Added comments on 3.6 bug fixes
Fixed minor spelling errors and typos
Corrected Gaussian reflectance model normalization (cosine factor)
Added notes about recent fixes
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Added -p option to histo to report percentiles and changed output slightly
Changed meta2tga so it outputs correct colors
Added mention of latest changes
Removed duplicate copies of file and fixed comment in release notes
