Revision 1.503 - (view) (download) (annotate) - [select for diffs]
Fri Nov 14 23:51:42 2025 UTC (3 days, 9 hours ago) by greg
Changes since 1.502: +5 -0 lines
Diff to previous 1.502
feat(rfluxmtx,rxfluxmtx): Added bin sample jittering for smoother visual results
Revision 1.502 - (view) (download) (annotate) - [select for diffs]
Wed Oct 29 02:48:50 2025 UTC (2 weeks, 6 days ago) by greg
Changes since 1.501: +2 -0 lines
Diff to previous 1.501
feat(pvsum): Added -m option to optimize speed and memory usage
Revision 1.501 - (view) (download) (annotate) - [select for diffs]
Wed Oct 22 02:38:27 2025 UTC (3 weeks, 6 days ago) by greg
Changes since 1.500: +5 -0 lines
Diff to previous 1.500
feat(rxfluxmtx): Created new tool with more x's in its name than any other
Revision 1.500 - (view) (download) (annotate) - [select for diffs]
Fri Sep 26 04:01:43 2025 UTC (7 weeks, 4 days ago) by greg
Changes since 1.499: +4 -0 lines
Diff to previous 1.499
docs: Recent updates and bug fixes
Revision 1.499 - (view) (download) (annotate) - [select for diffs]
Sun Sep 14 04:39:53 2025 UTC (2 months ago) by greg
Changes since 1.498: +3 -0 lines
Diff to previous 1.498
feat(ra_bmp): Added metadata handling and i/o
Revision 1.498 - (view) (download) (annotate) - [select for diffs]
Sat Sep 13 17:54:39 2025 UTC (2 months ago) by greg
Changes since 1.497: +3 -0 lines
Diff to previous 1.497
fix(rtpict): Further fixes for running under Windows with -o* option
Revision 1.497 - (view) (download) (annotate) - [select for diffs]
Fri Aug 22 01:16:39 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 1.496: +2 -0 lines
Diff to previous 1.496
docs(gensdaymtx): Fixed issue with zero illumination values (TW)
Revision 1.496 - (view) (download) (annotate) - [select for diffs]
Fri Aug 22 00:09:39 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 1.495: +3 -0 lines
Diff to previous 1.495
docs: Added note about fix to direct and diffuse illuminance for EPW files
Revision 1.495 - (view) (download) (annotate) - [select for diffs]
Thu Aug 21 22:33:30 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 1.494: +12 -1 lines
Diff to previous 1.494
docs: Notes on bug fixes since 6.0 official release
Revision 1.494 - (view) (download) (annotate) - [select for diffs]
Thu Jul 24 18:25:46 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.493: +5 -2 lines
Diff to previous 1.493
chore: Moving on to 6.1a
Revision 1.493 - (view) (download) (annotate) - [select for diffs]
Fri Jun 27 19:38:13 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.492: +8 -5 lines
Diff to previous 1.492
docs: Wording fixes
Revision 1.492 - (view) (download) (annotate) - [select for diffs]
Thu Jun 19 22:36:53 2025 UTC (4 months, 4 weeks ago) by greg
Changes since 1.491: +2 -0 lines
Diff to previous 1.491
feat(rcomb): Added -mt option to transpose concatenation matrix after load
Revision 1.491 - (view) (download) (annotate) - [select for diffs]
Wed Jun 4 20:32:24 2025 UTC (5 months, 2 weeks ago) by greg
Changes since 1.490: +2 -0 lines
Diff to previous 1.490
feat(rxpiece): Added rxpiece to standard distribution
Revision 1.490 - (view) (download) (annotate) - [select for diffs]
Thu May 29 16:42:28 2025 UTC (5 months, 2 weeks ago) by greg
Changes since 1.489: +4 -0 lines
Diff to previous 1.489
fix: Updated behavior of "mirror" type to handle indirect transmission, thanks to Jon Sargent
Revision 1.489 - (view) (download) (annotate) - [select for diffs]
Wed May 21 20:42:48 2025 UTC (5 months, 4 weeks ago) by greg
Changes since 1.488: +4 -0 lines
Diff to previous 1.488
perf(bsdf2ttree): Changed default -n from 256 down to 64 for faster calcs
Revision 1.488 - (view) (download) (annotate) - [select for diffs]
Wed May 21 17:23:07 2025 UTC (5 months, 4 weeks ago) by greg
Changes since 1.487: +3 -0 lines
Diff to previous 1.487
feat(bsdfpeaks): Added new utility to find and measure peaks in BSDFs
Revision 1.487 - (view) (download) (annotate) - [select for diffs]
Thu May 8 14:44:01 2025 UTC (6 months, 1 week ago) by greg
Changes since 1.486: +4 -0 lines
Diff to previous 1.486
fix: Spectral resampling error with -cw option
Revision 1.486 - (view) (download) (annotate) - [select for diffs]
Mon May 5 19:20:16 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 1.485: +3 -0 lines
Diff to previous 1.485
feat(genglaze): New tool created by Taoning Wang added to distro
Revision 1.485 - (view) (download) (annotate) - [select for diffs]
Fri May 2 23:56:18 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 1.484: +5 -0 lines
Diff to previous 1.484
feat(rvu): Altered the "origin" command to take shift distances
Revision 1.484 - (view) (download) (annotate) - [select for diffs]
Sun Apr 27 20:20:01 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 1.483: +6 -0 lines
Diff to previous 1.483
perf(rvu,rpict,rtrace,rcontrib): Reduced (eliminated?) bias due to ambient collision avoidance
Revision 1.483 - (view) (download) (annotate) - [select for diffs]
Tue Apr 22 17:12:25 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 1.482: +3 -0 lines
Diff to previous 1.482
Revision 1.482 - (view) (download) (annotate) - [select for diffs]
Thu Apr 10 23:30:58 2025 UTC (7 months, 1 week ago) by greg
Changes since 1.481: +3 -0 lines
Diff to previous 1.481
feat(gensdaymtx,genssky): TW fixed bug in genssky and added absolute calibration
Revision 1.481 - (view) (download) (annotate) - [select for diffs]
Fri Apr 4 18:06:48 2025 UTC (7 months, 2 weeks ago) by greg
Changes since 1.480: +6 -0 lines
Diff to previous 1.480
Revision 1.480 - (view) (download) (annotate) - [select for diffs]
Wed Apr 2 00:55:27 2025 UTC (7 months, 2 weeks ago) by greg
Changes since 1.479: +3 -0 lines
Diff to previous 1.479
feat(genBSDF): Added support for -r "-cs M" to employ M spectral samples
Revision 1.479 - (view) (download) (annotate) - [select for diffs]
Thu Mar 27 01:26:55 2025 UTC (7 months, 3 weeks ago) by greg
Changes since 1.478: +5 -0 lines
Diff to previous 1.478
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Revision 1.478 - (view) (download) (annotate) - [select for diffs]
Wed Mar 19 01:18:20 2025 UTC (8 months ago) by greg
Changes since 1.477: +4 -0 lines
Diff to previous 1.477
feat(rfluxmtx): Allow source and non-source receivers, which is valid in some cases
Revision 1.477 - (view) (download) (annotate) - [select for diffs]
Wed Feb 26 20:39:28 2025 UTC (8 months, 3 weeks ago) by greg
Changes since 1.476: +7 -0 lines
Diff to previous 1.476
feat(gendaymtx): Added ability to read dew point from EPW input data
Revision 1.476 - (view) (download) (annotate) - [select for diffs]
Tue Feb 4 19:11:49 2025 UTC (9 months, 1 week ago) by greg
Changes since 1.475: +4 -11 lines
Diff to previous 1.475
docs: Removed mention of -DSRCSKIPOPT, which was removed from distro.
Revision 1.475 - (view) (download) (annotate) - [select for diffs]
Thu Jan 23 22:03:59 2025 UTC (9 months, 3 weeks ago) by greg
Changes since 1.474: +0 -6 lines
Diff to previous 1.474
fix: Went back to previous ambient file locking method
Revision 1.474 - (view) (download) (annotate) - [select for diffs]
Thu Jan 23 19:09:38 2025 UTC (9 months, 3 weeks ago) by greg
Changes since 1.473: +3 -0 lines
Diff to previous 1.473
perf(rholo): Added rad -N option for efficiency with mkillum, mkpmap
Revision 1.473 - (view) (download) (annotate) - [select for diffs]
Thu Jan 23 02:15:33 2025 UTC (9 months, 3 weeks ago) by greg
Changes since 1.472: +6 -0 lines
Diff to previous 1.472
perf: Simplified operation of shared ambient files, more testing needed
Revision 1.472 - (view) (download) (annotate) - [select for diffs]
Tue Jan 21 01:56:27 2025 UTC (9 months, 3 weeks ago) by greg
Changes since 1.471: +4 -0 lines
Diff to previous 1.471
feat(gensurf): Added gensurf -i option to reverse surface normals
Revision 1.471 - (view) (download) (annotate) - [select for diffs]
Mon Dec 9 00:44:29 2024 UTC (11 months, 1 week ago) by greg
Changes since 1.470: +3 -0 lines
Diff to previous 1.470
Revision 1.470 - (view) (download) (annotate) - [select for diffs]
Tue Dec 3 01:11:42 2024 UTC (11 months, 2 weeks ago) by greg
Changes since 1.469: +3 -0 lines
Diff to previous 1.469
Revision 1.469 - (view) (download) (annotate) - [select for diffs]
Fri Nov 15 20:47:42 2024 UTC (12 months ago) by greg
Changes since 1.468: +7 -0 lines
Diff to previous 1.468
Revision 1.468 - (view) (download) (annotate) - [select for diffs]
Wed Oct 30 02:56:52 2024 UTC (12 months, 2 weeks ago) by greg
Changes since 1.467: +6 -0 lines
Diff to previous 1.467
docs: Added note about new rcontrib C++ class and rxcontrib tool
Revision 1.467 - (view) (download) (annotate) - [select for diffs]
Wed Oct 9 21:10:54 2024 UTC (13 months, 1 week ago) by greg
Changes since 1.466: +3 -0 lines
Diff to previous 1.466
feat(genssky): Taoning added -L option to specify illuminance
Revision 1.466 - (view) (download) (annotate) - [select for diffs]
Mon Oct 7 18:09:29 2024 UTC (13 months, 1 week ago) by greg
Changes since 1.465: +13 -16 lines
Diff to previous 1.465
docs: Consolidated some changes for readability
Revision 1.465 - (view) (download) (annotate) - [select for diffs]
Fri Oct 4 18:49:06 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 1.464: +4 -0 lines
Diff to previous 1.464
feat(ra_tiff): Added conversion of hyperspectral Radiance pictures on input
Revision 1.464 - (view) (download) (annotate) - [select for diffs]
Fri Oct 4 01:53:45 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 1.463: +3 -0 lines
Diff to previous 1.463
feat(ra_ps): Added conversion of hyperspectral pictures on input
Revision 1.463 - (view) (download) (annotate) - [select for diffs]
Wed Oct 2 15:58:56 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 1.462: +3 -0 lines
Diff to previous 1.462
feat(normtiff): Added ability to ingest hyperspectral radiance pictures
Revision 1.462 - (view) (download) (annotate) - [select for diffs]
Tue Oct 1 01:16:26 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 1.461: +4 -0 lines
Diff to previous 1.461
feat(ra_xyze): added accurate conversion of hyperspectral pictures on input
Revision 1.461 - (view) (download) (annotate) - [select for diffs]
Fri Sep 20 17:39:12 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 1.460: +3 -0 lines
Diff to previous 1.460
feat(pextrem): Added handling of hyperspectral pictures
Revision 1.460 - (view) (download) (annotate) - [select for diffs]
Wed Sep 18 19:52:35 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 1.459: +4 -0 lines
Diff to previous 1.459
fix(rtrace,rpict,rvu,rcontrib): David G-M found overestimation bug in BSDF's
Revision 1.459 - (view) (download) (annotate) - [select for diffs]
Mon Sep 16 23:52:18 2024 UTC (14 months ago) by greg
Changes since 1.458: +6 -0 lines
Diff to previous 1.458
feat(rxpiece): Added new rxpiece tiled rendering tool
Revision 1.458 - (view) (download) (annotate) - [select for diffs]
Wed Sep 11 18:56:11 2024 UTC (14 months ago) by greg
Changes since 1.457: +2 -1 lines
Diff to previous 1.457
feat(pcond,pvalue): Added hyperspectral input handling
Revision 1.457 - (view) (download) (annotate) - [select for diffs]
Tue Sep 10 20:24:42 2024 UTC (14 months, 1 week ago) by greg
Changes since 1.456: +4 -0 lines
Diff to previous 1.456
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Revision 1.456 - (view) (download) (annotate) - [select for diffs]
Wed Aug 14 20:05:23 2024 UTC (15 months ago) by greg
Changes since 1.455: +3 -0 lines
Diff to previous 1.455
Revision 1.455 - (view) (download) (annotate) - [select for diffs]
Wed Aug 7 18:42:56 2024 UTC (15 months, 1 week ago) by greg
Changes since 1.454: +4 -0 lines
Diff to previous 1.454
fix(rpict,rtrace,rcontrib,rfluxmtx,rtpict): Bug in distant source sampling introduced in August 2022, reported by Mik DiPompeo of LightStanza
Revision 1.454 - (view) (download) (annotate) - [select for diffs]
Fri Aug 2 18:47:25 2024 UTC (15 months, 2 weeks ago) by greg
Changes since 1.453: +3 -0 lines
Diff to previous 1.453
feat(gensdaymtx,epw2wea,genssky): Taoning added new gensdaymtx and updated others
Revision 1.453 - (view) (download) (annotate) - [select for diffs]
Fri Jul 5 18:04:36 2024 UTC (16 months, 1 week ago) by greg
Changes since 1.452: +3 -0 lines
Diff to previous 1.452
feat(genssky): Taoning Wang added utility for generating spectral skies
Revision 1.452 - (view) (download) (annotate) - [select for diffs]
Fri Jun 7 18:19:22 2024 UTC (17 months, 1 week ago) by greg
