root/radiance/ray/doc/notes/ReleaseNotes
Revision: 1.54
Committed: Thu Oct 28 00:49:27 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Changes since 1.53: +13 -0 lines
Added comments on 3.6 bug fixes
# User Rev Content
1 greg 1.1 =========================
2     Version 1.2 (Released 3/9/90)
3
4     Added a -p option to rpict and pfilt to set the pixel aspect ratio for
5     output. Instead of giving the absolute x and y resolutions, the user
6     now gives rpict and pfilt the maximum desired resolution for x and y
7     and the pixel aspect ratio is used along with the given view to
8     calculate appropriate values within this boundary. This makes for
9     much more natural view specifications. For example, for a 512x400
10     device with a pixel aspect ratio of 1.0, the pfilt command:
11
12     pfilt -x 512 -y 400 -p 1
13
14     will always produce the appropriate output, regardless of the aspect
15     ratio of the input picture. If necessary, the x or y output resolution
16     will be reduced to accommodate the device's resolution. A square image
17     would occupy a region of 400x400 pixels.
18
19     View shift and lift options were added to the list of standard view
20     parameters, for specifying views for panoramas and holograms.
21
22     Rview no longer takes options for x and y resolution, but instead
23     gets them from the device driver along with the pixel ratio. This
24     makes it much easier to change the view aspect ratio (with the vh
25     and vv parameters).
26
27     A -z option was added to rpict to write out the distances for each
28     pixel in an image. This may be useful for z-buffer operations, and
29     is used by the new program pinterp, described below.
30
31     A program called pinterp was added to the burgeoning list of
32     picture filters and converters. This program is designed primarily
33     to interpolate animated frames for walk-throughs of static scenes,
34     but it has a number of other useful functions besides. It takes as
35     its input one or more rendered pictures (with their corresponding z
36     value files) and desired viewpoint (hopefully not too far afield from
37     the given images). Pinterp then takes the input frames and moves the
38     pixels to their new computed location. Filling operations make sure
39     that the final image does not have large unpainted regions.
40
41     Added smoothing option to gensurf, using bilinear Phong surface normal
42     interpolation. Not perfect, but it's better than nothing and permits
43     the use of fewer polygons to represent smoothly curved surfaces.
44
45     =========================
46     Version 1.3 (Released 10/22/90)
47
48     Added conversion utility for IES (Illuminating Engineering Society) standard
49     format luminaire data. The translator, called ies2rad, takes any number
50     of luminaire data files and creates the necessary Radiance geometric
51     descriptions and data files and puts them in the specified library location.
52     A new data format was added to accommodate irregularly-spaced data points.
53
54     Added rview driver for NeWS for Sun and Silicon Graphics workstations.
55     This work was done by Isaac Kwo.
56
57     Fixed oconv for scenes with many overlapping instances (runs faster now).
58
59     Added consitency checks intended to detect stale octrees without restricting
60     changes to surface modifiers. (But you still can't change total number of
61     objects). Stale octrees caused some of the strangest behavior...
62
63     Finally broke down and wrote my own malloc(3) routines. There is a
64     CalTech module floating around Berkeley that caused a lot of trouble
65     for bmalloc(), resulting in about twice the needed memory use.
66
67     Added translator for Architrion. Arch2rad uses mapping rules to assign
68     materials to surfaces from input file. This is a general method (dreamed
69     up by Charles Ehrlich) that allows users to assign materials based on
70     whatever information is available from the CAD file. See the accompanying
71     description file on translators in the ray/doc/notes directory.
72
73     Added fisheye view types to rpict and rview, useful for looking at
74     entire scenes and for LEEP virtual reality wide field stereo viewer.
75
76     Wrote xshowtrace, a fun program for watching rays as they are being
77     traced on an X11 display.
78
79     Write ra_pr24 for converting between 24-bit Sun rasterfiles and
80     Radiance pictures. Perhaps this should be incorporated in ra_pr, as
81     ra_t8 and ra_t16 should be one program, but the algorithms and memory
82     requirements are totally different for colormapped images.
83
84     Added routines for performing 24-bit gamma correction in integer domain,
85     making programs like ra_pr24 and ra_t16 run faster.
86
87     =========================
88     Version 1.4 (Released early 1991?)
89
90     Fixed bug in IES translator that resulted in the incorrect
91     interpretation of type B photometric data. (1.3.1)
92
93     Added types for using BRDF data: plasfunc, metfunc, plasdata and metdata.
94
95     Added interpretation of source color to ies2rad and color corrective
96     filtering to pfilt. Reference file used by both is "lamp.tab" in
97     library directory.
98
99     Added picture flipping program, pflip, and pattern preprocessing script,
100     normpat.csh, to the px directory.
101
102     Fixed bug in ra_pr24 that caused the reversal of red and blue values.
103     New version accepts both RT_STANDARD and RT_FORMAT_RGB files but
104     produces only RT_STANDARD rasterfiles as output.
105
106     Added -m option to xform to change modifiers for surfaces.
107
108     Wrote replmarks program to replace markers in a Radiance scene file
109     for light sources or other objects.
110
111     Added global compilation script, makeall.
112
113     Fixed calculation of luminance in display programs and gensky to use
114     white light assumption.
115
116     Added options and features to pcomb.
117
118     Added FORMAT= line to all Radiance file headers for improved error
119     checking and clarity.
120
121     Added icon bitmaps for rview and x11image under X11 and fixed a bug
122     that caused x11image to ignore keyboard input.
123
124     ****** COMPATIBILITY CHANGE ********
125     Added constant definitions to cal files using ':' instead of '='.
126     This makes for faster calculations since many more constant
127     expressions can be reduced at "compile" time.
128
129     Created glare calculation programs in util directory. Findglare locates
130     glare sources, xglaresrc circles sources on a displayed image, and
131     glarendx computes various glare indices.
132
133     =========================
134     Version 2.0 (Released 11/26/91)
135
136     Added -i option to renderers for computing irradiance rather than
137     radiance. Eliminated redundant -oI option from rtrace and added
138     -I option to replace old -oi. This hack ignores glass and similar
139     surfaces during the calculation.
140
141     Changed icon for x11image (renamed ximage) to miniature bitmap of
142     picture.
143
144     Fixed bug in xshowtrace that prevented it from working with twm.
145
146     Added memory recovery feature to rview so that when it refines
147     itself out of memory it doesn't quit but instead gives the user
148     a command line saying "out of memory:", which allows the output to
149     be written and so forth before quitting or restarting the image.
150
151     Added -g (gamma correction) option to pvalue.
152
153     Added the more general BRTDfunc for procedural definition of bidirectional
154     reflectance-transmittance distribution functions. Also added transfunc
155     and transdata types.
156
157     Changed trans types to modify the color of the transmitted specular
158     component.
159
160     Fixed a bug in ra_t16 introduced in the last change which caused
161     problems for the (default) 16-bit output mode.
162
163     Improved Monte Carlo sampling for penumbras (-dj) and ambient
164     super-samples (-as) using stratified random number sequence introduced
165     by Christophe Schlick at '91 Eurographics workshop on rendering.
166
167     Wrote falsecolor program to transform images to false color with
168     value labels.
169
170     Modified pcomb to allow different output sizes and access to local
171     pixel neighborhood for specialty filtering applications.
