Changes for 3.7.1 patch release
Changed to 98th percentile for default threshold
Fixed serious bug in new Russian roulette algorithm
Onward to 3.8a
Documented new behavior with blank input lines in total(1)
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Fixed bug in rcalc with -l option where it sometimes hung
Changed rlam -t option to accept strings as well as tab characters
Added note on change to blackbody.cal
Created meta2bmp file to generate BMP output from metafile graphics
Created mksource program
Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Added comments on 3.6 bug fixes
Fixed minor spelling errors and typos
Corrected Gaussian reflectance model normalization (cosine factor)
Added notes about recent fixes
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Added -p option to histo to report percentiles and changed output slightly
Changed meta2tga so it outputs correct colors
Added mention of latest changes
Removed duplicate copies of file and fixed comment in release notes