Changes since 1.451: +3 -0 lines
Diff to previous 1.451
feature(rsplit,rlam): Modified to allow any number of files up to system limit
Revision 1.451 - (view) (download) (annotate) - [select for diffs]
Mon May 20 23:21:28 2024 UTC (17 months, 4 weeks ago) by greg
Changes since 1.450: +2 -0 lines
Diff to previous 1.450
Revision 1.450 - (view) (download) (annotate) - [select for diffs]
Fri May 17 20:50:57 2024 UTC (18 months ago) by greg
Changes since 1.449: +2 -0 lines
Diff to previous 1.449
feat(rcrop): Negative counts for #rows or #columns cut from the ends
Revision 1.449 - (view) (download) (annotate) - [select for diffs]
Fri Apr 26 23:10:59 2024 UTC (18 months, 3 weeks ago) by greg
Changes since 1.448: +3 -0 lines
Diff to previous 1.448
fix(gendaymtx): Added -i option and improved consistency with gendaylit, thanks to Yongqing
Revision 1.448 - (view) (download) (annotate) - [select for diffs]
Tue Apr 16 23:36:58 2024 UTC (19 months ago) by greg
Changes since 1.447: +4 -0 lines
Diff to previous 1.447
perf: Improved ambient super-sampling error estimation
Revision 1.447 - (view) (download) (annotate) - [select for diffs]
Fri Feb 23 03:47:57 2024 UTC (20 months, 3 weeks ago) by greg
Changes since 1.446: +3 -0 lines
Diff to previous 1.446
Revision 1.446 - (view) (download) (annotate) - [select for diffs]
Thu Feb 8 02:26:01 2024 UTC (21 months, 1 week ago) by greg
Changes since 1.445: +5 -0 lines
Diff to previous 1.445
Revision 1.445 - (view) (download) (annotate) - [select for diffs]
Thu Jan 25 19:25:50 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 1.444: +3 -0 lines
Diff to previous 1.444
feat(rcollate): Made -fbN where N>1 to specify exact input record size
Revision 1.444 - (view) (download) (annotate) - [select for diffs]
Wed Jan 17 00:43:45 2024 UTC (22 months ago) by greg
Changes since 1.443: +2 -1 lines
Diff to previous 1.443
feat(mgf2rad): Made spectra conversion optional with -s command-line flag
Revision 1.443 - (view) (download) (annotate) - [select for diffs]
Fri Jan 5 18:23:53 2024 UTC (22 months, 1 week ago) by greg
Changes since 1.442: +2 -0 lines
Diff to previous 1.442
feat(rcode2bmp): Added support for hyperspectral images
Revision 1.442 - (view) (download) (annotate) - [select for diffs]
Thu Jan 4 01:55:42 2024 UTC (22 months, 2 weeks ago) by greg
Changes since 1.441: +5 -3 lines
Diff to previous 1.441
feat(mgf2rad): Now handles spectral color translation
Revision 1.441 - (view) (download) (annotate) - [select for diffs]
Sat Dec 16 03:30:35 2023 UTC (23 months ago) by greg
Changes since 1.440: +4 -0 lines
Diff to previous 1.440
feat(rsensor): Supports n-channel color output for multispectral calcs
Revision 1.440 - (view) (download) (annotate) - [select for diffs]
Thu Dec 14 00:57:05 2023 UTC (23 months ago) by greg
Changes since 1.439: +4 -0 lines
Diff to previous 1.439
test: Added test cases for new "specdata" and "specpict" primitives
Revision 1.439 - (view) (download) (annotate) - [select for diffs]
Tue Dec 12 16:31:45 2023 UTC (23 months, 1 week ago) by greg
Changes since 1.438: +1 -1 lines
Diff to previous 1.438
Revision 1.438 - (view) (download) (annotate) - [select for diffs]
Mon Dec 11 19:21:43 2023 UTC (23 months, 1 week ago) by greg
Changes since 1.437: +3 -0 lines
Diff to previous 1.437
feat(rtpict): Added -co+ option support for hyperspectral image output
Revision 1.437 - (view) (download) (annotate) - [select for diffs]
Sat Dec 9 23:46:51 2023 UTC (23 months, 1 week ago) by greg
Changes since 1.436: +3 -0 lines
Diff to previous 1.436
feat(pcomb): Added support for 1- and 3-component float matrix i/o
Revision 1.436 - (view) (download) (annotate) - [select for diffs]
Fri Dec 8 17:56:26 2023 UTC (23 months, 1 week ago) by greg
Changes since 1.435: +2 -0 lines
Diff to previous 1.435
feat(pfilt): Added support for hyperspectral image filtering
Revision 1.435 - (view) (download) (annotate) - [select for diffs]
Wed Dec 6 01:27:00 2023 UTC (23 months, 1 week ago) by greg
Changes since 1.434: +12 -0 lines
Diff to previous 1.434
docs(rmtxcomb): Added man page for new rmtxcomb tool
Revision 1.434 - (view) (download) (annotate) - [select for diffs]
Sat Dec 2 00:42:21 2023 UTC (23 months, 2 weeks ago) by greg
Changes since 1.433: +8 -2 lines
Diff to previous 1.433
feat(rmtxop): Added -c _file_ and -C options for specifying color spaces
Revision 1.433 - (view) (download) (annotate) - [select for diffs]
Mon Nov 27 22:04:45 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 1.432: +2 -0 lines
Diff to previous 1.432
feat(rmtxop): Added symbolic transforms to -c option and made -s apply after any such transform, so both may be used simultaneously
Revision 1.432 - (view) (download) (annotate) - [select for diffs]
Tue Nov 21 19:22:38 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 1.431: +1 -1 lines
Diff to previous 1.431
feat(radcompare): Added ability to compare spectral images (untested)
Revision 1.431 - (view) (download) (annotate) - [select for diffs]
Tue Nov 21 02:06:14 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 1.430: +1 -0 lines
Diff to previous 1.430
feat(rcrop): Added spectral picture support
Revision 1.430 - (view) (download) (annotate) - [select for diffs]
Tue Nov 21 01:36:32 2023 UTC (23 months, 4 weeks ago) by greg
Changes since 1.429: +3 -0 lines
Diff to previous 1.429
docs: Noting new rmtxop functionality wrt. spectral pictures
Revision 1.429 - (view) (download) (annotate) - [select for diffs]
Fri Nov 17 20:02:07 2023 UTC (2 years ago) by greg
Changes since 1.428: +8 -0 lines
Diff to previous 1.428
Revision 1.428 - (view) (download) (annotate) - [select for diffs]
Wed Nov 15 18:02:52 2023 UTC (2 years ago) by greg
Changes since 1.427: +19 -0 lines
Diff to previous 1.427
Revision 1.427 - (view) (download) (annotate) - [select for diffs]
Tue Sep 12 17:08:38 2023 UTC (2 years, 2 months ago) by greg
Changes since 1.426: +3 -0 lines
Diff to previous 1.426
fix(bsdf2ttree): made reciprocity averaging default to "off"
Revision 1.426 - (view) (download) (annotate) - [select for diffs]
Fri Mar 17 20:43:16 2023 UTC (2 years, 8 months ago) by greg
Changes since 1.425: +3 -0 lines
Diff to previous 1.425
feat: Increased object and octree size limits
Revision 1.425 - (view) (download) (annotate) - [select for diffs]
Thu Mar 16 00:25:24 2023 UTC (2 years, 8 months ago) by greg
Changes since 1.424: +8 -0 lines
Diff to previous 1.424
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Revision 1.424 - (view) (download) (annotate) - [select for diffs]
Wed Nov 16 00:12:49 2022 UTC (3 years ago) by greg
Changes since 1.423: +4 -0 lines
Diff to previous 1.423
feat(rhcopy): Added -i* and -o* options for reading and writing rays
Revision 1.423 - (view) (download) (annotate) - [select for diffs]
Sat Nov 12 20:51:47 2022 UTC (3 years ago) by greg
Changes since 1.422: +3 -0 lines
Diff to previous 1.422
feat(falsecolor): Added -odim option for value matrix overlay
Revision 1.422 - (view) (download) (annotate) - [select for diffs]
Wed Oct 19 21:25:20 2022 UTC (3 years, 1 month ago) by greg
Changes since 1.421: +7 -0 lines
Diff to previous 1.421
Revision 1.421 - (view) (download) (annotate) - [select for diffs]
Sun Aug 21 16:20:42 2022 UTC (3 years, 2 months ago) by greg
Changes since 1.420: +5 -0 lines
Diff to previous 1.420
docs: Updated license and copyright using verbiage from LBNL's IPO
Revision 1.420 - (view) (download) (annotate) - [select for diffs]
Fri Aug 12 23:55:00 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.419: +7 -0 lines
Diff to previous 1.419
fix(iso2klems): used solid angle, when projected SA needed, and integral factor
Revision 1.419 - (view) (download) (annotate) - [select for diffs]
Thu Aug 11 15:09:13 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.418: +4 -0 lines
Diff to previous 1.418
fix: Keeping better track of which sources were visible with shadow cache
Revision 1.418 - (view) (download) (annotate) - [select for diffs]
Wed Aug 10 20:45:09 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.417: +2 -0 lines
Diff to previous 1.417
perf: Increased maximum set size to 8191 to avoid set overflow errors
Revision 1.417 - (view) (download) (annotate) - [select for diffs]
Thu Aug 4 22:43:46 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.416: +4 -0 lines
Diff to previous 1.416
fix: reduced aiming failures for triangular light sources
Revision 1.416 - (view) (download) (annotate) - [select for diffs]
Thu Jul 14 02:52:02 2022 UTC (3 years, 4 months ago) by greg
Changes since 1.415: +3 -0 lines
Diff to previous 1.415
fix: updated and corrected Klems half and quarter bases to match WINDOW
Revision 1.415 - (view) (download) (annotate) - [select for diffs]
Tue Apr 26 03:00:02 2022 UTC (3 years, 6 months ago) by greg
Changes since 1.414: +6 -0 lines
Diff to previous 1.414
docs: Recent bug-fix that turns out to be more important than first thought
Revision 1.414 - (view) (download) (annotate) - [select for diffs]
Mon Apr 11 18:08:19 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.413: +2 -0 lines
Diff to previous 1.413
feat(cnt): Added -s option to shuffle output
Revision 1.413 - (view) (download) (annotate) - [select for diffs]
Mon Apr 11 04:03:36 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.412: +2 -2 lines
Diff to previous 1.412
perf(rtpict): Improved random sampling to avoid ambient cache collisions
Revision 1.412 - (view) (download) (annotate) - [select for diffs]
Sun Apr 10 03:46:27 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.411: +4 -0 lines
Diff to previous 1.411
perf(rtpict): Added overture calculation with ambient cache and -n > 1
Revision 1.411 - (view) (download) (annotate) - [select for diffs]
Sat Apr 9 17:18:08 2022 UTC (3 years, 7 months ago) by greg
Changes since 1.410: +3 -0 lines
Diff to previous 1.410
fix(vwrays): No longer spits out -ld- with -d option, only -ld+
Revision 1.410 - (view) (download) (annotate) - [select for diffs]
Mon Mar 21 00:21:13 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.409: +3 -0 lines
Diff to previous 1.409
feat(getinfo): Added getinfo -r option (similar to -a but with remove/replace)
Revision 1.409 - (view) (download) (annotate) - [select for diffs]
Fri Mar 18 18:31:47 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.408: +3 -0 lines
Diff to previous 1.408
fix(pcomb): Changed behavior to elide exposure from indented header for evalglare
Revision 1.408 - (view) (download) (annotate) - [select for diffs]
Tue Mar 15 00:25:50 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.407: +4 -0 lines
Diff to previous 1.407
feat(rcrop): Created simple cropping utility for matrices and pictures
Revision 1.407 - (view) (download) (annotate) - [select for diffs]
Fri Mar 11 22:50:13 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.406: +2 -0 lines
Diff to previous 1.406
feat(rcalc): Added -P option to pass records where cond evaluates <= 0
Revision 1.406 - (view) (download) (annotate) - [select for diffs]
Fri Mar 11 02:27:02 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.405: +3 -0 lines
Diff to previous 1.405
feat(dctimestep): Added -x and -y options to specify picture output dimensions
Revision 1.405 - (view) (download) (annotate) - [select for diffs]
Tue Mar 8 22:27:56 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.404: +3 -0 lines
Diff to previous 1.404
fix(rpict,rvu,rtrace,rcontrib): Eliminated over-counting of diffuse for aBSDF's
Revision 1.404 - (view) (download) (annotate) - [select for diffs]
Tue Mar 8 19:04:56 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.403: +3 -0 lines
Diff to previous 1.403
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
Revision 1.403 - (view) (download) (annotate) - [select for diffs]
Mon Mar 7 17:55:09 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.402: +6 -0 lines
Diff to previous 1.402
docs: Added remark about ambient value sorting removal
Revision 1.402 - (view) (download) (annotate) - [select for diffs]
Fri Mar 4 01:28:51 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.401: +4 -0 lines
Diff to previous 1.401
perf(rmtxop): Added memory-mapping for double matrices
Revision 1.401 - (view) (download) (annotate) - [select for diffs]
Fri Feb 4 20:11:49 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.400: +3 -0 lines
Diff to previous 1.400
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
Revision 1.400 - (view) (download) (annotate) - [select for diffs]