172
173     Made cone and sphere routines more forgiving of negative radii,
174     switching between inverted types as necessary and giving warning
175     messages instead of bombing. Cones with equal radii are now
176     silently converted into cylinders. Hopefully, these changes will
177     make writing Radiance scene file translators a little bit easier.
178     Unfortunately, we still bomb for zero-sized cones and spheres.
179
180     Wrote a program called getbbox that just computes the bounding box
181     for a set of Radiance scene files. It is basically a modified version
182     of oconv that doesn't store objects in memory and doesn't care about
183     undefined modifiers.
184
185     Added -a and -l options to pcompos and made both pcompos and pcomb
186     read from commands as well as files.
187
188     Substantially improved the accuracy and appearance of the interreflection
189     calculation by computing gradients at the same time as primary values and
190     then using a first order interpolation scheme. This affects the information
191     stored in ambient files, so old files will have to be thrown away.
192
193     Added secondary light sources from planar mirror, prismatic and
194     holographic surfaces. This created the new options -dr (direct relays)
195     and -dp (direct presample density) to the renderers. The document
196     secsrc.note describes this feature in greater detail.
197
198     Put many of the routines into a common library.
199
200     Wrote a replacement for makedist, called mkillum, which generates
201     light distribtuions and illum descriptions for windows, skylights,
202     etc. in a much more natural and automatic fashion.
203
204     Fixed long-standing bug in text routines which caused slanted text
205     to slant the wrong way!
206
207     Added -e option to ra_bn, ra_pr, ra_pr24, ra_t8 and ra_t16 programs
208     for faster and more convenient image conversion w/o using pfilt.
209
210     ****** COMPATIBILITY CHANGE ********
211     Finally added contexts to calcomp routines so identical names in
212     different function files no longer conflict. Loading of function
213     files also works automatically without those nasty "key" variables.
214     New context marks (backquote characters) appear in some local variables
215     defined in some of the cal files. This is inconsistent with older
216     versions, and must be changed back to and underscore or some other legal
217     character if these files are used by 1.4 and earlier.
218
219     Wrote ra_tiff program, using Sam Leffler's libtiff package to read
220     and write 24-bit TIFF images.
221
222     Wrote ra_ppm program to convert to and from Poskanzer Pixmaps.
223
224     ****** COMPATIBILITY CHANGE ********
225     Changed run-length encoding of Radiance pictures to gain better
226     compression. Routines can still read old format, but new ra_rgbe
227     program must be used to write convert images to a more generic format
228     that can be read by release 1.4 and earlier.
229
230     Defined U and V parameters in rayinit.cal for more convenient (and
231     sloppy) use of 2-dimensional textures and patterns on planar surfaces.
232
233     Beefed up lampcolor program to compute spectral radiance for diffuse
234     emitters. This was a previously a pain in the butt and a serious
235     source of error for scenes not modeled using IES data files.
236
237     Added version reporting to rpict, rtrace and rview. Use standalone
238     -version option.
239
240     Changed to quincunx initial sampling pattern in rpict. This should
241     reduce artifacts from adaptive image sampling at no added cost.
242
243     Added -rgb option to ra_pr24 to produce RT_FORMAT_RGB files.
244
245     Added -ds option to renderers to make source sampling more accurate
246     for large area sources. It is no longer necessary or recommended
247     to break large sources (such as windows) into smaller pieces with
248     gensurf unless their output distribution changes over their surface.
249     Also, cylinders can now be used as light sources, provided they are not
250     too short compared to their radius (causing them to be frequently missed).
251
252     Added -I option to xform to invert surfaces.
253
254     Added SMLFLT and BIGMEM defines to better control the sizes of data
255     structures during compilation. Made their setting relatively
256     straightforward in makeall and created a separate rmake program to
257     hold the options generated by makeall.
258
259     Made the programs more forgiving of machine differences on octrees.
260
261     ****** COMPATIBILITY CHANGE ********
262     Fixed incorrect conversion factor between radiance and luminance.
263     The correct luminous efficacy value is now defined in color.h as
264     WHTEFFICACY. It was 470 lumens/watt previously, now it has been
265     corrected to 179 lumens/watt. This affects the absolute values
266     in the output of programs like gensky and ies2rad. Thus, these
267     programs should be rerun to generate corrected files for this
268     version of Radiance. Also, the new versions of display programs
269     like ximage will give different values with the 'l' command on
270     an image generated with 1.4 and previous releases. The following
271     alias may be used to fix the radiance values in a picture generated
272     using previous versions of gensky and ies2rad:
273
274     alias pfixabs '( echo EXPOSURE=.381 ; cat \!:1 ) > \!:1.$$ ; mv \!:1.$$ \!:1'
275
276     Improved accuracy of glass material type and added option for
277     user-supplied index of refraction.
278
279     Added sgi to rt/Makefile and px/Makefile SPECIAL category for compiling
280     Isaac Kwo's NeWS driver for rview and the glimage program by Jim Winget.
281     Also fixed various compile problems for the SGI.
282
283     Improved handling of alternate scanline orientations. The programs
284     pflip and protate (used to be prot) now affect the scanline ordering
285     of the file without messing up the view parameters for programs like
286     pinterp and findglare.
287
288     ==========================
289     Version 2.1 (Released 5/20/92)
290
291     ****** COMPATIBILITY CHANGE ********
292     Changed function specifications to allow the use of expressions as
293     well as variables in scene files. Use of this feature may result
294     in some loss of backwards compatibility as older software does not
295     support it.
296
297     Added makeall option for NeXT machine and changed code to suit.
298
299     ****** COMPATIBILITY CHANGE ********
300     Added off-specular sampling and anisotropic materials plastic2,
301     metal2 and trans2. The old options -sp, -sj, -st and -p have
302     been renamed to -ps, -pj, -pt and -pa, respectively. New options
303     -sj and -st have been introduced.
304
305     Improved ray intersection calculations using -DSMLFLT option by
306     increasing epsilon used in tests. This eliminates most of the
307     errors that occured when this compile option was used in version 2.0.
308
309     Added capability to gensurf to read height or point data from a
310     file. This makes it more convenient to make (optionally smoothed)
311     landscapes from recorded measurements and the like.
312
313     Corrected irradiance gradient calculation. New formula predicts
314     gradient better and thus reduces artifacts in indirect calculation.
315
316     Modified replmarks to accept multiple markers.
317
318     Added -aI and -aE options to read ambient include/exclude materials
319     from a file.
320
321     Reduced effect of light leaks during interreflection calculation.
322
323     Added -ang option to gensky for giving solar angles explicitly.
324
325     Added ability of "view" command within rview to accept view options.
326
327     Fixed a long-standing bug in gensky that caused it to report
328     inaccurate values for the ground ambient level. Since the dayfact
329     script uses this value in calculating its results, version 2.0 will
330     be in error (by as much as 30 or 40%).
331
332     Fixed a bug in the reflectance normalization for isotropic and
333     anisotropic Gaussian highlights that caused too much light to
334     be reflected near grazing angles. Much thanks to the folks at
335     Ohio State University (Steve Spencer and Kevin Simon) who
336     pointed this out to me!
337
338     Fixed bug in xshowtrace introduced in 2.0. It absolutely didn't work
339     after my most recent changes to image.c. (Sorry about that!)
