root/radiance/ray/doc/man/man1/ximage.1
Revision: 1.10
Committed: Tue Sep 10 20:24:42 2024 UTC (9 months, 1 week ago) by greg
Changes since 1.9: +5 -1 lines
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
# User Rev Content
1 greg 1.10 .\" RCSid "$Id: ximage.1,v 1.9 2019/07/20 02:07:23 greg Exp $"
2 greg 1.1 .TH XIMAGE 1 10/27/98 RADIANCE
3     .SH NAME
4 greg 1.2 ximage - RADIANCE picture display for X window system
5 greg 1.1 .SH SYNOPSIS
6     .B ximage
7     [
8     .B \=geometry
9     ][
10     .B "\-di display"
11     ][
12     .B "\-c ncolors"
13     ][
14     .B \-d
15     ][
16     .B \-b
17     ][
18     .B \-m
19     ][
20     .B "\-g gamma"
21     ][
22     .B \-f
23     ][
24     .B "\-e spec
25     ][
26     .BI -o spec
27     ][
28     .B "\-t intvl"
29     ][
30     .B \-s
31     ]
32     .B "picture .."
33     .SH DESCRIPTION
34     .I Ximage
35     takes one or more RADIANCE picture files
36     and displays them on an X server.
37     The
38     .I \-c
39     option specifies the number of colors to use (default fills color table).
40     The
41     .I \-d
42     option turns off color dithering.
43     The
44     .I \-b
45     option displays the image in black and white (greyscale).
46     The
47     .I \-m
48     option forces monochrome output.
49     The
50     .I \-g
51     option specifies the exponent used in gamma correction;
52     the default value is 2.2.
53     The
54     .I \-f
55     option stores a Pixmap on the server side for faster refresh.
56     This may not work with large images on some servers.
57     The
58     .I \-o
59     option specifies a sequence of information to print to the standard
60     output for the 't' command (see below).
61     The
62     .I \-t
63     option specifies a minimum interval (in milliseconds)
64     between successive ray outputs
65     in mouse tracking mode (right button pressed).
66     .PP
67     The
68     .I \-e
69     option specifies an exposure compensation in f-stops (powers of two).
70     Only integer stops are allowed, for efficiency.
71     If the special word,
72     .I auto
73     is given instead of a number of stops, then
74     .I ximage
75     performs an automatic exposure adjustment similar to
76     .I pcond(1),
77     compressing the dynamic range of the image to fit
78     within the dynamic range of the display.
79     If the special word,
80     .I human
81     is given instead, then
82     .I ximage
83     performs an exposure adjustment similar to
84     .I pcond
85     with the
86     .I \-s
87     and
88     .I \-c
89     options, which compensate for human contrast and color sensitivity
90     at the corresponding scene luminance levels.
91 greg 1.8 This option yields and appearance of the scene on the display that
92 greg 1.1 closely matches what would be experienced in the real world.
93     .PP
94     The
95     .I \-s
96     option tells
97     .I ximage
98     to display multiple pictures sequentially, rather than all at once.
99     If no
100     .I picture
101     is given, input is read from stdin provided either the
102     .I \-b
103     or
104     .I \-m
105     option is in effect, or the X server is capable of 24-bit color.
106     However, many of the commands given below will not work.
107     .SH COMMANDS
108     Once a picture is displayed, the user
109     may perform a number of operations.
110     Some of the operations make use of an area of interest, defined by pressing
111     the left mouse button and dragging the cursor over a section of the image.
112     Pressing the button and immediately releasing it defines a single point as
113     the area of interest.
114     A command is a single character.
115     .TP 10n
116     .BR q
117     Quit picture.
118     (Also Q or ^D.)\0
119     .TP 10
120     .BR <space>
121     Redraw the area of interest.
122     .TP 10
123     .BR ^R
124     Redraw the entire image.
125     .TP
126     .BR <return>
127     Display the radiance averaged over the area of interest.
128 greg 1.6 The maximum of the three (RGB) channels is reported.
129 greg 1.1 .TP
130     .BR l
131 greg 1.7 Display the photometrically-weighted luminance value in the area of interest.