Tue Dec 14 02:33:18 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.399: +3 -0 lines
Diff to previous 1.399
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
Revision 1.399 - (view) (download) (annotate) - [select for diffs]
Tue Dec 7 23:49:50 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.398: +4 -0 lines
Diff to previous 1.398
Revision 1.398 - (view) (download) (annotate) - [select for diffs]
Sat Dec 4 16:29:29 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.397: +5 -0 lines
Diff to previous 1.397
feat(vwrays,rtpict): Added support for -pd option to sample depth-of-field
Revision 1.397 - (view) (download) (annotate) - [select for diffs]
Mon Nov 29 16:07:36 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.396: +30 -0 lines
Diff to previous 1.396
feat(ies2rad): changes and enhancements to ies2rad by Randolph Fritz
Revision 1.396 - (view) (download) (annotate) - [select for diffs]
Thu Nov 18 19:38:20 2021 UTC (4 years ago) by greg
Changes since 1.395: +6 -0 lines
Diff to previous 1.395
perf(rpict, rtrace, rvu): improved function of -aw rendering parameter
Revision 1.395 - (view) (download) (annotate) - [select for diffs]
Tue Nov 16 03:30:45 2021 UTC (4 years ago) by greg
Changes since 1.394: +9 -0 lines
Diff to previous 1.394
feat(total): added automatic output flushing unless -r option is present
Revision 1.394 - (view) (download) (annotate) - [select for diffs]
Thu Sep 2 16:11:24 2021 UTC (4 years, 2 months ago) by greg
Changes since 1.393: +3 -0 lines
Diff to previous 1.393
feat(pcompos): added exposure preservation when possible
Revision 1.393 - (view) (download) (annotate) - [select for diffs]
Thu Apr 15 23:51:04 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.392: +5 -1 lines
Diff to previous 1.392
Revision 1.392 - (view) (download) (annotate) - [select for diffs]
Fri Apr 9 01:48:20 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.391: +3 -0 lines
Diff to previous 1.391
feat(genbox): Added polygonal modeling of rounded edges and -o option for .OBJ
Revision 1.391 - (view) (download) (annotate) - [select for diffs]
Wed Apr 7 21:13:52 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.390: +2 -0 lines
Diff to previous 1.390
perf: changed default dynamic range from 32 to 100 to reflect modern displays
Revision 1.390 - (view) (download) (annotate) - [select for diffs]
Mon Apr 5 19:56:18 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.389: +3 -0 lines
Diff to previous 1.389
feat(pabopto2bsdf): Added -g option to cull grazing measurements from input
Revision 1.389 - (view) (download) (annotate) - [select for diffs]
Sat Mar 27 17:50:18 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.388: +4 -0 lines
Diff to previous 1.388
Revision 1.388 - (view) (download) (annotate) - [select for diffs]
Fri Mar 12 18:32:33 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.387: +2 -0 lines
Diff to previous 1.387
Added +T option to triangulate all faces with 4 or more sides
Revision 1.387 - (view) (download) (annotate) - [select for diffs]
Fri Feb 19 22:05:46 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.386: +3 -0 lines
Diff to previous 1.386
perf: put maximum cap on gradient values to avoid over-extrapolation
Revision 1.386 - (view) (download) (annotate) - [select for diffs]
Tue Feb 16 20:06:06 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.385: +2 -0 lines
Diff to previous 1.385
feat: removed upper limit on number of modifiers in rcontrib
Revision 1.385 - (view) (download) (annotate) - [select for diffs]
Mon Feb 15 23:24:01 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.384: +3 -2 lines
Diff to previous 1.384
docs: small typo
Revision 1.384 - (view) (download) (annotate) - [select for diffs]
Mon Feb 15 23:22:50 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.383: +5 -0 lines
Diff to previous 1.383
feat: Added "up" symmetry for duplicating data @ phi += 180 degrees
Revision 1.383 - (view) (download) (annotate) - [select for diffs]
Fri Feb 12 01:04:39 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.382: +4 -0 lines
Diff to previous 1.382
fix: Added explicit edge tests to eliminate light leaks at corners
Revision 1.382 - (view) (download) (annotate) - [select for diffs]
Sun Jan 31 18:08:04 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.381: +8 -0 lines
Diff to previous 1.381
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Revision 1.381 - (view) (download) (annotate) - [select for diffs]
Tue Jan 19 23:32:00 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.380: +5 -1 lines
Diff to previous 1.380
Revision 1.380 - (view) (download) (annotate) - [select for diffs]
Fri Jan 15 23:16:06 2021 UTC (4 years, 10 months ago) by greg
Changes since 1.379: +2 -0 lines
Diff to previous 1.379
fix: fixed 64-bit addressing issues in some tools
Revision 1.379 - (view) (download) (annotate) - [select for diffs]
Fri Nov 13 19:21:11 2020 UTC (5 years ago) by greg
Changes since 1.378: +2 -0 lines
Diff to previous 1.378
feat(bsdf2ttree): made it so options/parameters may differ per input SIR
Revision 1.378 - (view) (download) (annotate) - [select for diffs]
Fri Sep 11 22:26:33 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.377: +2 -0 lines
Diff to previous 1.377
chore(makeall): Added "makeall test" to run unit tests and report success
Revision 1.377 - (view) (download) (annotate) - [select for diffs]
Wed Sep 9 21:28:19 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.376: +3 -0 lines
Diff to previous 1.376
Revision 1.376 - (view) (download) (annotate) - [select for diffs]
Mon Sep 7 17:08:08 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.375: +3 -0 lines
Diff to previous 1.375
feat(rcollate): Added -c option to force operation with checks.
Revision 1.375 - (view) (download) (annotate) - [select for diffs]
Thu Sep 3 15:46:32 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.374: +4 -1 lines
Diff to previous 1.374
chore: follow-up to official 5.3 release, working on 5.4 alpha now...
Revision 1.374 - (view) (download) (annotate) - [select for diffs]
Sat Aug 15 03:28:56 2020 UTC (5 years, 3 months ago) by greg
Changes since 1.373: +3 -0 lines
Diff to previous 1.373
feat(gendaymtx): added -u option for daylight hours only
Revision 1.373 - (view) (download) (annotate) - [select for diffs]
Tue Jun 30 15:52:48 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.372: +2 -0 lines
Diff to previous 1.372
docs(evalglare): new version from Jan Wienold
Revision 1.372 - (view) (download) (annotate) - [select for diffs]
Thu Jun 4 15:15:07 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.371: +9 -4 lines
Diff to previous 1.371
Updates and corrections
Revision 1.371 - (view) (download) (annotate) - [select for diffs]
Mon May 18 20:08:57 2020 UTC (5 years, 6 months ago) by greg
Changes since 1.370: +3 -0 lines
Diff to previous 1.370
Added -n and -s options to bsdf2ttree to control super-sampling
Revision 1.370 - (view) (download) (annotate) - [select for diffs]
Fri May 15 19:10:21 2020 UTC (5 years, 6 months ago) by greg
Changes since 1.369: +4 -0 lines
Diff to previous 1.369
Added memory cache limit for BSDFs
Revision 1.369 - (view) (download) (annotate) - [select for diffs]
Wed May 6 14:14:57 2020 UTC (5 years, 6 months ago) by greg
Changes since 1.368: +3 -0 lines
Diff to previous 1.368
Updates regarding bsdf2ttree
Revision 1.368 - (view) (download) (annotate) - [select for diffs]
Mon Apr 13 17:12:19 2020 UTC (5 years, 7 months ago) by greg
Changes since 1.367: +3 -1 lines
Diff to previous 1.367
Updates to gendaymtx requested by Ladybug Tools
Revision 1.367 - (view) (download) (annotate) - [select for diffs]
Mon Apr 6 21:13:33 2020 UTC (5 years, 7 months ago) by greg
Changes since 1.366: +9 -0 lines
Diff to previous 1.366
Added mention of recent changes to rtrace (mostly)
Revision 1.366 - (view) (download) (annotate) - [select for diffs]
Mon Mar 30 18:28:35 2020 UTC (5 years, 7 months ago) by greg
Changes since 1.365: +2 -0 lines
Diff to previous 1.365
Revision 1.365 - (view) (download) (annotate) - [select for diffs]
Wed Mar 25 01:51:09 2020 UTC (5 years, 7 months ago) by greg
Changes since 1.364: +3 -0 lines
Diff to previous 1.364
Revision 1.364 - (view) (download) (annotate) - [select for diffs]
Mon Feb 17 19:19:45 2020 UTC (5 years, 9 months ago) by greg
Changes since 1.363: +2 -0 lines
Diff to previous 1.363
Hopeful fix to dgi calculation issues
Revision 1.363 - (view) (download) (annotate) - [select for diffs]
Mon Jan 20 17:53:40 2020 UTC (5 years, 9 months ago) by greg
Changes since 1.362: +2 -0 lines
Diff to previous 1.362
Updated eplus_adduvf to work with version 9.x
Revision 1.362 - (view) (download) (annotate) - [select for diffs]
Tue Jan 7 01:42:30 2020 UTC (5 years, 10 months ago) by greg
Changes since 1.361: +3 -0 lines
Diff to previous 1.361
Added -n and -D options to gendaymtx
Revision 1.361 - (view) (download) (annotate) - [select for diffs]
Sat Dec 7 02:21:42 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.360: +3 -0 lines
Diff to previous 1.360
Changed gen{worm,surf,rev} to accept expressions for number of segments
Revision 1.360 - (view) (download) (annotate) - [select for diffs]
Fri Nov 8 02:10:38 2019 UTC (6 years ago) by greg
Changes since 1.359: +2 -0 lines
Diff to previous 1.359
Added capability to rcollate for reblocking input order for tensors
Revision 1.359 - (view) (download) (annotate) - [select for diffs]
Thu Nov 7 23:20:28 2019 UTC (6 years ago) by greg
Changes since 1.358: +8 -0 lines
Diff to previous 1.358
Revision 1.358 - (view) (download) (annotate) - [select for diffs]
Wed Oct 23 17:00:14 2019 UTC (6 years ago) by greg
Changes since 1.357: +4 -1 lines
Diff to previous 1.357
Revision 1.357 - (view) (download) (annotate) - [select for diffs]
Mon Sep 9 17:19:51 2019 UTC (6 years, 2 months ago) by greg
Changes since 1.356: +4 -0 lines
Diff to previous 1.356
Revision 1.356 - (view) (download) (annotate) - [select for diffs]
Sun Aug 25 22:24:01 2019 UTC (6 years, 2 months ago) by greg
Changes since 1.355: +2 -0 lines
Diff to previous 1.355
Added "tbo" color map thanks to Taoning
Revision 1.355 - (view) (download) (annotate) - [select for diffs]
Wed Aug 14 18:20:02 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.354: +4 -0 lines
Diff to previous 1.354
Revision 1.354 - (view) (download) (annotate) - [select for diffs]
Wed Aug 14 04:18:12 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.353: +2 -0 lines
Diff to previous 1.353
Revision 1.353 - (view) (download) (annotate) - [select for diffs]
Mon Aug 12 23:17:04 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.352: +8 -4 lines
Diff to previous 1.352
Fixed a few comments
Revision 1.352 - (view) (download) (annotate) - [select for diffs]
Mon Aug 12 02:26:46 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.351: +2 -1 lines
Diff to previous 1.351
Revision 1.351 - (view) (download) (annotate) - [select for diffs]
Mon Aug 12 01:20:25 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.350: +4 -0 lines
Diff to previous 1.350
Revision 1.350 - (view) (download) (annotate) - [select for diffs]
Fri Jul 26 00:34:06 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.349: +2 -0 lines
Diff to previous 1.349
Revision 1.349 - (view) (download) (annotate) - [select for diffs]
Tue Jul 23 18:17:54 2019 UTC (6 years, 3 months ago) by greg
Changes since 1.348: +3 -0 lines
Diff to previous 1.348
Added -o* option to rtpict
Revision 1.348 - (view) (download) (annotate) - [select for diffs]
Fri Jul 19 22:25:03 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.347: +4 -1 lines
Diff to previous 1.347
Revision 1.347 - (view) (download) (annotate) - [select for diffs]
Fri Jul 19 02:18:44 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.346: +4 -0 lines
Diff to previous 1.346
Revision 1.346 - (view) (download) (annotate) - [select for diffs]
Thu Jul 18 18:51:56 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.345: +5 -0 lines
Diff to previous 1.345
Revision 1.345 - (view) (download) (annotate) - [select for diffs]
Mon Jul 15 23:42:44 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.344: +2 -1 lines
Diff to previous 1.344
Allow skipping header bytes on standard input and more logical binary mode
Revision 1.344 - (view) (download) (annotate) - [select for diffs]
Mon Jul 15 22:39:50 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.343: +2 -0 lines
Diff to previous 1.343
Made pvalue -u option mean "uncompressed" with -r.