340
341     Finally fixed shortcoming of view reading routines so they can get
342     the views from pictures created with absolute program paths
343     (eg. /usr/local/bin/rpict). This affects programs like
344     xshowtrace and glare, as well as the recover option of rpict.
345
346     Fixed isotropic Gaussian distribution (highlights for types "metal"
347     and "plastic") to make them more accurate and bring them into line
348     with the new anisotropic Gaussian models ("metal2" and "plastic2").
349     This may affect the appearance of some hightlights.
350
351     Added -H and -R options to pvalue to control resolution strings
352     and color ordering.
353
354     Fixed byte ordering for 24-bit color displays in ximage.
355
356     ==========================
357     Version 2.2 (No official release)
358
359     Made more fixes in rview and ximage for different display hardware.
360     Philip Thompson and Peter Apian helped with suggestions and testing.
361
362     Fixed bug in -e option of xform that kept it from fully expanding
363     some scene files.
364
365     Added proportional text spacing (-s option for psign, new argument
366     for text primitives). Added antialiasing (3x3 super-sampling) to psign.
367
368     Added code in display drivers to read environment variable called
369     "GAMMA" to set gamma correction for different monitors. See notes in
370     this directory on gamma_corr.
371
372     Added CC defines to all the Rmakefiles so that other C compilers may be
373     used consistently.
374
375     Added -x and -y options to psign to control output dimensions directly.
376
377     Decreased value of FTINY with SMLFLT option once again in an attempt to
378     further reduce errors.
379
380     Reinstated rtrace's capability to produce 32-bit_rle_rgbe directly.
381
382     Added -S and -o options to rpict for more flexible production of
383     multiple images and slave operation. Rpict will also accept a recover
384     file name the same as the output file for more convenient recovery.
385
386     Added ra_ps program to translate Radiance picture into PostScript file.
387
388     ****** COMPATIBILITY CHANGE ********
389     Made ambient files machine-independent so they can be conveniently moved
390     and reused on any system. Also added coordinated reads and writes so
391     that multiple processes may use the same ambient file at the same time.
392     Along with the -S option of rpict, this should greatly facilitate parallel
393     rendering. The new ambient file format also contains a header that
394     can be read by getinfo. Lookamb now has a -h option.
395
396     Created rpiece program for parallel rendering of a single image on
397     multiple processors and workstations.
398
399     Eliminated star artifacts in mkillum distribution patterns by improving
400     data interpolation method. Improved ability of mkillum to correctly
401     sample non-axis-aligned polygons.
402
403     Added -s and -o options to pcompos for slightly more convenient use
404     of the -a option. Also eliminated incompatibility between -a and -y
405     options.
406
407     Fixed bug in spotlight sources that caused incorrect boundaries to be
408     cast by mirrors.
409
410     Fixed rounding of scanlines in ra_pr24 to 16-bit boundaries.
411
412     Added @file and $envar expansion capabilities to rtrace, rpict and
413     rview. This is primarily to overcome the 128-byte command limit of
414     MS-DOS.
415
416     Added -r option to gensky for the direct specification of solar
417     brightness.
418
419     Added -oN option to rtrace for reporting unperturbed surface normals,
420     and changed -on to report perturbed surface normals (used to be
421     unperturbed).
422
423     Changed -di switch of rtrace, rpict and rview to -dv and changed
424     sense. Thus, instead of having a boolean variable called "source
425     invisibility" that is normally off, there is now a boolean variable
426     called "source visibility" that is normally on. More logical, and
427     also allows for the addition of -di and -de options for direct
428     include and exclude in the future.
429
430     Fixed bug in image.c associated with -DSMLFLT that caused angular
431     fisheye views to repeat the center pixel in the middle of an image.
432
433     Modified colordata and colorpict to take functions of a single variable
434     instead of always requiring functions of three variables (red, green, blue).
435
436     Modified objview script to work in original object coordinates.
437
438     Added -P and -PP options to rpict and rtrace for persistent and parallel
439     processing, respectively. The -P option is most useful with the -fr
440     option of pinterp, since rtrace doesn't have to be restarted for every
441     frame in a long animation sequence. The -PP option is most useful when
442     running rpiece on a multiprocessing platform, to get acceptable memory
443     sharing without the hassle of threaded code.
444
445     Changed signal handling in rpict so CONT is now used to elicit
446     asynchronous progress reports. ALRM now causes rpict to die
447     unconditionally.
448
449     Created executive program called "rad" to run oconv, rview, rpict and
450     pfilt automatically. This should greatly simplify use of Radiance and
451     reduce the problems associated with poorly chosen parameter values.
452
453     Added slave driver to rview to make it easier to run from other
454     graphics applications. (Thanks to Chris Nicholas of Sun for the
455     suggestion.)
456
457     Fixed error in ies2rad.c and source.cal that caused incorrect
458     interpretation of asymmetric Type C (A) fixture photometry. Note the
459     new definition of src_phi in source.cal. This change may affect
460     manually entered photometry.
461
462     Added '@' command to ximage to adjust exposure based on Blackwell's
463     model of human contrast sensitivity.
464
465     Added functions to pcomb to get the ray origin and direction from the
466     input picture view specifications.
467
468     Removed Fresnel approximation to specular reflection from Radiance materials,
469     since the direct component was not being computed correctly. This
470     may have a slight affect on the appearance of surfaces, but it can't be
471     helped.
472
473     ****** COMPATIBILITY CHANGE ********
474     Changed the definition of the BRTDfunc type so as to be more general and to
475     allow for different reflection properties depending on what side of the
476     surface the ray is incident. Any scene and function files using the
477     old definition of BRTDfunc must be updated. Implemented the approximation
478     used in Window 4 to reflection from coated glazings in lib/glazing.cal.
479
480     Added -ti, -te, -tI and -tE options to rtrace for including or
481     excluding surfaces from those reported by the trace output specifier.
482
483     Fixed long-standing bug in pfilt gaussian filter option, which caused
484     the image to be excessively defocused.
485
486     Added -m option to pfilt for image sample smoothing. This helps get rid
487     of some of the "speckle" associated with specular sampling.
488
489     Made -ovt* compatible with -I option of rtrace.
490
491     Changed ximage to work with multiple pictures. It now opens one window
492     for each picture file.
493
494     Fixed error reporting in rpict for most machines. (Many thanks to Peter
495     Apian-Bennewitz for his help and suggestions.)
496
497     ****** COMPATIBILITY CHANGE ********
498     Added intermediate sky to gensky and changed its options slightly.
499     The new gensky uses a new version of skybright.cal, so any old
500     gensky output in files must be recomputed with the new gensky before
501     it will work. (A "skybright: undefined" error should clue you in.)
502
503     ==========================
504     Version 2.3 (Released 11/16/93)
505
506     No changes from the above, but the official release was designated 2.3
507     to avoid confusion with previous beta releases of 2.2.
508
509     ==========================
510     Version 2.4 (Released 4/20/94)
511
512     Philip Thompson of MIT added use of a radiance.gamma resource to ximage
513     and we added it to the x11 driver of rview as well. This is an alternative
514     to setting the GAMMA environment variable for X11 servers.
