root/radiance/ray/doc/man/man3/meta.3
Revision: 1.2
Committed: Tue Dec 9 15:59:07 2003 UTC (21 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Fixed RCSid specification
# User Rev Content
1 greg 1.2 .\" RCSid "$Id$"
2 greg 1.1 .TH META 3 11/15/93 Radiance
3     .SH NAME
4     libmeta.a - simplified interface to metafile(5)
5     .SH SYNOPSIS
6     .B extern FILE *pout;
7     .PP
8     .B mline(x, y, type, thick, color)
9     .PP
10     .B mpoly(x, y, border, pat, color)
11     .PP
12     .B mdraw(x, y)
13     .PP
14     .B mtext(x, y, s, cpi, color)
15     .br
16     .B char *s;
17     .PP
18     mvstr(xmin, ymin, xmax, ymax, s, d, thick, color)
19     .br
20     .B char *s;
21     .PP
22     mrectangle(xmin, ymin, xmax, ymax, pat, color)
23     .PP
24     mtriangle(xmin, ymin, xmax, ymax, d, pat, color)
25     .PP
26     msegment(xmin, ymin, xmax, ymax, sname, d, thick, color)
27     .br
28     .B char *sname;
29     .PP
30     .B msetpat(pat, pattern)
31     .br
32     .B char *pattern;
33     .PP
34     .B mopenseg(sname)
35     .br
36     .B char *sname;
37     .PP
38     .B mcloseseg()
39     .PP
40     .B minclude(fname)
41     .br
42     .B char *fname;
43     .PP
44     .B mendpage()
45     .PP
46     .B mdone()
47     .SH DESCRIPTION
48     The routines in
49     .I libmeta
50     provide a simple interface to the metafile(5) 2D graphics stream.
51     Output from these routines is sent to
52     .I pout.
53     .I Pout
54     defaults to the standard output,
55     and should be piped to the appropriate device driver.
56     .PP
57     All coordinates range from 0 to 16383 and map to a square area on
58     the output device.
59     .I D
60     values are one of 'r', 'u', 'l' and 'd' corresponding to right,
61     up, left, and down respectively.
62     .I Color
63     values range from 0 to 3 and normally correspond to black,
64     cyan, green and blue.
65     .I Pattern
66     values range from 0 to 3 and default to solid, thick lines,
67     thin lines, and candystripe.
68     Pattern value mapping may be changed via
69     .I setpat.
70     All strings are null-terminated, and do not contain newlines.
71     .PP
72     .I Mline
73     starts a line at the given coordinates.
74     The line
75     .I type
76     is a number from 0 to 3 corresponding to solid, dashed, dotted,
77     and dot-dashed.
78     The line thickness,
79     .I thick,
80     is a number from 0 to 3.
81     Connected lines are drawn with successive calls to
82     .I mdraw.
83     .PP
84     .I Mpoly
85     starts a polygon at the given coordinates.
86     The boolean
87     .I border
88     specifies whether or not a border is desired around the polygon.
89     .I Mdraw
90     is used to add vertices to the polygon.
91     The polygon will be closed automatically after the last call.
92     .PP
93     .I Mtext
94     prints a string of hardware characters starting at the given
95     coordinates.
96     The characters per inch are
97     .I cpi.
98     Text is always oriented to the right.
99     .PP
100     .I Mvstr
101     places a vector character string within the given boundaries.
102     The string is oriented according to
103     .I d.
104     The character line thickness is given by
105     .I thick.
106     .PP
107     .I Mrectangle
108     fills the given box with
109     .I pat.
110     .I Mtriangle
111     fills the half-box with orientation
112     .I d
113     in the given boundaries.
114     Right corresponds to a triangle in the lower right half of the
115     box.
116     Up corresponds to a triangle in the upper right, left is upper
117     left, and down is lower left.
118     .PP
119     .I Msegment
120     places an instance of the segment
121     .I sname
122     within the given boundaries.
123     The segment is oriented according to
124     .I d,
125     where 'r' is null rotation.
126     If either
127     .I thick
128     or
129     .I color
130     is nonzero,
131     its value will replace corresponding values in the segment
132     primitives. (For area filling, thick changes the fill pattern.)
133     .PP
134     .I Msetpat
135     maps
136     .I pat
137     to
138     .I pattern.
139     .I Pattern
140     is a string of the form "Pn" where n is a number between 0 and 11.
141     .PP
142     .I Mopenseg
143     opens the segment named
144     .I sname.
145     All graphics calls up to a matching call to
146     .I mcloseseg
147     are stored under
148     .I sname.
149     An instance of the segment is obtained with a call to
150     .I msegment.
151     Segments can be nested to any level, and redefining segments
152     is allowed.
153     Beware of calls to
154     .I mtext
155     within a segment, since text will not rotate or scale.
156     .PP
157     .I Minclude
158     includes the graphics metafile
159     .I fname
160     in the output stream.
161     .I Mendpage
162     advances to the next screen or page.
163     On a terminal, the bell rings and a line is read to prevent
164     premature erasure.
165     .I Mdone
166     completes metafile output, and is the only required call.
167     .SH DIAGNOSTICS
168     None.
169     .SH SEE ALSO
170     t4014(1), mx80(1), impress(1), primout(3), metafile(5)
