1 |
.\" RCSid "$Id: ximage.1,v 1.3 2003/12/09 15:59:07 greg Exp $" |
2 |
.TH XIMAGE 1 10/27/98 RADIANCE |
3 |
.SH NAME |
4 |
ximage - RADIANCE picture display for X window system |
5 |
.SH SYNOPSIS |
6 |
.B ximage |
7 |
8 |
.B \=geometry |
9 |
10 |
.B "\-di display" |
11 |
12 |
.B "\-c ncolors" |
13 |
14 |
.B \-d |
15 |
16 |
.B \-b |
17 |
18 |
.B \-m |
19 |
20 |
.B "\-g gamma" |
21 |
22 |
.B \-f |
23 |
24 |
.B "\-e spec |
25 |
26 |
.BI -o spec |
27 |
28 |
.B "\-t intvl" |
29 |
30 |
.B \-s |
31 |
32 |
.B "picture .." |
33 |
.SH DESCRIPTION |
34 |
.I Ximage |
35 |
takes one or more RADIANCE picture files |
36 |
and displays them on an X server. |
37 |
The |
38 |
.I \-c |
39 |
option specifies the number of colors to use (default fills color table). |
40 |
The |
41 |
.I \-d |
42 |
option turns off color dithering. |
43 |
The |
44 |
.I \-b |
45 |
option displays the image in black and white (greyscale). |
46 |
The |
47 |
.I \-m |
48 |
option forces monochrome output. |
49 |
The |
50 |
.I \-g |
51 |
option specifies the exponent used in gamma correction; |
52 |
the default value is 2.2. |
53 |
The |
54 |
.I \-f |
55 |
option stores a Pixmap on the server side for faster refresh. |
56 |
This may not work with large images on some servers. |
57 |
The |
58 |
.I \-o |
59 |
option specifies a sequence of information to print to the standard |
60 |
output for the 't' command (see below). |
61 |
The |
62 |
.I \-t |
63 |
option specifies a minimum interval (in milliseconds) |
64 |
between successive ray outputs |
65 |
in mouse tracking mode (right button pressed). |
66 |
.PP |
67 |
The |
68 |
.I \-e |
69 |
option specifies an exposure compensation in f-stops (powers of two). |
70 |
Only integer stops are allowed, for efficiency. |
71 |
If the special word, |
72 |
.I auto |
73 |
is given instead of a number of stops, then |
74 |
.I ximage |
75 |
performs an automatic exposure adjustment similar to |
76 |
.I pcond(1), |
77 |
compressing the dynamic range of the image to fit |
78 |
within the dynamic range of the display. |
79 |
80 |
.I human |
81 |
is given instead, then |
82 |
.I ximage |
83 |
performs an exposure adjustment similar to |
84 |
.I pcond |
85 |
with the |
86 |
.I \-s |
87 |
and |
88 |
.I \-c |
89 |
options, which compensate for human contrast and color sensitivity |
90 |
at the corresponding scene luminance levels. |
91 |
This option yeilds and appearance of the scene on the display that |
92 |
closely matches what would be experienced in the real world. |
93 |
.PP |
94 |
The |
95 |
.I \-s |
96 |
option tells |
97 |
.I ximage |
98 |
to display multiple pictures sequentially, rather than all at once. |
99 |
If no |
100 |
.I picture |
101 |
is given, input is read from stdin provided either the |
102 |
.I \-b |
103 |
or |
104 |
.I \-m |
105 |
option is in effect, or the X server is capable of 24-bit color. |
106 |
However, many of the commands given below will not work. |
107 |
.SH COMMANDS |
108 |
Once a picture is displayed, the user |
109 |
may perform a number of operations. |
110 |
Some of the operations make use of an area of interest, defined by pressing |
111 |
the left mouse button and dragging the cursor over a section of the image. |
112 |
Pressing the button and immediately releasing it defines a single point as |
113 |
the area of interest. |
114 |
A command is a single character. |
115 |
.TP 10n |
116 |
.BR q |
117 |
Quit picture. |
118 |
(Also Q or ^D.)\0 |
119 |
.TP 10 |
120 |
.BR <space> |
121 |
Redraw the area of interest. |
122 |
.TP 10 |
123 |
.BR ^R |
124 |
Redraw the entire image. |
125 |
.TP |
126 |
.BR <return> |
127 |
Display the radiance averaged over the area of interest. |
128 |
.TP |
129 |
.BR l |
130 |
Display the luminance value in the area of interest. |
131 |
This assumes that the image was correctly computed in terms of |
132 |
luminance. |
133 |
.TP |
134 |
.BR c |
135 |
Display the color in the area of interest. |
136 |
.TP |
137 |
.BR p |
