs '( echo EXPOSURE=.381 ; cat \!:1 ) > \!:1.$$ ; mv \!:1.$$ \!:1' |
| 275 |  |
| 276 | Improved accuracy of glass material type and added option for |
| 277 | user-supplied index of refraction. |
| 278 |  |
| 279 | Added sgi to rt/Makefile and px/Makefile SPECIAL category for compiling |
| 280 | Isaac Kwo's NeWS driver for rview and the glimage program by Jim Winget. |
| 281 | Also fixed various compile problems for the SGI. |
| 282 |  |
| 283 | Improved handling of alternate scanline orientations.  The programs |
| 284 | pflip and protate (used to be prot) now affect the scanline ordering |
| 285 | of the file without messing up the view parameters for programs like |
| 286 | pinterp and findglare. |
| 287 |  |
| 288 | ========================== |
| 289 | Version 2.1 (Released 5/20/92) |
| 290 |  |
| 291 | ****** COMPATIBILITY CHANGE ******** |
| 292 | Changed function specifications to allow the use of expressions as |
| 293 | well as variables in scene files.  Use of this feature may result |
| 294 | in some loss of backwards compatibility as older software does not |
| 295 | support it. |
| 296 |  |
| 297 | Added makeall option for NeXT machine and changed code to suit. |
| 298 |  |
| 299 | ****** COMPATIBILITY CHANGE ******** |
| 300 | Added off-specular sampling and anisotropic materials plastic2, |
| 301 | metal2 and trans2.  The old options -sp, -sj, -st and -p have |
| 302 | been renamed to -ps, -pj, -pt and -pa, respectively.  New options |
| 303 | -sj and -st have been introduced. |
| 304 |  |
| 305 | Improved ray intersection calculations using -DSMLFLT option by |
| 306 | increasing epsilon used in tests.  This eliminates most of the |
| 307 | errors that occured when this compile option was used in version 2.0. |
| 308 |  |
| 309 | Added capability to gensurf to read height or point data from a |
| 310 | file.  This makes it more convenient to make (optionally smoothed) |
| 311 | landscapes from recorded measurements and the like. |
| 312 |  |
| 313 | Corrected irradiance gradient calculation.  New formula predicts |
| 314 | gradient better and thus reduces artifacts in indirect calculation. |
| 315 |  |
| 316 | Modified replmarks to accept multiple markers. |
| 317 |  |
| 318 | Added -aI and -aE options to read ambient include/exclude materials |
| 319 | from a file. |
| 320 |  |
| 321 | Reduced effect of light leaks during interreflection calculation. |
| 322 |  |
| 323 | Added -ang option to gensky for giving solar angles explicitly. |
| 324 |  |
| 325 | Added ability of "view" command within rview to accept view options. |
| 326 |  |
| 327 | Fixed a long-standing bug in gensky that caused it to report |
| 328 | inaccurate values for the ground ambient level.  Since the dayfact |
| 329 | script uses this value in calculating its results, version 2.0 will |
| 330 | be in error (by as much as 30 or 40%). |
| 331 |  |
| 332 | Fixed a bug in the reflectance normalization for isotropic and |
| 333 | anisotropic Gaussian highlights that caused too much light to |
| 334 | be reflected near grazing angles.  Much thanks to the folks at |
| 335 | Ohio State University (Steve Spencer and Kevin Simon) who |
| 336 | pointed this out to me! |
| 337 |  |
| 338 | Fixed bug in xshowtrace introduced in 2.0.  It absolutely didn't work |
| 339 | after my most recent changes to image.c.  (Sorry about that!) |
| 340 |  |
| 341 | Finally fixed shortcoming of view reading routines so they can get |
| 342 | the views from pictures created with absolute program paths |
| 343 | (eg. /usr/local/bin/rpict).  This affects programs like |
| 344 | xshowtrace and glare, as well as the recover option of rpict. |
| 345 |  |
| 346 | Fixed isotropic Gaussian distribution (highlights for types "metal" |
| 347 | and "plastic") to make them more accurate and bring them into line |
| 348 | with the new anisotropic Gaussian models ("metal2" and "plastic2"). |
| 349 | This may affect the appearance of some hightlights. |
| 350 |  |
| 351 | Added -H and -R options to pvalue to control resolution strings |
| 352 | and color ordering. |
| 353 |  |
| 354 | Fixed byte ordering for 24-bit color displays in ximage. |
| 355 |  |
| 356 | ========================== |
| 357 | Version 2.2 (No official release) |
| 358 |  |
| 359 | Made more fixes in rview and ximage for different display hardware. |
| 360 | Philip Thompson and Peter Apian helped with suggestions and testing. |
| 361 |  |
| 362 | Fixed bug in -e option of xform that kept it from fully expanding |
| 363 | some scene files. |
| 364 |  |
| 365 | Added proportional text spacing (-s option for psign, new argument |
| 366 | for text primitives).  Added antialiasing (3x3 super-sampling) to psign. |
| 367 |  |
| 368 | Added code in display drivers to read environment variable called |
| 369 | "GAMMA" to set gamma correction for different monitors.  See notes in |
| 370 | this directory on gamma_corr. |
| 371 |  |
| 372 | Added CC defines to all the Rmakefiles so that other C compilers may be |
| 373 | used consistently. |
| 374 |  |
| 375 | Added -x and -y options to psign to control output dimensions directly. |
| 376 |  |
| 377 | Decreased value of FTINY with SMLFLT option once again in an attempt to |
| 378 | further reduce errors. |
| 379 |  |
| 380 | Reinstated rtrace's capability to produce 32-bit_rle_rgbe directly. |
| 381 |  |
| 382 | Added -S and -o options to rpict for more flexible production of |
| 383 | multiple images and slave operation.  Rpict will also accept a recover |
| 384 | file name the same as the output file for more convenient recovery. |
| 385 |  |
| 386 | Added ra_ps program to translate Radiance picture into PostScript file. |
| 387 |  |
| 388 | ****** COMPATIBILITY CHANGE ******** |
| 389 | Made ambient files machine-independent so they can be conveniently moved |
