root/radiance/ray/doc/man/man5/metafile.5
Revision: 1.2
Committed: Tue Dec 9 15:59:07 2003 UTC (21 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH METAFILE 5 10/23/98 RADIANCE
3 .SH NAME
4 metafile - graphics command interface, similar to plot(5)
5 .SH DESCRIPTION
6 The
7 .I metafile
8 graphics format was designed with the primary
9 goal of serving as a temporary file for routines which
10 output to dot-matrix and other line-at-a-time devices.
11 As a result, all of the "primitives" are completely self-contained
12 to facilitate sorting.
13 .PP
14 A primitive is a command which can itself be plotted.
15 Into this catagory fall line segments, rectangle and triangle fills,
16 matrix and vector strings.
17 Every primitive has a zeroeth argument which contains bundled attribute
18 information, and an extent.
19 The extent gives the x and y minimum and maximum values which enclose
20 the primitive.
21 The extent is used in sorting, and typically also in describing
22 the primitive.
23 For example, a line segment will be described completely by its
24 enclosing rectangle and attributes including specification
25 of which diagonal the segment falls on.
26 Other primitives will have additional arguments, such as vector string,
27 which must specify the string to be output within its extent.
28 .PP
29 "Global" commands separate the primitives
30 and allow functions which affect all commands.
31 These are commands such as end of page, pause, open and close segment,
32 set, unset and reset, and a special global, end of file.
33 The end of file command is included to facilitate finding the end of
34 file on systems which do not keep track exactly.
35 Global commands sometimes have arguments.
36 The open command, for instance, specifies the name of the segment.
37 Global commands never have extents.
38 .PP
39 The metafile commands are as follows:
40 .TP 3
41 .B F
42 end of file: no arguments.
43 .br
44 When end of file is reached, all processing stops.
45 .TP
46 .B E
47 end of page: no arguments.
48 .br
49 This causes the device to advance to the next screen or page.
50 If the output device is a terminal, it will beep and wait
51 for the user to hit return before clearing the screen.
52 .TP
53 .B P
54 pause: arguments specify the message to be printed.
55 .br
56 This causes output to be flushed and the controlling terminal
57 to be opened.
58 The user is then prompted with the specified string followed by
59 the message "- (hit return to continue)".
60 If no string is specified, the bell is sounded without a message.
61 After the user hits return, output continues.
62 This command is useful when the user is required for some part of
63 the output, such as changing paper or pens.
64 .TP
65 .B D
66 draw global: no arguments.
67 .br
68 This global forces flushing of output and updating of device.
69 .TP
70 .B I
71 include file: arg0 TRUE if standard file.
72 .br
73 The include global causes the contents of the named file to be
74 substituted in the include command's location.
75 If arg0 is 1 (TRUE), a standard location is searched if the
76 file is not found in the working directory.
77 If arg0 is 0 (FALSE), the file must be in the working directory.
78 Include files can be nested to the number of allowed open files.
79 .TP
80 .B S
81 set: arg0 specifies what to set (from meta.h):
82 .nf
83 SALL: place context mark on current settings.
84 SPAT0: set pattern 0 to the specified value.
85 SPAT1: set pattern 1 to the specified value.
86 SPAT2: set pattern 2 to the specified value.
87 SPAT3: set pattern 3 to the specified value.
88 .fi
89 The set command is used to globally affect certain attributes.
90 The zeroeth argument specifies the variable to set, and the
91 arguments following specify the value.
92 Pattern values can have two forms.
93 The first form begins with the letter 'P', immediately followed
94 by an integer between 0 and 11.
95 This selects one from the following patterns: solid,
96 thick \\\\\\, thin \\\\\\, mixed \\\\\\,
97 thick ///, thin ///, mixed ///, crisscross, web.
98 The default pattern settings are: 0=P0, 1=P1, 2=P2, 3=P3.
99 The second form gives the explicit values for a pattern.
100 The set all command makes a context mark with the current settings.
101 All settings which follow can be undone with the unset all command.
102 .TP
103 .B U
104 unset: arg0 specifies what to unset (from meta.h):
105 .nf
106 SALL: return to previous context.
107 SPAT0: set pattern 0 to the previous value.
108 SPAT1: set pattern 1 to the previous value.
109 SPAT2: set pattern 2 to the previous value.
110 SPAT3: set pattern 3 to the previous value.
111 .fi
112 The unset command returns a variable to its previous value.
113 The unset all command returns the settings to the values they had in
114 the previous context.
115 If no context has been marked by set all, variables are returned to
116 their default values.
117 .TP
118 .B R
119 reset: arg0 specifies what to reset (from meta.h):
120 .nf
121 SALL: reset all variables.
122 SPAT0: set pattern 0 to the default value.
123 SPAT1: set pattern 1 to the default value.
124 SPAT2: set pattern 2 to the default value.
125 SPAT3: set pattern 3 to the default value.
126 .fi
127 The reset command returns a variable to its default setting.
128 The reset all command returns all variables to their initial state.
129 .TP
130 .B O
131 open segment: arguments specify segment name.
132 .br
133 The commands following up to a C (close segment) are not to be output,
134 but are to be stored in the named segment.
135 Segment names can contain any ascii character (except newline)
136 in any sequence of reasonable length.
137 Segment definitions are local to the enclosing segment.
138 Side effects should
139 be avoided in segments by balancing calls to set and unset.