515
516     Added MLIB variable to Rmakefile's for defining alternate math libraries.
517     I discovered that the default version of sqrt() under IRIX is a whole
518     lot slower than what's in the libfastm.a library, and not much better.
519     This can make a significant difference to the renderers, since sqrt()
520     is relied on quite a bit, and it's assumed to be fast.
521
522     Added =SS option to pcompos to allow anchor points for image positions
523     other than the lower left corner.
524
525     Wrote raddepend script for finding dependencies in scene files.
526
527     Fixed a bug in mkillum that caused it to incorrectly sample ring sources.
528
529     Finally allowed mixtures to work with materials, thanks to the encouragement
530     and advice of Peter Apian-Bennewitz.
531
532     Wrote a triangular mesh converter, called tmesh2rad. I defined my own
533     format, since I wasn't too familiar with anyone else's format and I
534     wanted to support some additional possibilities (most notably patterns).
535
536     Added initial "#?RADIANCE" line to headers to simplify Radiance file
537     identification by programs used to magic numbers.
538
539     Created a translator for Wavefront .obj files, called obj2rad. It uses
540     the same type of mapping rules as arch2rad.
541
542     =============================
543     Version 2.5 (Released 6/26/95)
544
545     Wrote translators to and from the new MGF (Materials and Geometry
546     Format) specification.
547
548     Changed color conversion routines to make light source colors (from
549     lamp.tab) consistent with uniform white light standard.
550
551     Fixed a bug that caused very small local sources not to be sampled
552     at all!
553
554     Added the ability for rview to read commands from its standard input
555     under X11.
556
557     ****************** COMPATIBILITY CHANGE ***********************
558     Changed GAMMA environment variable to DISPLAY_GAMMA, to bring it in
559     line with the xli program, so users don't have to give two variables
560     for the same value!
561
562     Added -t (touch) option to rad, to make it easier to deal with minor
563     changes to input files.
564
565     Created graphical user interface to rad, called trad. Based on Tcl/Tk,
566     this should finally get people to start using this program!
567
568     Added -vo and -va (view fore and view aft) clipping plane options to
569     Radiance view parameters.
570
571     Added -bv option for (opaque) back face visibility control.
572
573     Added -q, -a and -e options to pinterp, and made it faster. (These
574     should be big improvements.)
575
576     Created tabfunc program for converting data tables to functional
577     language.
578
579     Wrote mgf2meta program to convert MGF data to line drawing.
580
581     Updated ies2rad program to interpret MGF geometry in IESNA-LM-63-1995
582     files.
583
584     Added sorting of ambient values according to access times to improve
585     reference locality for better virtual memory performance.
586
587     Added source solid angle argument to BRTD functions for averaging
588     values.
589
590     Wrote genclock program to create an analog clock.
591
592     Fixed a bug for bitmaps using hexbit4x1.fnt with brighttext, which
593     caused thin lines to appear.
594
595     =============================
596     Version 3.0 (Released 6/19/96)
597
598     Added comments to data and font files.
599
600     Changed behavior of mirror to allow void alternate material.
601
602     Added cylindrical view type for Quicktime VR authoring and other
603     interesting applications.
604
605     Increased default rtrace parameters for more accurate calculations when
606     options are not specified.
607
608     Added RAWFILE and ZFILE variables to rad for saving raw picture file and
609     Z (distance) information from rpict.
610
611     Ported trad for newer (4.0) version of Tk (wish). Thanks to Bob Lipman
612     of NIST for helping me track down the changes.
613
614     Added -B option to pinterp to blur multiple views into a single image,
615     useful for motion blur and depth of field simulation.
616
617     Created pdfblur script and modified vwright to automate depth-of-field
618     simulation with pinterp.
619
620     Added -c option for color PostScript output from ra_ps, and made both
621     this program and psmeta produce EPS-compatible files.
622
623     Created macbethcal program for calibrating color image scanners and
624     film recorders or printers using the Macbeth ColorChecker chart.
625
626     Created ra_xyze program for converting to and from new Radiance CIE XYZE
627     picture type and calibrating monitor colors. Modified Radiance picture
628     filters (pcompos, pflip, pcomb, pinterp, protate and pfilt) to handle
629     new picture type without complaint.
630
631     Added automatic ambient value computation to improve accuracy of results
632     no matter what -av value is given. (Only works for -ab > 0.) This was
633     a fairly obvious optomization I should have thought of ages ago.
634     (Default is old behavior -- -aw option puts in new code.)
635
636     Modified interreflection calculation to take textures (surface normal
637     perturbations) into account in indirect illumination. This should
638     improve the accuracy and appearance of textured surfaces in shadowed
639     regions.
640
641     Added -T option to rpiece to limit execution time.
642
643     Fixed bug in mixtext type introduced in last release -- caused improper
644     calculation of mixed modifiers.
645
646     Added basic options and functionality for participating media. New material
647     type "mist" and rendering options -me, -ma, -mg and -ms. This should permit
648     the modeling of visible light beams, uniform smoke, fog, and some types
649     of clouds.
650
651     Added -o option to ximage to control output of 't' command (and
652     middle mouse button). This adds the ability to produce pixel
653     position, radiance value and luminance. The default action is
654     the same as before.
655
656     Created pmblur script to generate views for camera motion blur in
657     walk-through animations.
658
659     Added "inpic" variable to picture.cal for determining when the edge
660     of a non-repeating image has been reached. Use with mixfunc primitive.
661
662     Created ranimate program to control walk-through and dynamic animations
663     on multiple hosts.
664
665     Fixed problem with antimatter type referring to final definition of
666     material names. Now, it uses the most recent ones.
667
668     Added an MC macro for true Monte Carlo sampling rather than the default
669     Quasi Monte Carlo. To enable, add -DMC to the OPT= line in rmake.
670
671     Fixed bug in pfilt -m option that caused floating point exceptions on
672     Alphas.
673
674     Wrote xyzimage script for X11 display of XYZE and corrected RGBE pictures.
675     Takes the same options as ximage with an added -p option, and checks
676     the environment variable DISPLAY_PRIMARIES for setting of monitor
677     primaries. (See the ra_xyze manual page for further explanation.)
678
679     Made colorpict's use much less memory by storing data in RGBE format
680     rather than floating point (takes 1/3 the space). This should help with
681     large image patterns.
682
683     At the insistence of Henrik Wann Jensen, changed the specular sampling
684     code so that very rough specular surfaces will sample more truly,
685     eliminating some strange mirror appearances evident using the old
686     method.
687
688     Added drawing of small and skinny light sources so rpict won't miss
689     these from inadequate image sampling. The method used may not work
690     perfectly for warped views (-vta, -vth and -vtc) having long,
691     cylindrical light sources. (Rob Shakespeare, take note!)
692
693     Added corner rounding to genprism command (-r option).
694
695     Changed mixtures so that mixing material with void is allowed, allowing
696     for opacity maps. Also altered general behavior so that surfaces
697     without materials in their modifier list are invisible, not only
698     surfaces with void modifiers.
699
700     ****************** COMPATIBILITY CHANGE ***********************
701     The behavior of xform has been changed to make object library
702     organization and usage simpler.
703     1) The RAYPATH directories are searched for matching file names.
704     2) Filenames beginning with '.', '/' or '~' do not result in searches.
705     3) Xform performs a chdir to the found file's directory, obviating
706     the need for peculiar inclusion names in subdirectories.
