root/radiance/ray/doc/man/man1/ximage.1
Revision: 1.7
Committed: Thu Jan 7 17:54:56 2010 UTC (15 years, 4 months ago) by greg
Further clarification
1 .\" RCSid "$Id: ximage.1,v 1.6 2010/01/07 17:52:38 greg Exp $"
2 .TH XIMAGE 1 10/27/98 RADIANCE
3 .SH NAME
4 ximage - RADIANCE picture display for X window system
5 .SH SYNOPSIS
6 .B ximage
7 [
8 .B \=geometry
9 ][
10 .B "\-di display"
11 ][
12 .B "\-c ncolors"
13 ][
14 .B \-d
15 ][
16 .B \-b
17 ][
18 .B \-m
19 ][
20 .B "\-g gamma"
21 ][
22 .B \-f
23 ][
24 .B "\-e spec
25 ][
26 .BI -o spec
27 ][
28 .B "\-t intvl"
29 ][
30 .B \-s
31 ]
32 .B "picture .."
33 .SH DESCRIPTION
34 .I Ximage
35 takes one or more RADIANCE picture files
36 and displays them on an X server.
37 The
38 .I \-c
39 option specifies the number of colors to use (default fills color table).
40 The
41 .I \-d
42 option turns off color dithering.
43 The
44 .I \-b
45 option displays the image in black and white (greyscale).
46 The
47 .I \-m
48 option forces monochrome output.
49 The
50 .I \-g
51 option specifies the exponent used in gamma correction;
52 the default value is 2.2.
53 The
54 .I \-f
55 option stores a Pixmap on the server side for faster refresh.
56 This may not work with large images on some servers.
57 The
58 .I \-o
59 option specifies a sequence of information to print to the standard
60 output for the 't' command (see below).
61 The
62 .I \-t
63 option specifies a minimum interval (in milliseconds)
64 between successive ray outputs
65 in mouse tracking mode (right button pressed).
66 .PP
67 The
68 .I \-e
69 option specifies an exposure compensation in f-stops (powers of two).
70 Only integer stops are allowed, for efficiency.
71 If the special word,
72 .I auto
73 is given instead of a number of stops, then
74 .I ximage
75 performs an automatic exposure adjustment similar to
76 .I pcond(1),
77 compressing the dynamic range of the image to fit
78 within the dynamic range of the display.
79 If the special word,
80 .I human
81 is given instead, then
82 .I ximage
83 performs an exposure adjustment similar to
84 .I pcond
85 with the
86 .I \-s
87 and
88 .I \-c
89 options, which compensate for human contrast and color sensitivity
90 at the corresponding scene luminance levels.
91 This option yeilds and appearance of the scene on the display that
92 closely matches what would be experienced in the real world.
93 .PP
94 The
95 .I \-s
96 option tells
97 .I ximage
98 to display multiple pictures sequentially, rather than all at once.
99 If no
100 .I picture
101 is given, input is read from stdin provided either the
102 .I \-b
103 or
104 .I \-m
105 option is in effect, or the X server is capable of 24-bit color.
106 However, many of the commands given below will not work.
107 .SH COMMANDS
108 Once a picture is displayed, the user
109 may perform a number of operations.
110 Some of the operations make use of an area of interest, defined by pressing
111 the left mouse button and dragging the cursor over a section of the image.
112 Pressing the button and immediately releasing it defines a single point as
113 the area of interest.
114 A command is a single character.
115 .TP 10n
116 .BR q
117 Quit picture.
118 (Also Q or ^D.)\0
119 .TP 10
120 .BR <space>
121 Redraw the area of interest.
122 .TP 10
123 .BR ^R
124 Redraw the entire image.
125 .TP
126 .BR <return>
127 Display the radiance averaged over the area of interest.
128 The maximum of the three (RGB) channels is reported.
129 .TP
130 .BR l
131 Display the photometrically-weighted luminance value in the area of interest.
132 This assumes that the image was correctly computed in terms of
133 luminance.
134 .TP
135 .BR c
136 Display the color in the area of interest, as adjusted by the current
137 exposure setting.
138 .TP
139 .BR p
140 Display the x and y location of the cursor.
141 .TP
142 .BR i
143 Identify identical pixels by assigning a random color at the cursor position.
144 This is useful for displaying contours, especially when combined
145 with the \-b option.
146 .TP
147 .BR t
148 Print information about the pixel under the cursor
149 according to the string following the
150 .I \-o
151 command line option.
152 The valid characters for this option correspond roughly to the other
153 .I ximage
154 commands:
155 .IP
156 o ray origin
157 .IP
158 d ray direction
159 .IP
160 v radiance value
161 .IP
162 l luminance value
163 .IP
164 p pixel position
165 .IP
166 The default output is "\-ood", which prints
167 the ray origin and direction.
168 This can be used as input to rtrace(1) to get additional information
169 about the image (ie. pipe the output of ximage into rtrace).
170 Pressing the middle mouse button is equivalent to typing the 't' key.
171 Pressing and holding the right mouse button is equivalent to
172 continuously pressing the 't' key.
173 .TP
174 .BR =
175 Adjust the exposure to the area of interest.
176 A crude adjustment is made immediately, and the number of stops
177 is printed while the colors are resampled.
178 After a few seconds to a minute, the final image is redisplayed.
179 If the area of interest is already within 1/2 stop of the ideal,
180 no adjustment is made.
181 .TP
182 .BR @
183 Same as '=' command, only the exposure is adjusted to provide
184 roughly the same visibility for the selected region
185 on screen as a viewer would experience
186 in the actual space.
187 Like the 'l' command, this adjustment assumes that the image
188 has been correctly computed in terms of luminance.
189 (See also the 'h' command, below.)
190 .TP
191 .BR a
192 Perform automatic exposure compensation, as if
193 .I ximage
194 were started with the
195 .I "\-e auto"
196 option.
197 If a rectangular area has been selected, the pixels in this region
198 will be emphasized in the histogram, offering this area exposure preference.
199 (Each pixel within the rectangle will be weighted as 21 outside pixels.)
200 .TP
201 .BR h
202 Perform human expsoure compensation, as if
203 .I ximage
204 were started with the
205 .I "\-e human"
206 option.
207 See the 'a' command above regarding pixel weighting.
208 .TP
209 .BR 0
210 Reset the origin to the upper left corner of the image.
211 This command is used to restore the original image position after
212 using the shift or control key with the mouse to relocate the image
213 within the frame (see below).
214 .TP
215 .BR f
216 Switch on the fast redraw option
217 .I (\-f),
218 loading the image pixmap over to the server side.
219 This command is useful when network delays are causing slow image
220 refresh, and the user didn't notice it until after
221 .I ximage
222 was started.
223 .TP
224 .BR F
225 Switch off the fast redraw option.
226 This frees up some memory on the server, as well as the color table
227 for other windows.
228 .PP
229 In addition to the commands listed above, the control or shift key may
230 be held while the cursor is dragged to reposition the image within the
231 window.
232 .SH "X RESOURCES"
233 radiance.gamma the default gamma correction value
234 .SH ENVIRONMENT
235 DISPLAY_GAMMA the default gamma correction value
236 .SH AUTHORS
237 Greg Ward
238 .br
239 Anat Grynberg (Paris)
240 .br
241 Philip Thompson (MIT)
242 .SH "SEE ALSO"
243 aedimage(1), normtiff(1), pcond(1), pfilt(1), rpict(1), rtrace(1),
244 rvu(1), xglaresrc(1), xshowtrace(1)