140 A segment cannot reference itself.
141 .TP
142 .B C
143 close segment: no arguments.
144 .br
145 The current segment is closed, which completes its usable definition.
146 .TP
147 .B l
148 line segment: fields of arg0 are:
149 .nf
150 100: orientation: positive slope, negative slope.
151 060: type: solid, dashed, dotted, dotted-dashed.
152 014: width: 0, 12, 24, 48, 96 units.
153 003: color: black, red, green, blue.
154 .fi
155 .TP
156 .B r
157 rectangle fill: fields of arg0 are:
158 .nf
159 100: toggle: OR fill, XOR fill.
160 014: pattern: choice of 4 (see set).
161 003: color: black, red, green, blue.
162 .fi
163 Fills the given extent with the specified pattern.
164 Toggle (XOR) fill allows the reversal of previous fills to an area.
165 .TP
166 .B t
167 triangle fill: fields of arg0 are:
168 .nf
169 100: toggle: OR fill, XOR fill.
170 060: orientation: right (& down), up, left, down.
171 014: pattern: choice of 4 (see set).
172 003: color: black, red, green, blue.
173 .fi
174 Fills the given half-rectangle with the specified pattern.
175 A triangle is oriented to the right if the the area between the
176 positive-sloped diagonal and the lower right corner of the
177 extent is filled.
178 Rotating this triangle ccw successively yields up, left and down
179 triangles.
180 Toggle (XOR) fill allows the reversal of previous fills to an area.
181 .TP
182 .B p
183 polygon fill: fields of arg0 are:
184 .nf
185 100: border: no border, line border.
186 060: orientation: right (& down), up, left, down.
187 014: pattern: choice of 4 (see set).
188 003: color: black, red, green, blue.
189 .fi
190 The argument string gives a blank separated list of the polygon
191 vertices in the form: "x0 y0 x1 y1 x2 y2 ... ".
192 The coordinates must be integers ranging between 0 and 16383.
193 The bounding box and orientation will be used to fit the original polygon
194 into a scaled and rotated position.
195 The last vertex will be connected to the first, and the polygon
196 will be filled in with the specified pattern.
197 If a border is requested, one will be drawn of solid black zero width
198 lines.
199 All polygon fills will toggle, therefore other polygon and toggled
200 triangle and rectangle fills will affect the final appearance of the
201 image.
202 For example, a polygon drawn inside another polygon of the same
203 pattern will make a hole.
204 .TP
205 .B m
206 matrix string: fields of arg0 are:
207 .nf
208 100: strike: single, double.
209 060: density: 10 cpi, 12 cpi, 17 cpi, 20 cpi.
210 014: size: normal, double width, double height, double both.
211 003: color: black, red, green, blue.
212 .fi
213 The upper left corner of the extent is used to place the beginning of
214 the string specified after the command.
215 More sophisticated drivers will use the extent for clipping,
216 but the size of the characters will not be altered.
217 .TP
218 .B v
219 vector string: fields of arg0 are:
220 .nf
221 060: orientation: right, up, left, down.
222 014: thickness: 0, 12, 24, 48, 96 units.
223 003: color: black, red, green, blue.
224 .fi
225 The string specified following the command will be made to fit
226 within the given extent.
227 .TP
228 .B s
229 print segment: fields of arg0 are:
230 .nf
231 060: orientation: right, up, left, down.
232 014: thickness: 0, 12, 24, 48, 96 units.
233 003: color: black, red, green, blue.
234 .fi
235 The segment whose name is specified in the arguments will be oriented
236 according to arg0 and made to fit in the given extent.
237 The thickness and color of the lines in the segment will be changed
238 also according to arg0.
239 In the case of area fill, it is the pattern rather than the width
240 which will change.
241 The segment must have been previously defined using the open segment
242 global.
243 Note that matrix strings will not transfer well since they cannot
244 be oriented or scaled.
245 .PP
246 The metafile has two basic formats.
247 The first format is meant to be user readable, and has the form:
248 .nf
249
250 c arg0 xmin ymin xmax ymax `args
251
252 .fi
253 Where c is the single letter command, arg0 is the octal value for
254 arg0, xmin ymin xmax ymax are the extent (ranging from 0 to 16283),
255 and the optional args following the backquote are additional arguments,
256 terminated by a newline.
257 If the command is a global, the extent is not present.
258 If the global has no arg0, 0200 is appropriate.
259 Any global which has a following string must have a value for
260 arg0 (< 0200).
261 Comments are permitted on lines beginning with a pound sign ('#').
262 .PP
263 The second format is roughly equivalent, but packs the extrema into
264 two bytes each.
265 It takes between one quarter and one third as much space, and much
266 less processing to use this type of file, hence it is the default
267 format for all of the programs.
268 Conversion between formats is accomplished with cv(1).
269 .SH FILES
270 The standard location for metafiles used by the programs
271 is /usr/lib/meta/, but can be changed by setting the environment
272 variable MDIR.
273 This is useful for systems where the owner does not have
274 access to the /usr/lib/ directory. It also allows the user
275 to create his own metafiles for vector characters and other symbols.
276 .SH BUGS
277 The command for line segment ('l') is awkward at best.
278 .SH AUTHOR
279 Greg Ward
280 .SH "SEE ALSO"
281 cv(1), meta(3), pexpand(1), primout(3), psort(1)
