--- ray/doc/man/man1/wrapBSDF.1 2015/05/29 07:45:48 1.3 +++ ray/doc/man/man1/wrapBSDF.1 2016/02/03 00:22:55 1.6 @@ -1,4 +1,4 @@ -.\" RCSid $Id: wrapBSDF.1,v 1.3 2015/05/29 07:45:48 greg Exp $ +.\" RCSid $Id: wrapBSDF.1,v 1.6 2016/02/03 00:22:55 greg Exp $ .TH WRAPBSDF 1 2/20/2015 RADIANCE .SH NAME wrapBSDF - put XML wrapper around WINDOW6 BSDF data @@ -27,6 +27,8 @@ wrapBSDF - put XML wrapper around WINDOW6 BSDF data ][ .B "\-rf inp" ][ +.B \-U +][ .B "\-C comm" ][ .B "input.xml" @@ -109,7 +111,7 @@ In the case of Klems data, the option may be specified to include a correction for solid angle, which is necessary to convert flux form factors into BSDF data. -Since it flux factors rather than BSDF values are computed by +Since flux factors rather than BSDF values are computed by .I rfluxmtx(1) and similar sources, this is often necessary for proper conversion. .PP @@ -125,6 +127,19 @@ option may be used to specify a comment to be inserted head of the output. Up to 30 comment strings may be given, and they will appear one after the other in the prologue surrounded by the XML comment syntax. +.PP +The +.I \-U +option tells +.I wrapBSDF +to unlink (remove) input data files following successful completion. +These files are often temporary, existing solely for the purposes +of data transfer. +If given as +.I \-UU, +then the MGF geometry file given by the +.I \-g +option (if any) will also be unlinked. .SH EXAMPLE Create an WINDOW6 BSDF from computed transmission matrix: .IP "" .2i
