1 |
.\" RCSid "$Id: xshowtrace.1,v 1.2 2003/12/09 15:59:07 greg Exp $" |
2 |
.TH XSHOWTRACE 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
xshowtrace - interactively show rays traced on RADIANCE image under X11 |
5 |
.SH SYNOPSIS |
6 |
.B xshowtrace |
7 |
8 |
.B \-s |
9 |
10 |
.B "rtrace options" |
11 |
12 |
.B octree |
13 |
.B picture |
14 |
.SH DESCRIPTION |
15 |
.I Xshowtrace |
16 |
takes a RADIANCE octree and a picture file |
17 |
and displays it on an X11 window server using |
18 |
.I ximage(1). |
19 |
The picture should have been created from a previous |
20 |
.I rpict(1) |
21 |
or |
22 |
.I rvu(1) |
23 |
calculation using the given octree. |
24 |
Once the image is displayed, the user can use the 't' command of |
25 |
.I ximage |
26 |
to select points on the image to display the ray tree. |
27 |
.I Rtrace |
28 |
then produces a ray tree, which |
29 |
.I xshowtrace |
30 |
will display (in red on a color screen). |
31 |
The |
32 |
.I \-s |
33 |
option slows the display of each ray traced to make it easier to |
34 |
follow the process. |
35 |
.SH AUTHOR |
36 |
Greg Ward |
37 |
.SH BUGS |
38 |
If the pointer is moved between the time 't' is pressed and |
39 |
.I xshowtrace |
40 |
starts drawing rays, the rays will be displaced. |
41 |
.SH "SEE ALSO" |
42 |
oconv(1), rpict(1), rtrace(1), rvu(1), ximage(1) |