| 390 | and reused on any system.  Also added coordinated reads and writes so |
| 391 | that multiple processes may use the same ambient file at the same time. |
| 392 | Along with the -S option of rpict, this should greatly facilitate parallel |
| 393 | rendering.  The new ambient file format also contains a header that |
| 394 | can be read by getinfo.  Lookamb now has a -h option. |
| 395 |  |
| 396 | Created rpiece program for parallel rendering of a single image on |
| 397 | multiple processors and workstations. |
| 398 |  |
| 399 | Eliminated star artifacts in mkillum distribution patterns by improving |
| 400 | data interpolation method.  Improved ability of mkillum to correctly |
| 401 | sample non-axis-aligned polygons. |
| 402 |  |
| 403 | Added -s and -o options to pcompos for slightly more convenient use |
| 404 | of the -a option.  Also eliminated incompatibility between -a and -y |
| 405 | options. |
| 406 |  |
| 407 | Fixed bug in spotlight sources that caused incorrect boundaries to be |
| 408 | cast by mirrors. |
| 409 |  |
| 410 | Fixed rounding of scanlines in ra_pr24 to 16-bit boundaries. |
| 411 |  |
| 412 | Added @file and $envar expansion capabilities to rtrace, rpict and |
| 413 | rview.  This is primarily to overcome the 128-byte command limit of |
| 414 | MS-DOS. |
| 415 |  |
| 416 | Added -r option to gensky for the direct specification of solar |
| 417 | brightness. |
| 418 |  |
| 419 | Added -oN option to rtrace for reporting unperturbed surface normals, |
| 420 | and changed -on to report perturbed surface normals (used to be |
| 421 | unperturbed). |
| 422 |  |
| 423 | Changed -di switch of rtrace, rpict and rview to -dv and changed |
| 424 | sense.  Thus, instead of having a boolean variable called "source |
| 425 | invisibility" that is normally off, there is now a boolean variable |
| 426 | called "source visibility" that is normally on.  More logical, and |
| 427 | also allows for the addition of -di and -de options for direct |
| 428 | include and exclude in the future. |
| 429 |  |
| 430 | Fixed bug in image.c associated with -DSMLFLT that caused angular |
| 431 | fisheye views to repeat the center pixel in the middle of an image. |
| 432 |  |
| 433 | Modified colordata and colorpict to take functions of a single variable |
| 434 | instead of always requiring functions of three variables (red, green, blue). |
| 435 |  |
| 436 | Modified objview script to work in original object coordinates. |
| 437 |  |
| 438 | Added -P and -PP options to rpict and rtrace for persistent and parallel |
| 439 | processing, respectively.  The -P option is most useful with the -fr |
| 440 | option of pinterp, since rtrace doesn't have to be restarted for every |
| 441 | frame in a long animation sequence.  The -PP option is most useful when |
| 442 | running rpiece on a multiprocessing platform, to get acceptable memory |
| 443 | sharing without the hassle of threaded code. |
| 444 |  |
| 445 | Changed signal handling in rpict so CONT is now used to elicit |
| 446 | asynchronous progress reports.  ALRM now causes rpict to die |
| 447 | unconditionally. |
| 448 |  |
| 449 | Created executive program called "rad" to run oconv, rview, rpict and |
| 450 | pfilt automatically.  This should greatly simplify use of Radiance and |
| 451 | reduce the problems associated with poorly chosen parameter values. |
| 452 |  |
| 453 | Added slave driver to rview to make it easier to run from other |
| 454 | graphics applications.  (Thanks to Chris Nicholas of Sun for the |
| 455 | suggestion.) |
| 456 |  |
| 457 | Fixed error in ies2rad.c and source.cal that caused incorrect |
| 458 | interpretation of asymmetric Type C (A) fixture photometry.  Note the |
| 459 | new definition of src_phi in source.cal.  This change may affect |
| 460 | manually entered photometry. |
| 461 |  |
| 462 | Added '@' command to ximage to adjust exposure based on Blackwell's |
| 463 | model of human contrast sensitivity. |
| 464 |  |
| 465 | Added functions to pcomb to get the ray origin and direction from the |
| 466 | input picture view specifications. |
| 467 |  |
| 468 | Removed Fresnel approximation to specular reflection from Radiance materials, |
| 469 | since the direct component was not being computed correctly.  This |
| 470 | may have a slight affect on the appearance of surfaces, but it can't be |
| 471 | helped. |
| 472 |  |
| 473 | ****** COMPATIBILITY CHANGE ******** |
| 474 | Changed the definition of the BRTDfunc type so as to be more general and to |
| 475 | allow for different reflection properties depending on what side of the |
| 476 | surface the ray is incident.  Any scene and function files using the |
| 477 | old definition of BRTDfunc must be updated.   Implemented the approximation |
| 478 | used in Window 4 to reflection from coated glazings in lib/glazing.cal. |
| 479 |  |
| 480 | Added -ti, -te, -tI and -tE options to rtrace for including or |
| 481 | excluding surfaces from those reported by the trace output specifier. |
| 482 |  |
| 483 | Fixed long-standing bug in pfilt gaussian filter option, which caused |
| 484 | the image to be excessively defocused. |
| 485 |  |
| 486 | Added -m option to pfilt for image sample smoothing.  This helps get rid |
| 487 | of some of the "speckle" associated with specular sampling. |
| 488 |  |
| 489 | Made -ovt* compatible with -I option of rtrace. |
| 490 |  |
| 491 | Changed ximage to work with multiple pictures.  It now opens one window |
| 492 | for each picture file. |
| 493 |  |
| 494 | Fixed error reporting in rpict for most machines.  (Many thanks to Peter |
| 495 | Apian-Bennewitz for his help and suggestions.) |
| 496 |  |
| 497 | ****** COMPATIBILITY CHANGE ******** |
| 498 | Added intermediate sky to gensky and changed its options slightly. |