Revision 1.343 - (view) (download) (annotate) - [select for diffs]
Sat Jul 6 14:08:07 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.342: +3 -0 lines
Diff to previous 1.342
Made getinfo -d option useful for header-skip ('-') and command ('-c') options
Revision 1.342 - (view) (download) (annotate) - [select for diffs]
Fri Jul 5 00:20:57 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.341: +3 -0 lines
Diff to previous 1.341
Revision 1.341 - (view) (download) (annotate) - [select for diffs]
Thu Jul 4 17:36:04 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.340: +4 -0 lines
Diff to previous 1.340
Changed rlam -iaN behavior to read N lines rather than N characters
Revision 1.340 - (view) (download) (annotate) - [select for diffs]
Thu Jul 4 01:25:07 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.339: +1 -1 lines
Diff to previous 1.339
More warnings and correction because -oW and -oV are useless options
Revision 1.339 - (view) (download) (annotate) - [select for diffs]
Thu Jul 4 01:07:25 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.338: +2 -0 lines
Diff to previous 1.338
Made -f?c RGBE output compatible with any of 'vVWrx' options and added warning
Revision 1.338 - (view) (download) (annotate) - [select for diffs]
Tue Jun 25 00:09:45 2019 UTC (6 years, 4 months ago) by greg
Changes since 1.337: +3 -0 lines
Diff to previous 1.337
Added gendaymtx -A option to efficiently compute average skies
Revision 1.337 - (view) (download) (annotate) - [select for diffs]
Tue Jun 18 00:00:35 2019 UTC (6 years, 5 months ago) by greg
Changes since 1.336: +4 -0 lines
Diff to previous 1.336
Added incident patch sampling to bsdf2klems when given SIR input
Revision 1.336 - (view) (download) (annotate) - [select for diffs]
Mon Jun 10 13:56:52 2019 UTC (6 years, 5 months ago) by greg
Changes since 1.335: +2 -0 lines
Diff to previous 1.335
Revision 1.335 - (view) (download) (annotate) - [select for diffs]
Sun Jun 9 20:58:26 2019 UTC (6 years, 5 months ago) by greg
Changes since 1.334: +4 -0 lines
Diff to previous 1.334
Added out-of-plane sampling to genBSDF for isotropic tensor trees
Revision 1.334 - (view) (download) (annotate) - [select for diffs]
Tue Mar 19 22:03:24 2019 UTC (6 years, 8 months ago) by greg
Changes since 1.333: +2 -0 lines
Diff to previous 1.333
Increased default -n option to 1024 (was 256)
Revision 1.333 - (view) (download) (annotate) - [select for diffs]
Fri Mar 1 01:00:03 2019 UTC (6 years, 8 months ago) by greg
Changes since 1.332: +3 -0 lines
Diff to previous 1.332
Changed output numbering to start from 0 for consistency with input
Revision 1.332 - (view) (download) (annotate) - [select for diffs]
Fri Nov 23 19:32:17 2018 UTC (6 years, 11 months ago) by greg
Changes since 1.331: +2 -0 lines
Diff to previous 1.331
Bug fixes and man page updates from Jan Wienold
Revision 1.331 - (view) (download) (annotate) - [select for diffs]
Tue Nov 13 19:58:33 2018 UTC (7 years ago) by greg
Changes since 1.330: +4 -0 lines
Diff to previous 1.330
Revision 1.330 - (view) (download) (annotate) - [select for diffs]
Thu Nov 8 00:54:07 2018 UTC (7 years ago) by greg
Changes since 1.329: +2 -0 lines
Diff to previous 1.329
Revision 1.329 - (view) (download) (annotate) - [select for diffs]
Thu Oct 18 23:00:38 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.328: +2 -0 lines
Diff to previous 1.328
Fixed issue with rcollate
Revision 1.328 - (view) (download) (annotate) - [select for diffs]
Mon Oct 15 17:52:52 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.327: +3 -0 lines
Diff to previous 1.327
Revision 1.327 - (view) (download) (annotate) - [select for diffs]
Tue Oct 9 17:57:17 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.326: +3 -0 lines
Diff to previous 1.326
Moving on to version 5.3a
Revision 1.326 - (view) (download) (annotate) - [select for diffs]
Mon Oct 8 20:04:09 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.325: +1 -1 lines
Diff to previous 1.325
Preparation for 5.2 release
Revision 1.325 - (view) (download) (annotate) - [select for diffs]
Sat Sep 1 16:42:39 2018 UTC (7 years, 2 months ago) by greg
Changes since 1.324: +3 -0 lines
Diff to previous 1.324
Added missing file from last commit
Revision 1.324 - (view) (download) (annotate) - [select for diffs]
Thu Jul 26 23:50:40 2018 UTC (7 years, 3 months ago) by greg
Changes since 1.323: +3 -0 lines
Diff to previous 1.323
Fixed issue with pfilt -m option and non-integer size divisors
Revision 1.323 - (view) (download) (annotate) - [select for diffs]
Fri Jul 20 00:50:40 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.322: +3 -0 lines
Diff to previous 1.322
Added "-r" option to bsdf2rad and bsdfview to fix plotting range
Revision 1.322 - (view) (download) (annotate) - [select for diffs]
Tue Jun 26 14:42:18 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.321: +1 -1 lines
Diff to previous 1.321
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Revision 1.321 - (view) (download) (annotate) - [select for diffs]
Mon Jun 25 20:49:10 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.320: +6 -0 lines
Diff to previous 1.320
Revision 1.320 - (view) (download) (annotate) - [select for diffs]
Wed Jun 13 21:23:45 2018 UTC (7 years, 5 months ago) by greg
Changes since 1.319: +3 -0 lines
Diff to previous 1.319
Fixed bug in rcontrib with virtual sources
Revision 1.319 - (view) (download) (annotate) - [select for diffs]
Thu Jun 7 15:39:35 2018 UTC (7 years, 5 months ago) by greg
Changes since 1.318: +6 -0 lines
Diff to previous 1.318
Resurrected original bsdf2rad utility (optional build)
Revision 1.318 - (view) (download) (annotate) - [select for diffs]
Fri May 4 23:56:49 2018 UTC (7 years, 6 months ago) by greg
Changes since 1.317: +4 -0 lines
Diff to previous 1.317
Revision 1.317 - (view) (download) (annotate) - [select for diffs]
Tue Apr 17 18:11:16 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.316: +2 -0 lines
Diff to previous 1.316
Revision 1.316 - (view) (download) (annotate) - [select for diffs]
Sat Apr 14 17:45:42 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.315: +7 -3 lines
Diff to previous 1.315
Updated ambient super-sampling variance estimator to reduce bias
Revision 1.315 - (view) (download) (annotate) - [select for diffs]
Fri Mar 30 23:14:07 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.314: +4 -0 lines
Diff to previous 1.314
Added single-argument mode to John M's "origin" command in rvu
Revision 1.314 - (view) (download) (annotate) - [select for diffs]
Mon Mar 19 23:40:33 2018 UTC (7 years, 8 months ago) by greg
Changes since 1.313: +2 -0 lines
Diff to previous 1.313
Revision 1.313 - (view) (download) (annotate) - [select for diffs]
Mon Feb 5 20:07:17 2018 UTC (7 years, 9 months ago) by greg
Changes since 1.312: +2 -0 lines
Diff to previous 1.312
Decided to share first input view in the output of pcomb
Revision 1.312 - (view) (download) (annotate) - [select for diffs]
Mon Jan 8 16:51:31 2018 UTC (7 years, 10 months ago) by greg
Changes since 1.311: +4 -0 lines
Diff to previous 1.311
Update to CMake build system from Rob G. and Alex S., adding test cases
Revision 1.311 - (view) (download) (annotate) - [select for diffs]
Fri Jan 5 02:47:45 2018 UTC (7 years, 10 months ago) by greg
Changes since 1.310: +5 -0 lines
Diff to previous 1.310
Tweaked peak extraction code to improve results
Revision 1.310 - (view) (download) (annotate) - [select for diffs]
Sat Dec 9 20:47:33 2017 UTC (7 years, 11 months ago) by greg
Changes since 1.309: +6 -2 lines
Diff to previous 1.309
Update of recent changes
Revision 1.309 - (view) (download) (annotate) - [select for diffs]
Mon Dec 4 21:58:10 2017 UTC (7 years, 11 months ago) by greg
Changes since 1.308: +2 -0 lines
Diff to previous 1.308
Added resources/ directory as requested by Rob G. and moved cmake_tests/ there
Revision 1.308 - (view) (download) (annotate) - [select for diffs]
Thu Nov 30 23:31:34 2017 UTC (7 years, 11 months ago) by greg
Changes since 1.307: +3 -0 lines
Diff to previous 1.307
Increased the limit on open files in rcontrib from 512 to 2048 under Windows
Revision 1.307 - (view) (download) (annotate) - [select for diffs]
Thu Nov 30 18:44:13 2017 UTC (7 years, 11 months ago) by greg
Changes since 1.306: +4 -0 lines
Diff to previous 1.306
Fixed issue with missing veil from very bright sources like the sun
Revision 1.306 - (view) (download) (annotate) - [select for diffs]
Tue Nov 28 22:16:59 2017 UTC (7 years, 11 months ago) by greg
Changes since 1.305: +3 -0 lines
Diff to previous 1.305
Fixed occasional issue with zero BSDF regions
Revision 1.305 - (view) (download) (annotate) - [select for diffs]
Mon Sep 25 18:48:11 2017 UTC (8 years, 1 month ago) by greg
Changes since 1.304: +2 -0 lines
Diff to previous 1.304
Improvements to falsecolor legend by David G-M and Stephen W
Revision 1.304 - (view) (download) (annotate) - [select for diffs]
Tue Sep 5 22:42:52 2017 UTC (8 years, 2 months ago) by greg
Changes since 1.303: +2 -0 lines
Diff to previous 1.303
Altered falsecolor behavior to match given scale (-s) value in legend
Revision 1.303 - (view) (download) (annotate) - [select for diffs]
Mon Aug 28 15:59:46 2017 UTC (8 years, 2 months ago) by greg
Changes since 1.302: +3 -0 lines
Diff to previous 1.302
Revision 1.302 - (view) (download) (annotate) - [select for diffs]
Sat Aug 26 16:07:22 2017 UTC (8 years, 2 months ago) by greg
Changes since 1.301: +6 -0 lines
Diff to previous 1.301
Revision 1.301 - (view) (download) (annotate) - [select for diffs]
Thu Aug 17 21:57:20 2017 UTC (8 years, 3 months ago) by greg
Changes since 1.300: +1 -1 lines
Diff to previous 1.300
Prep for 5.1 official release
Revision 1.300 - (view) (download) (annotate) - [select for diffs]
Fri Aug 11 21:39:52 2017 UTC (8 years, 3 months ago) by greg
Changes since 1.299: +3 -0 lines
Diff to previous 1.299
Revision 1.299 - (view) (download) (annotate) - [select for diffs]
Mon Jul 17 00:14:28 2017 UTC (8 years, 4 months ago) by greg
Changes since 1.298: +6 -1 lines
Diff to previous 1.298
Implemented view component for BTDFs
Revision 1.298 - (view) (download) (annotate) - [select for diffs]
Wed May 31 17:25:21 2017 UTC (8 years, 5 months ago) by greg
Changes since 1.297: +2 -0 lines
Diff to previous 1.297
Revision 1.297 - (view) (download) (annotate) - [select for diffs]
Mon May 15 22:50:33 2017 UTC (8 years, 6 months ago) by greg
Changes since 1.296: +3 -0 lines
Diff to previous 1.296
Made shadow testing work through BSDF's with through component (Thanks to David G-M)
Revision 1.296 - (view) (download) (annotate) - [select for diffs]
Sat May 13 01:50:54 2017 UTC (8 years, 6 months ago) by greg
Changes since 1.295: +2 -0 lines
Diff to previous 1.295
Fixed axis reversal in Reinhart sample generator (wrong since August 2014)
Revision 1.295 - (view) (download) (annotate) - [select for diffs]
Sun Apr 9 21:39:26 2017 UTC (8 years, 7 months ago) by greg
Changes since 1.294: +2 -0 lines
Diff to previous 1.294
Revision 1.294 - (view) (download) (annotate) - [select for diffs]
Fri Mar 3 01:25:27 2017 UTC (8 years, 8 months ago) by greg
Changes since 1.293: +2 -0 lines
Diff to previous 1.293
Added -v option to obj2mesh for reporting mesh statistics
Revision 1.293 - (view) (download) (annotate) - [select for diffs]
Wed Feb 22 03:16:20 2017 UTC (8 years, 8 months ago) by greg
Changes since 1.292: +5 -0 lines
Diff to previous 1.292
Added MAX2SHADE macro to limit precheck time for source obstructions.
