root/Development/ray/doc/man/man3/meta.3
Revision: 1.2
Committed: Tue Dec 9 15:59:07 2003 UTC (21 years, 11 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH META 3 11/15/93 Radiance
3 .SH NAME
4 libmeta.a - simplified interface to metafile(5)
5 .SH SYNOPSIS
6 .B extern FILE *pout;
7 .PP
8 .B mline(x, y, type, thick, color)
9 .PP
10 .B mpoly(x, y, border, pat, color)
11 .PP
12 .B mdraw(x, y)
13 .PP
14 .B mtext(x, y, s, cpi, color)
15 .br
16 .B char *s;
17 .PP
18 mvstr(xmin, ymin, xmax, ymax, s, d, thick, color)
19 .br
20 .B char *s;
21 .PP
22 mrectangle(xmin, ymin, xmax, ymax, pat, color)
23 .PP
24 mtriangle(xmin, ymin, xmax, ymax, d, pat, color)
25 .PP
26 msegment(xmin, ymin, xmax, ymax, sname, d, thick, color)
27 .br
28 .B char *sname;
29 .PP
30 .B msetpat(pat, pattern)
31 .br
32 .B char *pattern;
33 .PP
34 .B mopenseg(sname)
35 .br
36 .B char *sname;
37 .PP
38 .B mcloseseg()
39 .PP
40 .B minclude(fname)
41 .br
42 .B char *fname;
43 .PP
44 .B mendpage()
45 .PP
46 .B mdone()
47 .SH DESCRIPTION
48 The routines in
49 .I libmeta
50 provide a simple interface to the metafile(5) 2D graphics stream.
51 Output from these routines is sent to
52 .I pout.
53 .I Pout
54 defaults to the standard output,
55 and should be piped to the appropriate device driver.
56 .PP
57 All coordinates range from 0 to 16383 and map to a square area on
58 the output device.
59 .I D
60 values are one of 'r', 'u', 'l' and 'd' corresponding to right,
61 up, left, and down respectively.
62 .I Color
63 values range from 0 to 3 and normally correspond to black,
64 cyan, green and blue.
65 .I Pattern
66 values range from 0 to 3 and default to solid, thick lines,
67 thin lines, and candystripe.
68 Pattern value mapping may be changed via
69 .I setpat.
70 All strings are null-terminated, and do not contain newlines.
71 .PP
72 .I Mline
73 starts a line at the given coordinates.
74 The line
75 .I type
76 is a number from 0 to 3 corresponding to solid, dashed, dotted,
77 and dot-dashed.
78 The line thickness,
79 .I thick,
80 is a number from 0 to 3.
81 Connected lines are drawn with successive calls to
82 .I mdraw.
83 .PP
84 .I Mpoly
85 starts a polygon at the given coordinates.
86 The boolean
87 .I border
88 specifies whether or not a border is desired around the polygon.
89 .I Mdraw
90 is used to add vertices to the polygon.
91 The polygon will be closed automatically after the last call.
92 .PP
93 .I Mtext
94 prints a string of hardware characters starting at the given
95 coordinates.
96 The characters per inch are
97 .I cpi.
98 Text is always oriented to the right.
99 .PP
100 .I Mvstr
101 places a vector character string within the given boundaries.
102 The string is oriented according to
103 .I d.
104 The character line thickness is given by
105 .I thick.
106 .PP
107 .I Mrectangle
108 fills the given box with
109 .I pat.
110 .I Mtriangle
111 fills the half-box with orientation
112 .I d
113 in the given boundaries.
114 Right corresponds to a triangle in the lower right half of the
115 box.
116 Up corresponds to a triangle in the upper right, left is upper
117 left, and down is lower left.
118 .PP
119 .I Msegment
120 places an instance of the segment
121 .I sname
122 within the given boundaries.
123 The segment is oriented according to
124 .I d,
125 where 'r' is null rotation.
126 If either
127 .I thick
128 or
129 .I color
130 is nonzero,
131 its value will replace corresponding values in the segment
132 primitives. (For area filling, thick changes the fill pattern.)
133 .PP
134 .I Msetpat
135 maps
136 .I pat
137 to
138 .I pattern.
139 .I Pattern
140 is a string of the form "Pn" where n is a number between 0 and 11.
141 .PP
142 .I Mopenseg
143 opens the segment named
144 .I sname.
145 All graphics calls up to a matching call to
146 .I mcloseseg
147 are stored under
148 .I sname.
149 An instance of the segment is obtained with a call to
150 .I msegment.
151 Segments can be nested to any level, and redefining segments
152 is allowed.
153 Beware of calls to
154 .I mtext
155 within a segment, since text will not rotate or scale.
156 .PP
157 .I Minclude
158 includes the graphics metafile
159 .I fname
160 in the output stream.
161 .I Mendpage
162 advances to the next screen or page.
163 On a terminal, the bell rings and a line is read to prevent
164 premature erasure.
165 .I Mdone
166 completes metafile output, and is the only required call.
167 .SH DIAGNOSTICS
168 None.
169 .SH SEE ALSO
170 t4014(1), mx80(1), impress(1), primout(3), metafile(5)