| 499 | The new gensky uses a new version of skybright.cal, so any old |
| 500 | gensky output in files must be recomputed with the new gensky before |
| 501 | it will work.  (A "skybright: undefined" error should clue you in.) |
| 502 |  |
| 503 | ========================== |
| 504 | Version 2.3 (Released 11/16/93) |
| 505 |  |
| 506 | No changes from the above, but the official release was designated 2.3 |
| 507 | to avoid confusion with previous beta releases of 2.2. |
| 508 |  |
| 509 | ========================== |
| 510 | Version 2.4 (Released 4/20/94) |
| 511 |  |
| 512 | Philip Thompson of MIT added use of a radiance.gamma resource to ximage |
| 513 | and we added it to the x11 driver of rview as well.  This is an alternative |
| 514 | to setting the GAMMA environment variable for X11 servers. |
| 515 |  |
| 516 | Added MLIB variable to Rmakefile's for defining alternate math libraries. |
| 517 | I discovered that the default version of sqrt() under IRIX is a whole |
| 518 | lot slower than what's in the libfastm.a library, and not much better. |
| 519 | This can make a significant difference to the renderers, since sqrt() |
| 520 | is relied on quite a bit, and it's assumed to be fast. |
| 521 |  |
| 522 | Added =SS option to pcompos to allow anchor points for image positions |
| 523 | other than the lower left corner. |
| 524 |  |
| 525 | Wrote raddepend script for finding dependencies in scene files. |
| 526 |  |
| 527 | Fixed a bug in mkillum that caused it to incorrectly sample ring sources. |
| 528 |  |
| 529 | Finally allowed mixtures to work with materials, thanks to the encouragement |
| 530 | and advice of Peter Apian-Bennewitz. |
| 531 |  |
| 532 | Wrote a triangular mesh converter, called tmesh2rad.  I defined my own |
| 533 | format, since I wasn't too familiar with anyone else's format and I |
| 534 | wanted to support some additional possibilities (most notably patterns). |
| 535 |  |
| 536 | Added initial "#?RADIANCE" line to headers to simplify Radiance file |
| 537 | identification by programs used to magic numbers. |
| 538 |  |
| 539 | Created a translator for Wavefront .obj files, called obj2rad.  It uses |
| 540 | the same type of mapping rules as arch2rad. |
| 541 |  |
| 542 | ============================= |
| 543 | Version 2.5 (Released 6/26/95) |
| 544 |  |
| 545 | Wrote translators to and from the new MGF (Materials and Geometry |
| 546 | Format) specification. |
| 547 |  |
| 548 | Changed color conversion routines to make light source colors (from |
| 549 | lamp.tab) consistent with uniform white light standard. |
| 550 |  |
| 551 | Fixed a bug that caused very small local sources not to be sampled |
| 552 | at all! |
| 553 |  |
| 554 | Added the ability for rview to read commands from its standard input |
| 555 | under X11. |
| 556 |  |
| 557 | ****************** COMPATIBILITY CHANGE *********************** |
| 558 | Changed GAMMA environment variable to DISPLAY_GAMMA, to bring it in |
| 559 | line with the xli program, so users don't have to give two variables |
| 560 | for the same value! |
| 561 |  |
| 562 | Added -t (touch) option to rad, to make it easier to deal with minor |
| 563 | changes to input files. |
| 564 |  |
| 565 | Created graphical user interface to rad, called trad.  Based on Tcl/Tk, |
| 566 | this should finally get people to start using this program! |
| 567 |  |
| 568 | Added -vo and -va (view fore and view aft) clipping plane options to |
| 569 | Radiance view parameters. |
| 570 |  |
| 571 | Added -bv option for (opaque) back face visibility control. |
| 572 |  |
| 573 | Added -q, -a and -e options to pinterp, and made it faster.  (These |
| 574 | should be big improvements.) |
| 575 |  |
| 576 | Created tabfunc program for converting data tables to functional |
| 577 | language. |
| 578 |  |
| 579 | Wrote mgf2meta program to convert MGF data to line drawing. |
| 580 |  |
| 581 | Updated ies2rad program to interpret MGF geometry in IESNA-LM-63-1995 |
| 582 | files. |
| 583 |  |
| 584 | Added sorting of ambient values according to access times to improve |
| 585 | reference locality for better virtual memory performance. |
| 586 |  |
| 587 | Added source solid angle argument to BRTD functions for averaging |
| 588 | values. |
| 589 |  |
| 590 | Wrote genclock program to create an analog clock. |
| 591 |  |
| 592 | Fixed a bug for bitmaps using hexbit4x1.fnt with brighttext, which |
| 593 | caused thin lines to appear. |
| 594 |  |
| 595 | ============================= |
| 596 | Version 3.0 (Released 6/19/96) |
| 597 |  |
| 598 | Added comments to data and font files. |
| 599 |  |
| 600 | Changed behavior of mirror to allow void alternate material. |
| 601 |  |
| 602 | Added cylindrical view type for Quicktime VR authoring and other |
| 603 | interesting applications. |
| 604 |  |
| 605 | Increased default rtrace parameters for more accurate calculations when |
| 606 | options are not specified. |
| 607 |  |
| 608 | Added RAWFILE and ZFILE variables to rad for saving raw picture file and |
| 609 | Z (distance) information from rpict. |
| 610 |  |
| 611 | Ported trad for newer (4.0) version of Tk (wish).  Thanks to Bob Lipman |
| 612 | of NIST for helping me track down the changes. |
| 613 |  |
| 614 | Added -B option to pinterp to blur multiple views into a single image, |
| 615 | useful for motion blur and depth of field simulation. |
| 616 |  |
| 617 | Created pdfblur script and modified vwright to automate depth-of-field |
| 618 | simulation with pinterp. |
| 619 |  |
| 620 | Added -c option for color PostScript output from ra_ps, and made both |
| 621 | this program and psmeta produce EPS-compatible files. |
| 622 |  |
| 623 | Created macbethcal program for calibrating color image scanners and |