Revision 1.292 - (view) (download) (annotate) - [select for diffs]
Sat Jan 14 02:07:53 2017 UTC (8 years, 10 months ago) by greg
Changes since 1.291: +3 -0 lines
Diff to previous 1.291
Added 360-degree over/under stereo view calculation file by Mark Stock
Revision 1.291 - (view) (download) (annotate) - [select for diffs]
Tue Dec 6 23:19:50 2016 UTC (8 years, 11 months ago) by greg
Changes since 1.290: +3 -0 lines
Diff to previous 1.290
Improved behavior around peaks by limiting slope of accepted smooth regions
Revision 1.290 - (view) (download) (annotate) - [select for diffs]
Wed Nov 2 22:09:14 2016 UTC (9 years ago) by greg
Changes since 1.289: +2 -0 lines
Diff to previous 1.289
Fixed bug in ranimove introduced with photon map
Revision 1.289 - (view) (download) (annotate) - [select for diffs]
Tue Nov 1 20:39:39 2016 UTC (9 years ago) by greg
Changes since 1.288: +3 -0 lines
Diff to previous 1.288
Added code to handle textures (normal perturbations) with -aa 0
Revision 1.288 - (view) (download) (annotate) - [select for diffs]
Fri Oct 14 00:57:16 2016 UTC (9 years, 1 month ago) by greg
Changes since 1.287: +5 -0 lines
Diff to previous 1.287
Fixed regression in genBSDF for Klems output
Revision 1.287 - (view) (download) (annotate) - [select for diffs]
Fri Sep 16 17:54:56 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.286: +2 -0 lines
Diff to previous 1.286
Revision 1.286 - (view) (download) (annotate) - [select for diffs]
Thu Sep 15 22:34:41 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.285: +2 -0 lines
Diff to previous 1.285
Made mkillum more forgiving of non-planar polygons
Revision 1.285 - (view) (download) (annotate) - [select for diffs]
Mon Sep 12 20:31:34 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.284: +3 -0 lines
Diff to previous 1.284
Revision 1.284 - (view) (download) (annotate) - [select for diffs]
Tue Aug 30 06:10:12 2016 UTC (9 years, 2 months ago) by greg
Changes since 1.283: +2 -0 lines
Diff to previous 1.283
Added -a option to getinfo for adding lines to header
Revision 1.283 - (view) (download) (annotate) - [select for diffs]
Thu Jul 28 16:46:10 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.282: +5 -0 lines
Diff to previous 1.282
Updated evalglare man page and small bug fix from J. Wienold
Revision 1.282 - (view) (download) (annotate) - [select for diffs]
Wed Jul 27 18:05:53 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.281: +3 -0 lines
Diff to previous 1.281
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Revision 1.281 - (view) (download) (annotate) - [select for diffs]
Wed Jul 13 00:51:17 2016 UTC (9 years, 4 months ago) by greg
Changes since 1.280: +3 -0 lines
Diff to previous 1.280
Revision 1.280 - (view) (download) (annotate) - [select for diffs]
Sun Jul 10 23:41:37 2016 UTC (9 years, 4 months ago) by greg
Changes since 1.279: +2 -0 lines
Diff to previous 1.279
Added missing definition of ashik2 material type
Revision 1.279 - (view) (download) (annotate) - [select for diffs]
Thu Apr 28 16:28:20 2016 UTC (9 years, 6 months ago) by greg
Changes since 1.278: +4 -0 lines
Diff to previous 1.278
Added listening for mouse wheel
Revision 1.278 - (view) (download) (annotate) - [select for diffs]
Thu Mar 24 18:48:28 2016 UTC (9 years, 7 months ago) by greg
Changes since 1.277: +4 -0 lines
Diff to previous 1.277
Added -in options to commands for manual EOF specification
Revision 1.277 - (view) (download) (annotate) - [select for diffs]
Tue Mar 15 20:35:41 2016 UTC (9 years, 8 months ago) by greg
Changes since 1.276: +3 -0 lines
Diff to previous 1.276
Enabled ambient cache corral at all levels
Revision 1.276 - (view) (download) (annotate) - [select for diffs]
Fri Mar 4 16:52:03 2016 UTC (9 years, 8 months ago) by greg
Changes since 1.275: +9 -0 lines
Diff to previous 1.275
Notes on recent shared memory fix
Revision 1.275 - (view) (download) (annotate) - [select for diffs]
Wed Feb 3 01:57:06 2016 UTC (9 years, 9 months ago) by greg
Changes since 1.274: +1 -0 lines
Diff to previous 1.274
Added tristimulus color support for RBF and XML input
Revision 1.274 - (view) (download) (annotate) - [select for diffs]
Tue Feb 2 22:34:00 2016 UTC (9 years, 9 months ago) by greg
Changes since 1.273: +2 -0 lines
Diff to previous 1.273
Refactored bsdf2ttree for Yuv representation
Revision 1.273 - (view) (download) (annotate) - [select for diffs]
Fri Jan 29 16:21:55 2016 UTC (9 years, 9 months ago) by greg
Changes since 1.272: +6 -0 lines
Diff to previous 1.272
Revision 1.272 - (view) (download) (annotate) - [select for diffs]
Fri Dec 4 22:16:18 2015 UTC (9 years, 11 months ago) by greg
Changes since 1.271: +2 -0 lines
Diff to previous 1.271
Added support for (quoted) output commands in rfluxmtx
Revision 1.271 - (view) (download) (annotate) - [select for diffs]
Wed Oct 14 20:51:44 2015 UTC (10 years, 1 month ago) by greg
Changes since 1.270: +3 -0 lines
Diff to previous 1.270
Fixed issue with metafile libraries
Revision 1.270 - (view) (download) (annotate) - [select for diffs]
Fri Sep 25 23:01:12 2015 UTC (10 years, 1 month ago) by greg
Changes since 1.269: +5 -2 lines
Diff to previous 1.269
Starting now on 5.1 alpha
Revision 1.269 - (view) (download) (annotate) - [select for diffs]
Fri Sep 18 18:29:00 2015 UTC (10 years, 2 months ago) by greg
Changes since 1.268: +3 -0 lines
Diff to previous 1.268
Changes for 5.0 release
Revision 1.268 - (view) (download) (annotate) - [select for diffs]
Sun Aug 23 00:17:12 2015 UTC (10 years, 2 months ago) by greg
Changes since 1.267: +2 -0 lines
Diff to previous 1.267
Minor tweaks & performance improvements for rcontrib file locking
Revision 1.267 - (view) (download) (annotate) - [select for diffs]
Wed Aug 12 23:07:59 2015 UTC (10 years, 3 months ago) by greg
Changes since 1.266: +2 -0 lines
Diff to previous 1.266
Revision 1.266 - (view) (download) (annotate) - [select for diffs]
Tue Jul 14 16:08:28 2015 UTC (10 years, 4 months ago) by greg
Changes since 1.265: +6 -0 lines
Diff to previous 1.265
Added ability for dctimestep to accept matrix files in place of XML for T
Revision 1.265 - (view) (download) (annotate) - [select for diffs]
Thu Jun 4 01:19:30 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.264: +3 -0 lines
Diff to previous 1.264
Added Roland and Andreas' request to place images using -a from top-left
Revision 1.264 - (view) (download) (annotate) - [select for diffs]
Fri May 29 07:45:48 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.263: +3 -0 lines
Diff to previous 1.263
Revision 1.263 - (view) (download) (annotate) - [select for diffs]
Thu May 28 09:13:19 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.262: +3 -0 lines
Diff to previous 1.262
Fixed bug in source obstructor cache for antimatter
Revision 1.262 - (view) (download) (annotate) - [select for diffs]
Tue May 26 12:39:25 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.261: +2 -0 lines
Diff to previous 1.261
Added photon map support to trad
Revision 1.261 - (view) (download) (annotate) - [select for diffs]
Tue May 26 10:00:47 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.260: +3 -0 lines
Diff to previous 1.260
Revision 1.260 - (view) (download) (annotate) - [select for diffs]
Wed May 20 08:59:01 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.259: +6 -6 lines
Diff to previous 1.259
Corrected version placement, typos and omissions
Revision 1.259 - (view) (download) (annotate) - [select for diffs]
Mon May 4 20:53:21 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.258: +3 -0 lines
Diff to previous 1.258
Revision 1.258 - (view) (download) (annotate) - [select for diffs]
Wed Apr 8 02:41:01 2015 UTC (10 years, 7 months ago) by greg
Changes since 1.257: +4 -0 lines
Diff to previous 1.257
Fixed bug in randomization of vectors near surface normal (front or back)
Revision 1.257 - (view) (download) (annotate) - [select for diffs]
Sun Apr 5 01:32:01 2015 UTC (10 years, 7 months ago) by greg
Changes since 1.256: +1 -1 lines
Diff to previous 1.256
Added color rendering to tensor tree and minor fixes to Klems color rendering
Revision 1.256 - (view) (download) (annotate) - [select for diffs]
Thu Apr 2 16:40:31 2015 UTC (10 years, 7 months ago) by greg
Changes since 1.255: +3 -0 lines
Diff to previous 1.255
Support for color BSDF rendering using Klems representation
Revision 1.255 - (view) (download) (annotate) - [select for diffs]
Fri Mar 27 18:58:06 2015 UTC (10 years, 7 months ago) by greg
Changes since 1.254: +7 -0 lines
Diff to previous 1.254
Revision 1.254 - (view) (download) (annotate) - [select for diffs]
Tue Feb 24 19:39:26 2015 UTC (10 years, 8 months ago) by greg
Changes since 1.253: +3 -0 lines
Diff to previous 1.253
Revision 1.253 - (view) (download) (annotate) - [select for diffs]
Fri Feb 20 18:26:09 2015 UTC (10 years, 8 months ago) by greg
Changes since 1.252: +3 -0 lines
Diff to previous 1.252
Revision 1.252 - (view) (download) (annotate) - [select for diffs]
Thu Dec 4 05:26:27 2014 UTC (10 years, 11 months ago) by greg
Changes since 1.251: +3 -0 lines
Diff to previous 1.251
Revision 1.251 - (view) (download) (annotate) - [select for diffs]
Fri Nov 21 00:53:52 2014 UTC (11 years ago) by greg
Changes since 1.250: +3 -0 lines
Diff to previous 1.250
Further limit minimum to 5% of original interreflected value
Revision 1.250 - (view) (download) (annotate) - [select for diffs]
Wed Nov 12 17:42:34 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P2
Changes since 1.249: +11 -0 lines
Diff to previous 1.249
Notes for 4.2.2 patch release
Revision 1.249 - (view) (download) (annotate) - [select for diffs]
Fri Oct 3 21:57:06 2014 UTC (11 years, 1 month ago) by greg
Changes since 1.248: +10 -0 lines
Diff to previous 1.248
Revision 1.248 - (view) (download) (annotate) - [select for diffs]
Wed Sep 17 22:40:49 2014 UTC (11 years, 2 months ago) by greg
Changes since 1.247: +4 -0 lines
Diff to previous 1.247
Revision 1.247 - (view) (download) (annotate) - [select for diffs]
Mon Sep 15 16:49:08 2014 UTC (11 years, 2 months ago) by greg
Changes since 1.246: +2 -0 lines
Diff to previous 1.246
Updates for patch release
Revision 1.246 - (view) (download) (annotate) - [select for diffs]
Mon Sep 15 00:54:39 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2P1
Changes since 1.245: +2 -0 lines
Diff to previous 1.245
Revision 1.245 - (view) (download) (annotate) - [select for diffs]
Thu Aug 21 19:38:23 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.244: +5 -1 lines
Diff to previous 1.244
Updated top-level cmake file
Revision 1.244 - (view) (download) (annotate) - [select for diffs]
Wed Aug 6 02:38:24 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.243: +2 -0 lines
Diff to previous 1.243
Revision 1.243 - (view) (download) (annotate) - [select for diffs]
Wed Aug 6 00:59:53 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.242: +4 -0 lines
Diff to previous 1.242
Revision 1.242 - (view) (download) (annotate) - [select for diffs]
Sat Aug 2 17:10:43 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.241: +4 -0 lines
Diff to previous 1.241
Revision 1.241 - (view) (download) (annotate) - [select for diffs]
Thu Jul 31 18:32:41 2014 UTC (11 years, 3 months ago) by greg
CVS Tags: rad4R2
Changes since 1.240: +3 -1 lines
Diff to previous 1.240
Preparation for 4.2 release
Revision 1.240 - (view) (download) (annotate) - [select for diffs]
Mon Jul 28 17:25:03 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.239: +2 -0 lines
Diff to previous 1.239
Revision 1.239 - (view) (download) (annotate) - [select for diffs]
Tue Jul 22 21:55:31 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.238: +4 -0 lines
Diff to previous 1.238
Revision 1.238 - (view) (download) (annotate) - [select for diffs]
Sat Jul 19 18:19:33 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.237: +3 -0 lines
Diff to previous 1.237
Revision 1.237 - (view) (download) (annotate) - [select for diffs]
Thu Jun 19 16:26:55 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.236: +6 -0 lines
Diff to previous 1.236
Revision 1.236 - (view) (download) (annotate) - [select for diffs]
Sat May 31 21:33:21 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.235: +4 -0 lines
Diff to previous 1.235
Added rmtxop command for manipulating component matrices
Revision 1.235 - (view) (download) (annotate) - [select for diffs]
Fri May 30 00:00:54 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.234: +4 -0 lines
Diff to previous 1.234
Revision 1.234 - (view) (download) (annotate) - [select for diffs]
Tue Apr 15 22:36:25 2014 UTC (11 years, 7 months ago) by greg
Changes since 1.233: +3 -0 lines
Diff to previous 1.233
Revision 1.233 - (view) (download) (annotate) - [select for diffs]
Tue Feb 18 12:13:42 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.232: +3 -0 lines
Diff to previous 1.232
Revision 1.232 - (view) (download) (annotate) - [select for diffs]
Tue Feb 11 22:01:44 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.231: +2 -0 lines
Diff to previous 1.231
Revision 1.231 - (view) (download) (annotate) - [select for diffs]
Sat Feb 8 01:28:05 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.230: +3 -0 lines
Diff to previous 1.230
Revision 1.230 - (view) (download) (annotate) - [select for diffs]
Sat Jan 25 18:27:39 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.229: +7 -0 lines
Diff to previous 1.229
Revision 1.229 - (view) (download) (annotate) - [select for diffs]
Fri Jan 24 01:26:44 2014 UTC (11 years, 9 months ago) by greg
Changes since 1.228: +2 -0 lines
Diff to previous 1.228
Revision 1.228 - (view) (download) (annotate) - [select for diffs]
Thu Dec 19 16:38:12 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.227: +4 -0 lines
Diff to previous 1.227
Revision 1.227 - (view) (download) (annotate) - [select for diffs]
Sun Dec 8 18:59:53 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.226: +4 -0 lines
Diff to previous 1.226
Revision 1.226 - (view) (download) (annotate) - [select for diffs]
Thu Dec 5 18:11:41 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.225: +2 -0 lines
Diff to previous 1.225
Added mention of new Perl scripts by Axel
Revision 1.225 - (view) (download) (annotate) - [select for diffs]
Fri Oct 18 17:04:13 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.224: +3 -0 lines
Diff to previous 1.224
Added rvu "origin" command requested by John M.
