root/Development/ray/doc/man/man1/xform.1
Revision: 1.6
Committed: Sun Dec 2 16:54:29 2018 UTC (7 years, 1 month ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changed -f option to pass through comments and blank lines
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: xform.1,v 1.5 2015/06/29 00:32:51 greg Exp $"
2 greg 1.1 .TH XFORM 1 6/4/99 RADIANCE
3     .SH NAME
4     xform - transform a RADIANCE scene description
5     .SH SYNOPSIS
6     .B xform
7     [
8     .B \-c
9     ][
10     .B \-I
11     ][
12     .B "\-n name"
13     ][
14     .B "\-m newmod"
15     ][
16     .B "\-f argfile"
17     ][
18     .B xf0
19     ][
20     .B "\-a n1 xf1 .."
21     ][
22     .B "\-i 1 xff"
23     ]
24     .B "file .."
25     .SH DESCRIPTION
26     .I Xform
27     transforms each scene description
28     .I file
29     according to the options given.
30     If no
31     .I file
32     is specified, the standard input is read.
33     The
34     .I \-c
35     option causes commands in the input not to be expanded.
36     The default is to execute all in line commands.
37     (See note below about file names.)\0
38     The
39     .I \-n
40     option causes all identifiers to be prefixed with
41     .I name.
42     The
43     .I \-m
44     option causes all surfaces to be given the modifier
45     .I newmod.
46     The
47     .I \-I
48     option causes all surfaces to be inverted, reversing their
49     surface normal orientations.
50     These options are followed by the transformation options,
51     which are described below.
52     .PP
53     The
54     .I \-f
55     option causes the
56     .I xform
57     command line to be constructed from the given file,
58     by inserting each line of the file at the
59     current point in the command argument list.
60     Each line in the file will result in a logically separate invocation of
61     .I xform,
62 greg 1.5 and may contain any valid
63 greg 1.1 .I xform
64     arguments, including nested
65     .I \-f
66     options.
67     This is a convenient way to specify multiple copies of an object that
68     do not fit a regular array pattern, without having to actually execute
69     .I xform
70     many times.
71     Separate scene files may be specified this way as well, but remember
72     that the constructed command line must fit the format of initial options
73     .I "(-n, -m, -c, -I)"
74     followed by the transform then the scene files.
75     No initial options may appear after the first transform option, and
76     no transform options will be understood after the first named file.
77     In the special case where the argument to the
78     .I \-f
79     option is a hyphen ('-'),
80     .I xform
81     will take its arguments from the standard input.
82     Note that
83     .I xform
84     cannot simultaneously take its scene information from the standard input
85     if the option is used in this way.
86     Competely empty lines and lines beginning with a pound sign ('#') will be
87 greg 1.6 passed through to the output.
88 greg 1.1 Beginning "!xform" or "xform" command names will also be ignored.
89     .PP
90     If one or more scene files are given on the command line,
91     .I xform
92     will search the RADIANCE library directories for each file.
93     (No search takes place if a file name begins with a '.', '/' or '~'
94     character.)\0
95     Unless the
96     .I \-c
97     option is present,
98     .I xform
99     will also change to that file's directory before loading it.
100     Thus, any commands executed within that file will happen in that
101     file's directory, which simplifies object hierarchy construction.
102     .PP
103     The transformation consists of a sequence of operations which
104     are executed in the order they appear.
105     .SH OPTIONS
106     .TP 10n
107     .BI -t " x y z"
108     Translate the scene along the vector
109     .I "x y z".
110     .TP
111     .BI -rx \ degrees
112     Rotate the scene
113     .I degrees
114     about the x axis.
115     A positive rotation corresponds to counter-clockwise
116     when looking down the axis.
117     .TP
118     .BI -ry \ degrees
119     Rotate the scene
120     .I degrees
121     about the y axis.
122     .TP
123     .BI -rz \ degrees
124     Rotate the scene
125     .I degrees
126     about the z axis.
127     .TP
128     .BI -s \ factor
129     Scale the scene by
130     .I factor.
131     .TP
132     .BR \-mx
133     Mirror the scene about the yz plane.
134     .TP
135     .BR \-my
136     Mirror the scene about the xz plane.
137     .TP
138     .BR \-mz
139     Mirror the scene about the xy plane.
140     .TP
141     .BI -i \ count
142     Iterate (repeat) the following transformation (up to the next
143     .I \-i
144     option)
145     .I count
146     times.
147     This option is primarily to support the
148     .I \-a
149     option, which is described below.
150     .SS Arrays
151     An array is a repeated transformation that results in a repeated object.
152     It is specified using the
153     .I \-a
154     option, which takes the number to repeat as its argument.
155     The objects will step by the transformation given between
156     this
157     .I \-a
158     option and the next
159     .I \-a
160     or
161     .I \-i
162     option.
163     The first object will have zero applications of the transform.
164     A two-dimensional array is given by two different transformations
165     each preceded by an array count.
166     .SH EXAMPLE
167     To rotate ``book'' 30 degrees about the x axis then
168     move 20 in y, prepending the name book1:
169     .IP "" .2i
170 greg 1.4 xform \-n book1 \-rx 30 \-t 0 20 0 book > book1
171 greg 1.1 .PP
172     To expand all commands and see what information is actually used by RADIANCE:
173     .IP "" .2i
174     xform scene | more
175     .PP
176     To create a two-dimensional array of 20 lights, after an initial rotation
177     and followed by a global translation (no command expansion):
178     .IP "" .2i
179 greg 1.4 xform \-c \-rz 90 \-a 5 \-t 2 0 0 \-a 4 \-t 0 1.5 0 \-i 1 \-t 0 0 10 light
180 greg 1.1 .SH ENVIRONMENT
181     RAYPATH path to search for scene files
182     .SH AUTHOR
183     Greg Ward
184     .SH BUGS
185     Only regular (distortion-free) transformations are allowed.
186     .SH "SEE ALSO"
187 greg 1.3 genbox(1), gensurf(1), oconv(1), replmarks(1), rpict(1), rvu(1)