| 624 | film recorders or printers using the Macbeth ColorChecker chart. |
| 625 |  |
| 626 | Created ra_xyze program for converting to and from new Radiance CIE XYZE |
| 627 | picture type and calibrating monitor colors.  Modified Radiance picture |
| 628 | filters (pcompos, pflip, pcomb, pinterp, protate and pfilt) to handle |
| 629 | new picture type without complaint. |
| 630 |  |
| 631 | Added automatic ambient value computation to improve accuracy of results |
| 632 | no matter what -av value is given.  (Only works for -ab > 0.)  This was |
| 633 | a fairly obvious optomization I should have thought of ages ago. |
| 634 | (Default is old behavior -- -aw option puts in new code.) |
| 635 |  |
| 636 | Modified interreflection calculation to take textures (surface normal |
| 637 | perturbations) into account in indirect illumination.  This should |
| 638 | improve the accuracy and appearance of textured surfaces in shadowed |
| 639 | regions. |
| 640 |  |
| 641 | Added -T option to rpiece to limit execution time. |
| 642 |  |
| 643 | Fixed bug in mixtext type introduced in last release -- caused improper |
| 644 | calculation of mixed modifiers. |
| 645 |  |
| 646 | Added basic options and functionality for participating media.  New material |
| 647 | type "mist" and rendering options -me, -ma, -mg and -ms.  This should permit |
| 648 | the modeling of visible light beams, uniform smoke, fog, and some types |
| 649 | of clouds. |
| 650 |  |
| 651 | Added -o option to ximage to control output of 't' command (and |
| 652 | middle mouse button).  This adds the ability to produce pixel |
| 653 | position, radiance value and luminance.  The default action is |
| 654 | the same as before. |
| 655 |  |
| 656 | Created pmblur script to generate views for camera motion blur in |
| 657 | walk-through animations. |
| 658 |  |
| 659 | Added "inpic" variable to picture.cal for determining when the edge |
| 660 | of a non-repeating image has been reached.  Use with mixfunc primitive. |
| 661 |  |
| 662 | Created ranimate program to control walk-through and dynamic animations |
| 663 | on multiple hosts. |
| 664 |  |
| 665 | Fixed problem with antimatter type referring to final definition of |
| 666 | material names.  Now, it uses the most recent ones. |
| 667 |  |
| 668 | Added an MC macro for true Monte Carlo sampling rather than the default |
| 669 | Quasi Monte Carlo.  To enable, add -DMC to the OPT= line in rmake. |
| 670 |  |
| 671 | Fixed bug in pfilt -m option that caused floating point exceptions on |
| 672 | Alphas. |
| 673 |  |
| 674 | Wrote xyzimage script for X11 display of XYZE and corrected RGBE pictures. |
| 675 | Takes the same options as ximage with an added -p option, and checks |
| 676 | the environment variable DISPLAY_PRIMARIES for setting of monitor |
| 677 | primaries.  (See the ra_xyze manual page for further explanation.) |
| 678 |  |
| 679 | Made colorpict's use much less memory by storing data in RGBE format |
| 680 | rather than floating point (takes 1/3 the space).  This should help with |
| 681 | large image patterns. |
| 682 |  |
| 683 | At the insistence of Henrik Wann Jensen, changed the specular sampling |
| 684 | code so that very rough specular surfaces will sample more truly, |
| 685 | eliminating some strange mirror appearances evident using the old |
| 686 | method. |
| 687 |  |
| 688 | Added drawing of small and skinny light sources so rpict won't miss |
| 689 | these from inadequate image sampling.  The method used may not work |
| 690 | perfectly for warped views (-vta, -vth and -vtc) having long, |
| 691 | cylindrical light sources.  (Rob Shakespeare, take note!) |
| 692 |  |
| 693 | Added corner rounding to genprism command (-r option). |
| 694 |  |
| 695 | Changed mixtures so that mixing material with void is allowed, allowing |
| 696 | for opacity maps.  Also altered general behavior so that surfaces |
| 697 | without materials in their modifier list are invisible, not only |
| 698 | surfaces with void modifiers. |
| 699 |  |
| 700 | ****************** COMPATIBILITY CHANGE *********************** |
| 701 | The behavior of xform has been changed to make object library |
| 702 | organization and usage simpler. |
| 703 | 1)  The RAYPATH directories are searched for matching file names. |
| 704 | 2)  Filenames beginning with '.', '/' or '~' do not result in searches. |
| 705 | 3)  Xform performs a chdir to the found file's directory, obviating |
| 706 | the need for peculiar inclusion names in subdirectories. |
| 707 | 4)  The array option (-a) now works when xform reads from stdin. |
| 708 | 5)  The expand option (-e) is now the default -- -c gets |
| 709 | back old behavior. |
| 710 |  |
| 711 | ============================= |
| 712 | Version 3.1 (Released 7/24/97) |
| 713 |  |
| 714 | Changed gensky so it will accept hour specifications as HH:MM, with |
| 715 | designations for standard North American and European time zones. |
| 716 |  |
| 717 | Increased buffer size for in-line commands from 512 to 1024. |
| 718 |  |
| 719 | Added T(n), S(n), WE and pa(n) functions and constants to pcomb. |
| 720 |  |
| 721 | Created histo utility to compute 1-dimensional histograms from data files. |
| 722 |  |
| 723 | Created pacuity, pveil and psquish scripts (later combined in "pcond"): |
| 724 |  |
| 725 | o       The pacuity program takes a Radiance picture and defocuses it |
| 726 | in places where the human eye loses resolution.  Unless the |
| 727 | scene contains very low luminances (below .1 cd/m^2 or so), |
| 728 | this will not have an appreciable effect.  The output can then |
| 729 | be adjusted according to the Ferwerda, Pattanaik and Shirley |
| 730 | tone mapping function using pcomb with the file |
| 731 | src/cal/cal/ferwerda.cal.  (See the header comments therein.) |
| 732 |  |