Revision 1.224 - (view) (download) (annotate) - [select for diffs]
Tue Oct 8 18:59:42 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.223: +3 -0 lines
Diff to previous 1.223
Revision 1.223 - (view) (download) (annotate) - [select for diffs]
Wed Sep 25 16:52:28 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.222: +2 -0 lines
Diff to previous 1.222
Revision 1.222 - (view) (download) (annotate) - [select for diffs]
Thu Sep 5 17:53:22 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.221: +3 -0 lines
Diff to previous 1.221
Revision 1.221 - (view) (download) (annotate) - [select for diffs]
Thu Aug 29 15:37:15 2013 UTC (12 years, 2 months ago) by greg
Changes since 1.220: +4 -0 lines
Diff to previous 1.220
Fixed double-counting bug in mirror type with secondary material
Revision 1.220 - (view) (download) (annotate) - [select for diffs]
Thu Aug 8 05:26:55 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.219: +4 -0 lines
Diff to previous 1.219
Fixed bug in sampling of isotropic tensor trees from surface normal direction
Revision 1.219 - (view) (download) (annotate) - [select for diffs]
Mon Aug 5 22:56:50 2013 UTC (12 years, 3 months ago) by greg
Changes since 1.218: +3 -0 lines
Diff to previous 1.218
Revision 1.218 - (view) (download) (annotate) - [select for diffs]
Sun Apr 21 23:01:14 2013 UTC (12 years, 7 months ago) by greg
Changes since 1.217: +3 -0 lines
Diff to previous 1.217
Revision 1.217 - (view) (download) (annotate) - [select for diffs]
Thu Apr 4 15:13:43 2013 UTC (12 years, 7 months ago) by greg
Changes since 1.216: +1 -1 lines
Diff to previous 1.216
Man page wording fix
Revision 1.216 - (view) (download) (annotate) - [select for diffs]
Thu Apr 4 02:59:20 2013 UTC (12 years, 7 months ago) by greg
Changes since 1.215: +2 -0 lines
Diff to previous 1.215
Axel Jacobs added -pal eco option to falsecolor
Revision 1.215 - (view) (download) (annotate) - [select for diffs]
Tue Feb 5 06:00:19 2013 UTC (12 years, 9 months ago) by greg
Changes since 1.214: +3 -0 lines
Diff to previous 1.214
Added -r option to gendaymtx for rotating the sky about the zenith
Revision 1.214 - (view) (download) (annotate) - [select for diffs]
Tue Feb 5 05:41:16 2013 UTC (12 years, 9 months ago) by greg
Changes since 1.213: +3 -0 lines
Diff to previous 1.213
Revision 1.213 - (view) (download) (annotate) - [select for diffs]
Wed Jan 30 01:02:42 2013 UTC (12 years, 9 months ago) by greg
Changes since 1.212: +3 -0 lines
Diff to previous 1.212
Replaced gendaylit with new version by Wendelin Sprenger and Jan Wienold
Revision 1.212 - (view) (download) (annotate) - [select for diffs]
Sun Jan 20 02:07:16 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.211: +4 -0 lines
Diff to previous 1.211
Added documentation for new gendaymtx tool
Revision 1.211 - (view) (download) (annotate) - [select for diffs]
Fri Jan 11 17:21:39 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.210: +2 -1 lines
Diff to previous 1.210
Revision 1.210 - (view) (download) (annotate) - [select for diffs]
Fri Jan 11 05:07:47 2013 UTC (12 years, 10 months ago) by greg
Changes since 1.209: +3 -0 lines
Diff to previous 1.209
Revision 1.209 - (view) (download) (annotate) - [select for diffs]
Mon Nov 26 07:04:07 2012 UTC (12 years, 11 months ago) by greg
Changes since 1.208: +4 -0 lines
Diff to previous 1.208
Fixed bug in depth-of-field with non-zero fore clipping plane
Revision 1.208 - (view) (download) (annotate) - [select for diffs]
Thu Nov 15 19:41:03 2012 UTC (13 years ago) by greg
Changes since 1.207: +3 -0 lines
Diff to previous 1.207
Revision 1.207 - (view) (download) (annotate) - [select for diffs]
Sat Oct 13 20:15:43 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.206: +4 -0 lines
Diff to previous 1.206
Revision 1.206 - (view) (download) (annotate) - [select for diffs]
Fri Oct 5 00:59:38 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.205: +3 -0 lines
Diff to previous 1.205
Revision 1.205 - (view) (download) (annotate) - [select for diffs]
Fri Sep 28 22:20:49 2012 UTC (13 years, 1 month ago) by greg
Changes since 1.204: +2 -0 lines
Diff to previous 1.204
Revision 1.204 - (view) (download) (annotate) - [select for diffs]
Sun Sep 2 15:33:15 2012 UTC (13 years, 2 months ago) by greg
Changes since 1.203: +3 -0 lines
Diff to previous 1.203
Revision 1.203 - (view) (download) (annotate) - [select for diffs]
Tue Aug 7 18:17:17 2012 UTC (13 years, 3 months ago) by greg
Changes since 1.202: +2 -0 lines
Diff to previous 1.202
Revision 1.202 - (view) (download) (annotate) - [select for diffs]
Sun Jul 29 19:01:39 2012 UTC (13 years, 3 months ago) by greg
Changes since 1.201: +3 -0 lines
Diff to previous 1.201
Revision 1.201 - (view) (download) (annotate) - [select for diffs]
Thu Jun 28 20:48:03 2012 UTC (13 years, 4 months ago) by greg
Changes since 1.200: +2 -0 lines
Diff to previous 1.200
Added -d option for sun-only vector
Revision 1.200 - (view) (download) (annotate) - [select for diffs]
Thu Jun 14 22:42:21 2012 UTC (13 years, 5 months ago) by greg
Changes since 1.199: +4 -0 lines
Diff to previous 1.199
Revision 1.199 - (view) (download) (annotate) - [select for diffs]
Thu Jun 14 05:19:05 2012 UTC (13 years, 5 months ago) by greg
Changes since 1.198: +2 -0 lines
Diff to previous 1.198
Added -c option to repeat pixels
Revision 1.198 - (view) (download) (annotate) - [select for diffs]
Sun Jun 3 19:21:38 2012 UTC (13 years, 5 months ago) by greg
Changes since 1.197: +3 -0 lines
Diff to previous 1.197
Added slider to control rad -N option in trad
Revision 1.197 - (view) (download) (annotate) - [select for diffs]
Thu May 17 17:36:14 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.196: +2 -0 lines
Diff to previous 1.196
Permitted pflip to pipe from stdin for horizontal-only flip
Revision 1.196 - (view) (download) (annotate) - [select for diffs]
Wed Apr 25 22:21:06 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.195: +2 -0 lines
Diff to previous 1.195
Revision 1.195 - (view) (download) (annotate) - [select for diffs]
Fri Mar 30 15:08:40 2012 UTC (13 years, 7 months ago) by greg
Changes since 1.194: +2 -0 lines
Diff to previous 1.194
Fixed serious bug in transmitting proxy material ambient sampling
Revision 1.194 - (view) (download) (annotate) - [select for diffs]
Tue Mar 20 02:56:08 2012 UTC (13 years, 8 months ago) by greg
Changes since 1.193: +5 -0 lines
Diff to previous 1.193
Revision 1.193 - (view) (download) (annotate) - [select for diffs]
Fri Feb 17 00:14:46 2012 UTC (13 years, 9 months ago) by greg
Changes since 1.192: +2 -0 lines
Diff to previous 1.192
Revision 1.192 - (view) (download) (annotate) - [select for diffs]
Wed Jan 18 00:30:35 2012 UTC (13 years, 10 months ago) by greg
Changes since 1.191: +6 -1 lines
Diff to previous 1.191
Axel Jacobs added options and Windows compatibility to falsecolor
Revision 1.191 - (view) (download) (annotate) - [select for diffs]
Wed Oct 26 16:48:01 2011 UTC (14 years ago) by greg
Changes since 1.190: +4 -0 lines
Diff to previous 1.190
Revision 1.190 - (view) (download) (annotate) - [select for diffs]
Wed Oct 26 03:44:56 2011 UTC (14 years ago) by greg
Changes since 1.189: +3 -0 lines
Diff to previous 1.189
Fixed underestimation of reflection in non-metals below -st threshold
Revision 1.189 - (view) (download) (annotate) - [select for diffs]
Tue Aug 2 22:47:30 2011 UTC (14 years, 3 months ago) by greg
Changes since 1.188: +3 -0 lines
Diff to previous 1.188
Revision 1.188 - (view) (download) (annotate) - [select for diffs]
Thu Jun 23 18:05:18 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.187: +4 -0 lines
Diff to previous 1.187
Created pkgBSDF program
Revision 1.187 - (view) (download) (annotate) - [select for diffs]
Fri Jun 3 19:41:14 2011 UTC (14 years, 5 months ago) by greg
Changes since 1.186: +2 -0 lines
Diff to previous 1.186
Revision 1.186 - (view) (download) (annotate) - [select for diffs]
Thu May 19 16:09:38 2011 UTC (14 years, 6 months ago) by greg
Changes since 1.185: +2 -0 lines
Diff to previous 1.185
Bug fix related to zero rows and added check for negative sensitivities
Revision 1.185 - (view) (download) (annotate) - [select for diffs]
Mon Feb 21 22:48:51 2011 UTC (14 years, 8 months ago) by greg
Changes since 1.184: +2 -0 lines
Diff to previous 1.184
Revision 1.184 - (view) (download) (annotate) - [select for diffs]
Fri Feb 18 00:40:25 2011 UTC (14 years, 9 months ago) by greg
Changes since 1.183: +2 -0 lines
Diff to previous 1.183
Revision 1.183 - (view) (download) (annotate) - [select for diffs]
Thu Dec 16 21:34:41 2010 UTC (14 years, 11 months ago) by greg
Changes since 1.182: +3 -0 lines
Diff to previous 1.182
Added recording of other color spaces to pvalue -r conversion
Revision 1.182 - (view) (download) (annotate) - [select for diffs]
Thu Dec 2 18:08:11 2010 UTC (14 years, 11 months ago) by greg
Changes since 1.181: +2 -0 lines
Diff to previous 1.181
Revision 1.181 - (view) (download) (annotate) - [select for diffs]
Sun Oct 31 23:06:44 2010 UTC (15 years ago) by greg
Changes since 1.180: +2 -2 lines
Diff to previous 1.180
Wording fixes
Revision 1.180 - (view) (download) (annotate) - [select for diffs]
Thu Oct 14 05:54:43 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.179: +2 -0 lines
Diff to previous 1.179
Fixed long-standing bug in ambient file synchronization under FreeBSD
Revision 1.179 - (view) (download) (annotate) - [select for diffs]
Fri Oct 8 22:08:26 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.178: +6 -0 lines
Diff to previous 1.178
Revision 1.178 - (view) (download) (annotate) - [select for diffs]
Tue Oct 5 00:59:38 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.177: +3 -0 lines
Diff to previous 1.177
Revision 1.177 - (view) (download) (annotate) - [select for diffs]
Fri Oct 1 18:11:18 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.176: +3 -0 lines
Diff to previous 1.176
Updated reflection model to match paper by Geisler-Moroder an Duer
Revision 1.176 - (view) (download) (annotate) - [select for diffs]
Tue Sep 28 21:28:22 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.175: +3 -0 lines
Diff to previous 1.175
Fixed bug in "void" mapping of surfaces
Revision 1.175 - (view) (download) (annotate) - [select for diffs]
Sun Sep 26 15:51:15 2010 UTC (15 years, 1 month ago) by greg
Changes since 1.174: +15 -0 lines
Diff to previous 1.174
Revision 1.174 - (view) (download) (annotate) - [select for diffs]
Thu Sep 16 03:28:20 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.173: +3 -0 lines
Diff to previous 1.173
Changed obj2rad to accept illegal normals
Revision 1.173 - (view) (download) (annotate) - [select for diffs]
Fri Sep 3 23:53:49 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.172: +4 -0 lines
Diff to previous 1.172
Revision 1.172 - (view) (download) (annotate) - [select for diffs]
Thu Jul 1 21:54:55 2010 UTC (15 years, 4 months ago) by greg
Changes since 1.171: +3 -0 lines
Diff to previous 1.171
Revision 1.171 - (view) (download) (annotate) - [select for diffs]
Fri Jun 18 21:22:49 2010 UTC (15 years, 5 months ago) by greg
Changes since 1.170: +2 -0 lines
Diff to previous 1.170
Added -u option to rlam
Revision 1.170 - (view) (download) (annotate) - [select for diffs]
Thu May 27 19:32:12 2010 UTC (15 years, 5 months ago) by greg
Changes since 1.169: +3 -0 lines
Diff to previous 1.169
Revision 1.169 - (view) (download) (annotate) - [select for diffs]
Tue May 18 00:01:02 2010 UTC (15 years, 6 months ago) by greg
Changes since 1.168: +2 -0 lines
Diff to previous 1.168
Revision 1.168 - (view) (download) (annotate) - [select for diffs]
Fri May 7 15:46:48 2010 UTC (15 years, 6 months ago) by greg
Changes since 1.167: +4 -0 lines
Diff to previous 1.167
Changed BTDF normalization back to what it was in version 3.5
Revision 1.167 - (view) (download) (annotate) - [select for diffs]
Tue Mar 16 04:44:22 2010 UTC (15 years, 8 months ago) by greg
Changes since 1.166: +8 -1 lines
Diff to previous 1.166
Updated past 4.0
Revision 1.166 - (view) (download) (annotate) - [select for diffs]
Fri Mar 12 19:14:24 2010 UTC (15 years, 8 months ago) by greg
Changes since 1.165: +5 -5 lines
Diff to previous 1.165
Added release dates
Revision 1.165 - (view) (download) (annotate) - [select for diffs]
Sun Dec 13 19:13:04 2009 UTC (15 years, 11 months ago) by greg
Changes since 1.164: +1 -1 lines
Diff to previous 1.164
Revision 1.164 - (view) (download) (annotate) - [select for diffs]
Sat Dec 12 19:00:59 2009 UTC (15 years, 11 months ago) by greg
Changes since 1.163: +3 -0 lines
Diff to previous 1.163
Revision 1.163 - (view) (download) (annotate) - [select for diffs]
Sat Dec 12 05:20:10 2009 UTC (15 years, 11 months ago) by greg
Changes since 1.162: +3 -0 lines
Diff to previous 1.162
Revision 1.162 - (view) (download) (annotate) - [select for diffs]
Wed Jun 17 20:41:46 2009 UTC (16 years, 5 months ago) by greg
Changes since 1.161: +4 -0 lines
Diff to previous 1.161