132 greg 1.1 This assumes that the image was correctly computed in terms of
133     luminance.
134     .TP
135     .BR c
136 greg 1.6 Display the color in the area of interest, as adjusted by the current
137     exposure setting.
138 greg 1.1 .TP
139     .BR p
140     Display the x and y location of the cursor.
141     .TP
142     .BR i
143     Identify identical pixels by assigning a random color at the cursor position.
144     This is useful for displaying contours, especially when combined
145 greg 1.5 with the \-b option.
146 greg 1.1 .TP
147     .BR t
148     Print information about the pixel under the cursor
149     according to the string following the
150     .I \-o
151     command line option.
152     The valid characters for this option correspond roughly to the other
153     .I ximage
154     commands:
155     .IP
156     o ray origin
157     .IP
158     d ray direction
159     .IP
160     v radiance value
161     .IP
162     l luminance value
163     .IP
164     p pixel position
165     .IP
166 greg 1.5 The default output is "\-ood", which prints
167 greg 1.1 the ray origin and direction.
168     This can be used as input to rtrace(1) to get additional information
169     about the image (ie. pipe the output of ximage into rtrace).
170     Pressing the middle mouse button is equivalent to typing the 't' key.
171     Pressing and holding the right mouse button is equivalent to
172     continuously pressing the 't' key.
173     .TP
174     .BR =
175     Adjust the exposure to the area of interest.
176     A crude adjustment is made immediately, and the number of stops
177     is printed while the colors are resampled.
178     After a few seconds to a minute, the final image is redisplayed.
179     If the area of interest is already within 1/2 stop of the ideal,
180     no adjustment is made.
181     .TP
182     .BR @
183     Same as '=' command, only the exposure is adjusted to provide
184     roughly the same visibility for the selected region
185     on screen as a viewer would experience
186     in the actual space.
187     Like the 'l' command, this adjustment assumes that the image
188     has been correctly computed in terms of luminance.
189     (See also the 'h' command, below.)
190     .TP
191     .BR a
192     Perform automatic exposure compensation, as if
193     .I ximage
194     were started with the
195     .I "\-e auto"
196     option.
197     If a rectangular area has been selected, the pixels in this region
198     will be emphasized in the histogram, offering this area exposure preference.
199     (Each pixel within the rectangle will be weighted as 21 outside pixels.)
200     .TP
201     .BR h
202     Perform human expsoure compensation, as if
203     .I ximage
204     were started with the
205     .I "\-e human"
206     option.
207     See the 'a' command above regarding pixel weighting.
208     .TP
209     .BR 0
210     Reset the origin to the upper left corner of the image.
211     This command is used to restore the original image position after
212     using the shift or control key with the mouse to relocate the image
213     within the frame (see below).
214     .TP
215     .BR f
216     Switch on the fast redraw option
217     .I (\-f),
218     loading the image pixmap over to the server side.
219     This command is useful when network delays are causing slow image
220     refresh, and the user didn't notice it until after
221     .I ximage
222     was started.
223     .TP
224     .BR F
225     Switch off the fast redraw option.
226     This frees up some memory on the server, as well as the color table
227     for other windows.
228     .PP
229     In addition to the commands listed above, the control or shift key may
230     be held while the cursor is dragged to reposition the image within the
231     window.
232 greg 1.10 .SH NOTES
233     Hyperspectral Radiance pictures (.hsr files) are understood and crudely
234     converted to RGB for display.
235     However, the colors may not be very accurate.
236 greg 1.1 .SH "X RESOURCES"
237     radiance.gamma the default gamma correction value
238     .SH ENVIRONMENT
239     DISPLAY_GAMMA the default gamma correction value
240     .SH AUTHORS
241     Greg Ward
242     .br
243     Anat Grynberg (Paris)
244     .br
245     Philip Thompson (MIT)
246     .SH "SEE ALSO"
247 greg 1.9 aedimage(1), normtiff(1), pcond(1), pfilt(1), rcode_depth(1),
248     rcode_ident(1), rcode_norm(1), rpict(1), rtrace(1),
249 greg 1.4 rvu(1), xglaresrc(1), xshowtrace(1)