| 733 | o       The pveil program finds sources of glare in an image and adds |
| 734 | a corresponding amount of background luminance surrounding each |
| 735 | glare source according to the adaptation response of the human |
| 736 | eye.  This has the effect of reducing contrast around glare |
| 737 | sources. |
| 738 |  |
| 739 | o       The psquish program is probably the most useful of the three, |
| 740 | and must be applied after the other two if the others are |
| 741 | used.  With the -a option, psquish uses the human visual |
| 742 | response to compress the dynamic range of an image to fit within |
| 743 | the limited dynamic range of a display (assumed to go from 1 to |
| 744 | 100 cd/m^2), and also reduces color visibility in pictures with |
| 745 | low light levels (below 1 cd/m^2).  Without the -a option, |
| 746 | psquish simply does the best it can to fit a picture's dynamic |
| 747 | range into what can be readily displayed, without regard to |
| 748 | human visual response.  This has the effect of making problem |
| 749 | scenes viewable, such as indoor scenes with windows looking out |
| 750 | to bright exteriors. |
| 751 |  |
| 752 | Created pcond program, which combines pacuity, pveil and psquish in a |
| 753 | more efficient, robust package.  (See man page for details.) |
| 754 |  |
| 755 | Renamed Perlin noise function partial functions, noise3a(), noise3b() |
| 756 | and noise3c() to noise3x(), noise3y() and noise3z().  Added backward |
| 757 | compatibility defines to rayinit.cal so nothing should be broken. |
| 758 |  |
| 759 | Fixed double-counting bug in calculation of specular transmission of |
| 760 | light sources for trans type.  This might have caused unrealistically |
| 761 | high estimates for illumination beneath trans surfaces with non-zero |
| 762 | roughnesses when the interreflection calculation was used (-ab 1). |
| 763 |  |
| 764 | Added routines for reading and writing separate RGB files in pvalue. |
| 765 | Also added -pP (where P is one of 'R', 'G' or 'B' upper or lower case) |
| 766 | and -s option to skip specified number of bytes on header.  Finally, |
| 767 | added a -n option for non-interleaved RGB input and output. |
| 768 |  |
| 769 | Fixed obscure bug in rcalc that caused it to return "Bad call to |
| 770 | argument!" for certain combinations of function and output channel |
| 771 | definitions. |
| 772 |  |
| 773 | Added "-e auto" and "-e human" options to ximage(1) and corresponding |
| 774 | 'a' and 'h' commands to perform dynamic range compression similar to |
| 775 | pcond(1). |
| 776 |  |
| 777 | ============================== |
| 778 | Version 3.4 (Released 1/28/02) |
| 779 |  |
| 780 | Fixed bug in rpiece that caused it to incorrectly compute -vs and -vl |
| 781 | (view shift and lift) offsets.  (Included in 3.1.1.) |
| 782 |  |
| 783 | Fixed bug in xform handling mist's with > 5 real arguments. |
| 784 | (Included in 3.1.1.) |
| 785 |  |
| 786 | Fixed bug in mist handling routines that caused some incorrect calculations |
| 787 | for distant sources.  (Included in 3.1.1.) |
| 788 |  |
| 789 | Added ability for lam utility to read from commands. |
| 790 |  |
| 791 | Created vwrays command to compute ray origins and directions for specified |
| 792 | views or pictures. |
| 793 |  |
| 794 | Changed rtrace behavior to send bogus record when ray direction is zero. |
| 795 | (Before, it only flushed values with no corresponding record.)  This |
| 796 | change was needed to facilitate its use with the new vwrays program. |
| 797 |  |
| 798 | Modified ies2rad so that it no longer produces glow sources for the sides |
| 799 | of objects, which caused unnatural dark bands near the ceilings of |
| 800 | direct/indirect installations.  (Included in 3.1.4.) |
| 801 |  |
| 802 | Fixed bug in rpiece that caused the -pa option to fail.  (Included in 3.1.2.) |
| 803 |  |
| 804 | Made ximage emphasize pixels in the selected region for the 'a' and 'h' |
| 805 | commands to adjust the exposure using histogram compression. |
| 806 | (Included in 3.1.4.) |
| 807 |  |
| 808 | Fixed bug in trad which caused it to fail when there were tabs in the input. |
| 809 | (Included in 3.1.3.) |
| 810 |  |
| 811 | Fixed bug in pcond that caused it to white-out borders of some fisheye views. |
| 812 | (Included in 3.1.3.) |
| 813 |  |
| 814 | Added facility to ra_tiff to read and write new LogLuv high dynamic-range |
| 815 | image formats. |
| 816 |  |
| 817 | Changed ambient value averaging in rendering programs (-aw option) to use |
| 818 | geometric mean rather than arithmetic mean, which tended to arrive at |
| 819 | too-high estimates and cause runaway calculations.  (Included in 3.1.4.) |
| 820 |  |
| 821 | Added -g, -p, -m and -d options for gamma, paper size, margins and dpi |
| 822 | to the ra_ps program.  This allows for much better control over output |
| 823 | to PostScript printers. |
| 824 |  |
| 825 | Fixed compiles for AIX -- select() incompatibility and macro conflicts. |
| 826 | (Included in 3.1.6.) |
| 827 |  |
| 828 | Increased table sizes to allow up to 4 million primitives when -DBIGMEM |
| 829 | is defined, provided there's enough virtual memory to hold them! |
| 830 |  |
| 831 | Fixed error in viewloc() for computing view locations for cylindrical views. |
| 832 |  |
| 833 | Wrote rholo, rhcopy, rhpict, and rhoptimize programs for holodeck |
| 834 | creation, display, and manipulation.  This is a much more powerful way |
| 835 | to view a model than rview, though it lacks many of the utility commands. |
| 836 |  |
| 837 | Added the ability to separate concatanated animation frames using ra_rgbe. |
| 838 | This output facility of rpict was previously useless because nothing could |
| 839 | get anything past the first frame. |
| 840 |  |