Revision 1.161 - (view) (download) (annotate) - [select for diffs]
Tue Jun 16 04:54:08 2009 UTC (16 years, 5 months ago) by greg
Changes since 1.160: +3 -0 lines
Diff to previous 1.160
Revision 1.160 - (view) (download) (annotate) - [select for diffs]
Sun Jun 14 20:07:59 2009 UTC (16 years, 5 months ago) by greg
Changes since 1.159: +5 -2 lines
Diff to previous 1.159
Added klems_int.cal module for computing Klems window bins
Revision 1.159 - (view) (download) (annotate) - [select for diffs]
Sun Jun 14 00:33:16 2009 UTC (16 years, 5 months ago) by greg
Changes since 1.158: +5 -0 lines
Diff to previous 1.158
Revision 1.158 - (view) (download) (annotate) - [select for diffs]
Sat Jun 6 20:18:32 2009 UTC (16 years, 5 months ago) by greg
Changes since 1.157: +2 -0 lines
Diff to previous 1.157
Revision 1.157 - (view) (download) (annotate) - [select for diffs]
Thu May 21 18:08:43 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.156: +3 -0 lines
Diff to previous 1.156
Revision 1.156 - (view) (download) (annotate) - [select for diffs]
Wed Mar 4 00:12:24 2009 UTC (16 years, 8 months ago) by greg
Changes since 1.155: +3 -0 lines
Diff to previous 1.155
Revision 1.155 - (view) (download) (annotate) - [select for diffs]
Mon Feb 9 16:41:28 2009 UTC (16 years, 9 months ago) by greg
Changes since 1.154: +2 -0 lines
Diff to previous 1.154
Revision 1.154 - (view) (download) (annotate) - [select for diffs]
Thu Dec 18 23:26:57 2008 UTC (16 years, 11 months ago) by greg
Changes since 1.153: +5 -0 lines
Diff to previous 1.153
Revision 1.153 - (view) (download) (annotate) - [select for diffs]
Sat Dec 6 01:08:52 2008 UTC (16 years, 11 months ago) by greg
Changes since 1.152: +3 -0 lines
Diff to previous 1.152
Revision 1.152 - (view) (download) (annotate) - [select for diffs]
Fri Nov 21 01:30:16 2008 UTC (17 years ago) by greg
Changes since 1.151: +2 -0 lines
Diff to previous 1.151
Added -N option to support multiprocessing in objview
Revision 1.151 - (view) (download) (annotate) - [select for diffs]
Mon Nov 10 19:08:18 2008 UTC (17 years ago) by greg
Changes since 1.150: +8 -0 lines
Diff to previous 1.150
Revision 1.150 - (view) (download) (annotate) - [select for diffs]
Thu Aug 21 07:05:58 2008 UTC (17 years, 3 months ago) by greg
Changes since 1.149: +2 -0 lines
Diff to previous 1.149
Revision 1.149 - (view) (download) (annotate) - [select for diffs]
Wed Apr 30 21:48:02 2008 UTC (17 years, 6 months ago) by greg
Changes since 1.148: +3 -0 lines
Diff to previous 1.148
Post 3.9 release changes
Revision 1.148 - (view) (download) (annotate) - [select for diffs]
Wed Apr 30 21:11:35 2008 UTC (17 years, 6 months ago) by greg
Changes since 1.147: +0 -3 lines
Diff to previous 1.147
Correction to Window 6 notes
Revision 1.147 - (view) (download) (annotate) - [select for diffs]
Fri Apr 18 18:06:29 2008 UTC (17 years, 7 months ago) by greg
Changes since 1.146: +4 -0 lines
Diff to previous 1.146
Modified rtcontrib -c option to accumulate a specified number of rays
Revision 1.146 - (view) (download) (annotate) - [select for diffs]
Tue Mar 11 02:21:46 2008 UTC (17 years, 8 months ago) by greg
Changes since 1.145: +3 -0 lines
Diff to previous 1.145
Revision 1.145 - (view) (download) (annotate) - [select for diffs]
Thu Feb 21 01:22:06 2008 UTC (17 years, 9 months ago) by greg
Changes since 1.144: +5 -1 lines
Diff to previous 1.144
Revision 1.144 - (view) (download) (annotate) - [select for diffs]
Fri Jan 25 02:11:12 2008 UTC (17 years, 9 months ago) by greg
Changes since 1.143: +4 -0 lines
Diff to previous 1.143
Revision 1.143 - (view) (download) (annotate) - [select for diffs]
Thu Jan 24 23:15:46 2008 UTC (17 years, 9 months ago) by greg
Changes since 1.142: +6 -0 lines
Diff to previous 1.142
Revision 1.142 - (view) (download) (annotate) - [select for diffs]
Thu Dec 13 07:03:37 2007 UTC (17 years, 11 months ago) by greg
Changes since 1.141: +3 -0 lines
Diff to previous 1.141
Revision 1.141 - (view) (download) (annotate) - [select for diffs]
Sat Nov 17 01:13:51 2007 UTC (18 years ago) by greg
Changes since 1.140: +2 -0 lines
Diff to previous 1.140
Added -c option to rtcontrib (barely tested, and -r does not work)
Revision 1.140 - (view) (download) (annotate) - [select for diffs]
Thu Nov 15 18:33:50 2007 UTC (18 years ago) by greg
Changes since 1.139: +3 -0 lines
Diff to previous 1.139
Allow -P and -PP options to be set by user for rtcontrib
Revision 1.139 - (view) (download) (annotate) - [select for diffs]
Mon Nov 5 23:40:25 2007 UTC (18 years ago) by greg
Changes since 1.138: +2 -0 lines
Diff to previous 1.138
Revision 1.138 - (view) (download) (annotate) - [select for diffs]
Tue Sep 18 19:51:07 2007 UTC (18 years, 2 months ago) by greg
Changes since 1.137: +3 -0 lines
Diff to previous 1.137
Revision 1.137 - (view) (download) (annotate) - [select for diffs]
Wed Jul 25 04:12:35 2007 UTC (18 years, 3 months ago) by greg
Changes since 1.136: +4 -0 lines
Diff to previous 1.136
Revision 1.136 - (view) (download) (annotate) - [select for diffs]
Thu Jul 12 14:58:53 2007 UTC (18 years, 4 months ago) by greg
Changes since 1.135: +4 -1 lines
Diff to previous 1.135
Decreased default -n setting in obj2mesh from 15 to 9
Revision 1.135 - (view) (download) (annotate) - [select for diffs]
Mon Jul 2 20:16:00 2007 UTC (18 years, 4 months ago) by greg
Changes since 1.134: +2 -0 lines
Diff to previous 1.134
Corrected ray weighting for mixed materials
Revision 1.134 - (view) (download) (annotate) - [select for diffs]
Wed May 23 21:39:38 2007 UTC (18 years, 6 months ago) by greg
Changes since 1.133: +7 -0 lines
Diff to previous 1.133
Fixed original octree bug that made it take 8 times as much memory as it should
Revision 1.133 - (view) (download) (annotate) - [select for diffs]
Mon Feb 26 21:16:02 2007 UTC (18 years, 8 months ago) by greg
Changes since 1.132: +2 -0 lines
Diff to previous 1.132
Revision 1.132 - (view) (download) (annotate) - [select for diffs]
Sat Dec 23 17:27:45 2006 UTC (18 years, 11 months ago) by greg
Changes since 1.131: +2 -0 lines
Diff to previous 1.131
Revision 1.131 - (view) (download) (annotate) - [select for diffs]
Mon Nov 13 02:41:46 2006 UTC (19 years ago) by greg
Changes since 1.130: +6 -0 lines
Diff to previous 1.130
Added -spec and "-s auto" options to falsecolor
Revision 1.130 - (view) (download) (annotate) - [select for diffs]
Fri Sep 8 21:38:25 2006 UTC (19 years, 2 months ago) by greg
Changes since 1.129: +2 -0 lines
Diff to previous 1.129
Revision 1.129 - (view) (download) (annotate) - [select for diffs]
Thu Sep 7 05:20:54 2006 UTC (19 years, 2 months ago) by greg
Changes since 1.128: +3 -0 lines
Diff to previous 1.128
Revision 1.128 - (view) (download) (annotate) - [select for diffs]
Tue Aug 22 21:38:21 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.127: +2 -0 lines
Diff to previous 1.127
Added -o option to ra_xyze for original pixel values.
Revision 1.127 - (view) (download) (annotate) - [select for diffs]
Wed Jul 26 17:15:11 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.126: +5 -0 lines
Diff to previous 1.126
Changed default turbidity from 2.75 to 2.45
Revision 1.126 - (view) (download) (annotate) - [select for diffs]
Wed Jul 12 05:47:05 2006 UTC (19 years, 4 months ago) by greg
Changes since 1.125: +4 -0 lines
Diff to previous 1.125
Revision 1.125 - (view) (download) (annotate) - [select for diffs]
Tue Jun 6 19:13:00 2006 UTC (19 years, 5 months ago) by greg
Changes since 1.124: +2 -0 lines
Diff to previous 1.124
Fixed long-standing inaccuracy of +/-t threshold options
Revision 1.124 - (view) (download) (annotate) - [select for diffs]
Mon May 29 17:31:25 2006 UTC (19 years, 5 months ago) by greg
Changes since 1.123: +4 -0 lines
Diff to previous 1.123
Revision 1.123 - (view) (download) (annotate) - [select for diffs]
Fri May 19 03:50:13 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.122: +4 -0 lines
Diff to previous 1.122
Revision 1.122 - (view) (download) (annotate) - [select for diffs]
Wed May 10 15:34:16 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.121: +5 -0 lines
Diff to previous 1.121
Minor fixes to last change with IEEE float lookup function
Revision 1.121 - (view) (download) (annotate) - [select for diffs]
Sun May 7 15:44:27 2006 UTC (19 years, 6 months ago) by greg
Changes since 1.120: +2 -0 lines
Diff to previous 1.120
Made missing calls to SET_FILE_BINARY() for Windows
Revision 1.120 - (view) (download) (annotate) - [select for diffs]
Fri Apr 7 19:39:10 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.119: +2 -0 lines
Diff to previous 1.119
Added credit for -u+ bug fix
Revision 1.119 - (view) (download) (annotate) - [select for diffs]
Wed Apr 5 14:30:38 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.118: +2 -0 lines
Diff to previous 1.118
Changed default in rtrace to -u+ (random sampling)
Revision 1.118 - (view) (download) (annotate) - [select for diffs]
Wed Apr 5 06:22:56 2006 UTC (19 years, 7 months ago) by greg
Changes since 1.117: +1 -0 lines
Diff to previous 1.117
Made -u+ option truly random
Revision 1.117 - (view) (download) (annotate) - [select for diffs]
Fri Mar 10 19:40:11 2006 UTC (19 years, 8 months ago) by schorsch
Changes since 1.116: +4 -0 lines
Diff to previous 1.116
Revision 1.116 - (view) (download) (annotate) - [select for diffs]
Tue Feb 28 03:44:54 2006 UTC (19 years, 8 months ago) by greg
Changes since 1.115: +2 -0 lines
Diff to previous 1.115
Revision 1.115 - (view) (download) (annotate) - [select for diffs]
Sun Feb 5 22:22:20 2006 UTC (19 years, 9 months ago) by greg
Changes since 1.114: +3 -0 lines
Diff to previous 1.114
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Revision 1.114 - (view) (download) (annotate) - [select for diffs]
Fri Jan 6 06:40:53 2006 UTC (19 years, 10 months ago) by greg
Changes since 1.113: +3 -0 lines
Diff to previous 1.113
Fixed byte ordering for 16-bit/channel PPM files
Revision 1.113 - (view) (download) (annotate) - [select for diffs]
Wed Dec 28 19:42:13 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.112: +4 -0 lines
Diff to previous 1.112
Fixed problems with genblinds
Revision 1.112 - (view) (download) (annotate) - [select for diffs]
Wed Dec 28 18:35:41 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.111: +2 -0 lines
Diff to previous 1.111
Revision 1.111 - (view) (download) (annotate) - [select for diffs]
Fri Dec 16 04:05:16 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.110: +3 -0 lines
Diff to previous 1.110
Removed NICE macro settings in rpict and rtrace to improve performance
Revision 1.110 - (view) (download) (annotate) - [select for diffs]
Thu Dec 8 17:56:38 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.109: +4 -0 lines
Diff to previous 1.109
Added threshold to disable Fresnel approximation for specularities below 1.8%
Revision 1.109 - (view) (download) (annotate) - [select for diffs]
Sat Nov 12 06:14:51 2005 UTC (20 years ago) by greg
Changes since 1.108: +2 -0 lines
Diff to previous 1.108
Improved default ordinal color scale in falsecolor
Revision 1.108 - (view) (download) (annotate) - [select for diffs]
Tue Oct 11 23:41:44 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.107: +3 -0 lines
Diff to previous 1.107
Fixed rtcontrib flushing behavior
Revision 1.107 - (view) (download) (annotate) - [select for diffs]
Tue Oct 11 16:54:26 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.106: +3 -0 lines
Diff to previous 1.106
Added rtcontrib -fo option to override new reluctance to clobber existing files
Revision 1.106 - (view) (download) (annotate) - [select for diffs]
Thu Oct 6 05:49:44 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.105: +3 -0 lines
Diff to previous 1.105
Revision 1.105 - (view) (download) (annotate) - [select for diffs]
Sun Sep 25 20:36:02 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.104: +2 -0 lines
Diff to previous 1.104
Added -i option to allow rlam to work with binary input records
Revision 1.104 - (view) (download) (annotate) - [select for diffs]
Fri Sep 23 19:04:52 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.103: +2 -0 lines
Diff to previous 1.103
Revision 1.103 - (view) (download) (annotate) - [select for diffs]
Wed Sep 21 17:17:24 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.102: +3 -0 lines
Diff to previous 1.102
Revision 1.102 - (view) (download) (annotate) - [select for diffs]
Tue Sep 20 17:05:10 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.101: +3 -0 lines
Diff to previous 1.101
Fixed serious bug where rtcontrib would sometimes forget to write last file
Revision 1.101 - (view) (download) (annotate) - [select for diffs]
Mon Sep 19 04:26:08 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.100: +2 -0 lines
Diff to previous 1.100
Revision 1.100 - (view) (download) (annotate) - [select for diffs]
Mon Sep 19 02:23:58 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.99: +2 -0 lines
Diff to previous 1.99
Revision 1.99 - (view) (download) (annotate) - [select for diffs]
