--- ray/doc/man/man1/wrapBSDF.1 2015/05/20 08:40:48 1.2 +++ ray/doc/man/man1/wrapBSDF.1 2015/05/29 07:45:48 1.3 @@ -1,4 +1,4 @@ -.\" RCSid $Id: wrapBSDF.1,v 1.2 2015/05/20 08:40:48 greg Exp $ +.\" RCSid $Id: wrapBSDF.1,v 1.3 2015/05/29 07:45:48 greg Exp $ .TH WRAPBSDF 1 2/20/2015 RADIANCE .SH NAME wrapBSDF - put XML wrapper around WINDOW6 BSDF data @@ -27,6 +27,8 @@ wrapBSDF - put XML wrapper around WINDOW6 BSDF data ][ .B "\-rf inp" ][ +.B "\-C comm" +][ .B "input.xml" ] .SH DESCRIPTION @@ -116,6 +118,13 @@ can take data from the standard input by using a hyphe in place of the file, but only one option at most may read from stdin. Data input may be read from another program by beginning the input specification with a quoted exclamation point ('!') followed by the command. +.PP +The +.I \-C +option may be used to specify a comment to be inserted near the +head of the output. +Up to 30 comment strings may be given, and they will appear one +after the other in the prologue surrounded by the XML comment syntax. .SH EXAMPLE Create an WINDOW6 BSDF from computed transmission matrix: .IP "" .2i