| 841 | Wrote compamb program to compute a good ambient value for a rad input file. |
| 842 | Using this script is preferable to setting the -aw option of rpict, which |
| 843 | seems to result in splotchy artifacts in many situations. |
| 844 |  |
| 845 | Changed rad so it doesn't use the -aw option, which was causing some rather |
| 846 | annoying artifacts.  (Added as patch to 3.1.8.) |
| 847 |  |
| 848 | Modified ranimate to change directories before running transfer or archive |
| 849 | commands. |
| 850 |  |
| 851 | Added -pm option to rpict to perform jittered motion blurring. |
| 852 |  |
| 853 | Created phisto script and added -I option to pcond for computing |
| 854 | multiple, identical exposures. |
| 855 |  |
| 856 | Fixed time zone specifications in gensky.  (Added as patch to 3.1.9.) |
| 857 |  |
| 858 | Fixed bug in mixture functions that caused erroneous modifier loops. |
| 859 | (Added as patch to 3.1.10.) |
| 860 |  |
| 861 | Wrote glrad program for interactive display of Radiance scenes using OpenGL. |
| 862 | Modified objview program to use rad and glrad for rendering. |
| 863 |  |
| 864 | Changed the way ray weights are computed for participating media (including |
| 865 | dielectrics) so they more accurately reflect a ray's contribution, avoiding |
| 866 | some artifacts with unsealed dielectric objects and the ambient calculation. |
| 867 |  |
| 868 | Fixed problem with dielectric materials with textures where rays that should |
| 869 | have penetrated or reflected do the opposite. |
| 870 |  |
| 871 | Created ra_hexbit program to generate bitmap files for use with hexbit4x1.fnt. |
| 872 |  |
| 873 | ****************** COMPATIBILITY CHANGE *********************** |
| 874 | Altered mixtures to take the most recent modifier definition |
| 875 | rather than the last one in the entire description.  Made the |
| 876 | same change for illum's and mirror's.  Also, fixed a bug in |
| 877 | the antimatter type where it didn't always get the correct |
| 878 | material for shading. |
| 879 |  |
| 880 | Wrote normtiff program to quickly tone-map and convert Radiance pictures |
| 881 | and SGILOG-encoded TIFF's to flat RGB TIFF output. |
| 882 |  |
| 883 | Added -r option to protate for CCW rotations. |
| 884 |  |
| 885 | Added ability to load values from read-only ambient file in rpict, |
| 886 | rtrace and rview.  This may be useful when starting with the same |
| 887 | values on many processors, where NFS lock contention would slow |
| 888 | things down if they also wrote values back to the file. |
| 889 |  |
| 890 | Wrote rhinfo program for printing out holodeck section information. |
| 891 |  |
| 892 | Modified rad "scene" variable to allow in-line command specifications. |
| 893 |  |
| 894 | Added added -s and -b options to ra_ppm for changing output scale and |
| 895 | forcing greyscale output. |
| 896 |  |
| 897 | Now allow negative distances for the fore clipping plane in rpict. |
| 898 | This may be useful for rendering holographic stereograms. |
| 899 |  |
| 900 | Added -f option to xform to read arguments from files.  This can save |
| 901 | a lot of scene loading time by reducing multiple xform invocations. |
| 902 |  |
| 903 | Added support for 15-bit TrueColor visuals in ximage. |
| 904 |  |
| 905 | Added (undocumented) -P option to macbethcal for picking chart corners |
| 906 | directly using ximage. |
| 907 |  |
| 908 | Added -r option to rholo for opening holodeck files read-only. |
| 909 |  |
| 910 | Added correction factor for solid angle change in dielectrics as |
| 911 | noted in Eric Veach's thesis. |
| 912 |  |
| 913 | Added von Kries white balance transform for color conversion using |
| 914 | CMCCAT2000 matrix. |
| 915 |  |
| 916 | Added CAPDATE field to rendering headers to record render date. |
| 917 |  |
| 918 | Added mixpict primitive for using pictures to generate mixtures. |
| 919 |  |
| 920 | Fixed bug in Type B photometry angle calculation in source.cal discovered |
| 921 | by Erich Phillips. |
| 922 |  |
| 923 | ============================== |
| 924 | Version 3.5 (Released 3/21/03) |
| 925 |  |
| 926 | Fixed bug in replmarks pointed out by Georg Mischler, which caused |
| 927 | garbage to be output under specific conditions (unscaled, unrotated |
| 928 | instances). |
| 929 |  |
| 930 | Fixed bug in normtiff that caused occassional weird colors |
| 931 | on human tone-mapping of 32-bit LogLuv inputs (tmapluv.c). |
| 932 |  |
| 933 | Fixed -o option of pcomb so it resets le(i) and color exposure functions |
| 934 | to unity. |
| 935 |  |
| 936 | Fixed a bug in Type B photometry in ies2rad source.cal introduced |
| 937 | in last fix where spherical sources were getting symmetric |
| 938 | distributions front-to-back. |
| 939 |  |
| 940 | Fixed another bug in ies2rad for 90-270 bilaterally symmetric fixtures, which |
| 941 | seems to have been there from the beginning.  Thanks to Jack de Valpine |
| 942 | for pointing it out. |
| 943 |  |
| 944 | Added NORANDOM symbol for tests with all random sampling turned off. |
| 945 |  |
| 946 | Fixed a bug in expression evaluation code that was causing unneeded |
| 947 | evaluations of constants.  This is a fix on an earlier fix of a more |
| 948 | serious bug prior to the 3.4 release, where the expression clock |
| 949 | was wrapping silently and allowing values to go stale. |
| 950 |  |
| 951 | Fixed an even more serious bug in ies2rad for thin fixtures, where |
| 952 | it was using "flatcorr" without the proper correction for the |
| 953 | emitting area.  Thanks again to Jack de Valpine for spotting this. |
| 954 |  |
| 955 | --- All of the above was put into a 3.4.1 patch release 4/1/2002 |
| 956 |  |
| 957 | Added a facility to gensurf to make holes in the mesh using a |
| 958 | valid(s,t) function. |
| 959 |  |
