root/radiance/ray/doc/man/man1/ximage.1
Revision: 1.5
Committed: Tue Sep 4 17:36:41 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.4: +3 -3 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: ximage.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
2 .TH XIMAGE 1 10/27/98 RADIANCE
3 .SH NAME
4 ximage - RADIANCE picture display for X window system
5 .SH SYNOPSIS
6 .B ximage
7 [
8 .B \=geometry
9 ][
10 .B "\-di display"
11 ][
12 .B "\-c ncolors"
13 ][
14 .B \-d
15 ][
16 .B \-b
17 ][
18 .B \-m
19 ][
20 .B "\-g gamma"
21 ][
22 .B \-f
23 ][
24 .B "\-e spec
25 ][
26 .BI -o spec
27 ][
28 .B "\-t intvl"
29 ][
30 .B \-s
31 ]
32 .B "picture .."
33 .SH DESCRIPTION
34 .I Ximage
35 takes one or more RADIANCE picture files
36 and displays them on an X server.
37 The
38 .I \-c
39 option specifies the number of colors to use (default fills color table).
40 The
41 .I \-d
42 option turns off color dithering.
43 The
44 .I \-b
45 option displays the image in black and white (greyscale).
46 The
47 .I \-m
48 option forces monochrome output.
49 The
50 .I \-g
51 option specifies the exponent used in gamma correction;
52 the default value is 2.2.
53 The
54 .I \-f
55 option stores a Pixmap on the server side for faster refresh.
56 This may not work with large images on some servers.
57 The
58 .I \-o
59 option specifies a sequence of information to print to the standard
60 output for the 't' command (see below).
61 The
62 .I \-t
63 option specifies a minimum interval (in milliseconds)
64 between successive ray outputs
65 in mouse tracking mode (right button pressed).
66 .PP
67 The
68 .I \-e
69 option specifies an exposure compensation in f-stops (powers of two).
70 Only integer stops are allowed, for efficiency.
71 If the special word,
72 .I auto
73 is given instead of a number of stops, then
74 .I ximage
75 performs an automatic exposure adjustment similar to
76 .I pcond(1),
77 compressing the dynamic range of the image to fit
78 within the dynamic range of the display.
79 If the special word,
80 .I human
81 is given instead, then
82 .I ximage
83 performs an exposure adjustment similar to
84 .I pcond
85 with the
86 .I \-s
87 and
88 .I \-c
89 options, which compensate for human contrast and color sensitivity
90 at the corresponding scene luminance levels.
91 This option yeilds and appearance of the scene on the display that
92 closely matches what would be experienced in the real world.
93 .PP
94 The
95 .I \-s
96 option tells
97 .I ximage
98 to display multiple pictures sequentially, rather than all at once.
99 If no
100 .I picture
101 is given, input is read from stdin provided either the
102 .I \-b
103 or
104 .I \-m
105 option is in effect, or the X server is capable of 24-bit color.
106 However, many of the commands given below will not work.
107 .SH COMMANDS
108 Once a picture is displayed, the user
109 may perform a number of operations.
110 Some of the operations make use of an area of interest, defined by pressing
111 the left mouse button and dragging the cursor over a section of the image.
112 Pressing the button and immediately releasing it defines a single point as
113 the area of interest.
114 A command is a single character.
115 .TP 10n
116 .BR q
117 Quit picture.
118 (Also Q or ^D.)\0
119 .TP 10
120 .BR <space>
121 Redraw the area of interest.
122 .TP 10
123 .BR ^R
124 Redraw the entire image.
125 .TP
126 .BR <return>
127 Display the radiance averaged over the area of interest.
128 .TP
129 .BR l
130 Display the luminance value in the area of interest.
131 This assumes that the image was correctly computed in terms of
132 luminance.
133 .TP
134 .BR c
135 Display the color in the area of interest.
136 .TP
137 .BR p
138 Display the x and y location of the cursor.
139 .TP
140 .BR i
141 Identify identical pixels by assigning a random color at the cursor position.
142 This is useful for displaying contours, especially when combined
143 with the \-b option.
144 .TP
145 .BR t
146 Print information about the pixel under the cursor
147 according to the string following the
148 .I \-o
149 command line option.
150 The valid characters for this option correspond roughly to the other
151 .I ximage
152 commands:
153 .IP
154 o ray origin
155 .IP
156 d ray direction
157 .IP
158 v radiance value
159 .IP
160 l luminance value
161 .IP
162 p pixel position
163 .IP
164 The default output is "\-ood", which prints
165 the ray origin and direction.
166 This can be used as input to rtrace(1) to get additional information
167 about the image (ie. pipe the output of ximage into rtrace).
168 Pressing the middle mouse button is equivalent to typing the 't' key.
169 Pressing and holding the right mouse button is equivalent to
170 continuously pressing the 't' key.
171 .TP
172 .BR =
173 Adjust the exposure to the area of interest.
174 A crude adjustment is made immediately, and the number of stops
175 is printed while the colors are resampled.
176 After a few seconds to a minute, the final image is redisplayed.
177 If the area of interest is already within 1/2 stop of the ideal,
178 no adjustment is made.
179 .TP
180 .BR @
181 Same as '=' command, only the exposure is adjusted to provide
182 roughly the same visibility for the selected region
183 on screen as a viewer would experience
184 in the actual space.
185 Like the 'l' command, this adjustment assumes that the image
186 has been correctly computed in terms of luminance.
187 (See also the 'h' command, below.)
188 .TP
189 .BR a
190 Perform automatic exposure compensation, as if
191 .I ximage
192 were started with the
193 .I "\-e auto"
194 option.
195 If a rectangular area has been selected, the pixels in this region
196 will be emphasized in the histogram, offering this area exposure preference.
197 (Each pixel within the rectangle will be weighted as 21 outside pixels.)
198 .TP
199 .BR h
200 Perform human expsoure compensation, as if
201 .I ximage
202 were started with the
203 .I "\-e human"
204 option.
205 See the 'a' command above regarding pixel weighting.
206 .TP
207 .BR 0
208 Reset the origin to the upper left corner of the image.
209 This command is used to restore the original image position after
210 using the shift or control key with the mouse to relocate the image
211 within the frame (see below).
212 .TP
213 .BR f
214 Switch on the fast redraw option
215 .I (\-f),
216 loading the image pixmap over to the server side.
217 This command is useful when network delays are causing slow image
218 refresh, and the user didn't notice it until after
219 .I ximage
220 was started.
221 .TP
222 .BR F
223 Switch off the fast redraw option.
224 This frees up some memory on the server, as well as the color table
225 for other windows.
226 .PP
227 In addition to the commands listed above, the control or shift key may
228 be held while the cursor is dragged to reposition the image within the
229 window.
230 .SH "X RESOURCES"
231 radiance.gamma the default gamma correction value
232 .SH ENVIRONMENT
233 DISPLAY_GAMMA the default gamma correction value
234 .SH AUTHORS
235 Greg Ward
236 .br
237 Anat Grynberg (Paris)
238 .br
239 Philip Thompson (MIT)
240 .SH "SEE ALSO"
241 aedimage(1), normtiff(1), pcond(1), pfilt(1), rpict(1), rtrace(1),
242 rvu(1), xglaresrc(1), xshowtrace(1)
