1 |
.\" RCSid $Id$ |
2 |
.TH LAMP.TAB 5 2021-08-18 RADIANCE |
3 |
.SH NAME |
4 |
lamp.tab \- table of lamp colors and lumen depreciation factors |
5 |
.SH DESCRIPTION |
6 |
Lamp.tab contains a table of lamp data. The lines are formatted thus: |
7 |
.IP |
8 |
.RI / "light source name re" / |
9 |
.I x y m |
10 |
.PP |
11 |
or |
12 |
.IP |
13 |
.RI / "light source alias re" / |
14 |
.RI ( "light source name" ) |
15 |
.PP |
16 |
The first form gives the color and depreciation of a lamp whose name |
17 |
matches the light source name regular expression. The second gives |
18 |
an alternate name for a light source. Comments beginning with '#' |
19 |
are supported. |
20 |
.SS Notes |
21 |
.IP \(bu |
22 |
Basic regular expressions (original grep) are used with the addition |
23 |
of "\\<" for beginning of word and "\\>" for end-of-word. |
24 |
.IP \(bu |
25 |
.I x |
26 |
and |
27 |
.I y |
28 |
are CIE x and y coordinates. These give the color of the light. See |
29 |
.UR https://www.iso.org/standard/74165.html |
30 |
ISO/CIE 11664-3:2019 |
31 |
.UE |
32 |
\*(lqColorimetry \(em Part 3: Cie Tristimulus Values\*(rq for |
33 |
definitions. |
34 |
.IP \(bu |
35 |
.I m |
36 |
is a "coefficient of depreciation." This is a multiplier used to |
37 |
reduce the output of a lamp to the value it would have after it has |
38 |
been in operation for its expected life. It is used to predict the |
39 |
output of a lighting system comprised of many lamps. See the |
40 |
.I IES Lighting Handbook |
41 |
for more information. |
42 |
.IP \(bu |
43 |
Any character except '#' may be used to delimit the light source name |
44 |
regular expression; '/' is conventional, but not required. |
45 |
.IP \(bu |
46 |
Regular expressions may contain '\\' followed by the delimiter |
47 |
character; aliases may contain '\\' followed by ')'. |
48 |
.IP \(bu |
49 |
Comments begin with '#' and may occur at the end of any line. |
50 |
.IP \(bu |
51 |
Blank lines are ignored. |
52 |
.SH AUTHOR |
53 |
Greg Ward |
54 |
.SH SEE ALSO |
55 |
.BR ies2rad (1), |
56 |
.BR pfilt (1) |