| 960 | Fixed bug in pcond that caused a bus error on images with large dark |
| 961 | regions when acuity switch was set. |
| 962 |  |
| 963 | Fixed bug in pcomb that caused the S(n) function to return half |
| 964 | the solid angle value it should have.  (Thanks to John Mardaljevic |
| 965 | for discovering this error.) |
| 966 |  |
| 967 | Made rpict/rpiece/vwrays -vf option accept "-" as a synonym |
| 968 | for standard input. |
| 969 |  |
| 970 | Fixed bug in persist functions (-P and -PP) with FreeBSD |
| 971 | (including MacOS X) having to do with altered system function |
| 972 | behaviors.  Neither mknod() nor freopen() behave as they |
| 973 | used to. |
| 974 |  |
| 975 | Improved accuracy of irradiance gradient calculation near |
| 976 | specular surfaces by using the effective ray distance |
| 977 | rather than the first surface intersection.  (John |
| 978 | Mardaljevic had pointed out some errors he was seeing |
| 979 | with a particular atrium model.) |
| 980 |  |
| 981 | Reinstated my favorite little Fresnel approximation for |
| 982 | perfectly smooth materials, so grazing angles show an |
| 983 | accurate gradient.  Simultaneously revised the computation |
| 984 | of the direct component for proper energy balance. |
| 985 | (Thanks to Phillip Greenup for nagging John M. who nagged me.) |
| 986 |  |
| 987 | Improved the accuracy and appearance of indirect irradiance |
| 988 | interpolation for smoothed surfaces.  (Thanks to Bernhard |
| 989 | Spanlang for noticing the problem.) |
| 990 |  |
| 991 | Fixed intolerance for carriage-returns in mkillum's input files, |
| 992 | which caused problems for files imported from DOS/Windows. |
| 993 |  |
| 994 | Fixed apparent bug that I couldn't reproduce in rpict for very |
| 995 | narrow views, which sent it into an infinite loop under Linux. |
| 996 | (Rich Gillibrand of Bristol Univ. pointed it out.) |
| 997 |  |
| 998 | Improved movement in rholo for low-detail holodecks on fast |
| 999 | graphics processors by inserting 50 ms pause during motion |
| 1000 | feedback. |
| 1001 |  |
| 1002 | Finally fixed ages-old consistency error where ambient value |
| 1003 | lists were sorted incorrectly with the GNU-C compiler, |
| 1004 | causing the dreaded "address not found in avlmemi" crash.  All |
| 1005 | this time, I thought it was due to a faulty qsort(3) routine, |
| 1006 | when in fact it was due to the way GNU-C compares pointers. |
| 1007 | The fix was to change a single word in ambient.c from "AMBVAL" |
| 1008 | to "char" and now it all magically works.  No more -Dtracktime=0, |
| 1009 | hurrah! |
| 1010 |  |
| 1011 | Fixed pcond veil behavior for scenes that have their contrast |
| 1012 | reduced by primary tone-mapping algorithms.  Previously, the |
| 1013 | veil would come out looking like a fog because it was applied |
| 1014 | prior to dynamic range compression and did not consider the |
| 1015 | overall effect.  In the new version, the veil is adjusted |
| 1016 | after dynamic range compression so that the net reduction |
| 1017 | in visibility is approximately correct over the whole image. |
| 1018 | (Later made this optional on compile with the ADJ_VEIL symbol, as I |
| 1019 | noticed more artifacts than improvements in the resulting images.) |
| 1020 |  |
| 1021 | Fixed bug in BRTDfunc that caused an error in the calculation |
| 1022 | of the diffuse transmitted ambient component.  This must have |
| 1023 | been introduced early on, but never noticed by me or anyone. |
| 1024 |  |
| 1025 | Wrote an interactive script called "glaze" (src/gen/glaze.csh) |
| 1026 | that computes a good material model for fritted and low-E glazing |
| 1027 | systems.  Thanks to Visarc (Jack de Valpine) for paying for its |
| 1028 | development and permitting it into the general distribution. |
| 1029 |  |
| 1030 | Increased scanline window in pcomb to 64 (+/- 32 pixels) to allow |
| 1031 | for larger kernels in filtered images. |
| 1032 |  |
| 1033 | ****************** COMPATIBILITY CHANGE *********************** |
| 1034 | Changed behavior of pfilt gaussian blur to match more precise |
| 1035 | definition.  A blur radius of 0.6 is now preferred over the |
| 1036 | previous value of 1.0. |
| 1037 |  |
| 1038 | Added ANSI function prototypes to the header files in |
| 1039 | src/common/ and src/rt/ and cleaned up the options processing |
| 1040 | in the rpict, rtrace, and rview main procedures so that the |
| 1041 | core Radiance rendering code can be more easily |
| 1042 | called by new application programs.  Changed src/rt/Rmakefile |
| 1043 | to create a rendering library called "libradiance.a" and |
| 1044 | to install it in the src/lib/ directory along with the new |
| 1045 | raycalls.o module, which should facilitate the building |
| 1046 | of new applications outside the src/rt/ directory.  The |
| 1047 | raypcalls.o module, also installed in src/lib, manages |
| 1048 | parallel rendering on multiprocessors with shared memories. |
| 1049 |  |
| 1050 | Wrote new ranimove animation rendering program, which is an |
| 1051 | alternative to ranimate.  The key difference is that |
| 1052 | ranimove is optimized for moving scenes, and includes |
| 1053 | a complete blur simulation for camera and object motion. |
| 1054 | It also incorporates an sophisticated model of perceivable |
| 1055 | error based on visual focus, and allows progressive |
| 1056 | animation so one can explicitly control rendering time |
| 1057 | and/or accuracy.  See the man page for details. |
| 1058 |  |
| 1059 | ****************** COMPATIBILITY CHANGE *********************** |
| 1060 | The sense of the MBLUR setting has been changed for the ranimate |
| 1061 | command.  The first value is now the fraction of a frame during |
| 1062 | which the shutter is open, and the _second_ argument (which is |