707     4) The array option (-a) now works when xform reads from stdin.
708     5) The expand option (-e) is now the default -- -c gets
709     back old behavior.
710
711     =============================
712     Version 3.1 (Released 7/24/97)
713
714     Changed gensky so it will accept hour specifications as HH:MM, with
715     designations for standard North American and European time zones.
716
717     Increased buffer size for in-line commands from 512 to 1024.
718
719     Added T(n), S(n), WE and pa(n) functions and constants to pcomb.
720
721     Created histo utility to compute 1-dimensional histograms from data files.
722
723     Created pacuity, pveil and psquish scripts (later combined in "pcond"):
724
725     o The pacuity program takes a Radiance picture and defocuses it
726     in places where the human eye loses resolution. Unless the
727     scene contains very low luminances (below .1 cd/m^2 or so),
728     this will not have an appreciable effect. The output can then
729     be adjusted according to the Ferwerda, Pattanaik and Shirley
730     tone mapping function using pcomb with the file
731     src/cal/cal/ferwerda.cal. (See the header comments therein.)
732
733     o The pveil program finds sources of glare in an image and adds
734     a corresponding amount of background luminance surrounding each
735     glare source according to the adaptation response of the human
736     eye. This has the effect of reducing contrast around glare
737     sources.
738
739     o The psquish program is probably the most useful of the three,
740     and must be applied after the other two if the others are
741     used. With the -a option, psquish uses the human visual
742     response to compress the dynamic range of an image to fit within
743     the limited dynamic range of a display (assumed to go from 1 to
744     100 cd/m^2), and also reduces color visibility in pictures with
745     low light levels (below 1 cd/m^2). Without the -a option,
746     psquish simply does the best it can to fit a picture's dynamic
747     range into what can be readily displayed, without regard to
748     human visual response. This has the effect of making problem
749     scenes viewable, such as indoor scenes with windows looking out
750     to bright exteriors.
751
752     Created pcond program, which combines pacuity, pveil and psquish in a
753     more efficient, robust package. (See man page for details.)
754
755     Renamed Perlin noise function partial functions, noise3a(), noise3b()
756     and noise3c() to noise3x(), noise3y() and noise3z(). Added backward
757     compatibility defines to rayinit.cal so nothing should be broken.
758
759     Fixed double-counting bug in calculation of specular transmission of
760     light sources for trans type. This might have caused unrealistically
761     high estimates for illumination beneath trans surfaces with non-zero
762     roughnesses when the interreflection calculation was used (-ab 1).
763
764     Added routines for reading and writing separate RGB files in pvalue.
765     Also added -pP (where P is one of 'R', 'G' or 'B' upper or lower case)
766     and -s option to skip specified number of bytes on header. Finally,
767     added a -n option for non-interleaved RGB input and output.
768
769     Fixed obscure bug in rcalc that caused it to return "Bad call to
770     argument!" for certain combinations of function and output channel
771     definitions.
772
773     Added "-e auto" and "-e human" options to ximage(1) and corresponding
774     'a' and 'h' commands to perform dynamic range compression similar to
775     pcond(1).
776
777     ==============================
778     Version 3.4 (Released 1/28/02)
779
780     Fixed bug in rpiece that caused it to incorrectly compute -vs and -vl
781     (view shift and lift) offsets. (Included in 3.1.1.)
782
783     Fixed bug in xform handling mist's with > 5 real arguments.
784     (Included in 3.1.1.)
785
786     Fixed bug in mist handling routines that caused some incorrect calculations
787     for distant sources. (Included in 3.1.1.)
788
789     Added ability for lam utility to read from commands.
790
791     Created vwrays command to compute ray origins and directions for specified
792     views or pictures.
793
794     Changed rtrace behavior to send bogus record when ray direction is zero.
795     (Before, it only flushed values with no corresponding record.) This
796     change was needed to facilitate its use with the new vwrays program.
797
798     Modified ies2rad so that it no longer produces glow sources for the sides
799     of objects, which caused unnatural dark bands near the ceilings of
800     direct/indirect installations. (Included in 3.1.4.)
801
802     Fixed bug in rpiece that caused the -pa option to fail. (Included in 3.1.2.)
803
804     Made ximage emphasize pixels in the selected region for the 'a' and 'h'
805     commands to adjust the exposure using histogram compression.
806     (Included in 3.1.4.)
807
808     Fixed bug in trad which caused it to fail when there were tabs in the input.
809     (Included in 3.1.3.)
810
811     Fixed bug in pcond that caused it to white-out borders of some fisheye views.
812     (Included in 3.1.3.)
813
814     Added facility to ra_tiff to read and write new LogLuv high dynamic-range
815     image formats.
816
817     Changed ambient value averaging in rendering programs (-aw option) to use
818     geometric mean rather than arithmetic mean, which tended to arrive at
819     too-high estimates and cause runaway calculations. (Included in 3.1.4.)
820
821     Added -g, -p, -m and -d options for gamma, paper size, margins and dpi
822     to the ra_ps program. This allows for much better control over output
823     to PostScript printers.
824
825     Fixed compiles for AIX -- select() incompatibility and macro conflicts.
826     (Included in 3.1.6.)
827
828     Increased table sizes to allow up to 4 million primitives when -DBIGMEM
829     is defined, provided there's enough virtual memory to hold them!
830
831     Fixed error in viewloc() for computing view locations for cylindrical views.
832
833     Wrote rholo, rhcopy, rhpict, and rhoptimize programs for holodeck
834     creation, display, and manipulation. This is a much more powerful way
835     to view a model than rview, though it lacks many of the utility commands.
836
837     Added the ability to separate concatanated animation frames using ra_rgbe.
838     This output facility of rpict was previously useless because nothing could
839     get anything past the first frame.
840
841     Wrote compamb program to compute a good ambient value for a rad input file.
842     Using this script is preferable to setting the -aw option of rpict, which
843     seems to result in splotchy artifacts in many situations.
844
845     Changed rad so it doesn't use the -aw option, which was causing some rather
846     annoying artifacts. (Added as patch to 3.1.8.)
847
848     Modified ranimate to change directories before running transfer or archive
849     commands.
850
851     Added -pm option to rpict to perform jittered motion blurring.
852
853     Created phisto script and added -I option to pcond for computing
854     multiple, identical exposures.
855
856     Fixed time zone specifications in gensky. (Added as patch to 3.1.9.)
857
858     Fixed bug in mixture functions that caused erroneous modifier loops.
859     (Added as patch to 3.1.10.)
860
861     Wrote glrad program for interactive display of Radiance scenes using OpenGL.
862     Modified objview program to use rad and glrad for rendering.
863
864     Changed the way ray weights are computed for participating media (including
865     dielectrics) so they more accurately reflect a ray's contribution, avoiding
866     some artifacts with unsealed dielectric objects and the ambient calculation.
867
868     Fixed problem with dielectric materials with textures where rays that should
869     have penetrated or reflected do the opposite.
870
871     Created ra_hexbit program to generate bitmap files for use with hexbit4x1.fnt.
872
873     ****************** COMPATIBILITY CHANGE ***********************
874     Altered mixtures to take the most recent modifier definition
875     rather than the last one in the entire description. Made the
876     same change for illum's and mirror's. Also, fixed a bug in
877     the antimatter type where it didn't always get the correct
878     material for shading.
