root/Development/ray/doc/man/man1/xform.1
Revision: 1.6
Committed: Sun Dec 2 16:54:29 2018 UTC (7 years, 1 month ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changed -f option to pass through comments and blank lines
1 .\" RCSid "$Id: xform.1,v 1.5 2015/06/29 00:32:51 greg Exp $"
2 .TH XFORM 1 6/4/99 RADIANCE
3 .SH NAME
4 xform - transform a RADIANCE scene description
5 .SH SYNOPSIS
6 .B xform
7 [
8 .B \-c
9 ][
10 .B \-I
11 ][
12 .B "\-n name"
13 ][
14 .B "\-m newmod"
15 ][
16 .B "\-f argfile"
17 ][
18 .B xf0
19 ][
20 .B "\-a n1 xf1 .."
21 ][
22 .B "\-i 1 xff"
23 ]
24 .B "file .."
25 .SH DESCRIPTION
26 .I Xform
27 transforms each scene description
28 .I file
29 according to the options given.
30 If no
31 .I file
32 is specified, the standard input is read.
33 The
34 .I \-c
35 option causes commands in the input not to be expanded.
36 The default is to execute all in line commands.
37 (See note below about file names.)\0
38 The
39 .I \-n
40 option causes all identifiers to be prefixed with
41 .I name.
42 The
43 .I \-m
44 option causes all surfaces to be given the modifier
45 .I newmod.
46 The
47 .I \-I
48 option causes all surfaces to be inverted, reversing their
49 surface normal orientations.
50 These options are followed by the transformation options,
51 which are described below.
52 .PP
53 The
54 .I \-f
55 option causes the
56 .I xform
57 command line to be constructed from the given file,
58 by inserting each line of the file at the
59 current point in the command argument list.
60 Each line in the file will result in a logically separate invocation of
61 .I xform,
62 and may contain any valid
63 .I xform
64 arguments, including nested
65 .I \-f
66 options.
67 This is a convenient way to specify multiple copies of an object that
68 do not fit a regular array pattern, without having to actually execute
69 .I xform
70 many times.
71 Separate scene files may be specified this way as well, but remember
72 that the constructed command line must fit the format of initial options
73 .I "(-n, -m, -c, -I)"
74 followed by the transform then the scene files.
75 No initial options may appear after the first transform option, and
76 no transform options will be understood after the first named file.
77 In the special case where the argument to the
78 .I \-f
79 option is a hyphen ('-'),
80 .I xform
81 will take its arguments from the standard input.
82 Note that
83 .I xform
84 cannot simultaneously take its scene information from the standard input
85 if the option is used in this way.
86 Competely empty lines and lines beginning with a pound sign ('#') will be
87 passed through to the output.
88 Beginning "!xform" or "xform" command names will also be ignored.
89 .PP
90 If one or more scene files are given on the command line,
91 .I xform
92 will search the RADIANCE library directories for each file.
93 (No search takes place if a file name begins with a '.', '/' or '~'
94 character.)\0
95 Unless the
96 .I \-c
97 option is present,
98 .I xform
99 will also change to that file's directory before loading it.
100 Thus, any commands executed within that file will happen in that
101 file's directory, which simplifies object hierarchy construction.
102 .PP
103 The transformation consists of a sequence of operations which
104 are executed in the order they appear.
105 .SH OPTIONS
106 .TP 10n
107 .BI -t " x y z"
108 Translate the scene along the vector
109 .I "x y z".
110 .TP
111 .BI -rx \ degrees
112 Rotate the scene
113 .I degrees
114 about the x axis.
115 A positive rotation corresponds to counter-clockwise
116 when looking down the axis.
117 .TP
118 .BI -ry \ degrees
119 Rotate the scene
120 .I degrees
121 about the y axis.
122 .TP
123 .BI -rz \ degrees
124 Rotate the scene
125 .I degrees
126 about the z axis.
127 .TP
128 .BI -s \ factor
129 Scale the scene by
130 .I factor.
131 .TP
132 .BR \-mx
133 Mirror the scene about the yz plane.
134 .TP
135 .BR \-my
136 Mirror the scene about the xz plane.
137 .TP
138 .BR \-mz
139 Mirror the scene about the xy plane.
140 .TP
141 .BI -i \ count
142 Iterate (repeat) the following transformation (up to the next
143 .I \-i
144 option)
145 .I count
146 times.
147 This option is primarily to support the
148 .I \-a
149 option, which is described below.
150 .SS Arrays
151 An array is a repeated transformation that results in a repeated object.
152 It is specified using the
153 .I \-a
154 option, which takes the number to repeat as its argument.
155 The objects will step by the transformation given between
156 this
157 .I \-a
158 option and the next
159 .I \-a
160 or
161 .I \-i
162 option.
163 The first object will have zero applications of the transform.
164 A two-dimensional array is given by two different transformations
165 each preceded by an array count.
166 .SH EXAMPLE
167 To rotate ``book'' 30 degrees about the x axis then
168 move 20 in y, prepending the name book1:
169 .IP "" .2i
170 xform \-n book1 \-rx 30 \-t 0 20 0 book > book1
171 .PP
172 To expand all commands and see what information is actually used by RADIANCE:
173 .IP "" .2i
174 xform scene | more
175 .PP
176 To create a two-dimensional array of 20 lights, after an initial rotation
177 and followed by a global translation (no command expansion):
178 .IP "" .2i
179 xform \-c \-rz 90 \-a 5 \-t 2 0 0 \-a 4 \-t 0 1.5 0 \-i 1 \-t 0 0 10 light
180 .SH ENVIRONMENT
181 RAYPATH path to search for scene files
182 .SH AUTHOR
183 Greg Ward
184 .SH BUGS
185 Only regular (distortion-free) transformations are allowed.
186 .SH "SEE ALSO"
187 genbox(1), gensurf(1), oconv(1), replmarks(1), rpict(1), rvu(1)