138 |
Display the x and y location of the cursor. |
139 |
.TP |
140 |
.BR i |
141 |
Identify identical pixels by assigning a random color at the cursor position. |
142 |
This is useful for displaying contours, especially when combined |
143 |
with the -b option. |
144 |
.TP |
145 |
.BR t |
146 |
Print information about the pixel under the cursor |
147 |
according to the string following the |
148 |
.I \-o |
149 |
command line option. |
150 |
The valid characters for this option correspond roughly to the other |
151 |
.I ximage |
152 |
commands: |
153 |
.IP |
154 |
o ray origin |
155 |
.IP |
156 |
d ray direction |
157 |
.IP |
158 |
v radiance value |
159 |
.IP |
160 |
l luminance value |
161 |
.IP |
162 |
p pixel position |
163 |
.IP |
164 |
The default output is "-ood", which prints |
165 |
the ray origin and direction. |
166 |
This can be used as input to rtrace(1) to get additional information |
167 |
about the image (ie. pipe the output of ximage into rtrace). |
168 |
Pressing the middle mouse button is equivalent to typing the 't' key. |
169 |
Pressing and holding the right mouse button is equivalent to |
170 |
continuously pressing the 't' key. |
171 |
.TP |
172 |
.BR = |
173 |
Adjust the exposure to the area of interest. |
174 |
A crude adjustment is made immediately, and the number of stops |
175 |
is printed while the colors are resampled. |
176 |
After a few seconds to a minute, the final image is redisplayed. |
177 |
If the area of interest is already within 1/2 stop of the ideal, |
178 |
no adjustment is made. |
179 |
.TP |
180 |
.BR @ |
181 |
Same as '=' command, only the exposure is adjusted to provide |
182 |
roughly the same visibility for the selected region |
183 |
on screen as a viewer would experience |
184 |
in the actual space. |
185 |
Like the 'l' command, this adjustment assumes that the image |
186 |
has been correctly computed in terms of luminance. |
187 |
(See also the 'h' command, below.) |
188 |
.TP |
189 |
.BR a |
190 |
Perform automatic exposure compensation, as if |
191 |
.I ximage |
192 |
were started with the |
193 |
.I "\-e auto" |
194 |
option. |
195 |
If a rectangular area has been selected, the pixels in this region |
196 |
will be emphasized in the histogram, offering this area exposure preference. |
197 |
(Each pixel within the rectangle will be weighted as 21 outside pixels.) |
198 |
.TP |
199 |
.BR h |
200 |
Perform human expsoure compensation, as if |
201 |
.I ximage |
202 |
203 |
.I "\-e human" |
204 |
option. |
205 |
See the 'a' command above regarding pixel weighting. |
206 |
.TP |
207 |
.BR 0 |
208 |
Reset the origin to the upper left corner of the image. |
209 |
This command is used to restore the original image position after |
210 |
using the shift or control key with the mouse to relocate the image |
211 |
within the frame (see below). |
212 |
.TP |
213 |
.BR f |
214 |
Switch on the fast redraw option |
215 |
.I (\-f), |
216 |
loading the image pixmap over to the server side. |
217 |
This command is useful when network delays are causing slow image |
218 |
refresh, and the user didn't notice it until after |
219 |
.I ximage |
220 |
was started. |
221 |
.TP |
222 |
.BR F |
223 |
Switch off the fast redraw option. |
224 |
This frees up some memory on the server, as well as the color table |
225 |
for other windows. |
226 |
.PP |
227 |
In addition to the commands listed above, the control or shift key may |
228 |
be held while the cursor is dragged to reposition the image within the |
229 |
window. |
230 |
.SH "X RESOURCES" |
231 |
radiance.gamma the default gamma correction value |
232 |
.SH ENVIRONMENT |
233 |
DISPLAY_GAMMA the default gamma correction value |
234 |
.SH AUTHORS |
235 |
Greg Ward |
236 |
.br |
237 |
Anat Grynberg (Paris) |
238 |
.br |
239 |
Philip Thompson (MIT) |
240 |
.SH "SEE ALSO" |
241 |
aedimage(1), normtiff(1), pcond(1), pfilt(1), rpict(1), rtrace(1), |
242 |
rvu(1), xglaresrc(1), xshowtrace(1) |