879
880     Wrote normtiff program to quickly tone-map and convert Radiance pictures
881     and SGILOG-encoded TIFF's to flat RGB TIFF output.
882
883     Added -r option to protate for CCW rotations.
884
885     Added ability to load values from read-only ambient file in rpict,
886     rtrace and rview. This may be useful when starting with the same
887     values on many processors, where NFS lock contention would slow
888     things down if they also wrote values back to the file.
889
890     Wrote rhinfo program for printing out holodeck section information.
891
892     Modified rad "scene" variable to allow in-line command specifications.
893
894     Added added -s and -b options to ra_ppm for changing output scale and
895     forcing greyscale output.
896
897     Now allow negative distances for the fore clipping plane in rpict.
898     This may be useful for rendering holographic stereograms.
899
900     Added -f option to xform to read arguments from files. This can save
901     a lot of scene loading time by reducing multiple xform invocations.
902
903     Added support for 15-bit TrueColor visuals in ximage.
904
905     Added (undocumented) -P option to macbethcal for picking chart corners
906     directly using ximage.
907
908     Added -r option to rholo for opening holodeck files read-only.
909
910     Added correction factor for solid angle change in dielectrics as
911     noted in Eric Veach's thesis.
912
913     Added von Kries white balance transform for color conversion using
914     CMCCAT2000 matrix.
915
916     Added CAPDATE field to rendering headers to record render date.
917
918     Added mixpict primitive for using pictures to generate mixtures.
919
920     Fixed bug in Type B photometry angle calculation in source.cal discovered
921     by Erich Phillips.
922
923     ==============================
924 greg 1.3 Version 3.5 (Released 3/21/03)
925 greg 1.1
926     Fixed bug in replmarks pointed out by Georg Mischler, which caused
927     garbage to be output under specific conditions (unscaled, unrotated
928     instances).
929
930     Fixed bug in normtiff that caused occassional weird colors
931     on human tone-mapping of 32-bit LogLuv inputs (tmapluv.c).
932
933     Fixed -o option of pcomb so it resets le(i) and color exposure functions
934     to unity.
935
936     Fixed a bug in Type B photometry in ies2rad source.cal introduced
937     in last fix where spherical sources were getting symmetric
938     distributions front-to-back.
939
940     Fixed another bug in ies2rad for 90-270 bilaterally symmetric fixtures, which
941     seems to have been there from the beginning. Thanks to Jack de Valpine
942     for pointing it out.
943
944     Added NORANDOM symbol for tests with all random sampling turned off.
945
946     Fixed a bug in expression evaluation code that was causing unneeded
947     evaluations of constants. This is a fix on an earlier fix of a more
948     serious bug prior to the 3.4 release, where the expression clock
949     was wrapping silently and allowing values to go stale.
950
951     Fixed an even more serious bug in ies2rad for thin fixtures, where
952     it was using "flatcorr" without the proper correction for the
953     emitting area. Thanks again to Jack de Valpine for spotting this.
954
955     --- All of the above was put into a 3.4.1 patch release 4/1/2002
956
957     Added a facility to gensurf to make holes in the mesh using a
958     valid(s,t) function.
959
960     Fixed bug in pcond that caused a bus error on images with large dark
961     regions when acuity switch was set.
962
963     Fixed bug in pcomb that caused the S(n) function to return half
964     the solid angle value it should have. (Thanks to John Mardaljevic
965     for discovering this error.)
966
967     Made rpict/rpiece/vwrays -vf option accept "-" as a synonym
968     for standard input.
969
970     Fixed bug in persist functions (-P and -PP) with FreeBSD
971     (including MacOS X) having to do with altered system function
972     behaviors. Neither mknod() nor freopen() behave as they
973     used to.
974
975     Improved accuracy of irradiance gradient calculation near
976     specular surfaces by using the effective ray distance
977     rather than the first surface intersection. (John
978     Mardaljevic had pointed out some errors he was seeing
979     with a particular atrium model.)
980
981     Reinstated my favorite little Fresnel approximation for
982     perfectly smooth materials, so grazing angles show an
983     accurate gradient. Simultaneously revised the computation
984     of the direct component for proper energy balance.
985     (Thanks to Phillip Greenup for nagging John M. who nagged me.)
986
987     Improved the accuracy and appearance of indirect irradiance
988     interpolation for smoothed surfaces. (Thanks to Bernhard
989     Spanlang for noticing the problem.)
990
991     Fixed intolerance for carriage-returns in mkillum's input files,
992     which caused problems for files imported from DOS/Windows.
993
994     Fixed apparent bug that I couldn't reproduce in rpict for very
995     narrow views, which sent it into an infinite loop under Linux.
996     (Rich Gillibrand of Bristol Univ. pointed it out.)
997
998     Improved movement in rholo for low-detail holodecks on fast
999     graphics processors by inserting 50 ms pause during motion
1000     feedback.
1001
1002     Finally fixed ages-old consistency error where ambient value
1003     lists were sorted incorrectly with the GNU-C compiler,
1004     causing the dreaded "address not found in avlmemi" crash. All
1005     this time, I thought it was due to a faulty qsort(3) routine,
1006     when in fact it was due to the way GNU-C compares pointers.
1007     The fix was to change a single word in ambient.c from "AMBVAL"
1008     to "char" and now it all magically works. No more -Dtracktime=0,
1009     hurrah!
1010
1011     Fixed pcond veil behavior for scenes that have their contrast
1012     reduced by primary tone-mapping algorithms. Previously, the
1013     veil would come out looking like a fog because it was applied
1014     prior to dynamic range compression and did not consider the
1015     overall effect. In the new version, the veil is adjusted
1016     after dynamic range compression so that the net reduction
1017     in visibility is approximately correct over the whole image.
1018     (Later made this optional on compile with the ADJ_VEIL symbol, as I
1019     noticed more artifacts than improvements in the resulting images.)
1020
1021     Fixed bug in BRTDfunc that caused an error in the calculation
1022     of the diffuse transmitted ambient component. This must have
1023     been introduced early on, but never noticed by me or anyone.
1024
1025     Wrote an interactive script called "glaze" (src/gen/glaze.csh)
1026     that computes a good material model for fritted and low-E glazing
1027     systems. Thanks to Visarc (Jack de Valpine) for paying for its
1028     development and permitting it into the general distribution.
1029
1030     Increased scanline window in pcomb to 64 (+/- 32 pixels) to allow
1031     for larger kernels in filtered images.
1032
1033     ****************** COMPATIBILITY CHANGE ***********************
1034     Changed behavior of pfilt gaussian blur to match more precise
1035     definition. A blur radius of 0.6 is now preferred over the
1036     previous value of 1.0.
1037
1038     Added ANSI function prototypes to the header files in
1039     src/common/ and src/rt/ and cleaned up the options processing
1040     in the rpict, rtrace, and rview main procedures so that the
1041     core Radiance rendering code can be more easily
1042     called by new application programs. Changed src/rt/Rmakefile
1043     to create a rendering library called "libradiance.a" and
1044     to install it in the src/lib/ directory along with the new
1045     raycalls.o module, which should facilitate the building
1046     of new applications outside the src/rt/ directory. The
1047 greg 1.2 raypcalls.o module, also installed in src/lib, manages
1048 greg 1.1 parallel rendering on multiprocessors with shared memories.