Sat Sep 17 05:14:14 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.98: +4 -0 lines
Diff to previous 1.98
Revision 1.98 - (view) (download) (annotate) - [select for diffs]
Thu Sep 15 18:06:23 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.97: +3 -0 lines
Diff to previous 1.97
Revision 1.97 - (view) (download) (annotate) - [select for diffs]
Fri Sep 2 14:43:43 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.96: +1 -1 lines
Diff to previous 1.96
Added -e [default] and -o options for even/odd fields first
Revision 1.96 - (view) (download) (annotate) - [select for diffs]
Fri Sep 2 04:15:42 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.95: +3 -0 lines
Diff to previous 1.95
Revision 1.95 - (view) (download) (annotate) - [select for diffs]
Mon Aug 22 21:54:41 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R7P2
Changes since 1.94: +2 -0 lines
Diff to previous 1.94
Revision 1.94 - (view) (download) (annotate) - [select for diffs]
Mon Aug 22 16:07:26 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.93: +6 -0 lines
Diff to previous 1.93
Revision 1.93 - (view) (download) (annotate) - [select for diffs]
Fri Aug 19 02:31:32 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.92: +3 -0 lines
Diff to previous 1.92
Revision 1.92 - (view) (download) (annotate) - [select for diffs]
Fri Aug 5 17:24:53 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R7P1
Changes since 1.91: +3 -1 lines
Diff to previous 1.91
Changes for 3.7.1 patch release
Revision 1.91 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 17:01:30 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.90: +2 -0 lines
Diff to previous 1.90
Changed to 98th percentile for default threshold
Revision 1.90 - (view) (download) (annotate) - [select for diffs]
Sat Jul 30 16:41:46 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.89: +3 -0 lines
Diff to previous 1.89
Fixed serious bug in new Russian roulette algorithm
Revision 1.89 - (view) (download) (annotate) - [select for diffs]
Wed Jul 27 05:34:17 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.88: +5 -1 lines
Diff to previous 1.88
Onward to 3.8a
Revision 1.88 - (view) (download) (annotate) - [select for diffs]
Tue Jun 21 02:34:22 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.87: +4 -0 lines
Diff to previous 1.87
Documented new behavior with blank input lines in total(1)
Revision 1.87 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 22:23:31 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.86: +2 -0 lines
Diff to previous 1.86
Revision 1.86 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 17:10:05 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.85: +3 -0 lines
Diff to previous 1.85
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Revision 1.85 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 04:04:51 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.84: +2 -2 lines
Diff to previous 1.84
Revision 1.84 - (view) (download) (annotate) - [select for diffs]
Tue Jun 14 01:25:02 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.83: +3 -0 lines
Diff to previous 1.83
Fixed bug in rcalc with -l option where it sometimes hung
Revision 1.83 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 22:40:46 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.82: +2 -0 lines
Diff to previous 1.82
Changed rlam -t option to accept strings as well as tab characters
Revision 1.82 - (view) (download) (annotate) - [select for diffs]
Mon Jun 13 20:07:56 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.81: +3 -0 lines
Diff to previous 1.81
Revision 1.81 - (view) (download) (annotate) - [select for diffs]
Thu Jun 9 17:27:27 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.80: +2 -0 lines
Diff to previous 1.80
Revision 1.80 - (view) (download) (annotate) - [select for diffs]
Sun Jun 5 19:52:00 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.79: +3 -0 lines
Diff to previous 1.79
Revision 1.79 - (view) (download) (annotate) - [select for diffs]
Thu Jun 2 04:47:26 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.78: +4 -0 lines
Diff to previous 1.78
Revision 1.78 - (view) (download) (annotate) - [select for diffs]
Wed Jun 1 16:11:01 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.77: +4 -2 lines
Diff to previous 1.77
Revision 1.77 - (view) (download) (annotate) - [select for diffs]
Tue May 31 18:01:08 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.76: +3 -0 lines
Diff to previous 1.76
Revision 1.76 - (view) (download) (annotate) - [select for diffs]
Thu May 26 06:55:22 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.75: +4 -0 lines
Diff to previous 1.75
Revision 1.75 - (view) (download) (annotate) - [select for diffs]
Wed May 25 04:44:25 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.74: +6 -0 lines
Diff to previous 1.74
Revision 1.74 - (view) (download) (annotate) - [select for diffs]
Tue May 24 22:54:38 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.73: +3 -0 lines
Diff to previous 1.73
Added note on change to blackbody.cal
Revision 1.73 - (view) (download) (annotate) - [select for diffs]
Wed May 4 23:43:19 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.72: +2 -0 lines
Diff to previous 1.72
Created meta2bmp file to generate BMP output from metafile graphics
Revision 1.72 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 18:44:22 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.71: +2 -0 lines
Diff to previous 1.71
Revision 1.71 - (view) (download) (annotate) - [select for diffs]
Tue Apr 19 01:15:06 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.70: +17 -0 lines
Diff to previous 1.70
Thu Apr 14 18:04:12 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.69: +3 -0 lines
Diff to previous 1.69
Wed Apr 13 23:00:58 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.68: +4 -0 lines
Diff to previous 1.68
Tue Apr 12 03:30:43 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.67: +3 -0 lines
Diff to previous 1.67
Created mksource program
Tue Mar 22 04:51:56 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.66: +3 -0 lines
Diff to previous 1.66
Thu Mar 10 22:37:00 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.65: +7 -0 lines
Diff to previous 1.65
Mon Feb 7 17:08:16 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.64: +4 -1 lines
Diff to previous 1.64
Fri Jan 21 00:52:59 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.63: +3 -0 lines
Diff to previous 1.63
Tue Jan 18 03:59:41 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.62: +3 -0 lines
Diff to previous 1.62
Tue Jan 18 00:33:16 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.61: +5 -0 lines
Diff to previous 1.61
Fri Jan 7 20:33:01 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.60: +3 -0 lines
Diff to previous 1.60
Wed Jan 5 19:34:10 2005 UTC (20 years, 10 months ago) by greg
Changes since 1.59: +4 -0 lines
Diff to previous 1.59
Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Wed Dec 15 22:02:04 2004 UTC (20 years, 11 months ago) by greg
Changes since 1.58: +3 -0 lines
Diff to previous 1.58
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Thu Nov 25 14:47:03 2004 UTC (20 years, 11 months ago) by greg
Changes since 1.57: +3 -0 lines
Diff to previous 1.57
Mon Nov 8 15:50:59 2004 UTC (21 years ago) by greg
Changes since 1.56: +4 -0 lines
Diff to previous 1.56
Fri Nov 5 03:31:36 2004 UTC (21 years ago) by greg
Changes since 1.55: +14 -0 lines
Diff to previous 1.55
Sat Oct 30 04:59:41 2004 UTC (21 years ago) by greg
Changes since 1.54: +3 -0 lines
Diff to previous 1.54
Thu Oct 28 00:49:27 2004 UTC (21 years ago) by greg
CVS Tags: rad3R6P1
Changes since 1.53: +13 -0 lines
Diff to previous 1.53
Added comments on 3.6 bug fixes
Mon Oct 11 10:02:15 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.52: +3 -0 lines
Diff to previous 1.52
Mon Oct 4 22:32:58 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.51: +2 -2 lines
Diff to previous 1.51
Fixed minor spelling errors and typos
Mon Oct 4 17:44:22 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.50: +4 -0 lines
Diff to previous 1.50
Fri Oct 1 07:45:30 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.49: +4 -0 lines
Diff to previous 1.49
Thu Sep 23 18:00:54 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.48: +3 -0 lines
Diff to previous 1.48
Mon Sep 20 17:32:04 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.47: +10 -0 lines
Diff to previous 1.47
Corrected Gaussian reflectance model normalization (cosine factor)
Mon Sep 20 16:26:57 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.46: +6 -3 lines
Diff to previous 1.46
Sun Sep 19 08:42:22 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.45: +4 -0 lines
Diff to previous 1.45
Fri Sep 17 21:43:49 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.44: +2 -0 lines
Diff to previous 1.44
Fri Sep 10 18:19:24 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.43: +3 -0 lines
Diff to previous 1.43
Fri Sep 10 16:05:07 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.42: +4 -0 lines
Diff to previous 1.42
Thu Sep 9 20:08:21 2004 UTC (21 years, 2 months ago) by greg
Diff to previous 1.41
Thu Sep 9 17:05:43 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.40: +8 -0 lines
Diff to previous 1.40
Added notes about recent fixes
Wed Jun 9 16:00:13 2004 UTC (21 years, 5 months ago) by greg
Changes since 1.39: +4 -0 lines
Diff to previous 1.39
Fri Apr 30 20:29:24 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.38: +3 -0 lines
Diff to previous 1.38
Fri Apr 30 17:00:29 2004 UTC (21 years, 6 months ago) by greg
Changes since 1.37: +4 -0 lines
Diff to previous 1.37
Fri Apr 23 16:20:54 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.36: +3 -0 lines
Diff to previous 1.36
Fri Apr 23 00:56:27 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 1.35
Mon Apr 12 17:31:27 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.34: +7 -1 lines
Diff to previous 1.34
Sun Mar 28 16:31:14 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.33: +4 -0 lines
Diff to previous 1.33
Fri Mar 26 22:58:21 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.32: +1 -2 lines
Diff to previous 1.32
Added support to ra_bmp for 16-bit images and RLE, plus created man page
Fri Mar 26 03:11:50 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.31: +4 -0 lines
Diff to previous 1.31
Mon Mar 15 21:16:54 2004 UTC (21 years, 8 months ago) by greg
Diff to previous 1.30
Mon Mar 8 21:39:32 2004 UTC (21 years, 8 months ago) by greg
Diff to previous 1.29
Mon Mar 1 17:49:38 2004 UTC (21 years, 8 months ago) by greg
Changes since 1.28: +5 -1 lines
Diff to previous 1.28
Fri Jan 30 00:08:31 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 1.27
Thu Jan 29 22:20:31 2004 UTC (21 years, 9 months ago) by greg
Changes since 1.26: +13 -0 lines
Thu Jan 1 19:31:45 2004 UTC (21 years, 10 months ago) by greg
Changes since 1.25: +7 -0 lines
Wed Dec 31 01:50:02 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.24: +9 -0 lines
Sun Dec 14 16:33:37 2003 UTC (21 years, 11 months ago) by greg
Added -p option to histo to report percentiles and changed output slightly
Wed Nov 19 16:21:28 2003 UTC (22 years ago) by greg
Changes since 1.22: +2 -0 lines
Tue Nov 11 16:24:05 2003 UTC (22 years ago) by greg
Thu Nov 6 05:39:33 2003 UTC (22 years ago) by greg
Wed Oct 1 22:07:19 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.19: +3 -0 lines
Tue Sep 30 00:13:58 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.18: +3 -0 lines
Wed Sep 24 14:55:53 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.17: +6 -0 lines
Tue Sep 23 03:54:57 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.16: +3 -0 lines
Fri Sep 19 18:33:04 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.15: +3 -0 lines
Thu Sep 18 20:18:19 2003 UTC (22 years, 2 months ago) by greg
Thu Sep 18 16:53:52 2003 UTC (22 years, 2 months ago) by greg
Tue Sep 16 06:32:21 2003 UTC (22 years, 2 months ago) by greg
Changed meta2tga so it outputs correct colors
Sat Sep 13 15:24:13 2003 UTC (22 years, 2 months ago) by greg
Fri Aug 29 21:44:17 2003 UTC (22 years, 2 months ago) by greg
Tue Aug 26 16:09:43 2003 UTC (22 years, 2 months ago) by greg
Mon Jul 14 04:56:53 2003 UTC (22 years, 4 months ago) by greg
Changes since 1.8: +3 -0 lines
Thu Jul 10 03:47:00 2003 UTC (22 years, 4 months ago) by greg
Thu Jul 3 15:00:19 2003 UTC (22 years, 4 months ago) by greg
Changes since 1.6: +3 -0 lines
Tue Jul 1 19:04:08 2003 UTC (22 years, 4 months ago) by greg
Tue Jun 24 15:38:07 2003 UTC (22 years, 5 months ago) by greg
Fri Jun 6 01:01:09 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.3: +21 -0 lines
Added mention of latest changes
Fri Mar 21 18:48:45 2003 UTC (22 years, 8 months ago) by greg
Tue Mar 18 04:45:28 2003 UTC (22 years, 8 months ago) by greg
Removed duplicate copies of file and fixed comment in release notes
Sat Mar 15 17:32:55 2003 UTC (22 years, 8 months ago) by greg
