Revision 1.92 - (view) (download) (annotate) - [select for diffs]
Fri Aug 5 17:24:53 2005 UTC (20 years, 4 months ago) by greg
CVS Tags: rad3R7P1
Changes since 1.91: +3 -1 lines
Diff to previous 1.91 , to selected 1.88
Changes for 3.7.1 patch release
Revision 1.91 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 17:01:30 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.90: +2 -0 lines
Diff to previous 1.90 , to selected 1.88
Changed to 98th percentile for default threshold
Revision 1.90 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 16:41:46 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.89: +3 -0 lines
Diff to previous 1.89 , to selected 1.88
Fixed serious bug in new Russian roulette algorithm
Revision 1.89 - (view) (download) (annotate) - [select for diffs]
Wed Jul 27 05:34:17 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.88: +5 -1 lines
Diff to previous 1.88
Onward to 3.8a
Revision 1.88 - (view) (download) (annotate) - [selected]
Tue Jun 21 02:34:22 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.87: +4 -0 lines
Diff to previous 1.87
Documented new behavior with blank input lines in total(1)
Revision 1.87 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 22:23:31 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.86: +2 -0 lines
Diff to previous 1.86 , to selected 1.88
Revision 1.86 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 17:10:05 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.85: +3 -0 lines
Diff to previous 1.85 , to selected 1.88
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Revision 1.85 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 04:04:51 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.84: +2 -2 lines
Diff to previous 1.84 , to selected 1.88
Revision 1.84 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 01:25:02 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.83: +3 -0 lines
Diff to previous 1.83 , to selected 1.88
Fixed bug in rcalc with -l option where it sometimes hung
Revision 1.83 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 22:40:46 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.82: +2 -0 lines
Diff to previous 1.82 , to selected 1.88
Changed rlam -t option to accept strings as well as tab characters
Revision 1.82 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 20:07:56 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.81: +3 -0 lines
Diff to previous 1.81 , to selected 1.88
Revision 1.81 - (view) (download) (annotate) - [select for diffs]
Thu Jun 9 17:27:27 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.80: +2 -0 lines
Diff to previous 1.80 , to selected 1.88
Revision 1.80 - (view) (download) (annotate) - [select for diffs]
Sun Jun 5 19:52:00 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.79: +3 -0 lines
Diff to previous 1.79 , to selected 1.88
Revision 1.79 - (view) (download) (annotate) - [select for diffs]
Thu Jun 2 04:47:26 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.78: +4 -0 lines
Diff to previous 1.78 , to selected 1.88
Revision 1.78 - (view) (download) (annotate) - [select for diffs]
Wed Jun 1 16:11:01 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.77: +4 -2 lines
Diff to previous 1.77 , to selected 1.88
Revision 1.77 - (view) (download) (annotate) - [select for diffs]
Tue May 31 18:01:08 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.76: +3 -0 lines
Diff to previous 1.76 , to selected 1.88
Revision 1.76 - (view) (download) (annotate) - [select for diffs]
Thu May 26 06:55:22 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.75: +4 -0 lines
Diff to previous 1.75 , to selected 1.88
Revision 1.75 - (view) (download) (annotate) - [select for diffs]
Wed May 25 04:44:25 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.74: +6 -0 lines
Diff to previous 1.74 , to selected 1.88
Revision 1.74 - (view) (download) (annotate) - [select for diffs]
Tue May 24 22:54:38 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.73: +3 -0 lines
Diff to previous 1.73 , to selected 1.88
Added note on change to blackbody.cal
Revision 1.73 - (view) (download) (annotate) - [select for diffs]
Wed May 4 23:43:19 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.72: +2 -0 lines
Diff to previous 1.72 , to selected 1.88
Created meta2bmp file to generate BMP output from metafile graphics
Revision 1.72 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 18:44:22 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.71: +2 -0 lines
Diff to previous 1.71 , to selected 1.88