1049
1050     Wrote new ranimove animation rendering program, which is an
1051     alternative to ranimate. The key difference is that
1052     ranimove is optimized for moving scenes, and includes
1053     a complete blur simulation for camera and object motion.
1054     It also incorporates an sophisticated model of perceivable
1055     error based on visual focus, and allows progressive
1056     animation so one can explicitly control rendering time
1057     and/or accuracy. See the man page for details.
1058
1059     ****************** COMPATIBILITY CHANGE ***********************
1060     The sense of the MBLUR setting has been changed for the ranimate
1061     command. The first value is now the fraction of a frame during
1062     which the shutter is open, and the _second_ argument (which is
1063     optional) is the number of samples to specify to pmblur.
1064
1065     Enhanced octree reader behavior so it will accept command
1066     specifications preceded by an exclamation mark ('!'). This
1067     enables rtrace and rview to take octrees from commands similar
1068     to rpict reading its octree from the standard input. All
1069     programs taking octrees as arguments will be affected by this
1070     change. However, since rad needs to get the modified date
1071     from the octree, rad will refuse such an octree command
1072     specification.
1073
1074     Fixed a bug in src/common/fgetline.c where it failed to elide
1075     carriage-returns in Windows files.
1076
1077     Modified src/common/fgetword.c so it accepts single- or
1078     double-quoted words with spaces in preparation for the
1079     Windows version, which needs to allow spaces in file
1080     paths. Since fgetword() is called by all programs that
1081     read in string arguments in scene files, these may now
1082     be quoted with the expected behavior. Also added a
1083     fputword() call to the library to automatically quote
1084     words on output that contain white space. This routine
1085     is now called from all the right places, I hope! The
1086     code does not support spaces in primitive identifiers,
1087     and you will get peculiar errors if you try them.
1088
1089     Eliminated virtually all symbolic links from the source
1090     tree, most of which were links to compatibility routines
1091     and the calcomp functions for expression parsing.
1092     Replaced -D* defines used in cal* routines with "esupport"
1093     global that allows calling programs to set which language
1094     options they want to support at runtime. More programs now
1095     link against the -lrt library. Consolidated the src/cal
1096     subdirectories in the process.
1097
1098     Added -dw option to pvalue program to input and output
1099     16-bit word values (-dW for byte swapping).
1100
1101     Changed call ordering in material shaders to ensure
1102     proper surface normal perturbation for two-sided,
1103     textured surfaces.
1104
1105     Added a new "mesh" primitive, which permits very
1106     complicated geometries with associated (u,v) coordinates
1107     using the new obj2mesh converter and the new -o option
1108     of gensurf for .OBJ output. Mesh compilation takes
1109     roughly 500 bytes/triangle in obj2mesh, but memory
1110     access is well-ordered compared to rendering, which
1111     takes about 50 bytes/triangle with full surface normal
1112     and (u,v) coordinate interpolation. (The actual mesh
1113     is represented in 15 bytes/triangle, and the rest is
1114     taken by the octree structure and malloc overhead.)
1115     Local coordinates are set with the "vt" statement
1116     in the Wavefront .OBJ file and accessed via the new
1117     "Lu" and "Lv" variables in a Radiance .cal file.
1118     Multiple instances of the same mesh with different
1119     transformations take little additional space during
1120     rendering, permitting scanned relief surfaces and
1121     displacement-map-like effects to be repeated as desired.
1122
1123     Changed internal representation of alias'es in order
1124     to maintain information about links for programs like
1125     rshow that work from frozen octrees. Added a special
1126     alias modifier keyword, "inherit", to indicate that
1127     an alias should get the same modifier as the original
1128     target to simplify common alias usage for material
1129     substitution.
1130
1131     Increased default oconv -n value to 6. Since triangle
1132     meshes commonly have six faces joining at each vertex,
1133     values less than this cause resolution-limited voxel
1134     subdivision. Increased default -r option to 16384
1135     as well. Also increased maximum internal set size
1136     from 127 to 511, to accommodate difficult mesh
1137     models where many faces come together at a point.
1138     This required a little reprogramming in for couple
1139     of recursive routines using sets to avoid overrunning
1140     the stack limit.
1141 greg 1.4
1142     ==============================
1143     Version 3.6
1144
1145     Modified 4-byte RGBE encoding routine to avoid problems
1146     when one or two primary values is negative and the other(s)
1147     positive. This used to generate some strange color values.
1148
1149     Added -oc option to rtrace to output local (u,v) coordinates.
1150
1151     Fixed bugs in local uv and j unit vector variables in src/rt/func.c.
1152
1153     Added warning message to OpenGL rendering routines about new
1154     mesh primitive, which we cannot currently render.
1155
1156     Added -if, -id, -of, and -od options to rcalc to provide for
1157     binary float and double i/o.
1158
1159     ****************** COMPATIBILITY CHANGE ***********************
1160     Changed holodeck format to used off_t instead of long for beam
1161     positions, which allows holodecks to grow to system file size limit.
1162 greg 1.5
1163     Fixed wrapping long in source hit test code, which would cause
1164     odd horizontal lines in some very long renderings.
1165 greg 1.6
1166     Added -f and -w options to ra_tiff to create IEEE float and 16-bit/primary
1167     TIFF output, respectively. These formats are also understood on reverse
1168     conversion. (16-bit/primary has been understood for some time, but not
1169     IEEE float.)
1170 greg 1.7
1171     Added -N option to rad to start multiple rendering processes in
1172     parallel.
1173 greg 1.8
1174     Fixed bug where mesh instances were not being freed, so subsequent calls
1175 greg 1.35 in programs like ranimove would refer to bogus data.
1176 greg 1.9
1177     Added support in normtiff for floating-point and 16-bit/sample TIFF input
1178     files.
1179 greg 1.10
1180     Changed marksources() routine (src/rt/source.c) to check all
1181     primitives in the modifier chain for emitting types, not only
1182     the first. This permits sources to be described with intervening
1183 greg 1.29 modifiers before the light/illum/glow primitive and allows aliases
1184     as well.
1185 greg 1.10
1186 greg 1.11 Fixed bug in xform where it was neglecting to add transform arguments
1187     to new mesh primitive.
1188 greg 1.12
1189     Added -dF and -dD options to pvalue for byte-swapped floats and
1190     doubles, respectively.
1191 greg 1.13
1192     Changed meta2tga to output correct colors.
1193 greg 1.14
1194     Changed local coordinate index from 32-bits to 16-bits, which requires
1195 greg 1.28 that Radiance mesh files be recompiled. (Later decided against this
1196     change, as it caused problems with some models.)
1197 greg 1.15
1198     Changed integer tone-mapping routines to better deal with images
1199     containing large, constant regions.
1200 greg 1.16
1201     Improved interaction with rholo -o ogl driver under OS X, which was
1202     returning bad values from the depth buffer.
1203 greg 1.17
1204     Minor bug fix in ranimove where it was restarting processes when it
1205     didn't need to.
1206 greg 1.18
1207     Increased accuracy of default ambient parameters in rpict, rview, and
1208     rtrace. In rad program, doubled -ar value, -ad value, and -as value,
1209     and decreased -aa value a bit. Also adjusted -lr upwards and -lw
1210     downwards. I should have done these things long ago, as processors
1211     have been getting faster and faster over the years.