| 1063 | optional) is the number of samples to specify to pmblur. |
| 1064 |  |
| 1065 | Enhanced octree reader behavior so it will accept command |
| 1066 | specifications preceded by an exclamation mark ('!').  This |
| 1067 | enables rtrace and rview to take octrees from commands similar |
| 1068 | to rpict reading its octree from the standard input.  All |
| 1069 | programs taking octrees as arguments will be affected by this |
| 1070 | change.  However, since rad needs to get the modified date |
| 1071 | from the octree, rad will refuse such an octree command |
| 1072 | specification. |
| 1073 |  |
| 1074 | Fixed a bug in src/common/fgetline.c where it failed to elide |
| 1075 | carriage-returns in Windows files. |
| 1076 |  |
| 1077 | Modified src/common/fgetword.c so it accepts single- or |
| 1078 | double-quoted words with spaces in preparation for the |
| 1079 | Windows version, which needs to allow spaces in file |
| 1080 | paths.  Since fgetword() is called by all programs that |
| 1081 | read in string arguments in scene files, these may now |
| 1082 | be quoted with the expected behavior.  Also added a |
| 1083 | fputword() call to the library to automatically quote |
| 1084 | words on output that contain white space.  This routine |
| 1085 | is now called from all the right places, I hope!  The |
| 1086 | code does not support spaces in primitive identifiers, |
| 1087 | and you will get peculiar errors if you try them. |
| 1088 |  |
| 1089 | Eliminated virtually all symbolic links from the source |
| 1090 | tree, most of which were links to compatibility routines |
| 1091 | and the calcomp functions for expression parsing. |
| 1092 | Replaced -D* defines used in cal* routines with "esupport" |
| 1093 | global that allows calling programs to set which language |
| 1094 | options they want to support at runtime.  More programs now |
| 1095 | link against the -lrt library.  Consolidated the src/cal |
| 1096 | subdirectories in the process. |
| 1097 |  |
| 1098 | Added -dw option to pvalue program to input and output |
| 1099 | 16-bit word values (-dW for byte swapping). |
| 1100 |  |
| 1101 | Changed call ordering in material shaders to ensure |
| 1102 | proper surface normal perturbation for two-sided, |
| 1103 | textured surfaces. |
| 1104 |  |
| 1105 | Added a new "mesh" primitive, which permits very |
| 1106 | complicated geometries with associated (u,v) coordinates |
| 1107 | using the new obj2mesh converter and the new -o option |
| 1108 | of gensurf for .OBJ output.  Mesh compilation takes |
| 1109 | roughly 500 bytes/triangle in obj2mesh, but memory |
| 1110 | access is well-ordered compared to rendering, which |
| 1111 | takes about 50 bytes/triangle with full surface normal |
| 1112 | and (u,v) coordinate interpolation.  (The actual mesh |
| 1113 | is represented in 15 bytes/triangle, and the rest is |
| 1114 | taken by the octree structure and malloc overhead.) |
| 1115 | Local coordinates are set with the "vt" statement |
| 1116 | in the Wavefront .OBJ file and accessed via the new |
| 1117 | "Lu" and "Lv" variables in a Radiance .cal file. |
| 1118 | Multiple instances of the same mesh with different |
| 1119 | transformations take little additional space during |
| 1120 | rendering, permitting scanned relief surfaces and |
| 1121 | displacement-map-like effects to be repeated as desired. |
| 1122 |  |
| 1123 | Changed internal representation of alias'es in order |
| 1124 | to maintain information about links for programs like |
| 1125 | rshow that work from frozen octrees.  Added a special |
| 1126 | alias modifier keyword, "inherit", to indicate that |
| 1127 | an alias should get the same modifier as the original |
| 1128 | target to simplify common alias usage for material |
| 1129 | substitution. |
| 1130 |  |
| 1131 | Increased default oconv -n value to 6.  Since triangle |
| 1132 | meshes commonly have six faces joining at each vertex, |
| 1133 | values less than this cause resolution-limited voxel |
| 1134 | subdivision.  Increased default -r option to 16384 |
| 1135 | as well.  Also increased maximum internal set size |
| 1136 | from 127 to 511, to accommodate difficult mesh |
| 1137 | models where many faces come together at a point. |
| 1138 | This required a little reprogramming in for couple |
| 1139 | of recursive routines using sets to avoid overrunning |
| 1140 | the stack limit. |
| 1141 |  |
| 1142 | ============================== |
| 1143 | Version 3.6 |
| 1144 |  |
| 1145 | Modified 4-byte RGBE encoding routine to avoid problems |
| 1146 | when one or two primary values is negative and the other(s) |
| 1147 | positive.  This used to generate some strange color values. |
| 1148 |  |
| 1149 | Added -oc option to rtrace to output local (u,v) coordinates. |
| 1150 |  |
| 1151 | Fixed bugs in local uv and j unit vector variables in src/rt/func.c. |
| 1152 |  |
| 1153 | Added warning message to OpenGL rendering routines about new |
| 1154 | mesh primitive, which we cannot currently render. |
| 1155 |  |
| 1156 | Added -if, -id, -of, and -od options to rcalc to provide for |
| 1157 | binary float and double i/o. |
| 1158 |  |
| 1159 | ****************** COMPATIBILITY CHANGE *********************** |
| 1160 | Changed holodeck format to used off_t instead of long for beam |
| 1161 | positions, which allows holodecks to grow to system file size limit. |
| 1162 |  |
| 1163 | Fixed wrapping long in source hit test code, which would cause |
| 1164 | odd horizontal lines in some very long renderings. |
| 1165 |  |
| 1166 | Added -f and -w options to ra_tiff to create IEEE float and 16-bit/primary |
| 1167 | TIFF output, respectively.  These formats are also understood on reverse |
| 1168 | conversion.  (16-bit/primary has been understood for some time, but not |
| 1169 | IEEE float.) |
