Thu Oct 28 00:49:27 2004 UTC (20 years, 11 months ago) by greg
CVS Tags: rad3R6P1
Changes since 1.53: +13 -0 lines
Diff to previous 1.53 , to selected 1.20
Added comments on 3.6 bug fixes
Mon Oct 11 10:02:15 2004 UTC (21 years ago) by greg
Changes since 1.52: +3 -0 lines
Diff to previous 1.52 , to selected 1.20
Mon Oct 4 22:32:58 2004 UTC (21 years ago) by greg
Changes since 1.51: +2 -2 lines
Diff to previous 1.51 , to selected 1.20
Fixed minor spelling errors and typos
Mon Oct 4 17:44:22 2004 UTC (21 years ago) by greg
Changes since 1.50: +4 -0 lines
Diff to previous 1.50 , to selected 1.20
Fri Oct 1 07:45:30 2004 UTC (21 years ago) by greg
Changes since 1.49: +4 -0 lines
Diff to previous 1.49 , to selected 1.20
Thu Sep 23 18:00:54 2004 UTC (21 years ago) by greg
Changes since 1.48: +3 -0 lines
Diff to previous 1.48 , to selected 1.20
Mon Sep 20 17:32:04 2004 UTC (21 years ago) by greg
Changes since 1.47: +10 -0 lines
Diff to previous 1.47 , to selected 1.20
Corrected Gaussian reflectance model normalization (cosine factor)
Mon Sep 20 16:26:57 2004 UTC (21 years ago) by greg
Changes since 1.46: +6 -3 lines
Diff to previous 1.46 , to selected 1.20
Sun Sep 19 08:42:22 2004 UTC (21 years ago) by greg
Changes since 1.45: +4 -0 lines
Diff to previous 1.45 , to selected 1.20
Fri Sep 17 21:43:49 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.44: +2 -0 lines
Diff to previous 1.44 , to selected 1.20
Fri Sep 10 18:19:24 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.43: +3 -0 lines
Diff to previous 1.43 , to selected 1.20
Fri Sep 10 16:05:07 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.42: +4 -0 lines
Diff to previous 1.42 , to selected 1.20
Thu Sep 9 20:08:21 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 1.41 , to selected 1.20
Thu Sep 9 17:05:43 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.40: +8 -0 lines
Diff to previous 1.40 , to selected 1.20
Added notes about recent fixes
Wed Jun 9 16:00:13 2004 UTC (21 years, 4 months ago) by greg
Changes since 1.39: +4 -0 lines
Diff to previous 1.39 , to selected 1.20
Fri Apr 30 20:29:24 2004 UTC (21 years, 5 months ago) by greg
Changes since 1.38: +3 -0 lines
Diff to previous 1.38 , to selected 1.20
Fri Apr 30 17:00:29 2004 UTC (21 years, 5 months ago) by greg
Changes since 1.37: +4 -0 lines
Diff to previous 1.37 , to selected 1.20
Fri Apr 23 16:20:54 2004 UTC (21 years, 5 months ago) by greg
Changes since 1.36: +3 -0 lines
Diff to previous 1.36 , to selected 1.20
Fri Apr 23 00:56:27 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 1.35 , to selected 1.20
Mon Apr 12 17:31:27 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.34: +7 -1 lines
Diff to previous 1.34 , to selected 1.20
Sun Mar 28 16:31:14 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.33: +4 -0 lines
Diff to previous 1.33 , to selected 1.20
Fri Mar 26 22:58:21 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.32: +1 -2 lines
Diff to previous 1.32 , to selected 1.20
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.31: +4 -0 lines
Diff to previous 1.31 , to selected 1.20
Mon Mar 15 21:16:54 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 1.30 , to selected 1.20
Mon Mar 8 21:39:32 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 1.29 , to selected 1.20
Mon Mar 1 17:49:38 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.28: +5 -1 lines
Diff to previous 1.28 , to selected 1.20
Fri Jan 30 00:08:31 2004 UTC (21 years, 8 months ago) by greg
Diff to previous 1.27 , to selected 1.20
Thu Jan 29 22:20:31 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.26: +13 -0 lines
Diff to previous 1.26 , to selected 1.20
Thu Jan 1 19:31:45 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.25: +7 -0 lines
Diff to previous 1.25 , to selected 1.20
Wed Dec 31 01:50:02 2003 UTC (21 years, 9 months ago) by greg
Changes since 1.24: +9 -0 lines
Diff to previous 1.24 , to selected 1.20
Sun Dec 14 16:33:37 2003 UTC (21 years, 10 months ago) by greg
Diff to previous 1.23 , to selected 1.20
Added -p option to histo to report percentiles and changed output slightly
Wed Nov 19 16:21:28 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.22: +2 -0 lines
Diff to previous 1.22 , to selected 1.20
Tue Nov 11 16:24:05 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 1.21 , to selected 1.20
Thu Nov 6 05:39:33 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 1.20
Revision 1.20 - (view) (download) (annotate) - [selected]
Wed Oct 1 22:07:19 2003 UTC (22 years ago) by greg
Changes since 1.19: +3 -0 lines
Diff to previous 1.19
Tue Sep 30 00:13:58 2003 UTC (22 years ago) by greg
Changes since 1.18: +3 -0 lines
Diff to previous 1.18 , to selected 1.20
Wed Sep 24 14:55:53 2003 UTC (22 years ago) by greg
Changes since 1.17: +6 -0 lines
Diff to previous 1.17 , to selected 1.20
Tue Sep 23 03:54:57 2003 UTC (22 years ago) by greg
Changes since 1.16: +3 -0 lines
Diff to previous 1.16 , to selected 1.20
Fri Sep 19 18:33:04 2003 UTC (22 years ago) by greg
Changes since 1.15: +3 -0 lines
Diff to previous 1.15 , to selected 1.20
Thu Sep 18 20:18:19 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.14 , to selected 1.20
Thu Sep 18 16:53:52 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.13 , to selected 1.20
Tue Sep 16 06:32:21 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.12 , to selected 1.20
Changed meta2tga so it outputs correct colors
Sat Sep 13 15:24:13 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 1.20
Fri Aug 29 21:44:17 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.10 , to selected 1.20
Tue Aug 26 16:09:43 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 1.20
Mon Jul 14 04:56:53 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.8: +3 -0 lines
Diff to previous 1.8 , to selected 1.20
Thu Jul 10 03:47:00 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 1.20
Thu Jul 3 15:00:19 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.6: +3 -0 lines
Diff to previous 1.6 , to selected 1.20
Tue Jul 1 19:04:08 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 1.20
Tue Jun 24 15:38:07 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.4 , to selected 1.20
Fri Jun 6 01:01:09 2003 UTC (22 years, 4 months ago) by greg
Changes since 1.3: +21 -0 lines
Diff to previous 1.3 , to selected 1.20
Added mention of latest changes
Fri Mar 21 18:48:45 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 1.20
Tue Mar 18 04:45:28 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 1.1 , to selected 1.20
Removed duplicate copies of file and fixed comment in release notes
Sat Mar 15 17:32:55 2003 UTC (22 years, 7 months ago) by greg
Diff to selected 1.20