1212 greg 1.19
1213     Fixed bug discovered by Marcus Jacobs where oconv was dumping core
1214     when it was given too many modifiers.
1215 greg 1.20
1216     Fixed problem with rpict where it was drawing illum sources badly
1217     even when they weren't all that small in the view.
1218 greg 1.21
1219     Added in(i) function to rcalc for more flexible channel evaluation.
1220 greg 1.22
1221     Replaced all calls to vfork() with regular fork() calls.
1222 greg 1.23
1223     Fixed bug in glarendx for dgr calculation with sources behind view.
1224 greg 1.24
1225     Added -p option to histo to print percentages/percentiles r.t. counts.
1226 greg 1.25
1227     Added a source occluder cache to accelerate shadow testing. This
1228     can save up to 50% of the calculation time in scenes with many
1229     light sources, especially ones containing large occluders. This
1230     optimization may be tuned or switched off with the -DSHADCACHE=N
1231     compile switch, where N is the resolution of the shadow cache, or
1232     0 to disable it. Since this is purely a time vs. memory trade-off,
1233     I decided not to make it a new command-line option. (We already
1234     have plenty.)
1235 greg 1.26
1236     ****** COMPATIBILITY CHANGE ********
1237     Changed the following command names to avoid conflicts:
1238     rview -> rvu (with symbolic link back to rview)
1239     calc -> icalc
1240     lam -> rlam
1241     gencat -> gencatenary
1242 greg 1.27
1243     Improved -f option of normpat, which caused odd color changes before.
1244
1245     Created pgblur script which does fast Gaussian blur of image without changing
1246     its dimensions. This is very useful in certain types of image processing
1247     calculations, such as finding or removing low frequencies.
1248
1249     ****** COMPATIBILITY CHANGE ********
1250     Changed little-used objpict script so that it takes scene files rather than
1251     rpict options on the command line, and puts everything into the right
1252     coordinate position automatically rather than requiring the user to do it.
1253
1254     Added -I option to replmarks for mesh instancing.
1255 greg 1.29
1256     Made similar change for virtual sources to allow modifiers and aliases
1257     on the mirror and prism types to work properly.
1258 greg 1.30
1259 greg 1.52 Rob Guglielmetti added -lw and -lh options to falsecolor to control the
1260 greg 1.30 legend dimensions. Made it so -lw 0 and/or -lh 0 turns legend off.
1261 greg 1.31
1262     Made it so pcompos will read everything from a stream even if it doesn't
1263     need it, so input commands will not receive a hangup signal.
1264 greg 1.32
1265     Wrote ra_bmp program to convert to and from Windows BMP files (finally).
1266 greg 1.33 It's the most horrible image format I've ever seen, and I've seen a lot.
1267 greg 1.34
1268     Increased -aa default value for all renderers (and also -ad and -as in
1269     rview) at Schorsch's suggestion. I think this undid my earlier decrease
1270     of -aa last time, which I guess was ill-considered.
1271 greg 1.35
1272     Modified oconv to keep subdividing the octree if there are too many
1273     objects in a voxel even when the -r resolution limit has been
1274     reached. This was not done before due to problems with recursion,
1275     and still, it will only continue to 256 times the original -r limit.
1276     If that isn't enough, then there's probably no hope, anyway.
1277 greg 1.36
1278     Added -l option to obj2mesh to search for material files in library
1279     locations.
1280 greg 1.37
1281     Increased polygon vertex limit to 512 in obj2mesh and obj2rad and added
1282     warning if this limit is exceeded.
1283 greg 1.38
1284     Added tone-mapping and monitor primary options to ra_bmp. This gives
1285     new functionality similar to normtiff and ximage. It would be nice to
1286     add this feature to the other ra_* programs as well... someday.
1287 greg 1.39
1288     Fixed long-standing bug in reported pixel ordering out of certain
1289     protate commands.
1290 greg 1.40
1291     Added -p option to rcalc for "passive mode" that transmits
1292     unrecognized input -- useful for substituting data in the
1293     middle of a stream.
1294 greg 1.41
1295     Fixed a very obscure bug in rpict that caused a dark horizontal
1296     line in certain cylindrical projections due to improper drawing
1297     of the sky dome source in rt/srcdraw.c.
1298
1299 greg 1.52 Fixed problems with effective ray lengths computed for dielectric
1300 greg 1.41 and BRTDfunc materials. This was most evident in breakup of holodeck
1301     views when VDISTANCE=True.
1302 greg 1.42
1303     Fixed rad so that 'scene' variable may consist only of inline commands.
1304 greg 1.43
1305     Fixed bug introduced in shadow caching routines where sources in the
1306     middle of spheres were not illuminating properly. Thanks to Guilio
1307     Antonutto for spotting this problem.
1308 greg 1.44
1309     Modified gensky behavior so if time is given with standard time zone
1310     designation, any -m option is ignored.
1311 greg 1.45
1312     Added -n option to mkillum for (shared memory) parallel processing.
1313 greg 1.46
1314 greg 1.47 Fixed a long-standing bug in parallel processing code that only
1315     seemed to manifest with the new mkillum -n option, where rtrace
1316     would deadlock upon termination. The reason it never showed up
1317     before is because I always closed processes in the reverse order
1318     of opening them in other programs. I went through and found similar
1319     (potential) bugs in the rview device subprocess code and util/netproc.c.
1320 greg 1.48
1321     Corrected the normalization of the Gaussian reflectance model. This will
1322     cause an increase in specularity for low-lying light sources.
1323     Thanks to Don Walters of Boeing and Arne Duer of the Univ. of Innsbruck
1324     for pointing out this error. The square root used for the two cosines
1325     in the denominator of the normalization factor should not be present.
1326     This was a serious mistake I made in the original model, which went
1327     undiscovered (at least to my knowledge) for over a decade. I think
1328     Bruce Walter of Cornell may have known about it, but I never heard
1329     the details of his discovery.
1330 greg 1.49
1331     Enabled the -p option for primary conversion without tone-mapping
1332     in ra_bmp. Also provides for XYZE input conversion to RGB.
1333 greg 1.50
1334     Fixed what I consider a bug in pvalue -o when taking XYZE files on input,
1335     where it was inappropriately undoing the exposure value so that it always
1336     reported radiance rather than XYZ values with Y in cd/m^2.
1337 greg 1.51
1338     Made it so ra_bmp only produces run-length encoded 8-bit output for
1339     grayscale images that are tone-mapped. This minimizes circumstances
1340     under which output scanline order is reversed.
1341 greg 1.53
1342     Fixed bug in rcalc where it sometimes wasn't parsing the input format
1343     correctly.
1344 greg 1.54
1345     =====================
1346     Version 3.7
1347
1348     Fixed bug in source occluder cache which caused consistency error
1349     for distant sources and mist materials. (Thanks to Mark Stock for
1350     finding the problem.)
1351
1352     Fixed serious bug in source drawing routines for rpict, where the edges
1353     of light sources were appearing through obstructions. (Thanks to Veronica
1354     Sundstedt for pointing this out.)
1355
1356     (The above were included in the 3.6.1 patch release.)