Revision 1.71 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 01:15:06 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.70: +17 -0 lines
Diff to previous 1.70 , to selected 1.88
Thu Apr 14 18:04:12 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.69: +3 -0 lines
Diff to previous 1.69 , to selected 1.88
Wed Apr 13 23:00:58 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.68: +4 -0 lines
Diff to previous 1.68 , to selected 1.88
Tue Apr 12 03:30:43 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.67: +3 -0 lines
Diff to previous 1.67 , to selected 1.88
Created mksource program
Tue Mar 22 04:51:56 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.66: +3 -0 lines
Diff to previous 1.66 , to selected 1.88
Thu Mar 10 22:37:00 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.65: +7 -0 lines
Diff to previous 1.65 , to selected 1.88
Mon Feb 7 17:08:16 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.64: +4 -1 lines
Diff to previous 1.64 , to selected 1.88
Fri Jan 21 00:52:59 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.63: +3 -0 lines
Diff to previous 1.63 , to selected 1.88
Tue Jan 18 03:59:41 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.62: +3 -0 lines
Diff to previous 1.62 , to selected 1.88
Tue Jan 18 00:33:16 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.61: +5 -0 lines
Diff to previous 1.61 , to selected 1.88
Fri Jan 7 20:33:01 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.60: +3 -0 lines
Diff to previous 1.60 , to selected 1.88
Wed Jan 5 19:34:10 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.59: +4 -0 lines
Diff to previous 1.59 , to selected 1.88
Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Wed Dec 15 22:02:04 2004 UTC (21 years ago) by greg
Changes since 1.58: +3 -0 lines
Diff to previous 1.58 , to selected 1.88
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Thu Nov 25 14:47:03 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.57: +3 -0 lines
Diff to previous 1.57 , to selected 1.88
Mon Nov 8 15:50:59 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.56: +4 -0 lines
Diff to previous 1.56 , to selected 1.88
Fri Nov 5 03:31:36 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.55: +14 -0 lines
Diff to previous 1.55 , to selected 1.88
Sat Oct 30 04:59:41 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.54: +3 -0 lines
Diff to previous 1.54 , to selected 1.88
Thu Oct 28 00:49:27 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Changes since 1.53: +13 -0 lines
Diff to previous 1.53 , to selected 1.88
Added comments on 3.6 bug fixes
Mon Oct 11 10:02:15 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.52: +3 -0 lines
Diff to previous 1.52 , to selected 1.88
Mon Oct 4 22:32:58 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.51: +2 -2 lines
Diff to previous 1.51 , to selected 1.88
Fixed minor spelling errors and typos
Mon Oct 4 17:44:22 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.50: +4 -0 lines
Diff to previous 1.50 , to selected 1.88
Fri Oct 1 07:45:30 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.49: +4 -0 lines
Diff to previous 1.49 , to selected 1.88
Thu Sep 23 18:00:54 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.48: +3 -0 lines
Diff to previous 1.48 , to selected 1.88
Mon Sep 20 17:32:04 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.47: +10 -0 lines
Diff to previous 1.47 , to selected 1.88
Corrected Gaussian reflectance model normalization (cosine factor)
Mon Sep 20 16:26:57 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.46: +6 -3 lines
Diff to previous 1.46 , to selected 1.88
Sun Sep 19 08:42:22 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.45: +4 -0 lines
Diff to previous 1.45 , to selected 1.88
Fri Sep 17 21:43:49 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.44: +2 -0 lines
Diff to previous 1.44 , to selected 1.88
Fri Sep 10 18:19:24 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.43: +3 -0 lines
Diff to previous 1.43 , to selected 1.88
Fri Sep 10 16:05:07 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.42: +4 -0 lines
Diff to previous 1.42 , to selected 1.88
Thu Sep 9 20:08:21 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 1.41 , to selected 1.88
Thu Sep 9 17:05:43 2004 UTC (21 years, 3 months ago) by greg
Changes since 1.40: +8 -0 lines
Diff to previous 1.40 , to selected 1.88
Added notes about recent fixes
Wed Jun 9 16:00:13 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.39: +4 -0 lines
Diff to previous 1.39 , to selected 1.88
