root/Development/ray/doc/man/man1/wrapBSDF.1
Revision: 1.8
Committed: Thu Nov 6 18:49:50 2025 UTC (2 months ago) by greg
docs(wrapBSDF): typo
# User Rev Content
1 greg 1.8 .\" RCSid $Id: wrapBSDF.1,v 1.7 2017/02/14 19:58:37 greg Exp $
2 greg 1.1 .TH WRAPBSDF 1 2/20/2015 RADIANCE
3     .SH NAME
4     wrapBSDF - put XML wrapper around WINDOW6 BSDF data
5     .SH SYNOPSIS
6     .B wrapBSDF
7     [
8     .B \-W
9     ][
10     .B \-c
11     ][
12     .B "\-a {kf|kh|kq|t3|t4}"
13     ][
14     .B "\-u unit"
15     ][
16     .B "\-g geom.mgf"
17     ][
18     .B "\-f 'x=string;y=string'"
19     ][
20     .B "\-s spectr"
21     ][
22     .B "\-tb inp"
23     ][
24     .B "\-tf inp"
25     ][
26     .B "\-rb inp"
27     ][
28     .B "\-rf inp"
29     ][
30 greg 1.5 .B \-U
31     ][
32 greg 1.3 .B "\-C comm"
33     ][
34 greg 1.1 .B "input.xml"
35     ]
36     .SH DESCRIPTION
37     .I WrapBSDF
38     takes ASCII matrix or tensor tree data given in one or more
39     .I "\-tf, \-tb, \-rf,"
40     and
41     .I \-rb
42     options and adds them to the given
43     .I input.xml
44     file or to a standard template suitable for
45     .I Radiance
46     and
47     .I WINDOW6.
48     The
49     .I \-W
50     option may be given to ensure adherence to the
51     .I WINDOW6
52     requirements, which draws from a standard template
53     and warns the user if the required additional fields are not
54     provided.
55     .PP
56     Fields may be set by one or more
57     .I \-f
58     options, which take pairs of XML tag names and values, such as
59     .I "\-f Manufacturer=ACME".
60     A number of shorthand names are provided corresponding to the
61     following tags (asterisk tags are required with -W):
62     .sp
63     .nf
64     m Manufacturer(*)
65     n Name(*)
66 greg 1.7 d DeviceType
67 greg 1.1 c ThermalConductivity
68     ef EmissivityFront
69     eb EmissivityBack
70     eo EffectiveOpennessFraction
71     t Thickness(*)
72     h Height
73     w Width
74     .fi
75     .PP
76 greg 1.8 If any dimensions are given, their units will correspond to
77 greg 1.1 meters by default, or the
78     .I \-u
79     option may be used to specify one of:
80     meter, foot, inch, centimeter, or millimeter.
81     Any other unit specification will result in an error, and
82     only one set of units may be selected.
83     A "Materials and Geometry Format" file may be provided with the
84     .I \-g
85     option, and will also be in the indicated units.
86     .PP
87     The spectrum corresponding to a particular set of data may be given
88     before the data option using a
89     .I \-s
90     specification, whose argument is either the name of a spectral
91     sensitivity file or one of the standard spectra:
92     Visible, Solar, NIR, CIE-u, CIE-v, CIE-X, or CIE-Z.
93     Different spectra may be given for different distribution data,
94     and the default spectrum is Visible (CIE-Y).
95     .PP
96     The
97     .I \-a
98     option specifies the angular sampling basis for all the data
99     provided, and must be set if any data is given.
100     Legal arguments for this option are:
101     .sp
102     .nf
103     kf Klems full sampling (145x145 matrix)
104     kh Klems half sampling (73x73 matrix)
105     kq Klems quarter sampling (41x41 matrix)
106     t3 Tensor tree isotropic sampling
107     t4 Tensor tree anisotropic sampling
108     .fi
109     .sp
110     In the case of Klems data, the
111     .I \-c
112     option may be specified to include a correction for solid
113     angle, which is necessary to convert flux form factors into
114     BSDF data.
115 greg 1.4 Since flux factors rather than BSDF values are computed by
116 greg 1.1 .I rfluxmtx(1)
117     and similar sources, this is often necessary for proper conversion.
118     .PP
119     Most options that accept file names
120     can take data from the standard input by using a hyphen ('-')
121     in place of the file, but only one option at most may read from stdin.
122 greg 1.2 Data input may be read from another program by beginning the input
123     specification with a quoted exclamation point ('!') followed by the command.
124 greg 1.3 .PP
125     The
126     .I \-C
127     option may be used to specify a comment to be inserted near the
128     head of the output.
129     Up to 30 comment strings may be given, and they will appear one
130     after the other in the prologue surrounded by the XML comment syntax.
131 greg 1.5 .PP
132     The
133     .I \-U
134     option tells
135     .I wrapBSDF
136     to unlink (remove) input data files following successful completion.
137     These files are often temporary, existing solely for the purposes
138     of data transfer.
139 greg 1.6 If given as
140     .I \-UU,
141     then the MGF geometry file given by the
142     .I \-g
143     option (if any) will also be unlinked.
144 greg 1.1 .SH EXAMPLE
145     Create an WINDOW6 BSDF from computed transmission matrix:
146     .IP "" .2i
147     rfluxmtx -fa ... | wrapBSDF -W -u millimeter -f 't=5;m=3M;n=Trans30' -c -tb - > Trans30.xml
148     .PP
149     Add a name and MGF geometry to an XML file:
150     Add a name and MGF geometry to an XML file:
151     .IP "" .2i
152     wrapBSDF -f 'Name=My Device' -g MyDevice.mgf orig.xml > revised.xml
153     .SH AUTHOR
154     Greg Ward
155     .SH "SEE ALSO"
156     bsdf2klems(1), bsdf2ttree(1), genBSDF(1), mgf2rad(1),
157     pkgBSDF(1), rad2mgf(1), rfluxmtx(1)