Fri Apr 30 20:29:24 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.38: +3 -0 lines
Diff to previous 1.38 , to selected 1.88
Fri Apr 30 17:00:29 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.37: +4 -0 lines
Diff to previous 1.37 , to selected 1.88
Fri Apr 23 16:20:54 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.36: +3 -0 lines
Diff to previous 1.36 , to selected 1.88
Fri Apr 23 00:56:27 2004 UTC (21 years, 8 months ago) by greg
Diff to previous 1.35 , to selected 1.88
Mon Apr 12 17:31:27 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.34: +7 -1 lines
Diff to previous 1.34 , to selected 1.88
Sun Mar 28 16:31:14 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.33: +4 -0 lines
Diff to previous 1.33 , to selected 1.88
Fri Mar 26 22:58:21 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.32: +1 -2 lines
Diff to previous 1.32 , to selected 1.88
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.31: +4 -0 lines
Diff to previous 1.31 , to selected 1.88
Mon Mar 15 21:16:54 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 1.30 , to selected 1.88
Mon Mar 8 21:39:32 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 1.29 , to selected 1.88
Mon Mar 1 17:49:38 2004 UTC (21 years, 10 months ago) by greg
Changes since 1.28: +5 -1 lines
Diff to previous 1.28 , to selected 1.88
Fri Jan 30 00:08:31 2004 UTC (21 years, 11 months ago) by greg
Diff to previous 1.27 , to selected 1.88
Thu Jan 29 22:20:31 2004 UTC (21 years, 11 months ago) by greg
Changes since 1.26: +13 -0 lines
Diff to previous 1.26 , to selected 1.88
Thu Jan 1 19:31:45 2004 UTC (21 years, 11 months ago) by greg
Changes since 1.25: +7 -0 lines
Diff to previous 1.25 , to selected 1.88
Wed Dec 31 01:50:02 2003 UTC (22 years ago) by greg
Changes since 1.24: +9 -0 lines
Diff to previous 1.24 , to selected 1.88
Sun Dec 14 16:33:37 2003 UTC (22 years ago) by greg
Diff to previous 1.23 , to selected 1.88
Added -p option to histo to report percentiles and changed output slightly
Wed Nov 19 16:21:28 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.22: +2 -0 lines
Diff to previous 1.22 , to selected 1.88
Tue Nov 11 16:24:05 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.21 , to selected 1.88
Thu Nov 6 05:39:33 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.20 , to selected 1.88
Wed Oct 1 22:07:19 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.19: +3 -0 lines
Diff to previous 1.19 , to selected 1.88
Tue Sep 30 00:13:58 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.18: +3 -0 lines
Diff to previous 1.18 , to selected 1.88
Wed Sep 24 14:55:53 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.17: +6 -0 lines
Diff to previous 1.17 , to selected 1.88
Tue Sep 23 03:54:57 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.16: +3 -0 lines
Diff to previous 1.16 , to selected 1.88
Fri Sep 19 18:33:04 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.15: +3 -0 lines
Diff to previous 1.15 , to selected 1.88
Thu Sep 18 20:18:19 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.14 , to selected 1.88
Thu Sep 18 16:53:52 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.13 , to selected 1.88
Tue Sep 16 06:32:21 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.12 , to selected 1.88
Changed meta2tga so it outputs correct colors
Sat Sep 13 15:24:13 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.88
Fri Aug 29 21:44:17 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.88
Tue Aug 26 16:09:43 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 1.9 , to selected 1.88
Mon Jul 14 04:56:53 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.8: +3 -0 lines
Diff to previous 1.8 , to selected 1.88
Thu Jul 10 03:47:00 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 1.88
Thu Jul 3 15:00:19 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.6: +3 -0 lines
Diff to previous 1.6 , to selected 1.88
Tue Jul 1 19:04:08 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 1.88
Tue Jun 24 15:38:07 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 1.88
Fri Jun 6 01:01:09 2003 UTC (22 years, 6 months ago) by greg
Changes since 1.3: +21 -0 lines
Diff to previous 1.3 , to selected 1.88
Added mention of latest changes
Fri Mar 21 18:48:45 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 1.88
Tue Mar 18 04:45:28 2003 UTC (22 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.88
Removed duplicate copies of file and fixed comment in release notes
Sat Mar 15 17:32:55 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 1.88
